[GRASS-SVN] r61202 - in grass/trunk/general: g.list/testsuite g.mlist/testsuite g.mremove/testsuite
svn_grass at osgeo.org
Tue Jul 8 14:37:37 PDT 2014
Author: wenzeslaus
Date: 2014-07-08 14:37:37 -0700 (Tue, 08 Jul 2014)
New Revision: 61202
grass/trunk/general/g.list/testsuite/test_g_list.py
grass/trunk/general/g.mlist/testsuite/test_g_mlist.py
grass/trunk/general/g.mremove/testsuite/test_g_mremove.py
testing: rewrite tests to use gunittest (foreing mapset not expected on the path and not added)
Modified: grass/trunk/general/g.list/testsuite/test_g_list.py
--- grass/trunk/general/g.list/testsuite/test_g_list.py 2014-07-08 21:34:46 UTC (rev 61201)
+++ grass/trunk/general/g.list/testsuite/test_g_list.py 2014-07-08 21:37:37 UTC (rev 61202)
@@ -1,5 +1,5 @@
-import unittest
+import gunittest
from grass.script import read_command
LIST_RASTERS = """----------------------------------------------
@@ -20,11 +20,6 @@
elev_state_500m lsat7_2002_61 zipcodes_dbl
elevation lsat7_2002_62
-raster files available in mapset <landsat>:
-lsat5_1987_10 lsat5_1987_40 lsat5_1987_70 lsat7_2000_30 lsat7_2000_61
-lsat5_1987_20 lsat5_1987_50 lsat7_2000_10 lsat7_2000_40 lsat7_2000_70
-lsat5_1987_30 lsat5_1987_60 lsat7_2000_20 lsat7_2000_50 lsat7_2000_80
LIST_VECTORS = """----------------------------------------------
@@ -47,12 +42,9 @@
censusblk_swwake nc_state
comm_colleges overpasses
LIST_GROUPS = """----------------------------------------------
imagery group files available in mapset <landsat>:
lsat7_2000
@@ -111,23 +103,6 @@
zipcodes South West Wake: Zipcode areas derived from vector map
zipcodes_dbl South West Wake: Zipcode areas from vector map, fp
-lsat5_1987_10 LANDSAT-TM5 Band 1 Visible (0.45-0.52um) 30m
-lsat5_1987_20 LANDSAT-TM5 Band 2 Visible (0.52-0.60um) 30m
-lsat5_1987_30 LANDSAT-TM5 Band 3 Visible (0.63-0.69um) 30m
-lsat5_1987_40 LANDSAT-TM5 Band 4 Near Infrared (NIR) (0.76-0.90um) 30m
-lsat5_1987_50 LANDSAT-TM5 Band 5 Near Infrared (NIR) (1.55-1.75um) 30m
-lsat5_1987_60 LANDSAT-TM5 Band 6 Thermal (10.40-12.50um) 120m
-lsat5_1987_70 LANDSAT-TM5 Band 7 Mid Infrared (MIR) (2.08-2.35um) 30m
-lsat7_2000_10 LANDSAT-TM7 Band 1 Visible (0.45-0.52um) 30m
-lsat7_2000_20 LANDSAT-TM7 Band 2 Visible (0.52-0.60um) 30m
-lsat7_2000_30 LANDSAT-TM7 Band 3 Visible (0.63-0.69um) 30m
-lsat7_2000_40 LANDSAT-TM7 Band 4 Near Infrared (NIR) (0.76-0.90um) 30m
-lsat7_2000_50 LANDSAT-TM7 Band 5 Near Infrared (NIR) (1.55-1.75um) 30m
-lsat7_2000_61 LANDSAT-TM7 Band 6 Thermal (10.40-12.50um) 60m Low Gain
-lsat7_2000_70 LANDSAT-TM7 Band 7 Mid Infrared (MIR) (2.08-2.35um) 30m
-lsat7_2000_80 LANDSAT-TM7 Band 8 Panchromatic (PAN) (0.52-0.90um (15m)
LIST_RASTERS_TITLES_MAPSET = """----------------------------------------------
@@ -151,18 +126,14 @@
-class GListTest(unittest.TestCase):
+class GListTest(gunittest.TestCase):
- def setUp(self):
- pass
def test_list_rasters(self):
"""Test human readable list of rasters.
Supposing we are in user1 of NC and have access
to landsat (besides PERMANENT).
