[GRASS-SVN] r61186 - grass/trunk/raster/r.gwflow/testsuite
Tue Jul 8 03:58:50 PDT 2014
Author: huhabla
Date: 2014-07-08 03:58:50 -0700 (Tue, 08 Jul 2014)
New Revision: 61186
   grass/trunk/raster/r.gwflow/testsuite/validation_7x7_grid.py
   grass/trunk/raster/r.gwflow/testsuite/validation_excavation.py
Test update to use the latest improvements in PyGRASS
Modified: grass/trunk/raster/r.gwflow/testsuite/validation_7x7_grid.py
--- grass/trunk/raster/r.gwflow/testsuite/validation_7x7_grid.py	2014-07-08 10:29:48 UTC (rev 61185)
+++ grass/trunk/raster/r.gwflow/testsuite/validation_7x7_grid.py	2014-07-08 10:58:50 UTC (rev 61186)
@@ -7,56 +7,21 @@
 @author Soeren Gebbert
 import grass.script as grass
-import grass.pygrass.modules as pymod
 from gunittest.case import TestCase
-# Output of r.univar
-UNIVAR_OUTPUT="""n=49
-null_cells=0
-cells=49
-min=45.1219899394172
-max=50
-range=4.8780100605828
-mean=49.081632669812
-mean_of_abs=49.081632669812
-stddev=0.908558909200636
-variance=0.825479291487849
-coeff_var=1.85111794326975
-sum=2405.00000082079
-# Output of r.info, only a subset of the output is needed
-INFO_OUTPUT="""north=700
-south=0
-east=700
-west=0
-nsres=100
-ewres=100
-rows=7
-cols=7
-cells=49
-datatype=DCELL
-ncats=0
-max=50
-map=gwresult_conf
 class Validation7x7Grid(TestCase):
     @classmethod
     def setUpClass(cls):
-        """!Initiate the temporal GIS and set the region
-        # Use always the current mapset as temporal database
+        """Use temporary region settings"""
         grass.use_temp_region()
-        grass.run_command("g.region", res=100, n=700, s=0, w=0, e=700)
     def setUp(self):
-        """Create input data for transient groundwater flow computation
+        """Set region and create input data for transient groundwater flow computation
+        self.assertModule("g.region", res=100, n=700, s=0, w=0, e=700)
         self.assertModule("r.mapcalc", expression="phead=50")
         self.assertModule("r.mapcalc", expression="status=if(col() == 1 || col() == 7 , 2, 1)")
         self.assertModule("r.mapcalc", expression="well=if((row() == 4 && col() == 4), -0.1, 0)")
@@ -69,20 +34,48 @@
     def test_transient(self):
         #First compute the groundwater flow
-        grass.run_command("r.gwflow", "f", solver="cholesky", top="top_conf", bottom="bottom", phead="phead",\
+        self.assertModule("r.gwflow", flags="f", solver="cholesky", top="top_conf", bottom="bottom", phead="phead",\
          status="status", hc_x="hydcond", hc_y="hydcond", q="well", s="s",\
          recharge="recharge", output="gwresult_conf", dt=500, type="confined", budget="water_budget",  overwrite=True)
         # loop over the timesteps
         for i in range(20):
-            grass.run_command("r.gwflow", "f", solver="cholesky", top="top_conf", bottom="bottom", phead="gwresult_conf",\
+            self.assertModule("r.gwflow",  flags="f", solver="cholesky", top="top_conf", bottom="bottom", phead="gwresult_conf",\
+        # Output of r.univar
+        univar_string="""n=49
+        null_cells=0
+        cells=49
+        min=45.1219899394172
+        max=50
+        range=4.8780100605828
+        mean=49.081632669812
+        mean_of_abs=49.081632669812
+        stddev=0.908558909200636
+        variance=0.825479291487849
+        coeff_var=1.85111794326975
+        sum=2405.00000082079"""
-        global UNIVAR_OUTPUT
-        self.assertRasterFitsUnivar(raster="gwresult_conf",  reference=UNIVAR_OUTPUT,  precision=3)
-        global INFO_OUTPUT
-        self.assertRasterFitsInfo(raster="gwresult_conf",  reference=INFO_OUTPUT,  precision=3)
+        # Output of r.info, only a subset of the output is needed
