[GRASS-SVN] r61179 - in grass/trunk/raster/r.gwflow: . testsuite
Mon Jul 7 15:49:16 PDT 2014
Author: huhabla
Date: 2014-07-07 15:49:16 -0700 (Mon, 07 Jul 2014)
New Revision: 61179
Added:
   grass/trunk/raster/r.gwflow/testsuite/
   grass/trunk/raster/r.gwflow/testsuite/validation_7x7_grid.py
   grass/trunk/raster/r.gwflow/testsuite/validation_excavation.py
Removed:
   grass/trunk/raster/r.gwflow/valid_calc_7x7.py
   grass/trunk/raster/r.gwflow/valid_calc_excavation.py
Moved the validation code into the testsuite directory that contains now gunittests
with r.info and r.univar validation of raster results.
Added: grass/trunk/raster/r.gwflow/testsuite/validation_7x7_grid.py
--- grass/trunk/raster/r.gwflow/testsuite/validation_7x7_grid.py	                        (rev 0)
+++ grass/trunk/raster/r.gwflow/testsuite/validation_7x7_grid.py	2014-07-07 22:49:16 UTC (rev 61179)
@@ -0,0 +1,97 @@
+"""Test to verify r.gwflow calculation, this calculation is based on
+the example at page 133 of the following book:
+author = "Kinzelbach, W. and Rausch, R.",
+title = "Grundwassermodellierung",
+publisher = "Gebr{\"u}der Borntraeger (Berlin, Stuttgart)",
+year = "1995"
+ at author Soeren Gebbert
+import grass.script as grass
+import grass.pygrass.modules as pymod
+from gunittest.case import TestCase
+# Output of r.univar
+UNIVAR_OUTPUT="""n=49
+null_cells=0
+cells=49
+min=45.1219899394172
+max=50
+range=4.8780100605828
+mean=49.081632669812
+mean_of_abs=49.081632669812
+stddev=0.908558909200636
+variance=0.825479291487849
+coeff_var=1.85111794326975
+sum=2405.00000082079
+# Output of r.info, only a subset of the output is needed
+INFO_OUTPUT="""north=700
+south=0
+east=700
+west=0
+nsres=100
+ewres=100
+rows=7
+cols=7
+cells=49
+datatype=DCELL
+ncats=0
+max=50
+map=gwresult_conf
+class Validation7x7Grid(TestCase):
+    @classmethod
+    def setUpClass(cls):
+        """!Initiate the temporal GIS and set the region
+        # Use always the current mapset as temporal database
+        grass.use_temp_region()
+        grass.run_command("g.region", res=100, n=700, s=0, w=0, e=700)
+    def setUp(self):
+        """Create input data for transient groundwater flow computation
+        self.assertModule("r.mapcalc", expression="phead=50")
+        self.assertModule("r.mapcalc", expression="status=if(col() == 1 || col() == 7 , 2, 1)")
+        self.assertModule("r.mapcalc", expression="well=if((row() == 4 && col() == 4), -0.1, 0)")
+        self.assertModule("r.mapcalc", expression="hydcond=0.0005")
+        self.assertModule("r.mapcalc", expression="recharge=0")
+        self.assertModule("r.mapcalc", expression="top_conf=20")
+        self.assertModule("r.mapcalc", expression="bottom=0")
+        self.assertModule("r.mapcalc", expression="s=0.0001")
+        self.assertModule("r.mapcalc", expression="null=0.0")
+    def test_transient(self):
+        #First compute the groundwater flow
+        grass.run_command("r.gwflow", "f", solver="cholesky", top="top_conf", bottom="bottom", phead="phead",\
+         status="status", hc_x="hydcond", hc_y="hydcond", q="well", s="s",\
+         recharge="recharge", output="gwresult_conf", dt=500, type="confined", budget="water_budget",  overwrite=True)
+        # loop over the timesteps
+        for i in range(20):
+            grass.run_command("r.gwflow", "f", solver="cholesky", top="top_conf", bottom="bottom", phead="gwresult_conf",\
+        global UNIVAR_OUTPUT
+        self.assertRasterFitsUnivar(raster="gwresult_conf",  reference=UNIVAR_OUTPUT,  precision=3)
+        global INFO_OUTPUT
+        self.assertRasterFitsInfo(raster="gwresult_conf",  reference=INFO_OUTPUT,  precision=3)
+    @classmethod
+    def tearDownClass(cls):
+        """!Remove the temporary region
+        grass.del_temp_region()
+if __name__ == '__main__':
+    from gunittest.main import test
+    test()
Added: grass/trunk/raster/r.gwflow/testsuite/validation_excavation.py
--- grass/trunk/raster/r.gwflow/testsuite/validation_excavation.py	                        (rev 0)
+++ grass/trunk/raster/r.gwflow/testsuite/validation_excavation.py	2014-07-07 22:49:16 UTC (rev 61179)
@@ -0,0 +1,96 @@
+the example at page 167 of the following book:
+year = "1995"
+# Output of r.univar -g
+UNIVAR_OUTPUT="""n=760
+null_cells=0
+cells=760
+min=3
+max=5.39762629189687
+range=2.39762629189687
+mean=5.02846950820457
+mean_of_abs=5.02846950820457
+stddev=0.333565013446849
+variance=0.111265618195797
+coeff_var=6.63352960384062
+sum=3821.63682623547
+# Output of r.info -gre, only a subset of the output is needed
+INFO_OUTPUT="""north=950
+south=0
+east=2000
+west=0
+nsres=50
+ewres=50
+rows=19
+cols=40
+cells=760
+datatype=DCELL
+ncats=0
+min=3
+map=gwresult
+class ValidationExcavation(TestCase):
+    @classmethod
+        grass.run_command("g.region", flags="p",  res=50, n=950, s=0, w=0, e=2000)
+    def setUp(self):
+        """Create input data for steady state groundwater flow computation
+        self.assertModule("r.mapcalc", expression="phead= if(row() == 19, 5, 3)")
+        self.assertModule("r.mapcalc", expression="status=if((col() == 1 && row() == 13) ||\
+                                      (col() == 1 && row() == 14) ||\
+                                      (col() == 2 && row() == 13) ||\
+                                      (col() == 2 && row() == 14) ||\
+                                      (row() == 19), 2, 1)")
+        self.assertModule("r.mapcalc", expression="hydcond=0.001")
+        self.assertModule("r.mapcalc", expression="recharge=0.000000006")
+        self.assertModule("r.mapcalc", expression="top=20")
+        self.assertModule("r.mapcalc", expression="poros=0.1")
+    def test_steady_state(self):
+        #compute a steady state groundwater flow
+        grass.run_command("r.gwflow", flags="f", solver="cholesky", top="top", bottom="bottom", phead="phead", \
+            status="status", hc_x="hydcond", hc_y="hydcond", s="poros", \
+            recharge="recharge", output="gwresult", dt=864000000000, type="unconfined", budget="water_budget")
+        self.assertRasterFitsUnivar(raster="gwresult",  reference=UNIVAR_OUTPUT,  precision=3)
+        self.assertRasterFitsInfo(raster="gwresult",  reference=INFO_OUTPUT,  precision=3)
+    @classmethod
+    test()
Deleted: grass/trunk/raster/r.gwflow/valid_calc_7x7.py
--- grass/trunk/raster/r.gwflow/valid_calc_7x7.py	2014-07-07 22:33:28 UTC (rev 61178)
+++ grass/trunk/raster/r.gwflow/valid_calc_7x7.py	2014-07-07 22:49:16 UTC (rev 61179)
@@ -1,43 +0,0 @@
-#!/usr/bin/env python
-# Python script to verify r.gwflow calculation, this calculation is based on
-# the example at page 133 of the following book:
-#	author = "Kinzelbach, W. and Rausch, R.",
-#	title = "Grundwassermodellierung",
-#	publisher = "Gebr{\"u}der Borntraeger (Berlin, Stuttgart)",
-#	year = "1995"
-import sys
-import os
-import grass.script as grass
-# Overwrite existing maps
-grass.run_command("g.gisenv", set="OVERWRITE=1")
-grass.message(_("Set the region"))
-# The area is 2000m x 1000m with a cell size of 25m x 25m
-grass.run_command("g.region", res=100, n=700, s=0, w=0, e=700)
-grass.run_command("r.mapcalc", expression="phead=50")
-grass.run_command("r.mapcalc", expression="status=if(col() == 1 || col() == 7 , 2, 1)")
-grass.run_command("r.mapcalc", expression="well=if((row() == 4 && col() == 4), -0.1, 0)")
-grass.run_command("r.mapcalc", expression="hydcond=0.0005")
-grass.run_command("r.mapcalc", expression="recharge=0")
-grass.run_command("r.mapcalc", expression="top_conf=20")
-grass.run_command("r.mapcalc", expression="bottom=0")
-grass.run_command("r.mapcalc", expression="s=0.0001")
-grass.run_command("r.mapcalc", expression="null=0.0")
-#First compute the groundwater flow
-grass.run_command("r.gwflow", "f", solver="cholesky", top="top_conf", bottom="bottom", phead="phead",\
- status="status", hc_x="hydcond", hc_y="hydcond", q="well", s="s",\
- recharge="recharge", output="gwresult_conf", dt=500, type="confined", budget="water_budget")
-count=500
-# loop over the timesteps
-for i in range(20):
-    grass.run_command("r.gwflow", "f", solver="cholesky", top="top_conf", bottom="bottom", phead="gwresult_conf",\
-    count += 500
Deleted: grass/trunk/raster/r.gwflow/valid_calc_excavation.py
--- grass/trunk/raster/r.gwflow/valid_calc_excavation.py	2014-07-07 22:33:28 UTC (rev 61178)
+++ grass/trunk/raster/r.gwflow/valid_calc_excavation.py	2014-07-07 22:49:16 UTC (rev 61179)
@@ -1,38 +0,0 @@
-# Shellscript to verify r.gwflow calculation, this calculation is based on
-# the example at page 167 of the following book:
-#	year = "1995"
-import sys
-import os
-grass.run_command("g.region", res=50, n=950, s=0, w=0, e=2000)
-grass.run_command("r.mapcalc", expression="phead= if(row() == 19, 5, 3)")
-grass.run_command("r.mapcalc", expression="status=if((col() == 1 && row() == 13) ||\
-                     (col() == 1 && row() == 14) ||\
-		     (col() == 2 && row() == 13) ||\
-		     (col() == 2 && row() == 14) ||\
-		     (row() == 19), 2, 1)")
-grass.run_command("r.mapcalc", expression="hydcond=0.001")
-grass.run_command("r.mapcalc", expression="recharge=0.000000006")
-grass.run_command("r.mapcalc", expression="top=20")
-grass.run_command("r.mapcalc", expression="poros=0.1")
-#compute a steady state groundwater flow
-grass.run_command("r.gwflow", "f", solver="cholesky", top="top", bottom="bottom", phead="phead", \
- status="status", hc_x="hydcond", hc_y="hydcond", s="poros", \
- recharge="recharge", output="gwresult", dt=864000000000, type="unconfined", budget="water_budget")
