[GRASS-SVN] r61200 - in sandbox/wenzeslaus/gunittest: . testsuite
svn_grass at osgeo.org
Tue Jul 8 14:33:46 PDT 2014
Author: wenzeslaus
Date: 2014-07-08 14:33:46 -0700 (Tue, 08 Jul 2014)
New Revision: 61200
sandbox/wenzeslaus/gunittest/case.py
sandbox/wenzeslaus/gunittest/gmodules.py
sandbox/wenzeslaus/gunittest/testsuite/test_doctests.py
sandbox/wenzeslaus/gunittest/testsuite/test_gmodules.py
gunittest: add class for convenient PyGRASS module creation (right parameters set), remove run module functions covered by call_module
Modified: sandbox/wenzeslaus/gunittest/case.py
--- sandbox/wenzeslaus/gunittest/case.py 2014-07-08 19:16:04 UTC (rev 61199)
+++ sandbox/wenzeslaus/gunittest/case.py 2014-07-08 21:33:46 UTC (rev 61200)
@@ -18,8 +18,9 @@
from unittest.util import safe_repr
from grass.pygrass.modules import Module
+from grass.exceptions import CalledModuleError
-from .gmodules import call_module, CalledModuleError
+from .gmodules import call_module
from .checkers import (check_text_ellipsis,
text_to_keyvalue, compare_keyvalue, diff_keyvalue,
file_md5, files_equal_md5)
@@ -35,6 +36,7 @@
the firt two, it is recommened to use keyword arguments but not required.
longMessage = True # to get both standard and custom message
+ maxDiff = None # we can afford long diffs
_temp_region = None # to control the temporary region
def __init__(self, methodName):
Modified: sandbox/wenzeslaus/gunittest/gmodules.py
--- sandbox/wenzeslaus/gunittest/gmodules.py 2014-07-08 19:16:04 UTC (rev 61199)
+++ sandbox/wenzeslaus/gunittest/gmodules.py 2014-07-08 21:33:46 UTC (rev 61200)
@@ -1,86 +1,62 @@
# -*- coding: utf-8 -*-
+"""!@package grass.gunittest.case
+ at brief GRASS Python testing framework specialized GRASS module interfaces
+(C) 2014 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Vaclav Petras
+ at author Soeren Gebbert
import subprocess
from grass.script.core import start_command
+from grass.pygrass.modules import Module
from .utils import do_doctest_gettext_workaround
-class CalledModuleError(subprocess.CalledProcessError):
- def __init__(self, returncode, module, kwargs, errors=None):
- # expecting module name to be args[0]
- super(CalledModuleError, self).__init__(returncode, module)
- # TODO: this must be somewhere when doctest is called, not here
- # TODO: ultimate solution is not to use _ as a buildin in lib/python
- # for now it is the only place where it works
- do_doctest_gettext_workaround()
- # TODO: format parameters
- # TODO: ignore std* params
- msg = _("Module run %s %s ended with error") % (module, kwargs)
- msg += _("\nProcess ended with non-zero return code %s") % returncode
- if errors:
- msg += _(". See the following errors:\n%s") % errors
- else:
- msg += _(". See errors in the (error) output.")
- self.msg = msg
- # TODO: handle other parameters
+class SimpleModule(Module):
+ """Simple wrapper around pygrass.modules.Module to make sure that
+ run_, finish_, stdout and stderr are set correctly.
- def __str__(self):
- return self.msg
+ >>> mapcalc = SimpleModule('r.mapcalc', expression='test_a = 1',
+ ... overwrite=True)
+ >>> mapcalc.run()
+ Module('r.mapcalc')
+ >>> mapcalc.popen.returncode
+ 0
-def run_module(module, **kwargs):
- """Run module with parameters given in `kwargs`.