+        info_string="""north=700
+        south=0
+        east=700
+        west=0
+        nsres=100
+        ewres=100
+        rows=7
+        cols=7
+        cells=49
+        datatype=DCELL
+        ncats=0
+        max=50
+        map=gwresult_conf"""
+        self.assertRasterFitsUnivar(raster="gwresult_conf",  reference=univar_string,  precision=3)
+        self.assertRasterFitsInfo(raster="gwresult_conf",  reference=info_string,  precision=3)
     @classmethod
     def tearDownClass(cls):
Modified: grass/trunk/raster/r.gwflow/testsuite/validation_excavation.py
--- grass/trunk/raster/r.gwflow/testsuite/validation_excavation.py	2014-07-08 10:29:48 UTC (rev 61185)
+++ grass/trunk/raster/r.gwflow/testsuite/validation_excavation.py	2014-07-08 10:58:50 UTC (rev 61186)
@@ -9,55 +9,21 @@
-# Output of r.univar -g
-UNIVAR_OUTPUT="""n=760
-null_cells=0
-cells=760
-min=3
-max=5.39762629189687
-range=2.39762629189687
-mean=5.02846950820457
-mean_of_abs=5.02846950820457
-stddev=0.333565013446849
-variance=0.111265618195797
-coeff_var=6.63352960384062
-sum=3821.63682623547
-# Output of r.info -gre, only a subset of the output is needed
-INFO_OUTPUT="""north=950
-south=0
-east=2000
-west=0
-nsres=50
-ewres=50
-rows=19
-cols=40
-cells=760
-datatype=DCELL
-ncats=0
-min=3
-map=gwresult
 class ValidationExcavation(TestCase):
     @classmethod
-        grass.run_command("g.region", flags="p",  res=50, n=950, s=0, w=0, e=2000)
     def setUp(self):
-        """Create input data for steady state groundwater flow computation
+        """Set region and create input data for steady state groundwater flow computation
+        self.assertModule("g.region", flags="p",  res=50, n=950, s=0, w=0, e=2000)
         self.assertModule("r.mapcalc", expression="phead= if(row() == 19, 5, 3)")
         self.assertModule("r.mapcalc", expression="status=if((col() == 1 && row() == 13) ||\
                                       (col() == 1 && row() == 14) ||\
@@ -74,15 +40,43 @@
     def test_steady_state(self):
         #compute a steady state groundwater flow
-        grass.run_command("r.gwflow", flags="f", solver="cholesky", top="top", bottom="bottom", phead="phead", \
+        self.assertModule("r.gwflow", flags="f", solver="cholesky", top="top", bottom="bottom", phead="phead", \
             status="status", hc_x="hydcond", hc_y="hydcond", s="poros", \
             recharge="recharge", output="gwresult", dt=864000000000, type="unconfined", budget="water_budget")
-        self.assertRasterFitsUnivar(raster="gwresult",  reference=UNIVAR_OUTPUT,  precision=3)
-        self.assertRasterFitsInfo(raster="gwresult",  reference=INFO_OUTPUT,  precision=3)
+        # Output of r.univar -g
+        univar_string="""n=760
+        null_cells=0
+        cells=760
+        min=3
+        max=5.39762629189687
+        range=2.39762629189687
+        mean=5.02846950820457
+        mean_of_abs=5.02846950820457
+        stddev=0.333565013446849
+        variance=0.111265618195797
+        coeff_var=6.63352960384062
+        sum=3821.63682623547"""
+        # Output of r.info -gre, only a subset of the output is needed
+        info_string="""north=950
+        south=0
+        east=2000
+        west=0
+        nsres=50
+        ewres=50
+        rows=19
+        cols=40
+        cells=760
+        datatype=DCELL
+        ncats=0
+        min=3
+        map=gwresult"""
+        self.assertRasterFitsUnivar(raster="gwresult",  reference=univar_string,  precision=3)
+        self.assertRasterFitsInfo(raster="gwresult",  reference=info_string,  precision=3)
     @classmethod
         """!Remove the temporary region
