[GRASS-SVN] r61122 - grass-addons/grass7/raster/r.valley.bottom
svn_grass at osgeo.org
Wed Jul 2 11:22:56 PDT 2014
Author: hellik
Date: 2014-07-02 11:22:56 -0700 (Wed, 02 Jul 2014)
New Revision: 61122
grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.html
grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py
r.valley.bottom: add flag s for a square moving window in calculations
Modified: grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.html
--- grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.html 2014-07-02 17:16:24 UTC (rev 61121)
+++ grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.html 2014-07-02 18:22:56 UTC (rev 61122)
@@ -6,6 +6,11 @@
raster</b> map.
</p>
+<p>
+Default moving window is cells in 8 directions. With the <b>-s</b> flag
+a square moving window is used in calculations.
+</p>
<h2>EXAMPLE</h2>
<div class="code">
Modified: grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py
--- grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py 2014-07-02 17:16:24 UTC (rev 61121)
+++ grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py 2014-07-02 18:22:56 UTC (rev 61122)
@@ -1,4 +1,5 @@
#!/usr/bin/env python
+# -*- coding: utf-8
MODULE: r.valley.bottom
@@ -30,6 +31,12 @@
#% required: yes
#%end
+#%flag
+#% key: s
+#% description: Use square moving window instead of moving window in 8 directions
+#%end
# TODO: Design the script independent of input elevation raster resolution. At
# the moment the input elevation raster map must have a resolution of 25m
@@ -48,7 +55,8 @@
def main():
r_elevation = options['elevation'].split('@')[0] # elevation raster
r_slope_degree = r_elevation+'_slope_degree' # slope (percent) step 1
+ moving_window_square = flags['s']
# Region settings
current_region = grass.region()
@@ -114,18 +122,34 @@
grass.message( "..." )
grass.mapcalc("elevation_step1 = $r_elevation",
r_elevation = r_elevation)
+ if moving_window_square :
+ offsets1 = [d
+ for j in xrange(1,3+1)
+ for i in [j,-j]
+ for d in [(i,0),(i,1),(i,2),(i,3),(i,-1),(i,-2),(i,-3)]]
+ grass.message( "..." )
+ terms = ["(elevation_step1[%d,%d] < elevation_step1)" % d
+ for d in offsets1]
+ expr1 = "PCTL1 = (100.0 / 48.0) * (%s)" % " + ".join(terms)
- offsets = [d
- for j in xrange(1,3+1)
- for i in [j,-j]
- for d in [(i,0),(0,i),(i,i),(i,-i)]]
+ else :
+ offsets1 = [d
+ for i in [j,-j]
+ for d in [(i,0),(0,i),(i,i),(i,-i)]]
- grass.message( "..." )
- terms = ["(elevation_step1[%d,%d] < elevation_step1)" % d
- for d in offsets]
- expr1 = "PCTL1 = (100.0 / 24.0) * (%s)" % " + ".join(terms)
+ expr1 = "PCTL1 = (100.0 / 24.0) * (%s)" % " + ".join(terms)
grass.mapcalc( expr1 )
@@ -174,21 +198,37 @@
grass.message( "----" )
# Calculation of elevation percentile PCTL2 step 2
- # elevation of percentile step 2: radius of 3 cells
+ # elevation of percentile step 2: radius of 6 cells
grass.message( "Step 2: Calculation of elevation percentile PCTL2" )
+ offsets2 = [d
+ for j in xrange(1,6+1)
+ for i in [j,-j]
+ for d in [(i,0),(i,1),(i,2),(i,3),(i,4),(i,5),(i,6),(i,-1),(i,-2),(i,-3),(i,-4),(i,-5),(i,-6)]]
+ terms2 = ["(elevation_step1[%d,%d] < elevation_step1)" % d
+ for d in offsets2]
+ expr2 = "PCTL2 = (100.0 / 168.0) * (%s)" % " + ".join(terms2)
- offsets2 = [d
- for j in xrange(1,6+1)
- for i in [j,-j]
+ else :
+ offsets2 = [d
+ for i in [j,-j]
- terms2 = ["(elevation_step1[%d,%d] < elevation_step1)" % d
- for d in offsets2]
- expr2 = "PCTL2 = (100.0 / 48.0) * (%s)" % " + ".join(terms2)
+ expr2 = "PCTL2 = (100.0 / 48.0) * (%s)" % " + ".join(terms2)
grass.mapcalc( expr2 )
grass.run_command("g.remove", rast = "elevation_step1",
@@ -291,7 +331,7 @@
# change resolution
- grass.message( "Step 3: change to resolution to 3 x base resolution" )
+ grass.message( "Step 3: change to resolution of 3 x base resolution" )
grass.run_command('g.region', res = Xres_step3,
flags = 'a')
@@ -307,18 +347,34 @@
grass.mapcalc("DEM_smoothed_step3_coarsed = DEM_smoothed_step3")
- offsets3 = [d
- for i in [j,-j]
+ offsets3 = [d
+ for i in [j,-j]
- terms3 = ["(DEM_smoothed_step3_coarsed[%d,%d] < DEM_smoothed_step3_coarsed)" % d
- for d in offsets3]
+ terms3 = ["(DEM_smoothed_step3_coarsed[%d,%d] < DEM_smoothed_step3_coarsed)" % d
+ for d in offsets3]
- expr3 = "PCTL3 = (100.0 / 48.0) * (%s)" % " + ".join(terms3)
+ expr3 = "PCTL3 = (100.0 / 168.0) * (%s)" % " + ".join(terms3)
+ else :
+ offsets3 = [d
+ for i in [j,-j]
+ expr3 = "PCTL3 = (100.0 / 48.0) * (%s)" % " + ".join(terms3)
grass.mapcalc( expr3 )
grass.message( "Step 3: Calculation of elevation percentile PCTL3 done." )
@@ -472,18 +528,34 @@
grass.mapcalc("DEM_smoothed_step4_coarsed = DEM_smoothed_step4")
- offsets4 = [d
- for i in [j,-j]
+ offsets4 = [d
+ for i in [j,-j]
- terms4 = ["(DEM_smoothed_step4_coarsed[%d,%d] < DEM_smoothed_step4_coarsed)" % d
- for d in offsets4]
+ terms4 = ["(DEM_smoothed_step4_coarsed[%d,%d] < DEM_smoothed_step4_coarsed)" % d
+ for d in offsets4]
- expr4 = "PCTL4 = (100.0 / 48.0) * (%s)" % " + ".join(terms4)
+ expr4 = "PCTL4 = (100.0 / 168.0) * (%s)" % " + ".join(terms4)
+ else :
+ offsets4 = [d
+ for i in [j,-j]
+ expr4 = "PCTL4 = (100.0 / 48.0) * (%s)" % " + ".join(terms4)
grass.mapcalc( expr4 )
grass.message( "Step 4: Calculation of elevation percentile PCTL4 done." )
