[GRASS-SVN] r61206 - grass/trunk/raster/r.stream.distance
svn_grass at osgeo.org
Tue Jul 8 20:09:44 PDT 2014
Author: hcho
Date: 2014-07-08 20:09:44 -0700 (Tue, 08 Jul 2014)
New Revision: 61206
grass/trunk/raster/r.stream.distance/distance_calc.c
grass/trunk/raster/r.stream.distance/distance_init.c
grass/trunk/raster/r.stream.distance/local_proto.h
grass/trunk/raster/r.stream.distance/local_vars.h
grass/trunk/raster/r.stream.distance/main.c
grass/trunk/raster/r.stream.distance/r.stream.distance.html
r.stream.distance: Change the output type from FCELL to DCELL for a higher precision (ticket #2359)
Modified: grass/trunk/raster/r.stream.distance/distance_calc.c
--- grass/trunk/raster/r.stream.distance/distance_calc.c 2014-07-09 03:07:37 UTC (rev 61205)
+++ grass/trunk/raster/r.stream.distance/distance_calc.c 2014-07-09 03:09:44 UTC (rev 61206)
@@ -27,18 +27,18 @@
-int ram_calculate_downstream(CELL ** dirs, FCELL ** distance,
- FCELL ** elevation, OUTLET outlet, int outs)
+int ram_calculate_downstream(CELL ** dirs, DCELL ** distance,
+ DCELL ** elevation, OUTLET outlet, int outs)
int r, c, i, j;
int next_r, next_c;
POINT n_cell;
- float cur_dist = 0;
- float tmp_dist = 0;
- float target_elev; /* eleavation at stream or outlet */
- float easting, northing;
- float cell_easting, cell_northing;
+ double cur_dist = 0;
+ double tmp_dist = 0;
+ double target_elev; /* eleavation at stream or outlet */
+ double easting, northing;
+ double cell_easting, cell_northing;
struct Cell_head window;
Rast_get_window(&window);
@@ -134,14 +134,14 @@
int r, c, i, j;
int next_r, next_c;
POINT n_cell;
CELL dirs_cell;
- FCELL distance_cell, elevation_cell;
- FCELL zero_cell = 0;
+ DCELL distance_cell, elevation_cell;
+ DCELL zero_cell = 0;
@@ -235,12 +235,12 @@
return 0;
-int ram_fill_basins(OUTLET outlet, FCELL ** distance, CELL ** dirs)
+int ram_fill_basins(OUTLET outlet, DCELL ** distance, CELL ** dirs)
/* fill empty spaces with zeros but leave -1 as a markers of NULL */
int r, c, i, j;
int next_r, next_c;
- float stop, val;
+ double stop, val;
POINT n_cell;
tail = 0;
@@ -285,10 +285,10 @@
int r, c, i, j;
int next_r, next_c;
- float stop, val;
+ double stop, val;
POINT n_cell;
CELL dirs_cell;
- FCELL distance_cell;
+ DCELL distance_cell;
tail = 0;
head = -1;
@@ -331,29 +331,29 @@
return 0;
-int ram_calculate_upstream(FCELL ** distance, CELL ** dirs,
- FCELL ** elevation, FCELL ** tmp_elevation,
+int ram_calculate_upstream(DCELL ** distance, CELL ** dirs,
+ DCELL ** elevation, DCELL ** tmp_elevation,
int near)
int r, c;
int next_r, next_c;
int i, j, k, d;
int done;
int counter;
int n_inits = 0;
- float cur_dist;
+ double cur_dist;
POINT *d_inits;
- float target_elev = 0;
+ double target_elev = 0;
size_t elevation_data_size;
if (elevation) {
- elevation_data_size = Rast_cell_size(FCELL_TYPE);
+ elevation_data_size = Rast_cell_size(DCELL_TYPE);
for (r = 0; r < nrows; ++r)
memcpy(tmp_elevation[r], elevation[r],
ncols * elevation_data_size);
@@ -472,27 +472,27 @@
int r, c;
int next_r, next_c;
int i, j, k, d, d_next;
- FCELL minus_one_cell = -1;
+ DCELL minus_one_cell = -1;
int done;
int counter;
int n_inits = 0;
- float cur_dist;
+ double cur_dist;
POINT *d_inits;
CELL dirs_cell;
- FCELL distance_cell, elevation_cell, tmp_elevation_cell;
+ DCELL distance_cell, elevation_cell, tmp_elevation_cell;
/* size_t elevation_data_size; */
if (elevation) {
- /* elevation_data_size = Rast_cell_size(FCELL_TYPE); */
+ /* elevation_data_size = Rast_cell_size(DCELL_TYPE); */
