[GRASS-SVN] r58777 - grass/branches/releasebranch_6_4/general/g.parser
svn_grass at osgeo.org
Sat Jan 25 11:03:32 PST 2014
Author: neteler
Date: 2014-01-25 11:03:32 -0800 (Sat, 25 Jan 2014)
New Revision: 58777
grass/branches/releasebranch_6_4/general/g.parser/description.html
g.parser manual: update (partial backport of r58759)
Modified: grass/branches/releasebranch_6_4/general/g.parser/description.html
--- grass/branches/releasebranch_6_4/general/g.parser/description.html 2014-01-25 18:47:22 UTC (rev 58776)
+++ grass/branches/releasebranch_6_4/general/g.parser/description.html 2014-01-25 19:03:32 UTC (rev 58777)
@@ -1,7 +1,7 @@
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
-<title>g.parser</title>
+<title>GRASS GIS manual: g.parser</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<link rel="stylesheet" href="grassdocs.css" type="text/css">
</head>
@@ -10,7 +10,8 @@
<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
<h2>NAME</h2>
-<em><b>g.parser</b></em>
+<em><b>g.parser</b></em> - Provides full parser support for GRASS
+scripts.
<h2>SYNOPSIS</h2>
<b>g.parser help</b><br>
@@ -21,7 +22,7 @@
<dt><b>-t</b></dt>
<dd>Print strings for translation</dd>
<dt><b>-s</b></dt>
-<dd>Write option values to stdout instead of reinvoking script</dd>
+<dd>Write option values to standard output instead of reinvoking script</dd>
</dl>
<h2>DESCRIPTION</h2>
@@ -47,12 +48,12 @@
<p>
If the <b>-s</b> switch is used, the options and flags are written to
-stdout in the form <em>opt_<name>=<value></em> and
+standard output in the form <em>opt_<name>=<value></em> and
<em>flag_<name>=<value></em>, preceded by the string
<b>@ARGS_PARSED@</b>. If this string doesn't appear as the first line
-of stdout, it indicates that the script was invoked with a switch such
+of standard output, it indicates that the script was invoked with a switch such
as <b>--html-description</b>. In this case, the data written by
-<em>g.parser</em> to stdout should be copied to the script's stdout
+<em>g.parser</em> to standard output should be copied to the script's standard output
verbatim.
<p>
@@ -107,16 +108,16 @@
<tt>[input=filename]</tt>.
<p>
-If a script is run with --o, G_parser() will
+If a script is run with <b>--o</b>, G_parser() will
set <tt>GRASS_OVERWRITE=1</tt>, which has the same effect as passing
---o to every module which is run from the script. Similarly, passing
---q or --v will set <tt>GRASS_VERBOSE</tt> to 0 or 3 respectively,
-which has the same effect as passing --q or --v to every module which
-is run from the script. Rather than checking whether --o, --q or --v
+<b>--o</b> to every module which is run from the script. Similarly, passing
+<b>--q</b> or <b>--v</b> will set <tt>GRASS_VERBOSE</tt> to 0 or 3 respectively,
+which has the same effect as passing <b>--q</b> or <b>--v</b> to every module which
+is run from the script. Rather than checking whether <b>--o</b>, <b>--q</b> or <b>--v</b>
were used, you should be checking <tt>GRASS_OVERWRITE</tt> and/or
<tt>GRASS_VERBOSE</tt> instead. If those variables are set, the
script should behave the same way regardless of whether they were set
-by --o, --q or --v being passed to the script or set by other means.
+by <b>--o</b>, <b>--q</b> or <b>--v</b> being passed to the script or set by other means.
<h2>AUTOMATED SCRIPT CREATION</h2>
@@ -170,7 +171,7 @@
</pre></div>
<em>g.parser</em> will print the text of the translatable options to
-<tt>stdout</tt>, one per line, and exit. This is for internal use within
+standard output, one per line, and exit. This is for internal use within
the build system to prepare GRASS scripts for translation.
@@ -180,7 +181,9 @@
without parameters of flags:
<p>
+<center>
<img src="g_parser_test.png" alt="Autogenerated GUI window">
+</center>
<h3>Example code for SHELL</h3>
@@ -316,6 +319,7 @@
option1 = options['option1']
raster = options['raster']
vector = options['vector']
#### add your code here ####
if flag_f:
@@ -325,10 +329,10 @@
# test if parameter present:
if option1:
- print "Value of option1= option: '%s'" % option1
+ print "Value of option1 option: '%s'" % option1
- print "Value of raster= option: '%s'" % raster
- print "Value of vector= option: '%s'" % vector
+ print "Value of raster option: '%s'" % raster
+ print "Value of vector option: '%s'" % vector
#### end of your code ####
@@ -406,7 +410,6 @@
exit 1;
if( $ARGV[0] ne '@ARGS_PARSED@' ){
my $arg = "";
for (my $i=0; $i < @ARGV;$i++) {
@@ -448,7 +451,8 @@
<a href="g.tempfile.html">g.tempfile</a>
</em>
-and the <tt>SUBMITTING_SCRIPTS</tt> file in the GRASS source code.
+and <a href="http://svn.osgeo.org/grass/grass/branches/releasebranch_6_4/SUBMITTING_PYTHON">SUBMITTING_PYTHON</a>
+file in the GRASS source code.
<p>
Related Wiki pages:
<a href="http://grasswiki.osgeo.org/wiki/Category:Linking_to_other_languages">Using GRASS with other programming languages</a>
@@ -459,5 +463,8 @@
<p>
<i>Last changed: $Date$</i>
+<hr>
+<p><a href="index.html">Main index</a> | <a href="full_index.html">Full index</a></p>
+<p>© 2003-2014 <a href="http://grass.osgeo.org">GRASS Development Team</a>
</body>
</html>
