[GRASS-SVN] r58658 - grass/branches/releasebranch_6_4/locale/po
svn_grass at osgeo.org
Thu Jan 9 15:53:49 PST 2014
Author: neteler
Date: 2014-01-09 15:53:48 -0800 (Thu, 09 Jan 2014)
New Revision: 58658
grass/branches/releasebranch_6_4/locale/po/grasslibs_fr.po
grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po
Sylvain Maillard: FR translation cont'ed
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_fr.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_fr.po 2014-01-09 23:28:48 UTC (rev 58657)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_fr.po 2014-01-09 23:53:48 UTC (rev 58658)
@@ -12,7 +12,7 @@
"Project-Id-Version: grasslibs_fr\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2013-10-30 21:55+0100\n"
-"PO-Revision-Date: 2013-10-31 01:11+0100\n"
+"PO-Revision-Date: 2014-01-01 11:06+0100\n"
"Last-Translator: Sylvain Maillard <sylvain.maillard at gmail.com>\n"
"Language-Team: French <grass-translations at lists.osgeo.org>\n"
"Language: fr\n"
@@ -276,8 +276,9 @@
msgstr "A tenté de dépiler une mémoire vide"
#: ../lib/ogsf/gsd_surf.c:1742
+#, fuzzy
msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
-msgstr ""
+msgstr "Non concordance des points de surface de coupe. Vérifiez les résolutions."
#: ../lib/ogsf/gsdrape.c:207
msgid "Unable to process vector map - out of memory"
@@ -2499,8 +2500,9 @@
msgstr "Le somment suivant a déjà été visité mais n'est pas le premier !!! Interruption de la boucle"
#: ../lib/vector/Vlib/buffer2.c:657
+#, fuzzy
msgid "side != 0 feature not implemented"
-msgstr ""
+msgstr "fonctionnalité side != 0 non implémentée"
#: ../lib/vector/Vlib/buffer2.c:899 ../lib/vector/Vlib/buffer2.c:946
msgid "zero area size"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po 2014-01-09 23:28:48 UTC (rev 58657)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po 2014-01-09 23:53:48 UTC (rev 58658)
@@ -13,15 +13,14 @@
"Project-Id-Version: grassmods_fr\n"
-"PO-Revision-Date: 2013-01-27 09:31+0100\n"
+"PO-Revision-Date: 2014-01-01 11:35+0100\n"
"Language-Team: Français <grass-translations at lists.osgeo.org>\n"
"Language: fr\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
-"X-Poedit-Language: French\n"
-"X-Poedit-Country: FRANCE\n"
+"X-Generator: Poedit 1.5.5\n"
#: ../visualization/nviz/src/nviz_init.c:53 ../misc/m.nviz.image/main.c:49
msgid "visualization, raster, vector, raster3d"
@@ -99,11 +98,11 @@
#: ../raster/r.in.mat/main.c:125 ../display/d.vect/main.c:367
#: ../display/d.mon/pgms/release.c:36
msgid "The '-v' flag is superseded and will be removed in future. Please use '--verbose' instead."
-msgstr "Le drapeau '-v' est caduque et sera supprimé à l'avenir. Merci d'utiliser '--verbose' à la place."
+msgstr "Le drapeau '-v' est obsolète et sera supprimé à l'avenir. Merci d'utiliser '--verbose' à la place."
#: ../visualization/nviz/src/nviz_init.c:287
msgid "Number of elevation files does not match number of colors files"
-msgstr "Le nombre de fichiers d'altitudes ne correspond pas au nombre de fichiers de couleur"
+msgstr "Le nombre de fichiers d'altitudes ne correspond pas au nombre de fichiers de couleurs"
#: ../visualization/nviz/src/nviz_init.c:298
msgid "Loading data failed"
@@ -111,7 +110,7 @@
#: ../visualization/nviz/src/nviz_init.c:411
msgid "Entering script mode ..."
-msgstr "Entrant dans le mode script..."
+msgstr "Entrée dans le mode script ..."
