[GRASS-SVN] r61111 - grass-addons/grass7/vector/v.class.ml
svn_grass at osgeo.org
Wed Jul 2 00:36:55 PDT 2014
Author: zarch
Date: 2014-07-02 00:36:54 -0700 (Wed, 02 Jul 2014)
New Revision: 61111
grass-addons/grass7/vector/v.class.ml/v.class.ml.html
v.class.ml: Start manual page
Modified: grass-addons/grass7/vector/v.class.ml/v.class.ml.html
--- grass-addons/grass7/vector/v.class.ml/v.class.ml.html 2014-07-02 07:36:18 UTC (rev 61110)
+++ grass-addons/grass7/vector/v.class.ml/v.class.ml.html 2014-07-02 07:36:54 UTC (rev 61111)
@@ -0,0 +1,200 @@
+<h2>DESCRIPTION</h2>
+<b>v.class.ml</b> uses machine-learning algorithms to classify a vector maps
+based on the values of its attribute table.
+The module uses different machine-learning libraries available for python
+at the moment uses:
+<a href="http://scikit-learn.org/">scikit-learn</a> and
+<a href="http://mlpy.sourceforge.net/">MLPY</a>, but should be possible to
+add easily other python libraries.
+The module is though to be use in a modular way, using the flags it is
+possible to define which independent tasks should be execute.
+<h3>Flags:</h3>
+<dl>
+ <dt><b>-e</b>
+ <dd>Extract the training set from a vector map (vtraining).</dd>
+ <dt><b>-n</b>
+ <dd>Store: attribute table data, columns names, categories training data,
+ training index to a numpy binary files.</dd>
+ <dt><b>-f</b>
+ <dd>Rank feature importances using a
+ <a href="http://scikit-learn.org/stable/modules/generated/sklearn.ensemble.ExtraTreesClassifier.html">ExtraTreesClassifier</a> algorithm.</dd>
+ <dt><b>-b</b>
+ <dd>Balance the training using the class with the minor number of training
+ samples or the parameter set in n_training.</dd>
+ <dt><b>-o</b>
+ <dd>Optimize a balanced training dataset using the class with the minor
+ number of training samples or the parameter set in n_training.</dd>
+ <dt><b>-c</b>
+ <dd>Classify the whole dataset.</dd>
+ <dt><b>-r</b>
+ <dd>Export machine-learning results to raster maps.</dd>
+ <dt><b>-t</b>
+ <dd>Test several machine-learning algorithms on your dataset.</dd>
+ <dt><b>-v</b>
+ <dd>Test also the bias variance.</dd>
+ <dt><b>-x</b>
+ <dd>Compute also extra parameters to evaluate different algorithms like:
+ confusion matrix, ROC, PR.</dd>
+ <dt><b>-d</b>
+ <dd>Explore the Support Vector Classification (SVC) domain.</dd>
+</dl>
+<h3>Input parameters:</h3>
+<p>The <i>vector</i> parameter is the input vector map. The input vector map
+must be prepared with <a href="grass.osgeo.org/grass70/manuals/v.category.html">v.category</a> to copy the
+categories to all the layers that will be created.
+<p>The <i>vtraining</i> parameter is a vector input map that can be used to
+select the training areas. Currently only supervised classification is
+implemented so this parameter is mandatory. The training vector map can
+be generated using the GRASS standard tool for supervised classification
+<a href="http://grass.osgeo.org/grass70/manuals/g.gui.iclass.html">g.gui.iclass</a>.
+<p>The <i>vlayer</i> parameter is the layer name or number of the
+attribute tables with the data that must be used as input for the
+machine-learning algorithms.
+<p>The <i>tlayer</i> parameter is the layer name or number of the
+attribute tables where are or will be stored the training data for
+the machine-learning algorithms.
+<p>The <i>rlayer</i> parameter is the layer name or number the
+attribute tables where will be stored the machine-learning results.
+<p>The <i>npy_data</i> parameter is a string with the path to define where
+the binary <a href="http://www.numpy.org//">numpy</a> files containing the complete
+dataset will be saved.
+<p>The <i>npy_cats</i> parameter is a string with the path to define where
+the binary numpy files containing the vector categories will be saved.
+<p>The <i>npy_cols</i> parameter is a string with the path to define where
+the binary numpy files containing the column names of the data attribute table
+will be saved.
+<p>The <i>npy_index</i> parameter is a string with the path to define where
+the binary numpy files containing a boolean array to say if the category is
+used or not as training.
+<p>The <i>npy_tdata</i> parameter is a string with the path to define where
+the binary numpy files containing a training data array will be saved.
+<p>The <i>npy_tclasses</i> parameter is a string with the path to define where
+the binary numpy files containing the training classes will be saved.
+<p>The <i>npy_btdata</i> parameter as npy_tdata but only for a balance dataset.
+<p>The <i>npy_btclasses</i> parameter as npy_tclasses but only for a balance
+dataset.
+<p>The <i>imp_csv</i> parameter is a string with the path to define where a CSV
+file containing the rank of the feature importances should be save.
