[GRASS-SVN] r61195 - in sandbox/wenzeslaus/gunittest: . testsuite
svn_grass at osgeo.org
Tue Jul 8 07:59:49 PDT 2014
Author: wenzeslaus
Date: 2014-07-08 07:59:49 -0700 (Tue, 08 Jul 2014)
New Revision: 61195
sandbox/wenzeslaus/gunittest/case.py
sandbox/wenzeslaus/gunittest/testsuite/test_assertions.py
gunittest: set and use temporary region as class methods; ignore empty lines in key-value text
Modified: sandbox/wenzeslaus/gunittest/case.py
--- sandbox/wenzeslaus/gunittest/case.py 2014-07-08 14:49:12 UTC (rev 61194)
+++ sandbox/wenzeslaus/gunittest/case.py 2014-07-08 14:59:49 UTC (rev 61195)
@@ -35,10 +35,10 @@
the firt two, it is recommened to use keyword arguments but not required.
longMessage = True # to get both standard and custom message
+ _temp_region = None # to control the temporary region
def __init__(self, methodName):
super(TestCase, self).__init__(methodName)
- self._temp_region = None
def _formatMessage(self, msg, standardMsg):
"""Honour the longMessage attribute when generating failure messages.
@@ -66,39 +66,49 @@
except UnicodeDecodeError:
return '%s \n%s' % (safe_repr(msg), safe_repr(standardMsg))
- def use_temp_region(self):
+ @classmethod
+ def use_temp_region(cls):
"""Use temporary region instead of the standard one for this process.
- If you use this method, you have to call it in `setUp()` and call
- `del_temp_region()` in `tearDown()`. By this you ensure that each test
- method will have its own region and will not influece others.
+ If you use this method, you have to call it in `setUpClass()`
+ and call `del_temp_region()` in `tearDownClass()`. By this you
+ ensure that each test method will have its own region and will
+ not influece other classes.
- def setUp(self):
+ @classmethod
+ def setUpClass(self):
self.use_temp_region()
- def tearDown(self):
+ @classmethod
+ def tearDownClass(self):
self.del_temp_region()
+ You can also call the methods in `setUp()` and `tearDown()` if
+ you are using them.
Copies the current region to a temporary region with
``g.region save=``, then sets ``WIND_OVERRIDE`` to refer
to that region.
- # this should be unique for each object because method name is used
- name = "tmp.%s" % (self.id())
+ # we use just the class name since we rely on the invokation system
+ # where each test file is separate process and nothing runs
+ # in parallel inside
+ name = "tmp.%s" % (cls.__name__)
call_module("g.region", save=name, overwrite=True)
os.environ['WIND_OVERRIDE'] = name
- self._temp_region = name
+ cls._temp_region = name
- def del_temp_region(self):
+ @classmethod
+ def del_temp_region(cls):
"""Remove the temporary region.
Unsets WIND_OVERRIDE and removes any region named by it.
- assert self._temp_region
+ assert cls._temp_region
name = os.environ.pop('WIND_OVERRIDE')
- if name != self._temp_region:
+ if name != cls._temp_region:
# be strict about usage of region
raise RuntimeError("Inconsistent use of"
" TestCase.use_temp_region, WIND_OVERRIDE"
@@ -107,12 +117,12 @@
" by TestCase class"
"does not corresond to currently set"
" WIND_OVERRIDE ({c})",
- n=self._temp_region, c=name)
+ n=cls._temp_region, c=name)
call_module("g.remove", quiet=True, region=name)
# TODO: we don't know if user calls this
# so perhaps some decorator which would use with statemet
- # but we have zero chance of infuencing another test
- # since we use method-specific name for region
+ # but we have zero chance of infuencing another test class
+ # since we use class-specific name for temporary region
def assertLooksLike(self, actual, reference, msg=None):
"""Test that ``actual`` text is the same as ``referece`` with ellipses.
@@ -137,9 +147,9 @@
def assertCommandKeyValue(self, module, parameters, reference, sep,
precision=None, msg=None):
if isinstance(reference, basestring):
- reference = text_to_keyvalue(reference, sep=sep)
+ reference = text_to_keyvalue(reference, sep=sep, skip_empty=True)
stdout = call_module(module, **parameters)
- raster_univar = text_to_keyvalue(stdout, sep=sep)
+ raster_univar = text_to_keyvalue(stdout, sep=sep, skip_empty=True)
if not compare_keyvalue(dict_a=reference, dict_b=raster_univar,
a_is_subset=True, precision=precision):
unused, missing, mismatch = diff_keyvalue(dict_a=reference,
@@ -241,6 +251,7 @@
# TODO: use precision?
+ # TODO: write a test for this method with r.in.ascii
def assertRasterMinMax(self, map, refmin, refmax, msg=None):
"""Test that raster map minimum and maximum are within limits.
Modified: sandbox/wenzeslaus/gunittest/testsuite/test_assertions.py
--- sandbox/wenzeslaus/gunittest/testsuite/test_assertions.py 2014-07-08 14:49:12 UTC (rev 61194)
+++ sandbox/wenzeslaus/gunittest/testsuite/test_assertions.py 2014-07-08 14:59:49 UTC (rev 61195)
@@ -86,13 +86,15 @@
class TestRasterMapAssertations(gunittest.TestCase):
# pylint: disable=R0904
- def setUp(self):
- self.use_temp_region()
+ @classmethod
+ def setUpClass(cls):
+ cls.use_temp_region()
# TODO: here we should actually not call self.runModule but call_module
- self.runModule(Module('g.region', rast='elevation', run_=False))
+ cls.runModule(Module('g.region', rast='elevation', run_=False))
- self.del_temp_region()
+ @classmethod
+ def tearDownClass(cls):
+ cls.del_temp_region()
def test_assertRasterFitsUnivar(self):
self.assertRasterFitsUnivar('elevation', R_UNIVAR_ELEVATION_SUBSET,