#: ../visualization/ximgview/main.c:62
msgid "Unable to open display"
@@ -147,7 +146,7 @@
#: ../visualization/ximgview/main.c:271
msgid "View BMP images from the PNG driver."
-msgstr "Visionner des images BMP depuis le pilote PNG."
+msgstr "Visionner des images BMP avec le pilote PNG."
#: ../visualization/ximgview/main.c:279
#, fuzzy
@@ -164,22 +163,22 @@
#: ../visualization/xganim/Clr_table.c:318
#, c-format
msgid "Unknown visual class [%d]."
-msgstr "Classe visuelle inconnue [%d]"
+msgstr "Classe visuelle inconnue [%d]."
#: ../visualization/ximgview/color.c:239
#: ../visualization/xganim/Clr_table.c:243
msgid "Unable to get sufficient gray shades."
-msgstr "Impossible de trouver un nombre de nuances de gris suffisant"
+msgstr "Impossible d'obtenir un nombre de nuances de gris suffisant."
#: ../visualization/ximgview/color.c:256
#: ../visualization/xganim/Clr_table.c:260
msgid "Unable to get sufficient colors."
-msgstr "Impossible de trouver un nombre de couleurs suffisant"
+msgstr "Impossible d'obtenir un nombre de couleurs suffisant."
#: ../visualization/ximgview/color.c:269
#: ../visualization/xganim/Clr_table.c:273
msgid "Using private colormap for DirectColor visual."
-msgstr "Utilisation d'une table de couleur privée pour la visualisation DirectColor"
+msgstr "Utilisation d'une table de couleur privée pour la visualisation DirectColor."
#: ../visualization/xganim/main.c:362
#, fuzzy, c-format
@@ -297,7 +296,7 @@
#: ../vector/v.drape/main.c:245
#, c-format
msgid "Raster map <%s> not found"
-msgstr "couche raster <%s> non trouvée"
+msgstr "Couche raster <%s> non trouvée"
# c-format
#: ../visualization/xganim/main.c:370 ../doc/raster/r.example/main.c:122
@@ -388,6 +387,7 @@
msgstr "Impossible de lire la ligne raster."
#: ../visualization/xganim/main.c:544 ../raster/r.out.mpeg/main.c:346
+#, fuzzy
msgid "Error reading wildcard"
msgstr "Erreur de lecture de la wildcard"
@@ -402,7 +402,7 @@
#: ../doc/raster/r.example/main.c:85
msgid "raster, keyword2, keyword3"
-msgstr "couche matricielle, mot-clé2, mot-clé3"
+msgstr "raster, mot-clé2, mot-clé3"
#: ../doc/raster/r.example/main.c:86
#, fuzzy
@@ -536,7 +536,7 @@
#: ../doc/vector/v.example/main.c:50
msgid "vector, keyword2, keyword3"
-msgstr "couche vectorielle, mot-clé2, mot-clé3"
+msgstr "vecteur, mot-clé2, mot-clé3"
#: ../doc/vector/v.example/main.c:51
#, fuzzy
@@ -804,7 +804,7 @@
#: ../raster3d/r3.gwflow/main.c:101
msgid "Specific yield in 1/m"
-msgstr "débit spécifique en 1/m"
+msgstr "Débit spécifique en 1/m"
#: ../raster3d/r3.gwflow/main.c:108
msgid "Recharge raster map in m^3/s"
@@ -871,7 +871,7 @@
#: ../raster3d/r3.mkdspf/main.c:77
msgid "Creates a display file from an existing grid3 file according to specified threshold levels."
-msgstr "Crée un affichage à partir d'une couche raster 3D existante à partir de seuils de valeur spécifiée"
+msgstr "Créé un affichage à partir d'une couche raster 3D existante et de seuils de valeurs spécifiées."
