[GRASS-SVN] r61224 - sandbox/wenzeslaus/gunittest
svn_grass at osgeo.org
Wed Jul 9 15:20:12 PDT 2014
Author: wenzeslaus
Date: 2014-07-09 15:20:12 -0700 (Wed, 09 Jul 2014)
New Revision: 61224
sandbox/wenzeslaus/gunittest/case.py
sandbox/wenzeslaus/gunittest/checkers.py
gunittest: fix spelling
Modified: sandbox/wenzeslaus/gunittest/case.py
--- sandbox/wenzeslaus/gunittest/case.py 2014-07-09 21:47:37 UTC (rev 61223)
+++ sandbox/wenzeslaus/gunittest/case.py 2014-07-09 22:20:12 UTC (rev 61224)
@@ -33,7 +33,7 @@
Always use keyword arguments for all parameters other than first two. For
- the firt two, it is recommened to use keyword arguments but not required.
+ the first two, it is recommended to use keyword arguments but not required.
longMessage = True # to get both standard and custom message
maxDiff = None # we can afford long diffs
@@ -43,7 +43,7 @@
super(TestCase, self).__init__(methodName)
def _formatMessage(self, msg, standardMsg):
- """Honour the longMessage attribute when generating failure messages.
+ """Honor the longMessage attribute when generating failure messages.
If longMessage is False this means:
@@ -55,7 +55,7 @@
* Use the standard message
* If an explicit message is provided, return string with both messages
- Based on Python unittest _formatMessage, formatting chanaged.
+ Based on Python unittest _formatMessage, formatting changed.
if not self.longMessage:
return msg or standardMsg
@@ -75,7 +75,7 @@
If you use this method, you have to call it in `setUpClass()`
and call `del_temp_region()` in `tearDownClass()`. By this you
ensure that each test method will have its own region and will
- not influece other classes.
+ not influence other classes.
@@ -234,7 +234,7 @@
Use keyword arguments syntax for all function parameters.
- This function supports values obtainded -r (range) and
+ This function supports values obtained -r (range) and
-e (extended metadata) flags.
self.assertCommandKeyValue(module='r.info',
@@ -278,7 +278,7 @@
def assertRasterMinMax(self, map, refmin, refmax, msg=None):
"""Test that raster map minimum and maximum are within limits.
- Map mimimum and maximum is tested against expression::
+ Map minimum and maximum is tested against expression::
refmin <= actualmin and refmax >= actualmax
@@ -318,7 +318,7 @@
stdmsg = 'File %s is empty' % filename
self.fail(self._formatMessage(msg, stdmsg))
if not skip_access_check and not os.access(filename, os.R_OK):
- stdmsg = 'File %s is not accesible for reading' % filename
+ stdmsg = 'File %s is not accessible for reading' % filename
def assertFileMd5(self, filename, md5, msg=None):
@@ -391,7 +391,7 @@
"""Test that `actual` raster is not different from `reference` raster
Method behaves in the same way as `assertRasterFitsUnivar()`
- but works on difference ``referece - actual``.
+ but works on difference ``reference - actual``.
If statistics is not given ``dict(min=-precision, max=precision)``
is used.
@@ -413,7 +413,7 @@
def assertRastersDifference(self, actual, reference,
statistics, precision, msg=None):
- """Test statistical values of differece of reference and actual rasters
+ """Test statistical values of difference of reference and actual rasters
For cases when you are interested in no or minimal difference,
use `assertRastersNoDifference()` instead.
@@ -432,7 +432,7 @@
def runModule(cls, module, **kwargs):
"""Run PyGRASS module.
- Runs the module and raises an expception if the module ends with
+ Runs the module and raises an exception if the module ends with
non-zero return code. Usually, this is the same as testing the
return code and raising exception but by using this method,
you give testing framework more control over the execution,
@@ -490,7 +490,7 @@
# it would be better to be able to use this multiple times
# TODO: enable merging streams?
def assertModule(self, module, msg=None, **kwargs):
- """Run PyGRASS module in controled way and assert non-zero return code.
+ """Run PyGRASS module in controlled way and assert non-zero return code.
You should use this method to invoke module you are testing.
By using this method, you give testing framework more control over
Modified: sandbox/wenzeslaus/gunittest/checkers.py
--- sandbox/wenzeslaus/gunittest/checkers.py 2014-07-09 21:47:37 UTC (rev 61223)
+++ sandbox/wenzeslaus/gunittest/checkers.py 2014-07-09 22:20:12 UTC (rev 61224)
@@ -24,7 +24,7 @@
def unify_projection(dic):
"""Unifies names of projections.
- Some projections has possibily duplicate names like
+ Some projections are referred using different names like
'Universal Transverse Mercator' and 'Universe Transverse Mercator'.
This function replaces synonyms by a unified name.
@@ -155,7 +155,7 @@
:return: a dictionary representation of text
:return type: grass.script.core.KeyValue
- And example of converting text with text, floats, integeres and list
+ And example of converting text with text, floats, integers and list
to a dictionary::
>>> sorted(text_to_keyvalue('''a: Hello
@@ -166,7 +166,7 @@
.. warning::
And empty string is a valid input because empty dictionary is a valid
- dictionary. You need to test this separately accorting
+ dictionary. You need to test this separately according
to the circumstances.
# splitting according to universal newlines approach
@@ -345,7 +345,7 @@
a_is_subset=False):
"""Determine the difference of two dictionaries.
- The function returns missing keys and differnt values for common keys::
+ The function returns missing keys and different values for common keys::
>>> a = {'c': 2, 'b': 3, 'a': 4}
>>> b = {'c': 1, 'b': 3, 'd': 5}
@@ -367,7 +367,7 @@
Comparing to the Python ``difflib`` package this function does not create
any difference output. It just returns the dictionaries.
- Comapring to the Python ``unittest`` ``assertDictEqual()``,
+ Comparing to the Python ``unittest`` ``assertDictEqual()``,
this function does not issues error or exception, it just determines
what it the difference.
@@ -482,7 +482,7 @@
>>> check_text_ellipsis("a=11\nb=...", "a=11\nb=22\n")
True
- This function is based on regular expression containg .+ but no other
+ This function is based on regular expression containing .+ but no other
regular expression matching will be done.
>>> check_text_ellipsis("Result: [569] (...)",
