[GRASS-SVN] r61164 - grass/trunk/lib/python/pygrass/modules/interface/testsuite
svn_grass at osgeo.org
Mon Jul 7 03:24:00 PDT 2014
Author: zarch
Date: 2014-07-07 03:24:00 -0700 (Mon, 07 Jul 2014)
New Revision: 61164
Added:
grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_parameter.py
pygrass: Add test to check Parameter value check
Added: grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_parameter.py
--- grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_parameter.py (rev 0)
+++ grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_parameter.py 2014-07-07 10:24:00 UTC (rev 61164)
@@ -0,0 +1,245 @@
+# -*- coding: utf-8 -*-
+Created on Fri Jul 4 16:32:54 2014
+ at author: pietro
+from __future__ import print_function
+import unittest
+from grass.pygrass.modules.interface.parameter import Parameter, _check_value
+GETTYPE = {
+ 'string': str,
+ 'integer': int,
+ 'float': float,
+ 'double': float,
+ 'file': str,
+ 'all': lambda x: x,
+class TestCheckValueFunction(unittest.TestCase):
+ def test_single_all(self):
+ param = Parameter(diz=dict(name='int_number', required='yes',
+ multiple='no', type='all'))
+ value = 1
+ self.assertTupleEqual((value, value), _check_value(param, value))
+ value = 1.2
+ value = "elev"
+ # test errors
+ with self.assertRaises(TypeError):
+ _check_value(param, (1, 2))
+ def test_single_float_double(self):
+ for ptype in ('float', 'double'):
+ multiple='no', type=ptype))
+ value = 1
+ self.assertTupleEqual((float(value), value), _check_value(param, value))
+ value = 1.2
+ value = "1"
+ value = "1.35"
+ # test errors
+ with self.assertRaises(ValueError):
+ _check_value(param, "elev")
+ _check_value(param, (1., 2.))
+ def test_multiple_float_double(self):
+ param = Parameter(diz=dict(name='number', required='yes',
+ multiple='yes', type=ptype))
+ value = (1.4, 2.3)
+ self.assertTupleEqual((list(value), value),
+ _check_value(param, value))
+ value = (1, 2)
+ self.assertTupleEqual(([float(v) for v in value], value),
+ value = ("1", "2")
+ value = ("1.4", "2.3")
+ # test errors
+ _check_value(param, 1.)
+ _check_value(param, 1)
+ _check_value(param, ("elev", "slope", "aspect"))
+ def test_range_float_double(self):
+ multiple='no', type=ptype,
+ values=["0.0-2.5", ]))
+ value = 1
+ value = 1.2
+ value = "0"
+ value = "2.5"
+ # test errors
+ _check_value(param, -1.)
+ _check_value(param, 2.6)
+ def test_single_integer(self):
+ multiple='no', type='integer'))
+ value = 1
+ value = 1.2
+ self.assertTupleEqual((int(value), value), _check_value(param, value))
+ value = "1"
+ # test errors
+ _check_value(param, "1.")
+ def test_multiple_integer(self):
+ multiple='yes', type='integer'))
+ value = (1, 2)
+ self.assertTupleEqual((list(value), value), _check_value(param, value))
+ value = (1.2, 2.3)
+ self.assertTupleEqual(([int(v) for v in value], value),
+ # test errors
+ _check_value(param, 1.0)
+ def test_range_integer(self):
+ multiple='no', type='integer',
+ values=["0-10", ]))
+ value = 1
+ value = 0
+ value = 10
+ value = 1.2
+ value = "1"
+ # test errors
+ _check_value(param, -1)
+ _check_value(param, 11)
+ def test_choice_integer(self):
+ values=[2, 4, 6, 8]))
+ value = 4
+ value = 2
+ value = "8"
+ # test errors
+ _check_value(param, "2.")
+ #import ipdb; ipdb.set_trace()
+ _check_value(param, 3)
+ def test_single_string_file(self):
+ for ptype in ('string', 'file'):
+ param = Parameter(diz=dict(name='name', required='yes',
+ value = u'elev'
+ # test errors
+ _check_value(param, ('abc', 'def'))
+ def test_multiple_strings(self):
+ param = Parameter(diz=dict(name='rastnames', required='yes',
+ multiple='yes', type='string'))
+ value = ['elev', 'slope', 'aspect']
+ value = ('elev', 'slope', 'aspect')
+ value = ['1.3', '2.3', '4.5']
+ # test errors
+ _check_value(param, (1, 2, 3))
+ def test_choice_string(self):
+ values = ["elev", "asp", "slp"]
+ param = Parameter(diz=dict(name='rastname', required='yes',
+ multiple='no', type='string',
+ values=values))
+ value="asp"
+ # test errors
+ _check_value(param, "2")
+ _check_value(param, "elevation")
+if __name__ == '__main__':
+ unittest.main()
Property changes on: grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_parameter.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