#: ../raster3d/r3.mkdspf/main.c:85
msgid "Name of an existing 3d raster map"
@@ -879,11 +879,11 @@
#: ../raster3d/r3.mkdspf/main.c:91
msgid "Name of output display file"
-msgstr "Nom de la couche raster cible à afficher"
+msgstr "Nom du fichier d'affichage en sortie"
#: ../raster3d/r3.mkdspf/main.c:98
msgid "List of thresholds for isosurfaces"
-msgstr "Liste des valeurs de seuillage pour les iso-surfaces"
+msgstr "Liste des valeurs seuils pour les iso-surfaces"
#: ../raster3d/r3.mkdspf/main.c:104
msgid "Minimum isosurface level"
@@ -895,11 +895,11 @@
#: ../raster3d/r3.mkdspf/main.c:116
msgid "Positive increment between isosurface levels"
-msgstr "Dénivelé (de valeur positive) entre les courbes de niveau des iso-surfaces"
+msgstr "Dénivelé (positif) entre les courbes de niveau des iso-surfaces"
#: ../raster3d/r3.mkdspf/main.c:123
msgid "Number of isosurface threshold levels"
-msgstr "Nombre de niveaux de seuillage pour construire l'iso-surface"
+msgstr "Nombre de niveaux de seuils pour construire l'iso-surface"
#: ../raster3d/r3.mkdspf/main.c:127
msgid "Suppress progress report & min/max information"
@@ -937,7 +937,7 @@
#: ../raster3d/r3.mkdspf/main.c:216
#, c-format
msgid "Writing %s from %s..."
-msgstr "Écriture de %s à partir de %s..."
+msgstr "Écriture de %s à partir de %s ..."
#: ../raster3d/r3.out.ascii/main.c:76
#, fuzzy
@@ -1031,15 +1031,15 @@
#: ../raster3d/base/r3.info.main.c:96
msgid "Print 3D raster map resolution (NS-res, EW-res, TB-res) only"
-msgstr "Écrire uniquement la résolution de la couche raster 3D (NS-res, EW-res, Haut-Bas-res)"
+msgstr "Afficher uniquement la résolution de la couche raster 3D (NS-res, EW-res, Haut-Bas-res)"
#: ../raster3d/base/r3.info.main.c:100
msgid "Print 3D raster map type (float/double) only"
-msgstr "Écrire uniquement le type de couche raster 3D (float/double)"
+msgstr "Afficher uniquement le type de couche raster 3D (float/double)"
#: ../raster3d/base/r3.info.main.c:104
msgid "Print 3D raster map region only"
-msgstr "Afficher seulement la région de la couche raster 3D"
+msgstr "Afficher uniquement la région de la couche raster 3D"
#: ../raster3d/base/r3.info.main.c:108
#, fuzzy
@@ -1048,7 +1048,7 @@
#: ../raster3d/base/r3.info.main.c:113
msgid "Print 3D raster map timestamp (day.month.year hour:minute:seconds) only"
-msgstr "Afficher seulement l'étiquette date&heure du raster 3D (sous la forme jour.mois.année heure:minute:secondes)"
+msgstr "Afficher uniquement l'étiquette date&heure du raster 3D (sous la forme jour.mois.année heure:minute:secondes)"
#: ../raster3d/base/r3.info.main.c:121
#, fuzzy, c-format
@@ -1067,6 +1067,7 @@
#: ../raster3d/base/r3.info.main.c:308 ../raster3d/base/r3.info.main.c:313
#: ../raster3d/base/r3.info.main.c:321 ../raster3d/base/r3.info.main.c:334
#: ../raster/r.info/main.c:307 ../raster/r.info/main.c:433
+#, fuzzy
msgid "Cannot allocate memory for string"
msgstr "Impossible de calculer le centroïde de la surface (problème d'allocation mémoire)"
@@ -1081,7 +1082,7 @@
#: ../raster3d/base/r3.null.main.c:58
msgid "3d raster map for which to modify null values"
-msgstr "Nom de la couche raster 3D où modifier les valeurs null"
+msgstr "Nom de la couche raster 3D où modifier les valeurs nulles"
#: ../raster3d/base/r3.null.main.c:66 ../raster/r.null/null.c:70
msgid "List of cell values to be set to NULL"
@@ -1098,13 +1099,15 @@
#: ../raster3d/base/r3.null.main.c:125
msgid "modifyNull: error opening tmp file"
-msgstr "modifyNull (modification des valeurs nulles) : erreur d'ouverture du fichier temporaire"
+msgstr "modifyNull : erreur d'ouverture du fichier temporaire"
#: ../raster3d/base/r3.null.main.c:174
+#, fuzzy
msgid "modifyNull: error flushing tiles in cube"
msgstr "modifyNull : erreur dans le tuilage de la couche dans le cube"
#: ../raster3d/base/r3.null.main.c:180
+#, fuzzy
msgid "modifyNull: error flushing all tiles"
msgstr "modifyNull : erreur dans le tuilage de la couche"
@@ -1120,7 +1123,7 @@
#: ../raster3d/base/r3.null.main.c:207
msgid "Explicitly create the 3D NULL-value bitmap file."