- self.maxDiff = None
stdout = read_command('g.list', type='rast')
self.assertMultiLineEqual(stdout, LIST_RASTERS)
@@ -172,18 +143,16 @@
stdout = read_command('g.list', type='vect')
self.assertMultiLineEqual(stdout, LIST_VECTORS)
- def test_list_groups(self):
- """Test human readable list of imagery groups.
+ def test_list_groups_in_mapset(self):
+ """Test human readable list of imagery groups in a specific mapset.
- stdout = read_command('g.list', type='group')
+ stdout = read_command('g.list', type='group', mapset='landsat')
self.assertMultiLineEqual(stdout, LIST_GROUPS)
def test_list_rasters_in_mapset(self):
@@ -192,34 +161,23 @@
stdout = read_command('g.list', type='rast', mapset='landsat')
self.assertMultiLineEqual(stdout, LIST_RASTERS_MAPSET)
def test_list_rasters_titles(self):
"""Test human readable list of rasters with titles.
- Supposing we are in user1 of NC and have access
- to landsat (besides PERMANENT).
stdout = read_command('g.list', flags='f', type='rast')
self.assertMultiLineEqual(stdout, LIST_RASTERS_TITLES)
def test_list_rasters_titles_in_mapset(self):
stdout = read_command('g.list', flags='f', type='rast',
mapset='landsat')
self.assertMultiLineEqual(stdout, LIST_RASTERS_TITLES_MAPSET)
- def tearDown(self):
- pass
if __name__ == '__main__':
- unittest.main()
+ gunittest.test()
Modified: grass/trunk/general/g.mlist/testsuite/test_g_mlist.py
--- grass/trunk/general/g.mlist/testsuite/test_g_mlist.py 2014-07-08 21:34:46 UTC (rev 61201)
+++ grass/trunk/general/g.mlist/testsuite/test_g_mlist.py 2014-07-08 21:37:37 UTC (rev 61202)
@@ -1,39 +1,55 @@
+"""g.mlist tests"""
-import unittest
-from grass.script import start_command
-import subprocess
+import gunittest
+from gunittest.gmodules import SimpleModule
-class GMlistWrongParamertersTest(unittest.TestCase):
- def setUp(self):
- pass
+class GMlistWrongParamertersTest(gunittest.TestCase):
+ """Test wrong input of parameters for g.mlist module"""
+ @classmethod
+ def setUpClass(cls):
+ """Create maps in a small region."""
+ cls.use_temp_region()
+ cls.runModule("g.region", s=0, n=5, w=0, e=5, res=1)
+ @classmethod
+ def tearDownClass(cls):
+ """Remove temporary region"""
+ cls.del_temp_region()
def test_pt_flags(self):
- p = start_command('g.mlist', flags='pt', type='rast', stderr=subprocess.PIPE)
- stderr = p.communicate()[1]
- self.assertEqual(stderr, "ERROR: -p/-f and -m/-t are mutually exclusive\n")
+ """Test that -p and -t flags are exclusive"""
+ module = SimpleModule('g.mlist', flags='pt', type='rast')
+ self.assertModuleFail(module)
+ stderr = module.outputs.stderr
+ self.assertIn('-p', stderr)
+ self.assertIn('-t', stderr)
def test_ft_flags(self):
- p = start_command('g.mlist', flags='ft', type='rast', stderr=subprocess.PIPE)
+ """Test that -f and -t flags are exclusive"""
+ module = SimpleModule('g.mlist', flags='ft', type='rast')
+ self.assertIn('-f', stderr)
def test_pf_flags(self):
- p = start_command('g.mlist', flags='pf', type='rast', stderr=subprocess.PIPE)
- self.assertEqual(stderr, "ERROR: -p and -f are mutually exclusive\n")
+ """Test that -p and -f flags are exclusive"""
+ module = SimpleModule('g.mlist', flags='pf', type='rast')
def test_re_flags(self):
- p = start_command('g.mlist', flags='re', type='rast', stderr=subprocess.PIPE)
- self.assertEqual(stderr, "ERROR: -r and -e are mutually exclusive\n")
+ """Test that -r and -e flags are exclusive"""
+ module = SimpleModule('g.mlist', flags='re', type='rast')
+ self.assertIn('-r', stderr)
+ self.assertIn('-e', stderr)
- pass
- unittest.main()
+ gunittest.test()
Modified: grass/trunk/general/g.mremove/testsuite/test_g_mremove.py
--- grass/trunk/general/g.mremove/testsuite/test_g_mremove.py 2014-07-08 21:34:46 UTC (rev 61201)
+++ grass/trunk/general/g.mremove/testsuite/test_g_mremove.py 2014-07-08 21:37:37 UTC (rev 61202)
@@ -1,10 +1,13 @@
+"""Test of g.mremove module"""
-import unittest
-import subprocess
-from grass.script import start_command, read_command, run_command
-import grass.script.core as gcore
+# TODO: rmapcalc probably fatals, replace or add raise on error?
