[GRASS-SVN] r61184 - sandbox/krejcmat/src
svn_grass at osgeo.org
Tue Jul 8 03:28:23 PDT 2014
Author: krejcmat
Date: 2014-07-08 03:28:23 -0700 (Tue, 08 Jul 2014)
New Revision: 61184
sandbox/krejcmat/src/editor2.py
sandbox/krejcmat/src/jinjainfo.py
change storage of md values
Modified: sandbox/krejcmat/src/editor2.py
--- sandbox/krejcmat/src/editor2.py 2014-07-08 08:24:08 UTC (rev 61183)
+++ sandbox/krejcmat/src/editor2.py 2014-07-08 10:28:23 UTC (rev 61184)
@@ -150,32 +150,19 @@
#register tag to created wx.id
+ #get wxpython id
self.currWXid= self.valueCtrl.GetId()
- val=self.mdDescription[self.cTmp].value
- mdVal=MdDescription()
+ #get current value
+ val=self.mdDescription[self.cTmp].getValue()
+ #set value to ctrl text
self.valueCtrl.SetValue(str(val))
- self.valueStorageWxID[self.currWXid]=val
+ #add id to object
+ self.mdDescription[self.cTmp].addId(self.currWXid)
+ self.valueStorageWxID[self.currWXid]=self.mdDescription[self.cTmp]
- try:
- mdVal=self.mdDescription[self.c]
- except:
- # print mdVal
- mdVal.value=str(val)
- mdVal.id=str(self.currWXid)
- self.mdDescriptionList.append(mdVal)
- # print '='*50
- # print self.currWXid
- # print val
- # print mdVal.value
- # print '='*50
if multiple:
self.addItemButt=wx.Button(self.place,-1,size=(20,20),label='+')
#self.addInfoButt=wx.Button(self,-1,size=(20,20),label='I')
@@ -259,7 +246,8 @@
# self.addItem(item)
+ def saveEditor(self):
#------------------------------------------------------------- MAIN PANEL LAYOUT
def _layout(self):
@@ -298,7 +286,9 @@
markgroup markers of created list in GUI notebook
self.max length of lstruct and linfo
self.stop index self.c is increasing by function plusC(), that care about not exceeding the index
self.addNotebook()
markgroup=[] #notebok panel marker
lstruct=self.mdOWSTagStrList
@@ -307,7 +297,7 @@
self.c=0 #this valus is the index of self.mdOWSTagStrList and also in self.mdDescription
self.stop=False
self.max=len(linfo)
def chckLen():
@note: -length of list in jinja template is provided by |length.
@@ -336,8 +326,8 @@
if not 'for' in str(lstruct[self.c]).split() or 'if' in str(lstruct[self.c]).split():
value= str(self.mdOWSTagStrList[self.c])
#print value
- str1+= '\t' +'self.mdDescription['+str(self.c)+'].value='+str(value)+'\n'
- str1+= '\t' +'self.cTmp='+str(self.c)+'\n' #save wx id
+ str1+= '\t' +'self.mdDescription['+str(self.c)+'].addValue('+str(value)+')\n'
+ str1+= '\t' +'self.cTmp='+str(self.c)+'\n' #save -*+9wx id
str1+= '\t' +'self.addItem(linfo[' + str(self.c) + '], True)\n'
tab='\t'
else:#if loop in loop
@@ -348,17 +338,18 @@
while '\t\t' in lstruct[self.c] and self.stop is False:
- str1+= '\t\t' +'self.mdDescription['+str(self.c)+'].value='+str(value)+'\n'
+ str1+= '\t\t' +'self.mdDescription['+str(self.c)+'].addValue('+str(value)+')\n'
str1+= '\t\t' +'self.cTmp='+str(self.c)+'\n' #save wx id
str1+= '\t\t' +'self.addItem(linfo[' + str(self.c) + '], True)\n'
tab='\t\t'
self.plusC()
self.plusC()
##print '--'*80
self.c-=1
str1+= tab+'self.c+=1\n'
self.executeStr(str1,linfo)
@@ -371,14 +362,13 @@
markgroup.append(group) #mark group
self.addNotebookPage(linfo[self.c].group) #crate notebog page in gui
+ val=[]
if '\t' in lstruct[self.c]and self.stop is False: #if starting the loop
- inBox2()
+ inBox2()
chckLen()
elif not 'for' in str(lstruct[self.c]).split() or 'if' in str(lstruct[self.c]).split(): # if just singe item without loop
value= 'self.'+str(self.mdOWSTagStrList[self.c]).replace('\n','')
- addStr='self.mdDescription['+str(self.c)+'].value='+str(value)
+ addStr='self.mdDescription['+str(self.c)+'].addValue('+str(value)+')'
##print '--'*80
##print addStr
self.executeStr(addStr,False)
@@ -391,7 +381,7 @@
self.plusC()
#print str(lstruct[self.c])
# print '========================================'
# for keys,values in self.valueStorageWxID.items():
Modified: sandbox/krejcmat/src/jinjainfo.py
--- sandbox/krejcmat/src/jinjainfo.py 2014-07-08 08:24:08 UTC (rev 61183)
+++ sandbox/krejcmat/src/jinjainfo.py 2014-07-08 10:28:23 UTC (rev 61184)
@@ -20,7 +20,7 @@
from jinja2 import Environment, FileSystemLoader
class MdDescription():
- def __init__(self,tag= None, name = None, desc = None, example = None, type = None, multi = 0, inboxmulti=None, group = None, inbox = None, multiline = None, value=None,id=None,num=None ):
+ def __init__(self,tag= None, name = None, desc = None, example = None, type = None, multi = 0, inboxmulti=None, group = None, inbox = None, multiline = None, value=[],id=[],num=None ):
self.tag=tag
self.name = name
@@ -36,6 +36,29 @@
self.value=value
self.id=id
+ self.valueIndex=-1
+ self.idIndex=-1
+ def addValue(self,value):
+ #print value
+ self.value.append(value)
+ self.valueIndex+=1
+ #print self.valueIndex
+ def addId(self,id):
+ self.id.append(id)
+ self.idIndex+=1
+ def getId(self):
+ self.idIndex-=1
+ return self.id[self.idIndex]
+ def getValue(self):
+ self.valueIndex-=1
+ return self.value[self.valueIndex]
class JinjaTemplateInfo():
def __init__(self,template):
@@ -47,7 +70,6 @@
self.mdOWSTagStrList=[]
#self.mdDescriptionStr=''
self._readJinjaInfo()
self._readJinjaTags()
self._domdOWSTagStr()