-msgstr "Créer de façon explicite le fichier bitmap 3D de valeur-NULL"
+msgstr "Créer de façon explicite le fichier bitmap 3D de valeurs NULL."
#: ../raster3d/base/r3.timestamp.main.c:45
#, fuzzy
@@ -1156,10 +1159,12 @@
msgstr ""
#: ../raster3d/base/r3.mask.main.c:124
+#, fuzzy
msgid "makeMask: error flushing tiles in cube"
msgstr "makeMask : erreur de tuilage de la couche dans le cube"
#: ../raster3d/base/r3.mask.main.c:129
+#, fuzzy
msgid "makeMask: error flushing all tiles"
msgstr "makeMask : erreur de tuilage de la couche"
@@ -1175,14 +1180,14 @@
#: ../raster3d/base/r3.mask.main.c:155
msgid "Establishes the current working 3D raster mask."
-msgstr "Active le masque raster 3D courant"
+msgstr "Active le masque raster 3D courant."
#: ../raster3d/base/r3.mask.main.c:159
msgid ""
"Cannot create mask file: G3D_MASK already exists!\n"
" Use 'g.remove rast3d=G3D_MASK' to remove the existing mask."
msgstr ""
-"Impossible de créer un fichier masque : G3D_MASK existe déjà!\n"
+"Impossible de créer un fichier masque : G3D_MASK existe déjà !\n"
"Utilisez 'g.remove rast3d=G3D_MASK' pour supprimer le masque existant."
#: ../raster3d/r3.out.v5d/main.c:72
@@ -1231,7 +1236,7 @@
#: ../raster3d/r3.to.rast/main.c:85
msgid "Basename for resultant raster slice maps"
-msgstr "Racine du nom des tranches rasters créées"
+msgstr "Nom de base pour les tranches de rasters créées"
#: ../raster3d/r3.to.rast/main.c:95
msgid "Use the same resolution as the input 3D raster map for the 2D outputmaps, independent of the current region settings"
@@ -1304,7 +1309,7 @@
#: ../raster3d/r3.to.rast/main.c:302 ../raster3d/r3.cross.rast/main.c:349
#: ../raster/r.to.rast3/main.c:239
msgid "Illegal output file name"
-msgstr "Nom du fichier de sortie illégal"
+msgstr "Nom du fichier de sortie invalide"
# c-format
#: ../raster3d/r3.to.rast/main.c:304
@@ -1325,7 +1330,7 @@
#: ../raster3d/r3.cross.rast/main.c:91
msgid "Input 3D raster map for cross section."
-msgstr "Couche raster 3D en entrée pour la coupe"
+msgstr "Couche raster 3D en entrée pour la section de coupe."
