[GRASS-SVN] r61150 - grass/trunk/gui/wxpython/lmgr
svn_grass at osgeo.org
Fri Jul 4 02:49:28 PDT 2014
Author: martinl
Date: 2014-07-04 02:49:27 -0700 (Fri, 04 Jul 2014)
New Revision: 61150
grass/trunk/gui/wxpython/lmgr/datacatalog.py
wxGUI/datacatalog: select current location and expand it when loading tree
Modified: grass/trunk/gui/wxpython/lmgr/datacatalog.py
--- grass/trunk/gui/wxpython/lmgr/datacatalog.py 2014-07-04 09:40:13 UTC (rev 61149)
+++ grass/trunk/gui/wxpython/lmgr/datacatalog.py 2014-07-04 09:49:27 UTC (rev 61150)
@@ -75,6 +75,7 @@
def LoadItemsDone(self):
self._loaded = True
+ self.tree.ExpandCurrent()
class LocationMapTree(wx.TreeCtrl):
def __init__(self, parent):
@@ -257,6 +258,17 @@
stringm = 'MAPSET='+mapset
RunCommand('g.gisenv', set=stringm)
+ def ExpandCurrent(self):
+ """Expand current location"""
+ location = grass.gisenv()['LOCATION_NAME']
+ item = self.getItemByName(location, self.root)
+ if item is not None:
+ self.SelectItem(item)
+ self.ExpandAllChildren(item)
+ self.EnsureVisible(item)
+ else:
+ Debug.msg(1, "Location <%s> not found" % location)
class DataCatalogTree(LocationMapTree):
"""Data Catalog Tree constructor."""
@@ -471,7 +483,7 @@
res = dlg.ShowModal()
dlg.Destroy()
return res
def _popupMenuLayer(self):
"""Create popup menu for layers"""
menu = wx.Menu()
