[GRASS-SVN] r61222 - sandbox/wenzeslaus/gunittest
svn_grass at osgeo.org
Wed Jul 9 14:01:57 PDT 2014
Author: wenzeslaus
Date: 2014-07-09 14:01:57 -0700 (Wed, 09 Jul 2014)
New Revision: 61222
Removed:
sandbox/wenzeslaus/gunittest/suite.py
sandbox/wenzeslaus/gunittest/loader.py
gunittest: custom test suite class is not needed if we invoke separate files as separate processes and allow them to fail with any error
Modified: sandbox/wenzeslaus/gunittest/loader.py
--- sandbox/wenzeslaus/gunittest/loader.py 2014-07-09 20:54:01 UTC (rev 61221)
+++ sandbox/wenzeslaus/gunittest/loader.py 2014-07-09 21:01:57 UTC (rev 61222)
@@ -18,9 +18,7 @@
import collections
import importlib
-from .suite import TestSuite
GrassTestPythonModule = collections.namedtuple('GrassTestPythonModule',
['name', 'module',
'tested_dir',
@@ -82,12 +80,12 @@
# see unittest.loader
return modules
class GrassTestLoader(unittest.TestLoader):
skip_dirs = ['.svn', 'dist.*', 'bin.*', 'OBJ.*']
testsuite_dir = 'testsuite'
files_in_testsuite = '*.py'
- suiteClass = TestSuite
all_tests_value = 'all'
universal_tests_value = 'universal'
Deleted: sandbox/wenzeslaus/gunittest/suite.py
--- sandbox/wenzeslaus/gunittest/suite.py 2014-07-09 20:54:01 UTC (rev 61221)
+++ sandbox/wenzeslaus/gunittest/suite.py 2014-07-09 21:01:57 UTC (rev 61222)
@@ -1,51 +0,0 @@
-# -*- coding: utf-8 -*-
-import unittest
-# TODO: this is not necessary if we handle separate files as separate processes
-class TestSuite(unittest.TestSuite):
- def run(self, result, debug=False):
- Original function implementation taken from Python's ``unittest.suite``.
- topLevel = False
- if getattr(result, '_testRunEntered', False) is False:
- result._testRunEntered = topLevel = True
- for test in self:
- if result.shouldStop:
- break
- if _isnotsuite(test):
- self._tearDownPreviousClass(test, result)
- self._handleModuleFixture(test, result)
- self._handleClassSetUp(test, result)
- result._previousTestClass = test.__class__
- if (getattr(test.__class__, '_classSetupFailed', False) or
- getattr(result, '_moduleSetUpFailed', False)):
- continue
- if not debug:
- test(result)
- else:
- test.debug()
- if topLevel:
- self._tearDownPreviousClass(None, result)
- self._handleModuleTearDown(result)
- result._testRunEntered = False
- return result
-# helper from unittest.suite for the original implementation of run
-def _isnotsuite(test):
- "A crude way to tell apart testcases and suites with duck-typing"
- try:
- iter(test)
- except TypeError:
- return True
- return False