for (c = 0; c < ncols; ++c) {
segment_get(elevation, &elevation_cell, r, c);
Modified: grass/trunk/raster/r.stream.distance/distance_init.c
--- grass/trunk/raster/r.stream.distance/distance_init.c 2014-07-09 03:07:37 UTC (rev 61205)
+++ grass/trunk/raster/r.stream.distance/distance_init.c 2014-07-09 03:09:44 UTC (rev 61206)
@@ -126,13 +126,13 @@
return outlets_num;
-int ram_init_distance(CELL ** streams, FCELL ** distance, int outlets_num,
+int ram_init_distance(CELL ** streams, DCELL ** distance, int outlets_num,
int outs)
int r, c, i;
/* size_t data_size;
- data_size = Rast_cell_size(FCELL_TYPE);
+ data_size = Rast_cell_size(DCELL_TYPE);
if (!outs) { /* stream mode */
@@ -157,9 +157,9 @@
int r, c, i;
CELL streams_cell;
@@ -180,7 +180,7 @@
return 0;
-int ram_prep_null_elevation(FCELL ** distance, FCELL ** elevation)
+int ram_prep_null_elevation(DCELL ** distance, DCELL ** elevation)
int r, c;
@@ -198,7 +198,7 @@
int seg_prep_null_elevation(SEGMENT * distance, SEGMENT * elevation)
int r, c;
Modified: grass/trunk/raster/r.stream.distance/local_proto.h
--- grass/trunk/raster/r.stream.distance/local_proto.h 2014-07-09 03:07:37 UTC (rev 61205)
+++ grass/trunk/raster/r.stream.distance/local_proto.h 2014-07-09 03:09:44 UTC (rev 61206)
@@ -3,17 +3,17 @@
/* inits */
int ram_find_outlets(CELL **streams, int number_of_streams, CELL **dirs, int subs, int outs);
-int ram_init_distance(CELL **streams, FCELL **distance, int outlets_num, int outs);
-int ram_prep_null_elevation(FCELL **distance, FCELL **elevation);
+int ram_init_distance(CELL **streams, DCELL **distance, int outlets_num, int outs);
+int ram_prep_null_elevation(DCELL **distance, DCELL **elevation);
int seg_find_outlets(SEGMENT *streams, int number_of_streams, SEGMENT *dirs, int subs, int outs);
int seg_prep_null_elevation(SEGMENT *distance, SEGMENT *elevation);
int seg_init_distance(SEGMENT *streams, SEGMENT *distance, int outlets_num, int outs);
/* calculate */
-int ram_calculate_downstream(CELL **dirs, FCELL **distance, FCELL **elevation, OUTLET outlet, int outs);
-int ram_fill_basins(OUTLET outlet, FCELL **distance, CELL **dirs);
-int ram_calculate_upstream(FCELL **distance, CELL **dirs, FCELL **elevation, FCELL **tmp_elevation, int near);
+int ram_calculate_downstream(CELL **dirs, DCELL **distance, DCELL **elevation, OUTLET outlet, int outs);
+int ram_fill_basins(OUTLET outlet, DCELL **distance, CELL **dirs);
+int ram_calculate_upstream(DCELL **distance, CELL **dirs, DCELL **elevation, DCELL **tmp_elevation, int near);
int seg_calculate_downstream (SEGMENT *dirs, SEGMENT *distance, SEGMENT *elevation, OUTLET outlet, int outs);
int seg_fill_basins(OUTLET outlet, SEGMENT *distance, SEGMENT *dirs);
Modified: grass/trunk/raster/r.stream.distance/local_vars.h
--- grass/trunk/raster/r.stream.distance/local_vars.h 2014-07-09 03:07:37 UTC (rev 61205)
+++ grass/trunk/raster/r.stream.distance/local_vars.h 2014-07-09 03:09:44 UTC (rev 61206)
@@ -22,8 +22,8 @@
typedef struct {
int r,c;
- float cur_dist;
+ double cur_dist;
} POINT;
GLOBAL int nextr[9];
Modified: grass/trunk/raster/r.stream.distance/main.c
--- grass/trunk/raster/r.stream.distance/main.c 2014-07-09 03:07:37 UTC (rev 61205)
+++ grass/trunk/raster/r.stream.distance/main.c 2014-07-09 03:09:44 UTC (rev 61206)
@@ -147,19 +147,19 @@
MAP map_dirs, map_streams, map_distance, map_elevation,
map_tmp_elevation;
CELL **streams, **dirs;
- FCELL **distance;
- FCELL **elevation = NULL;
- FCELL **tmp_elevation = NULL;
+ DCELL **distance;
