[GRASS-SVN] r58727 - grass/trunk/scripts/v.rast.stats
Tue Jan 14 15:15:24 PST 2014
Author: lucadelu
Date: 2014-01-14 15:15:24 -0800 (Tue, 14 Jan 2014)
New Revision: 58727
   grass/trunk/scripts/v.rast.stats/v.rast.stats.py
fix bug introduced in r58726, remove unuseful functions and for cicle
Modified: grass/trunk/scripts/v.rast.stats/v.rast.stats.py
--- grass/trunk/scripts/v.rast.stats/v.rast.stats.py	2014-01-14 22:14:38 UTC (rev 58726)
+++ grass/trunk/scripts/v.rast.stats/v.rast.stats.py	2014-01-14 23:15:24 UTC (rev 58727)
@@ -72,11 +72,6 @@
 import grass.script as grass
-# TODO it is not used, could we remove it?
-def has_column(vector, col):
-    return
 def cleanup():
     if rastertmp:
         grass.run_command('g.remove', rast=rastertmp, quiet=True)
@@ -173,7 +168,7 @@
     if not fi['table']:
         grass.fatal(_('There is no table connected to this map. Run v.db.connect or v.db.addtable first.'))
-    # replaced by user choiche
+    # replaced by user choiche
     #basecols = ['n', 'min', 'max', 'range', 'mean', 'stddev', 'variance', 'cf_var', 'sum']
     # we need at least three chars to distinguish [mea]n from [med]ian
@@ -182,6 +177,8 @@
         colprefix = colprefix[:6]
     # do extended stats?
+    # by default perccol variable is used only for "variables" variable
+    perccol = "percentile"
     if flags['e']:
         # namespace is limited in DBF but the % value is important
         if dbfdriver:
@@ -193,12 +190,14 @@
         extracols = []
     addcols = []
+    colnames = []
     for i in basecols + extracols:
         # check if column already present
         currcolumn = ("%s_%s" % (colprefix, i))
         if dbfdriver:
             currcolumn = currcolumn[:10]
+        colnames.append(currcolumn)
         if currcolumn in grass.vector_columns(vector, layer).keys():
             if not flags['c']:
                 grass.fatal((_("Cannot create column <%s> (already present). ") % currcolumn) +
@@ -222,15 +221,6 @@
     # get rid of any earlier attempts
     grass.try_remove(sqltmp)
-    colnames = []
-    for var in basecols + extracols:
-        colname = '%s_%s' % (colprefix, var)
-        if dbfdriver:
-            colname = colname[:10]
-        colnames.append(colname)
-    ntabcols = len(colnames)
     if flags['e']:
         extstat = 'e'
@@ -244,10 +234,12 @@
                            zones=rastertmp, percentile=percentile, sep=';')
     first_line = 1
+    # dictionary with name of methods and position in "r.univar -gt"  output
     variables = {'number': 2, 'minimum': 4, 'maximum': 5, 'range': 6,
                  'mean': 7, 'stddev': 9, 'variance': 10, 'coeff_var': 11,
                  'sum': 12, 'first_quartile': 14, 'median': 15,
-                 'third_quartile': 16, perccol: 17 }
+                 'third_quartile': 16, perccol: 17}
     f.write("BEGIN TRANSACTION\n")
     for line in p.stdout:
