[GRASS-SVN] r61182 - in grass/trunk/lib/python/pygrass/modules/interface: . testsuite
svn_grass at osgeo.org
Tue Jul 8 00:10:51 PDT 2014
Author: zarch
Date: 2014-07-08 00:10:51 -0700 (Tue, 08 Jul 2014)
New Revision: 61182
grass/trunk/lib/python/pygrass/modules/interface/parameter.py
grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_parameter.py
pygrass: modify the parameter check function to be less stringent with strings parameters
Modified: grass/trunk/lib/python/pygrass/modules/interface/parameter.py
--- grass/trunk/lib/python/pygrass/modules/interface/parameter.py 2014-07-08 03:45:45 UTC (rev 61181)
+++ grass/trunk/lib/python/pygrass/modules/interface/parameter.py 2014-07-08 07:10:51 UTC (rev 61182)
@@ -18,7 +18,6 @@
must_val = 'The Parameter <%s>, must be one of the following values: %r'
req = 'The Parameter <%s>, require: %s, get: %s instead: %r\n%s'
- string = (str, unicode)
def raiseexcpet(exc, param, ptype, value):
"""Function to modifa the error message"""
@@ -33,10 +32,14 @@
def check_string(value):
"""Function to check that a string parameter is already a string"""
- if param.type in string and type(value) not in string:
- msg = ("The Parameter <%s> require a string,"
- " %s instead is provided: %r")
- raise ValueError(msg % (param.name, type(value), value))
+ string = (str, unicode)
+ if param.type in string:
+ if type(value) in (int, float):
+ value = str(value)
+ if type(value) not in string:
+ msg = ("The Parameter <%s> require a string,"
+ " %s instead is provided: %r")
+ raise ValueError(msg % (param.name, type(value), value))
return value
# return None if None
Modified: grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_parameter.py
--- grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_parameter.py 2014-07-08 03:45:45 UTC (rev 61181)
+++ grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_parameter.py 2014-07-08 07:10:51 UTC (rev 61182)
@@ -189,7 +189,6 @@
_check_value(param, "elev")
with self.assertRaises(TypeError):
_check_value(param, (1, 2))
- #import ipdb; ipdb.set_trace()
with self.assertRaises(ValueError):
_check_value(param, 3)
@@ -199,12 +198,14 @@
multiple='no', type=ptype))
value = u'elev'
self.assertTupleEqual((value, value), _check_value(param, value))
+ value = 10
+ self.assertTupleEqual((str(value), value),
+ _check_value(param, value))
+ value = 12.5
# test errors
- with self.assertRaises(ValueError):
- _check_value(param, 1)
- _check_value(param, 1.0)
_check_value(param, ('abc', 'def'))
@@ -217,10 +218,16 @@
self.assertTupleEqual((list(value), value), _check_value(param, value))
value = ['1.3', '2.3', '4.5']
+ value = [1.3, 2.3, 4.5]
+ self.assertTupleEqual(([str(v) for v in value], value),
+ value = (1, 2, 3)
# test errors
- _check_value(param, (1, 2, 3))
+ _check_value(param, ({}, {}, {}))
def test_choice_string(self):
values = ["elev", "asp", "slp"]