+ DCELL **elevation = NULL;
+ DCELL **tmp_elevation = NULL;
ram_create_map(&map_streams, CELL_TYPE);
ram_read_map(&map_streams, in_stm_opt->answer, 1, CELL_TYPE);
ram_create_map(&map_dirs, CELL_TYPE);
ram_read_map(&map_dirs, in_dir_opt->answer, 1, CELL_TYPE);
- ram_create_map(&map_distance, FCELL_TYPE);
+ ram_create_map(&map_distance, DCELL_TYPE);
streams = (CELL **) map_streams.map;
dirs = (CELL **) map_dirs.map;
- distance = (FCELL **) map_distance.map;
+ distance = (DCELL **) map_distance.map;
number_of_streams = (int)map_streams.max + 1;
outlets_num =
@@ -168,9 +168,9 @@
ram_release_map(&map_streams);
if (in_elev_opt->answer) {
- ram_create_map(&map_elevation, FCELL_TYPE);
+ ram_create_map(&map_elevation, DCELL_TYPE);
ram_read_map(&map_elevation, in_elev_opt->answer, 0, -1);
- elevation = (FCELL **) map_elevation.map;
+ elevation = (DCELL **) map_elevation.map;
} /* map elevation will be replaced by elevation difference map */
@@ -187,8 +187,8 @@
else if (method == UPSTREAM) {
if (out_diff_opt->answer) {
- ram_create_map(&map_tmp_elevation, FCELL_TYPE);
- tmp_elevation = (FCELL **) map_tmp_elevation.map;
+ ram_create_map(&map_tmp_elevation, DCELL_TYPE);
+ tmp_elevation = (DCELL **) map_tmp_elevation.map;
for (j = 0; j < outlets_num; ++j)
@@ -203,12 +203,12 @@
ram_prep_null_elevation(distance, elevation);
- ram_write_map(&map_elevation, out_diff_opt->answer, FCELL_TYPE, 1,
+ ram_write_map(&map_elevation, out_diff_opt->answer, DCELL_TYPE, 1,
-1);
if (out_dist_opt->answer)
- ram_write_map(&map_distance, out_dist_opt->answer, FCELL_TYPE, 1,
+ ram_write_map(&map_distance, out_dist_opt->answer, DCELL_TYPE, 1,
-1);
ram_release_map(&map_dirs);
@@ -240,7 +240,7 @@
seg_create_map(&map_dirs, SROWS, SCOLS, number_of_segs, CELL_TYPE);
seg_read_map(&map_dirs, in_dir_opt->answer, 1, CELL_TYPE);
seg_create_map(&map_distance, SROWS, SCOLS, number_of_segs,
- FCELL_TYPE);
+ DCELL_TYPE);
streams = &map_streams.seg;
dirs = &map_dirs.seg;
@@ -254,7 +254,7 @@
seg_create_map(&map_elevation, SROWS, SCOLS, number_of_segs,
- FCELL_TYPE);
+ DCELL_TYPE);
seg_read_map(&map_elevation, in_elev_opt->answer, 0, -1);
elevation = &map_elevation.seg;
@@ -273,7 +273,7 @@
seg_create_map(&map_tmp_elevation, SROWS, SCOLS,
- number_of_segs, FCELL_TYPE);
+ number_of_segs, DCELL_TYPE);
tmp_elevation = &map_tmp_elevation.seg;
@@ -288,12 +288,12 @@
} /* end methods */
- seg_write_map(&map_distance, out_dist_opt->answer, FCELL_TYPE, 1,
+ seg_write_map(&map_distance, out_dist_opt->answer, DCELL_TYPE, 1,
-1);
seg_prep_null_elevation(distance, elevation);
- seg_write_map(&map_elevation, out_diff_opt->answer, FCELL_TYPE, 1,
+ seg_write_map(&map_elevation, out_diff_opt->answer, DCELL_TYPE, 1,
-1);
Modified: grass/trunk/raster/r.stream.distance/r.stream.distance.html
--- grass/trunk/raster/r.stream.distance/r.stream.distance.html 2014-07-09 03:07:37 UTC (rev 61205)
+++ grass/trunk/raster/r.stream.distance/r.stream.distance.html 2014-07-09 03:09:44 UTC (rev 61206)
@@ -85,11 +85,11 @@
<dt><b>difference</b></dt>
<dd>Name of output map of elevation difference to the target (outlet, node,
-stream, divide, maximum) along watercoures. The map is of FCELL type.</dd>
+stream, divide, maximum) along watercoures. The map is of DCELL type.</dd>
<dt><b>distance</b></dt>
<dd>Name of output map of distance to the target (outlet, node, stream,
-divide, maximum) along watercoures. The map is of FCELL type.</dd>
+divide, maximum) along watercoures. The map is of DCELL type.</dd>
</dl>
<h2>NOTES</h2>