#: ../raster3d/r3.cross.rast/main.c:98
msgid "2D elevation map used to create the cross section map"
@@ -1333,7 +1338,7 @@
#: ../raster3d/r3.cross.rast/main.c:105
msgid "Resulting cross section 2D raster map"
-msgstr "couche raster en coupe 2D en sortie"
+msgstr "Carte raster pour la sortie de la section de coupe 2D"
#: ../raster3d/r3.cross.rast/main.c:162
#, fuzzy
@@ -1423,7 +1428,7 @@
#: ../raster3d/r3.out.vtk/parameters.c:41
msgid "Float value to represent no data cell/points"
-msgstr "Valeur flottante pour figurer les cellules/point sans valeur"
+msgstr "Valeur flottante pour les cellules/point sans valeur"
#: ../raster3d/r3.out.vtk/parameters.c:47
msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
@@ -1530,7 +1535,7 @@
#: ../raster3d/r3.out.vtk/main.c:389
msgid "failed to interpret dp as an integer"
-msgstr "Echec pour interpréter dp comme valeur entière (integer)"
+msgstr "Échec pour interpréter dp comme valeur entière (integer)"
#: ../raster3d/r3.out.vtk/main.c:391 ../raster/r.out.ascii/main.c:125
msgid "dp has to be from 0 to 20"
@@ -1579,16 +1584,16 @@
#: ../raster3d/r3.in.ascii/main.c:90
msgid "String representing NULL value data cell (use 'none' if no such value)"
-msgstr "Chaîne représentant les cellules de données NULL (utilisez 'none' si toutes les valeurs sont définies)"
+msgstr "Chaîne représentant les cellules de données NULL (utilise 'none' si toutes les valeurs sont définies)"
#: ../raster3d/r3.in.ascii/main.c:175
#, c-format
msgid "Loading data ... (%dx%dx%d)"
-msgstr "Chargement des données... (%dx%dx%d)"
+msgstr "Chargement des données ... (%dx%dx%d)"
#: ../raster3d/r3.in.ascii/main.c:192
msgid "End of file reached while still loading data."
-msgstr "Fin de fichier atteinte en cours de chargement de la donnée."
+msgstr "Fin de fichier atteinte pendant le chargement des données."
#: ../raster3d/r3.in.ascii/main.c:205
#, fuzzy
@@ -2016,7 +2021,7 @@
#: ../misc/m.nviz.image/args.c:936
#, c-format
msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"
-msgstr "Nombre d'attributs incohérent (<%s/%s> %d: <%s> %d)"
+msgstr "Nombre d'attributs incohérent (<%s/%s> %d : <%s> %d)"
#: ../misc/m.nviz.image/args.c:947
#, fuzzy, c-format
@@ -2029,7 +2034,7 @@
#: ../misc/m.nviz.image/args.c:996 ../misc/m.nviz.image/args.c:1028
#, c-format
msgid "Inconsistent number of attributes (<%s> %d: <%s> %d)"
-msgstr "Nombre d'attributs incohérent (<%s> %d: <%s> %d)"
+msgstr "Nombre d'attributs incohérent (<%s> %d : <%s> %d)"
#: ../misc/m.nviz.image/args.c:1012 ../misc/m.nviz.image/args.c:1021
#, fuzzy, c-format
@@ -2044,7 +2049,7 @@
#: ../misc/m.nviz.image/args.c:1045
#, c-format
msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d, <%s> %d)"
-msgstr "Nombre d'attributs incohérent (<%s/%s> %d: <%s> %d, <%s> %d"
+msgstr "Nombre d'attributs incohérent (<%s/%s> %d : <%s> %d, <%s> %d)"
#: ../misc/m.nviz.image/volume.c:42 ../misc/m.nviz.image/volume.c:125
#, fuzzy, c-format
@@ -2454,7 +2459,7 @@
#: ../raster/r.external/main.c:598
msgid "input= and source= are mutually exclusive"
-msgstr "l"
+msgstr "input= et source= sont mutuellements exclusifs"
#: ../raster/r.external/main.c:601 ../raster/r.in.gdal/main.c:222
msgid "Name for output raster map not specified"
@@ -2519,19 +2524,19 @@
#: ../raster/r.mode/main.c:52
msgid "Finds the mode of values in a cover map within areas assigned the same category value in a user-specified base map."
-msgstr "Trouve la mode des valeurs d'une couche de couverture pour les zones définies par les catégories d'une couche de base."