from grass.script.raster import mapcalc as rmapcalc
+import gunittest
+from gunittest.gutils import get_curret_mapset
+# when used user1 must be replaced by current mapset
REMOVE_RASTERS = """rast/test_map_0 at user1
rast/test_map_1 at user1
rast/test_map_2 at user1
@@ -32,64 +35,75 @@
-class GMremoveTest(unittest.TestCase):
+class GMRemoveTest(gunittest.TestCase):
+ """Test removing with g.mremove"""
- def setUp(self):
- gcore.set_raise_on_error(True)
- gcore.use_temp_region()
- ret = run_command("g.region", s=0, n=5, w=0, e=5, res=1)
- if ret != 0:
- gcore.fatal("g.region failed")
+ @classmethod
+ """Set up small region for fast map creation."""
+ @classmethod
def test_remove_procedure(self):
+ """Test that maps are removed only with -f"""
for i in range(0, 10):
rmapcalc("test_map_%i = 100" % i)
rmapcalc("test_two = 2")
- p = start_command('g.mremove', rast='test_map_*,*two',
- stdout=subprocess.PIPE, stderr=subprocess.PIPE)
- stdout = p.communicate()[0]
- self.assertMultiLineEqual(stdout, REMOVE_RASTERS)
- p = start_command('g.mremove', rast='test_map_*,*two', flags='f',
- stdout, stderr = p.communicate()
- self.assertMultiLineEqual(stdout, '')
- self.assertMultiLineEqual(stderr, REMOVING_RASTERS_LOG)
- #@unittest.skip("only for the new g.mremove with g.mlist interface")
- def test_remove_procedure(self):
+ module = SimpleModule('g.mremove',
+ type='rast', pattern='test_map_*,*two')
+ self.assertModule(module)
+ self.assertMultiLineEqual(module.outputs.stdout,
+ REMOVE_RASTERS.replace('user1',
+ get_curret_mapset()))
+ module = SimpleModule('g.mremove', type='rast',
+ pattern='test_map_*,*two', flags='f')
+ self.assertMultiLineEqual(module.outputs.stdout, '')
+ self.assertMultiLineEqual(module.outputs.stderr, REMOVING_RASTERS_LOG)
+ def test_remove_procedure_exclude(self):
+ """Test that exclude does not list excluded maps"""
rmapcalc("test_apples = 100")
rmapcalc("test_oranges = 200")
rmapcalc("test_apples_big = 300")
rmapcalc("test_apples_small = 300")
- p = start_command('g.mremove', type='rast',
- pattern='test_{apples,oranges}*',
- exclude="*_small",
+ pattern='test_{apples,oranges}*',
+ exclude="*_small")
'rast/test_apples at user1\n'
'rast/test_apples_big at user1\n'
- 'rast/test_oranges at user1\n')
- pattern='test_{apples,oranges}{_small,_big,*}',
- flags='f',
- self.assertRegexpMatches(stderr, "(.*<.+>[^\n]*\n){4}", "4 maps should be removed")
+ 'rast/test_oranges at user1\n'.replace(
+ 'user1', get_curret_mapset()))
+ pattern='test_{apples,oranges}{_small,_big,*}',
+ flags='f')
+ self.assertRegexpMatches(module.outputs.stderr, "(.*<.+>[^\n]*\n){4}",
+ msg="4 maps should be removed")
+class GMRemoveWrongInputTest(gunittest.TestCase):
- p = start_command('g.mremove', flags='re', type='rast', pattern='xxxyyyzzz',
- stderr=subprocess.PIPE)
+ module = SimpleModule('g.mremove', flags='re',
+ type='rast', pattern='xxxyyyzzz')
- gcore.del_temp_region()
- unittest.main()
+ gunittest.test()