- :param str module: module name
- :param kwargs: module parameters
- :raises CalledModuleError: if module return code is non-zero
+ >>> colors = SimpleModule('r.colors',
+ ... map='test_a', rules='-', stdin_='1 red')
+ >>> colors.run()
+ Module('r.colors')
+ >>> colors.popen.returncode
+ 0
+ >>> str(colors.inputs.stdin)
+ '1 red'
+ >>> str(colors.outputs.stdout)
+ >>> colors.outputs.stderr.strip()
+ "Color table for raster map <test_a> set to 'rules'"
- process = start_command(module, **kwargs)
- returncode = process.wait()
- if returncode:
- raise CalledModuleError(returncode, module, kwargs)
+ def __init__(self, cmd, *args, **kargs):
+ for banned in ['stdout_', 'stderr_', 'finish_', 'run_']:
+ if banned in kargs:
+ raise ValueError('Do not set %s parameter'
+ ', it would be overriden' % banned)
+ kargs['stdout_'] = subprocess.PIPE
+ kargs['stderr_'] = subprocess.PIPE
+ kargs['finish_'] = True
+ kargs['run_'] = False
+ Module.__init__(self, cmd, *args, **kargs)
-def read_module(module, **kwargs):
- """Run module with parameters given in `kwargs` and return its output.
- if 'stdout' in kwargs:
- raise TypeError('stdout argument not allowed, it would be overridden.')
- kwargs['stdout'] = subprocess.PIPE
- output = process.communicate()[0]
- returncode = process.poll()
- if returncode:
- return output
-def write_module(module, stdin, **kwargs):
- """Run module with given parameters and feed module standard input.
- :param stdin: string to be used as module standard input (stdin)
- if not stdin:
- raise ValueError('stdin argument is required.')
- kwargs['stdin'] = subprocess.PIPE # to be able to send data to stdin
- process.communicate(stdin)
- if returncode:
def call_module(module, stdin=None,
merge_stderr=False, capture_stdout=True, capture_stderr=True,
**kwargs):
Modified: sandbox/wenzeslaus/gunittest/testsuite/test_doctests.py
--- sandbox/wenzeslaus/gunittest/testsuite/test_doctests.py 2014-07-08 19:16:04 UTC (rev 61199)
+++ sandbox/wenzeslaus/gunittest/testsuite/test_doctests.py 2014-07-08 21:33:46 UTC (rev 61200)
@@ -6,6 +6,7 @@
import doctest
import gunittest
+import gunittest.utils
# doctest does not allow changing the base classes of test case, skip test case
@@ -22,6 +23,10 @@
def load_tests(loader, tests, ignore):
+ # TODO: this must be somewhere when doctest is called, not here
+ # TODO: ultimate solution is not to use _ as a buildin in lib/python
+ # for now it is the only place where it works
+ gunittest.utils.do_doctest_gettext_workaround()
# this should be called at some top level
tests.addTests(doctest.DocTestSuite(gunittest.gmodules))
tests.addTests(doctest.DocTestSuite(gunittest.checkers))
Modified: sandbox/wenzeslaus/gunittest/testsuite/test_gmodules.py
--- sandbox/wenzeslaus/gunittest/testsuite/test_gmodules.py 2014-07-08 19:16:04 UTC (rev 61199)
+++ sandbox/wenzeslaus/gunittest/testsuite/test_gmodules.py 2014-07-08 21:33:46 UTC (rev 61200)
@@ -3,8 +3,7 @@
import subprocess
import gunittest
-from gunittest.gmodules import (call_module, CalledModuleError,
- run_module, read_module, write_module)
+from gunittest.gmodules import (call_module, CalledModuleError)
G_REGION_OUTPUT = """n=...
s=...
@@ -89,35 +88,5 @@
stderr='any_value_or_type_here')
-class ModuleFunctionsTest(gunittest.TestCase):
- def test_run_module_raise(self):
- self.assertRaises(CalledModuleError,
- run_module,
- 'r.univar', aaabbbcc='notexist')
- def test_read_module_return(self):
- self.assertTrue(read_module('r.info', map='elevation'))
- def test_read_module_raise(self):
- read_module,
- def test_write_module_missing_stdin(self):
- self.assertRaises(TypeError,
- write_module,
- 'm.proj', aaabbbcc='notexist')
- def test_write_module_return(self):
- self.assertIsNone(write_module('m.proj', input='-', stdin='50,50',
- flags='o'))
- def test_write_module_raise(self):
- write_module,
- 'm.proj', stdin='50,50', aaabbbcc='notexist')
if __name__ == '__main__':
gunittest.test()