+msgstr "Trouve le « mode » (valeur la plus présente) des valeurs d'une couche de couverture pour les zones définies par les catégories d'une couche de base."
#: ../raster/r.mode/main.c:58
msgid "Base map to be reclassified"
-msgstr "couche de base à reclasser"
+msgstr "Couche de base à reclasser"
#: ../raster/r.mode/main.c:65
msgid "Coverage map"
-msgstr "couche de couverture"
+msgstr "Couche de couverture"
#: ../raster/r.mode/main.c:72
msgid "Output map"
-msgstr "couche de sortie"
+msgstr "Couche de sortie"
# c-format
#: ../raster/r.mode/main.c:86
@@ -2557,15 +2562,16 @@
#: ../raster/r.mode/read_stats.c:14
msgid "reading r.stats output"
-msgstr "e lecture de r.stats en sortie"
+msgstr "Lecture de la sortie de r.stats"
#: ../raster/r.profile/main.c:53
msgid "raster, profile"
msgstr ""
#: ../raster/r.profile/main.c:55
+#, fuzzy
msgid "Outputs the raster map layer values lying on user-defined line(s)."
-msgstr "Sort les valeurs de la couche raster à partir de ligne(s) définies par l'utilisateur"
+msgstr "Sort les valeurs de la couche raster à partir de ligne(s) définie(s) par l'utilisateur."
#: ../raster/r.profile/main.c:66
msgid "Name of file for output (use output=- for stdout)"
@@ -2578,7 +2584,7 @@
#: ../raster/r.profile/main.c:81
msgid "Resolution along profile (default = current region resolution)"
-msgstr "Résolution utilisée pour le profil (par défaut = la résolution de la région courante)"
+msgstr "Résolution utilisée pour le profil (par défaut = résolution de la région courante)"
#: ../raster/r.profile/main.c:88
msgid "Character to represent no data cell"
@@ -2677,7 +2683,9 @@
msgid ""
"Right: Finish profile and exit\n"
"\n"
-msgstr "Droit : finir le profil et sortir\n"
+msgstr ""
+"Droit : finir le profil et sortir\n"
+"\n"
#: ../raster/r.profile/main.c:305
#, c-format
@@ -2706,12 +2714,12 @@
#: ../raster/r.sun2/main.c:230 ../raster/r.sun/main.c:176
msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
-msgstr "Calcule des couches de rayonnement solaire direct (beam), diffus et réfléchi pour un jour donné, une latitude; des propriétés de surface et des conditions atmosphériques. Les paramètres solaires (par exemple, le lever du soleil, le coucher du soleil, la déclinaison, les radiations extra-terrestres, la durée du jour) sont sauvegardées dans un fichier texte local. Sinon, une heure locale peut être indiquée pour calculer des angles d'incidence ou d'irradiance du rayonnement solaire. Les effets d'ombres portées par la topographie peuvent être pris en compte de façon optionnelle."
+msgstr "Calcule des couches de rayonnement solaire direct (beam), diffus et réfléchi pour un jour donné, une latitude, des propriétés de surface et des conditions atmosphériques. Les paramètres solaires (par exemple, le lever du soleil, le coucher du soleil, la déclinaison, les radiations extra-terrestres, la durée du jour) sont enregistrées dans un fichier texte local. Sinon, une heure locale peut être indiquée pour calculer des angles d'incidence ou d'irradiance du rayonnement solaire. Les effets d'ombres portées par la topographie peuvent être pris en compte de façon optionnelle."