+<p>The <i>imp_fig</i> parameter is a string with the path to define where a
+figure file containing the rank of the feature importances should be save.
+<p>The <i>scalar</i> parameter is a string with scaler methods that will be
+apply to pre-process the data. Two main methods are available:
+with_mean, with_std.
+This is a quite common task therefore the default parameter apply both methods.
+<p>The <i>decomposition</i> parameter is a string with scaler methods that will
+be apply to pre-process the data. The main decomposition methods available are:
+<a href="http://scikit-learn.org/stable/modules/generated/sklearn.decomposition.PCA.html">PCA</a>,
+<a href="http://scikit-learn.org/stable/modules/generated/sklearn.decomposition.KernelPCA.html">KernelPCA</a>,
+<a href="http://scikit-learn.org/stable/modules/generated/sklearn.decomposition.ProbabilisticPCA.html">ProbabilisticPCA</a>,
+<a href="http://scikit-learn.org/stable/modules/generated/sklearn.decomposition.RandomizedPCA.htmlc">RandomizedPCA</a>,
+<a href="http://scikit-learn.org/stable/modules/generated/sklearn.decomposition.FastICA.html">FastICA</a>,
+<a href="http://scikit-learn.org/stable/modules/generated/sklearn.decomposition.TruncatedSVD.html">TruncatedSVD</a>.
+Each of this methods could take several parameters. Use "|" as separator
+between the decomposition method name and its options, using the "," to
+separate the options. For examples imagine that we want to decompose using
+the KernelPCA method with 10 number of components and using a linear kernel,
+so the correct string is:
+"KernelPCA|n_components=10,kernel=linear"
+<p>The <i>n_training</i> parameter is an integer with the number of training
+that must be use per class. Some machine-learning methods are sensitive if the
+training dataset is balanced or not. As default all the training will be used.
+<p>The <i>pyclassifiers</i> parameter is a file path to a python file containing
+a list of dictionary to define classifiers class and options. See an example of
+the <a href="http://trac.osgeo.org/grass/browser/grass-addons/grass7/vector/v.class.ml/ml_classifiers.py">default classifiers</a> used by the v.class.ml
+module.
+<p>The <i>pyvar</i> parameter is a string with the python variable name defined
+in the pyclassifiers file.
+<p>The <i>pyindx</i> parameter is a string with the indexes of the classifiers
+that will be used. In the string you could define a range using the minus
+character, or list the index usig the comma as separator, or combine both
+options together. For example: '1-5,34-36,40' it means that only classifiers
+with index: 1, 2, 3, 4, 5, 34, 35, 36 and 40 will be used.
+<p>The <i>pyindx_optimize</i> parameter is a integer with the classifier index
+that will be used to optimize a balance training dataset. This option is used
+only if optimize is true otherwise will be ignored.
+<p>The <i>nan</i> parameter is a string that allows user to define for each
+column in the attribute table which value or function should be used to
+substitute NaN values. The syntax could be: 'col0:9999,col1:9999'.
+The column name could be also a pattern, so it is possible to define a rule like:
+'*_mean:nanmean,*_max:nanmax' that substitute in all the columns
+that finish with '_mean' the mean value of the column and for column that end
+with '_max' the maximum value.
+This operation is needed because machine-learning algorithms are not able to
+handle nan, inf, neginf, and posinf values.
+<p>The <i>inf</i> parameter is similar to nan, but instead of substituting nan
+values the rules will be applied for infinite values.
+<p>The <i>neginf</i> parameter is similar to nan, but instead of substituting nan
+values the rules will be applied for negative infinite values.
+<p>The <i>posinf</i> parameter is similar to nan, but instead of substituting nan
+values the rules will be applied for positive infinite values.
+<p>The <i>csv_test_cls</i> parameter is the file name/path where the results of
+the classification test will be written.
+<p>The <i>report_class</i> parameter is the file name/path where a summary for
+each machine learning algorithms will be written.
+<p>The <i>svc_c_range</i> parameter is a range of C values that will be used
+when exploring the domain of the Support Vector Machine algorithms.
+<p>The <i>svc_gamma_range</i> parameter is a range of gamma values that will
+be used when exploring the domain of the Support Vector Machine algorithms.
+<p>The <i>svc_kernel_range</i> parameter is a range of kernel values that will
+<p>The <i>svc_n_jobs</i> parameter is an integer with the number of process
+that will be used during the domain exploration of Support Vector Machine
+algorithms.
+<p>The <i>svc_img</i> parameter is the file name/path pattern of the image that
+will be generated from the domain exploration.
+<p>The <i>svc_c</i> parameter is the definitive C value that will be used
+for final classification.
+<p>The <i>svc_gamma</i> parameter is the definitive gamma value that will be
+used for final classification.
+<p>The <i>svc_kernel</i> parameter is the definitive kernel value that will be
+<p>The <i>rst_names</i> parameter is the name pattern that will be use to
+generate the output raster map for each algorithm.
