[GRASS-SVN] r58683 - grass/branches/develbranch_6/vector/v.buffer2
svn_grass at osgeo.org
Sun Jan 12 13:01:13 PST 2014
Author: neteler
Date: 2014-01-12 13:01:13 -0800 (Sun, 12 Jan 2014)
New Revision: 58683
Added:
grass/branches/develbranch_6/vector/v.buffer2/v_buffer_lines.png
grass/branches/develbranch_6/vector/v.buffer2/description.html
v.buffer manual: example updated to NC; screenshot added
Modified: grass/branches/develbranch_6/vector/v.buffer2/description.html
--- grass/branches/develbranch_6/vector/v.buffer2/description.html 2014-01-12 20:17:20 UTC (rev 58682)
+++ grass/branches/develbranch_6/vector/v.buffer2/description.html 2014-01-12 21:01:13 UTC (rev 58683)
@@ -16,31 +16,37 @@
<h2>EXAMPLES</h2>
+All examples are based on the North Carolina sample dataset.
<h3>Buffer around input lines</h3>
<div class="code"><pre>
-v.buffer input=map output=buffer type=line distance=100
+v.buffer input=roadsmajor output=roadsmajor_buffer type=line distance=100
</pre></div>
+<center>
+<img src="v_buffer_lines.png" border="1"><br>
+Buffer of 100m along the "roadsmajor" lines (map subset, original center line
+shown in black)
+</center>
<h3>Circles around input points</h3>
-v.buffer input=pointsmap output=circles type=point distance=1000
+v.buffer input=hospitals output=hospitals_circled type=point distance=1000
</pre></div>
-<h3>Non-overlapping circles around input points with attribute transfer</h3>
+<h3>Overlapping circles around input points with attribute transfer</h3>
-v.buffer input=archsites output=circles type=point distance=200
+v.buffer input=hospitals output=circles type=point distance=2000
# change original points to centroids:
-v.type in=archsites out=archcentroids type=point,centroid
+v.type in=hospitals out=hospital_centroids type=point,centroid
# patch circles and centroids:
-v.patch in=archcentroids,circles out=circles_db
-# attach attributes, either use
-# db.copy ...
-# or link to the original table:
-v.db.connect map=circles_db table=archsites field=1 key=cat driver=dbf \
-database='$GISDBASE/$LOCATION_NAME/$MAPSET/dbf'
+v.patch in=hospital_centroids,circles out=circles_db
+# attach attributes, either use db.copy or link to the original table:
+v.db.connect map=circles_db table=hospitals layer=1 key=cat driver=dbf \
+ database='$GISDBASE/$LOCATION_NAME/$MAPSET/dbf'
</pre></div>
@@ -54,7 +60,6 @@
<a href="v.db.connect.html">v.db.connect</a>
</em>
<h2>AUTHORS</h2>
Radim Blazek<br>
Added: grass/branches/develbranch_6/vector/v.buffer2/v_buffer_lines.png
(Binary files differ)
Property changes on: grass/branches/develbranch_6/vector/v.buffer2/v_buffer_lines.png
___________________________________________________________________
Added: svn:mime-type
+ image/png
