[GRASS-SVN] r61216 - grass/trunk/lib/init
svn_grass at osgeo.org
Wed Jul 9 05:08:31 PDT 2014
Author: martinl
Date: 2014-07-09 05:08:31 -0700 (Wed, 09 Jul 2014)
New Revision: 61216
grass/trunk/lib/init/grass.py
fix grass.py to accept custom PS1 and aliases (bashrc)
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2014-07-09 11:05:55 UTC (rev 61215)
+++ grass/trunk/lib/init/grass.py 2014-07-09 12:08:31 UTC (rev 61216)
@@ -744,6 +744,9 @@
return
for line in readfile(grass_env_file).split(os.linesep):
+ if not line.lower().startswith('export'):
+ continue
try:
k, v = map(lambda x: x.strip(), line.strip().split(' ', 1)[1].split('=', 1))
except:
@@ -1139,16 +1142,27 @@
_("Raster MASK present"),
_("3D raster MASK present")))
- # read environmental variables
- path = os.path.join(userhome, ".grass.bashrc") # left for backward compatibility
+ # read environmental variables from GRASS 6 (left for backward
+ # compatibility)
+ path = os.path.join(userhome, ".grass.bashrc")
if os.access(path, os.R_OK):
f.write(readfile(path) + '\n')
+ # write GRASS environmental variables to $LOCATION/.bashrc
for env in os.environ.keys():
if env.startswith('GRASS'):
val = os.environ[env]
if ' ' in val:
val = '"%s"' % val
f.write('export %s=%s\n' % (env, val))
+ # write aliases and custom settings from grass_env_file to
+ # $LOCATION/.bashrc
+ if os.access(grass_env_file, os.R_OK):
+ for line in readfile(grass_env_file).split(os.linesep):
+ if line.lower().startswith('export'):
+ continue
+ f.write(line + '\n')
### Replaced by code above (do not override already set up environment variables)
### if os.access(grass_env_file, os.R_OK):
### f.write(readfile(grass_env_file) + '\n')
