[GRASS-SVN] r61126 - grass/trunk/include/Make
Wed Jul 2 13:31:18 PDT 2014
Author: martinl
Date: 2014-07-02 13:31:18 -0700 (Wed, 02 Jul 2014)
New Revision: 61126
   grass/trunk/include/Make/Doxyfile_arch_html.in
   grass/trunk/include/Make/Doxyfile_arch_latex.in
doxygen: remove obsolete configuration options
Modified: grass/trunk/include/Make/Doxyfile_arch_html.in
--- grass/trunk/include/Make/Doxyfile_arch_html.in	2014-07-02 20:21:05 UTC (rev 61125)
+++ grass/trunk/include/Make/Doxyfile_arch_html.in	2014-07-02 20:31:18 UTC (rev 61126)
@@ -319,22 +319,6 @@
 TYPEDEF_HIDES_STRUCT   = NO
-# The SYMBOL_CACHE_SIZE determines the size of the internal cache use to
-# determine which symbols to keep in memory and which to flush to disk.
-# When the cache is full, less often used symbols will be written to disk.
-# For small to medium size projects (<1000 input files) the default value is
-# probably good enough. For larger projects a too small cache size can cause
-# doxygen to be busy swapping symbols to and from disk most of the time
-# causing a significant performance penalty.
-# If the system has enough physical memory increasing the cache will improve the
-# performance by keeping more symbols in memory. Note that the value works on
-# a logarithmic scale so increasing the size by one will roughly double the
-# memory usage. The cache size is given by this formula:
-# 2^(16+SYMBOL_CACHE_SIZE). The valid range is 0..9, the default is 0,
-# corresponding to a cache size of 2^16 = 65536 symbols.
-SYMBOL_CACHE_SIZE      = 0
 # Similar to the SYMBOL_CACHE_SIZE the size of the symbol lookup cache can be
 # set using LOOKUP_CACHE_SIZE. This cache is used to resolve symbols given
 # their name and scope. Since this can be an expensive process and often the
@@ -1449,18 +1433,6 @@
 XML_OUTPUT             = xml
-# The XML_SCHEMA tag can be used to specify an XML schema,
-# which can be used by a validating XML parser to check the
-# syntax of the XML files.
-XML_SCHEMA             =
-# The XML_DTD tag can be used to specify an XML DTD,
-XML_DTD                =
 # If the XML_PROGRAMLISTING tag is set to YES Doxygen will
 # dump the program listings (including syntax highlighting
 # and cross-referencing information) to the XML output. Note that
Modified: grass/trunk/include/Make/Doxyfile_arch_latex.in
--- grass/trunk/include/Make/Doxyfile_arch_latex.in	2014-07-02 20:21:05 UTC (rev 61125)
+++ grass/trunk/include/Make/Doxyfile_arch_latex.in	2014-07-02 20:31:18 UTC (rev 61126)
@@ -26,7 +26,7 @@
 # identify the project. Note that if you do not use Doxywizard you need
 # to put quotes around the project name if it contains spaces.
-PROJECT_NAME           = "GRASS GIS 7 Programmer's Manual"
+PROJECT_NAME           = "GRASS GIS @GRASS_VERSION_MAJOR@ Programmer's Manual"
 # The PROJECT_NUMBER tag can be used to enter a project or revision number.
 # This could be handy for archiving the generated documentation or
 XML_OUTPUT             = xml
-XML_SCHEMA             =
-XML_DTD                =
