[GRASS-SVN] r58751 - grass/branches/releasebranch_6_4/gui/wxpython/core
svn_grass at osgeo.org
Mon Jan 20 13:40:55 PST 2014
Author: annakrat
Date: 2014-01-20 13:40:54 -0800 (Mon, 20 Jan 2014)
New Revision: 58751
grass/branches/releasebranch_6_4/gui/wxpython/core/render.py
wxGUI: check for invalid map size (merge from develbranch, r54951)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/core/render.py
--- grass/branches/releasebranch_6_4/gui/wxpython/core/render.py 2014-01-20 18:23:09 UTC (rev 58750)
+++ grass/branches/releasebranch_6_4/gui/wxpython/core/render.py 2014-01-20 21:40:54 UTC (rev 58751)
@@ -557,22 +557,21 @@
def ChangeMapSize(self, (width, height)):
"""!Change size of rendered map.
- @param width,height map size
- @return True on success
- @return False on failure
+ @param width,height map size given as tuple
try:
self.width = int(width)
self.height = int(height)
- Debug.msg(2, "Map.ChangeMapSize(): width=%d, height=%d" % \
- (self.width, self.height))
- return True
- except:
+ if self.width < 1 or self.height < 1:
+ sys.stderr.write(_("Invalid map size %d,%d\n") % (self.width, self.height))
+ raise ValueError
+ except ValueError:
self.width = 640
self.height = 480
- return False
+ Debug.msg(2, "Map.ChangeMapSize(): width=%d, height=%d" % \
+ (self.width, self.height))
def GetRegion(self, rast = [], zoom = False, vect = [], regionName = None,
n = None, s = None, e = None, w = None, default = False,
update = False):