#: ../raster/r.sun2/main.c:244 ../raster/r.sun/main.c:206
#: ../raster/r.horizon/main.c:225
msgid "Name of the input elevation raster map [meters]"
-msgstr "Nom de la couche raster d'altitude (mètres)"
+msgstr "Nom du raster d'altitudes en entrée [mètres]"
#: ../raster/r.sun2/main.c:245 ../raster/r.sun2/main.c:254
#: ../raster/r.sun2/main.c:263 ../raster/r.sun2/main.c:272
@@ -2740,7 +2748,7 @@
#: ../raster/r.sun2/main.c:253 ../raster/r.sun/main.c:215
msgid "Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]"
-msgstr "Nom de la couche d'aspect source (aspect du terrain ou azimut du panneau solaire) [degrés décimaux]"
+msgstr "Nom de la couche d'aspect en entrée (aspect du terrain ou azimut du panneau solaire) [degrés décimaux]"
#: ../raster/r.sun2/main.c:262
msgid "A single value of the orientation (aspect), 270 is south"
@@ -2748,7 +2756,7 @@
#: ../raster/r.sun2/main.c:271 ../raster/r.sun/main.c:225
msgid "Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]"
-msgstr "Nom de la couche raster source de pente (pente du terrain ou inclinaison du panneau solaire) [degrés décimaux]"
+msgstr "Nom du raster de pentes en entrée (pente du terrain ou inclinaison du panneau solaire) [degrés décimaux]"
#: ../raster/r.sun2/main.c:279
msgid "A single value of inclination (slope)"
@@ -2756,7 +2764,7 @@
#: ../raster/r.sun2/main.c:288 ../raster/r.sun/main.c:234
msgid "Name of the Linke atmospheric turbidity coefficient input raster map [-]"
-msgstr "Nom de la couche raster source pour le coefficient atmosphérique d'opacité de Linke"
+msgstr "Nom du raster en entrée pour le coefficient atmosphérique d'opacité de Linke [-]"
#: ../raster/r.sun2/main.c:298 ../raster/r.sun/main.c:245
msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
@@ -2764,15 +2772,15 @@
#: ../raster/r.sun2/main.c:308 ../raster/r.sun/main.c:254
msgid "Name of the ground albedo coefficient input raster map [-]"
-msgstr "Nom de la couche raster source pour le coefficient d'albedo"
+msgstr "Nom du raster en entrée pour le coefficient d'albedo du sol [-]"
#: ../raster/r.sun2/main.c:318 ../raster/r.sun/main.c:265
msgid "A single value of the ground albedo coefficient [-]"
-msgstr "Valeur unique pour le coefficient d'albedo terrestre [-]"
+msgstr "Valeur unique pour le coefficient d'albedo du sol [-]"
#: ../raster/r.sun2/main.c:328
msgid "Name of input raster map containing latitudes [decimal degrees]"
-msgstr "Nom de la couche en entrée contenant "
+msgstr "Nom du raster en entrée contenant les laltitudes [degrés décimaux]"
#: ../raster/r.sun2/main.c:337
#, fuzzy
@@ -2829,7 +2837,7 @@
#: ../raster/r.sun2/main.c:389 ../raster/r.sun/main.c:320
msgid "Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr "Fichier raster en sortie pour le rayonnement solaire [W.m-2] (mode 1) ou l'irradiation [Wh.m-2.day-1] (mode 2)"
+msgstr "Couche raster en sortie pour le rayonnement solaire [W.m-2] (mode 1) ou l'irradiation [Wh.m-2.day-1] (mode 2)"
#: ../raster/r.sun2/main.c:398 ../raster/r.sun/main.c:329
msgid "Output insolation time raster map [h] (mode 2 only)"
@@ -2854,7 +2862,7 @@
#: ../raster/r.sun2/main.c:441 ../raster/r.sun/main.c:362
msgid "Time step when computing all-day radiation sums [decimal hours]"
-msgstr "Pas temporel pour calculer le rayonnement total sur une journée [heures décimales]"
+msgstr "Pas de temps pour le calcul du rayonnement total sur une journée [heures décimales]"
#: ../raster/r.sun2/main.c:448 ../raster/r.sun/main.c:369
msgid "Declination value (overriding the internally computed value) [radians]"
@@ -2879,7 +2887,7 @@
#: ../raster/r.sun2/main.c:502 ../raster/r.regression.line/main.c:68
#: ../vector/v.buffer2/main.c:218 ../vector/v.generalize/main.c:209
msgid "This does nothing. It is retained for backwards compatibility"
-msgstr "Ceci ne fait rien. C'est maintenu pour la rétrocompatibilité "
+msgstr "Ceci ne fait rien. Maintenu pour la rétrocompatibilité"
#: ../raster/r.sun2/main.c:503 ../vector/v.buffer2/main.c:216
#: ../vector/v.buffer2/main.c:228 ../vector/v.build.polylines/main.c:134
@@ -2893,7 +2901,7 @@
#: ../raster/r.sun2/main.c:514
msgid "Use the low-memory version of the program"
-msgstr "Utiliser la version basse-mémoire du programme"
+msgstr "Utiliser la version faible-mémoire du programme"
#: ../raster/r.sun2/main.c:561
msgid "You must give the longitude raster if you use civil time"
@@ -2936,7 +2944,7 @@
#: ../raster/r.sun2/main.c:610
msgid "If you use the horizon option you must also set the 'horizonstep' parameter."
-msgstr "Si vous utilisez l'option horizon vous devez aussi fournir le paramètre 'horizonstep'"
+msgstr "Si vous utilisez l'option horizon vous devez aussi fournir le paramètre 'horizonstep'."
#: ../raster/r.sun2/main.c:616
#, fuzzy
@@ -2968,14 +2976,14 @@
#: ../general/g.region/printwindow.c:247 ../general/g.region/printwindow.c:503
#: ../general/g.region/printwindow.c:622
msgid "Can't get projection info of current location"
-msgstr "Impossible d'obtenir les informations de projection pour le Secteur (location) courant"
+msgstr "Impossible d'obtenir les informations de projection pour le Secteur courant"
#: ../raster/r.sun2/main.c:732 ../raster/r.sun/main.c:475
#: ../raster/r.horizon/main.c:482 ../display/d.where/main.c:96
#: ../general/g.region/printwindow.c:250 ../general/g.region/printwindow.c:506
#: ../general/g.region/printwindow.c:625
msgid "Can't get projection units of current location"
-msgstr "Impossible d'obtenir les unités de projection pour le Secteur (location) courant"
+msgstr "Impossible d'obtenir les unités de projection pour le Secteur courant"
#: ../raster/r.sun2/main.c:736 ../raster/r.sun/main.c:479
#: ../raster/r.horizon/main.c:486 ../ps/ps.map/do_geogrid.c:272
@@ -2983,14 +2991,14 @@
#: ../general/g.region/printwindow.c:253 ../general/g.region/printwindow.c:509
#: ../general/g.region/printwindow.c:628
msgid "Can't get projection key values of current location"
-msgstr "Impossible d'obtenir les valeurs clefs de projection pour le Secteur (location) courant"
+msgstr "Impossible d'obtenir les valeurs clefs de projection pour le Secteur courant"
#: ../raster/r.sun2/main.c:746 ../raster/r.sun/main.c:489
#: ../raster/r.horizon/main.c:496 ../ps/ps.map/do_geogrid.c:278
#: ../display/d.where/main.c:106 ../display/d.where/main.c:132
#: ../display/d.grid/plot.c:326 ../display/d.grid/plot.c:353
msgid "Unable to set up lat/long projection parameters"
-msgstr "Impossible de fixer les paramètres de projection longitude/latitude"
+msgstr "Impossible de fixer les paramètres de projection latitude/longitude"
#: ../raster/r.sun2/main.c:750
msgid "latin and longin raster maps have no effect when in a Lat/Lon location"
@@ -4661,7 +4669,7 @@
#: ../raster/r.covar/main.c:75 ../vector/v.mkgrid/main.c:141
#: ../vector/v.qcount/main.c:117
msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead."
-msgstr "Le drapeau '-q' est caduque et sera supprimé à l'avenir. Merci d'utiliser '--quiet' à la place."
+msgstr "Le drapeau '-q' est obsolète et sera supprimé à l'avenir. Merci d'utiliser '--quiet' à la place."
#: ../raster/r.cross/main.c:122
#, fuzzy, c-format
