[GRASS-SVN] r61147 - grass/trunk/lib/python/pygrass/gis
svn_grass at osgeo.org
Thu Jul 3 23:27:14 PDT 2014
Author: zarch
Date: 2014-07-03 23:27:14 -0700 (Thu, 03 Jul 2014)
New Revision: 61147
grass/trunk/lib/python/pygrass/gis/__init__.py
pygrass: Add docs to Gisdbase, Location, Mapset classes and small clean code
Modified: grass/trunk/lib/python/pygrass/gis/__init__.py
--- grass/trunk/lib/python/pygrass/gis/__init__.py 2014-07-04 02:49:13 UTC (rev 61146)
+++ grass/trunk/lib/python/pygrass/gis/__init__.py 2014-07-04 06:27:14 UTC (rev 61147)
@@ -36,6 +36,22 @@
def _check(value, path, type):
+ """Private function to check the correctness of a value.
+ :param value: Name of the directory
+ :type value: str
+ :param path: Path where the directory is located
+ :type path: path
+ :param type: it is a string defining the type that will e checked,
+ valid types are: GISBASE, GISDBASE, LOCATION_NAME, MAPSET
+ :type type: str
+ :return: the value if verify else None and
+ if value is empty return environmental variable
+ :rtype: str
if value and CHECK_IS[type](join(path, value)):
return value
elif value is '':
@@ -47,6 +63,15 @@
def set_current_mapset(mapset, location=None, gisdbase=None):
"""Set the current mapset as working area
+ :param mapset: Name of the mapset
+ :type value: str
+ :param location: Name of the location
+ :type location: str
+ :param gisdbase: Name of the gisdbase
+ :type gisdbase: str
libgis.G_setenv('MAPSET', mapset)
if location:
@@ -56,7 +81,16 @@
def make_mapset(mapset, location=None, gisdbase=None):
- """Create a new mapset"""
+ """Create a new mapset
+ :type value: str
+ :type gisdbase: str"""
res = libgis.G_make_mapset(gisdbase, location, mapset)
if res == -1:
raise GrassError("Cannot create new mapset")
@@ -127,12 +161,8 @@
- locations = []
- for loc in listdir(self.name):
- if libgis.G_is_location(join(self.name, loc)):
- locations.append(loc)
- locations.sort()
- return locations
+ return sorted([loc for loc in listdir(self.name)
+ if libgis.G_is_location(join(self.name, loc))])
class Location(object):
@@ -198,14 +228,15 @@
:type pattern: str
:param permissions: check the permission of mapset
:type permissions: bool
- :returns: a list of mapset's names
+ :return: a list of mapset's names
+ :rtype: list of strings
>>> location = Location()
- >>> location.mapsets()
+ >>> sorted(location.mapsets())
['PERMANENT', 'user1']
mapsets = [mapset for mapset in self]
if permissions:
@@ -216,6 +247,7 @@
return mapsets
def path(self):
+ """Return the complete path of the location"""
return join(self.gisdbase, self.name)
@@ -301,8 +333,8 @@
>>> rast.sort()
>>> rast # doctest: +ELLIPSIS
['basins', 'elevation', ...]
- >>> mapset.glist('rast', pattern='el*')
- ['elevation_shade', 'elevation']
+ >>> sorted(mapset.glist('rast', pattern='el*'))
+ ['elevation', 'elevation_shade']
@@ -338,6 +370,7 @@
shutil.rmtree(self.path())
def path(self):
+ """Return the complete path of the mapset"""
return join(self.gisdbase, self.location, self.name)
