[GRASS-SVN] r61188 - grass/trunk/raster/r.stream.distance
svn_grass at osgeo.org
Tue Jul 8 06:00:09 PDT 2014
Author: hcho
Date: 2014-07-08 06:00:09 -0700 (Tue, 08 Jul 2014)
New Revision: 61188
grass/trunk/raster/r.stream.distance/r.stream.distance.html
r.stream.distance: Fix typos in the manual
Modified: grass/trunk/raster/r.stream.distance/r.stream.distance.html
--- grass/trunk/raster/r.stream.distance/r.stream.distance.html 2014-07-08 12:09:32 UTC (rev 61187)
+++ grass/trunk/raster/r.stream.distance/r.stream.distance.html 2014-07-08 13:00:09 UTC (rev 61188)
@@ -84,11 +84,11 @@
<b>upstream</b> from any cell upstream to the nearest maximum or divide.</dd>
<dt><b>difference</b></dt>
-<dd>Name of output map of elevation difference to the targer (outlet, node,
+<dd>Name of output map of elevation difference to the target (outlet, node,
stream, divide, maximum) along watercoures. The map is of FCELL type.</dd>
<dt><b>distance</b></dt>
-<dd>Name of output map of distance to the targer (outlet, node, stream,
+<dd>Name of output map of distance to the target (outlet, node, stream,
</dl>
