[GRASS-SVN] r58806 - grass-addons/grass7/raster/r.to.vect.tiled
    svn_grass at osgeo.org
    Wed Jan 29 11:29:26 PST 2014
Author: mmetz
Date: 2014-01-29 11:29:26 -0800 (Wed, 29 Jan 2014)
New Revision: 58806
Added:
   grass-addons/grass7/raster/r.to.vect.tiled/Makefile
   grass-addons/grass7/raster/r.to.vect.tiled/r.to.vect.tiled.html
   grass-addons/grass7/raster/r.to.vect.tiled/r.to.vect.tiled.py
add r.to.vect.tiled
Added: grass-addons/grass7/raster/r.to.vect.tiled/Makefile
--- grass-addons/grass7/raster/r.to.vect.tiled/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.to.vect.tiled/Makefile	2014-01-29 19:29:26 UTC (rev 58806)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.to.vect.tiled
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/raster/r.to.vect.tiled/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Added: grass-addons/grass7/raster/r.to.vect.tiled/r.to.vect.tiled.html
--- grass-addons/grass7/raster/r.to.vect.tiled/r.to.vect.tiled.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.to.vect.tiled/r.to.vect.tiled.html	2014-01-29 19:29:26 UTC (rev 58806)
@@ -0,0 +1,25 @@
+<h2>DESCRIPTION</h2>
+<em>r.to.vect.tiled</em> vectorizes the <b>input</b> raster map and
+produces several tiled vector maps covering the current region.
+<p>
+Vectorizing a large raster map with <em>r.to.vect</em> can require a
+lot of memory. In these cases, <em>r.to.vect.tiled</em> can reduce
+memory usage by vectorizing each tile separately.
+<p>
+The tiles are optionally patched together with the <em>-p</em> flag.
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.to.vect.html">r.to.vect</a>,
+<a href="g.region.html">g.region</a>,
+<a href="v.patch.html">v.patch</a>,
+<a href="r.thin.html">r.thin</a>,
+<a href="v.clean.html">v.clean</a>
+</em>
+<h2>AUTHORS</h2>
+Markus Metz
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/raster/r.to.vect.tiled/r.to.vect.tiled.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Added: grass-addons/grass7/raster/r.to.vect.tiled/r.to.vect.tiled.py
--- grass-addons/grass7/raster/r.to.vect.tiled/r.to.vect.tiled.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.to.vect.tiled/r.to.vect.tiled.py	2014-01-29 19:29:26 UTC (rev 58806)
@@ -0,0 +1,251 @@
+#!/usr/bin/env python
+# MODULE:       r.to.vect.tiled
+# AUTHOR(S):    Markus Metz
+# PURPOSE:      Tiled raster to vector conversion
+# COPYRIGHT:    (C) 2014 by the GRASS Development Team
+#  This program is free software; you can redistribute it and/or modify
+#  it under the terms of the GNU General Public License as published by
+#  the Free Software Foundation; either version 2 of the License, or
+#  (at your option) any later version.
+#  This program is distributed in the hope that it will be useful,
+#  but WITHOUT ANY WARRANTY; without even the implied warranty of
+#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+#  GNU General Public License for more details.
+#%module
+#% description: Converts a raster map into vector tiles.
+#% keywords: raster, conversion, geometry, vectorization, tiling
+#% overwrite: yes
+#%end
+#%option G_OPT_R_INPUT
+#%end
+#%option
+#% key: output
+#% type: string
+#% required: yes
+#% multiple: no
+#% description: Output base name
+#%end
+#%option
+#% key: type
+#% type: string
+#% required: yes
+#% multiple: no
+#% options: point,line,area
+#% description: Feature type
+#%end
+#%option
+#% key: column
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% label: Name of attribute column to store value
+#% description: Name must be SQL compliant
+#% answer: value
+#% guisection: Attributes
+#%end
+#%flag
+#% key: s
+#% description: Smooth corners of linear features
+#%end
+#%flag
+#% key: v
+#% description: Use raster values as categories instead of unique sequence (CELL only)
+#%end
+#%flag
+#% key: z
+#% label: Write raster values as z coordinate
+#% description: Table is not created. Currently supported only for points.
