[GRASS-SVN] r61193 - grass/trunk/raster/r.gwflow/testsuite
Tue Jul 8 07:42:49 PDT 2014
Author: huhabla
Date: 2014-07-08 07:42:49 -0700 (Tue, 08 Jul 2014)
New Revision: 61193
   grass/trunk/raster/r.gwflow/testsuite/validation_7x7_grid.py
   grass/trunk/raster/r.gwflow/testsuite/validation_excavation.py
Cite from Vaclav: it is a good idea to write tear down just after set up
Modified: grass/trunk/raster/r.gwflow/testsuite/validation_7x7_grid.py
--- grass/trunk/raster/r.gwflow/testsuite/validation_7x7_grid.py	2014-07-08 14:39:31 UTC (rev 61192)
+++ grass/trunk/raster/r.gwflow/testsuite/validation_7x7_grid.py	2014-07-08 14:42:49 UTC (rev 61193)
@@ -18,6 +18,12 @@
         grass.use_temp_region()
         cls.runModule("g.region", res=100, n=700, s=0, w=0, e=700)
+    @classmethod
+    def tearDownClass(cls):
+        """!Remove the temporary region
+        grass.del_temp_region()
     def setUp(self):
         """Set region and create input data for transient groundwater flow computation
@@ -76,11 +82,6 @@
         self.assertRasterFitsUnivar(raster="gwresult_conf",  reference=univar_string,  precision=3)
         self.assertRasterFitsInfo(raster="gwresult_conf",  reference=info_string,  precision=3)
-    @classmethod
-    def tearDownClass(cls):
-        """!Remove the temporary region
-        grass.del_temp_region()
 if __name__ == '__main__':
     from gunittest.main import test
Modified: grass/trunk/raster/r.gwflow/testsuite/validation_excavation.py
--- grass/trunk/raster/r.gwflow/testsuite/validation_excavation.py	2014-07-08 14:39:31 UTC (rev 61192)
+++ grass/trunk/raster/r.gwflow/testsuite/validation_excavation.py	2014-07-08 14:42:49 UTC (rev 61193)
@@ -19,6 +19,12 @@
         cls.runModule("g.region", flags="p",  res=50, n=950, s=0, w=0, e=2000)
+    @classmethod
     def setUp(self):
         """Set region and create input data for steady state groundwater flow computation
@@ -75,12 +81,6 @@
         self.assertRasterFitsUnivar(raster="gwresult",  reference=univar_string,  precision=3)
         self.assertRasterFitsInfo(raster="gwresult",  reference=info_string,  precision=3)
-    @classmethod
     test()