+#%end
+#%flag
+#% key: b
+#% label: Do not build vector topology
+#% description: Recommended for massive point conversion
+#%end
+#%flag
+#% key: t
+#% description: Do not create attribute table
+#%end
+#%flag
+#% key: p
+#% description: Patch the tiles
+#%end
+#%option
+#% key: x
+#% type: integer
+#% required: no
+#% answer: 2
+#% multiple: no
+#% description: Number of tiles in x direction
+#% guisection: Tiling
+#%end
+#%option
+#% key: y
+#% type: integer
+#% required: no
+#% answer: 2
+#% multiple: no
+#% description: Number of tiles in y direction
+#%end
+import sys
+import grass.script as grass
+def main():
+    input = options['input']
+    output = options['output']
+    column = options['column']
+    ftype = options['type']
+    xtiles = int(options['x'])
+    ytiles = int(options['y'])
+    rtvflags=""
+    for key in 'sbtvz':
+	if flags[key]:
+	    rtvflags += key
+    # check options
+    if xtiles <= 0:
+	grass.fatal(_("Number of tiles in x direction must be > 0"))
+    if ytiles < 0:
+	grass.fatal(_("Number of tiles in y direction must be > 0"))
+    if grass.find_file(name = input)['name'] == '':
+	grass.fatal(_("Input raster %s not found") % input)
+    grass.use_temp_region()
+    curr = grass.region()
+    width = int(curr['cols'] / xtiles)
+    if width <= 1:
+	grass.fatal("The requested number of tiles in x direction is too large")
+    height = int(curr['rows'] / ytiles)
+    if height <= 1:
+	grass.fatal("The requested number of tiles in y direction is too large")
+    do_clip = False
+    overlap = 0
+    if flags['s'] and ftype == 'area':
+	do_clip = True
+	overlap = 2
+    ewres = curr['ewres']
+    nsres = curr['nsres']
+    xoverlap = overlap * ewres
+    yoverlap = overlap * nsres
+    xoverlap2 = (overlap / 2) * ewres
+    yoverlap2 = (overlap / 2) * nsres
+    e = curr['e']
+    w = curr['w'] + xoverlap
+    if w >= e:
+	grass.fatal(_("Overlap is too large"))
+    n = curr['n'] - yoverlap
+    s = curr['s']
+    if s >= n:
+    datatype = grass.raster_info(input)['datatype']
+    vtiles = None
+    # north to south
+    for ytile in range(ytiles):
+	n = curr['n'] - ytile * height * nsres
+	s = n - height * nsres - yoverlap
+	if ytile == ytiles - 1:
+	    s = curr['s']
+	# west to east
+	for xtile in range(xtiles):
+	    w = curr['w'] + xtile * width * ewres
+	    e = w + width * ewres + xoverlap
+	    if xtile == xtiles - 1:
+	        e = curr['e']
+	    grass.run_command('g.region', n = n, s = s, e = e, w = w, nsres = nsres, ewres = ewres)
+	    if do_clip:
+		tilename = output + '_stile_' + str(ytile) + str(xtile)
+	    else:
+		tilename = output + '_tile_' + str(ytile) + str(xtile)
+	    outname = output + '_tile_' + str(ytile) + str(xtile)
+	    grass.run_command('r.to.vect', input = input, output = tilename,
+	                      type = ftype, column = column, flags = rtvflags)
+	    if do_clip:
+		n2 = curr['n'] - ytile * height * nsres - yoverlap2
+		s2 = n2 - height * nsres
+		if ytile == 0:
+		    n2 = curr['n']
+		    s2 = n2 - height * nsres - yoverlap2
+		    s2 = curr['s']
+		w2 = curr['w'] + xtile * width * ewres + xoverlap2
+		e2 = w2 + width * ewres
+		if xtile == 0:
+		    w2 = curr['w']
+		    e2 = w2 + width * ewres + xoverlap2
+		    e2 = curr['e']
+		if grass.vector_info_topo(tilename)['areas'] > 0:
+		    grass.run_command('g.region', n = n2, s = s2, e = e2, w = w2,
+				      nsres = nsres, ewres = ewres)
+		    extname = 'extent_tile_' + str(ytile) + str(xtile)
+		    grass.run_command('v.in.region', output = extname, flags = 'd')
+		    grass.run_command('v.overlay', ainput = tilename, binput = extname,
+				      output = outname, operator = 'and', olayer = '0,1,0')
+		    grass.run_command('g.remove', vect = extname, quiet = True)
+		    if vtiles is None:
+			vtiles = outname
+		    else:
+			vtiles = vtiles + ',' + outname
+		grass.run_command('g.remove', vect = tilename, quiet = True)
+	    else:
+		# write cmd history:
+		grass.vector_history(outname)
+		    vtiles = outname
+		else:
+    if flags['p']:
+	grass.run_command('v.patch', input = vtiles, output = output,
+			  flags = 'e')
+        grass.run_command('g.remove', vect = vtiles, quiet = True)
+	if grass.vector_info_topo(output)['boundaries'] > 0:
+	    outpatch = output + '_patch'
+	    grass.run_command('g.rename', vect = (output,outpatch))
+	    grass.run_command('v.clean', input = outpatch, output = output,
+			      tool = 'break', flags = 'c')
+	    grass.run_command('g.remove', vect = outpatch)
+    grass.message(_("%s complete") % 'r.to.vect.tiled')
+    return 0
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    sys.exit(main())
Property changes on: grass-addons/grass7/raster/r.to.vect.tiled/r.to.vect.tiled.py
   + text/x-python
   + native
