[GRASS-SVN] r61228 - in grass/trunk/lib/python: docs docs/src gunittest
svn_grass at osgeo.org
Wed Jul 9 20:24:54 PDT 2014
Author: wenzeslaus
Date: 2014-07-09 20:24:54 -0700 (Wed, 09 Jul 2014)
New Revision: 61228
Added:
grass/trunk/lib/python/docs/src/gunittest_testing.rst
Removed:
grass/trunk/lib/python/gunittest/testing.rst
grass/trunk/lib/python/docs/Makefile
grass/trunk/lib/python/docs/conf.py
grass/trunk/lib/python/docs/src/index.rst
sphinx: add gunittest and exceptions to sphinx, few improvements in testing doc
Modified: grass/trunk/lib/python/docs/Makefile
--- grass/trunk/lib/python/docs/Makefile 2014-07-10 02:18:32 UTC (rev 61227)
+++ grass/trunk/lib/python/docs/Makefile 2014-07-10 03:24:54 UTC (rev 61228)
@@ -59,6 +59,8 @@
-rm -rf $(BUILDDIR)/*
-rm -f _templates/layout.html
-rm -f src/ctypes*.rst
+ -rm -f src/exceptions.rst
+ -rm -f src/gunittest.*rst
-rm -f src/imaging.rst
-rm -f src/pydispatch.rst
-rm -f src/pygrass.*rst
@@ -68,6 +70,8 @@
libpythonapidoc:
@echo $(SPHINXAPIDOC)
$(call run_grass,$(SPHINXAPIDOC) -T -f -o src/ ../imaging/)
+ $(call run_grass,$(SPHINXAPIDOC) -T -f -o src/ ../exceptions/)
+ $(call run_grass,$(SPHINXAPIDOC) -T -f -o src/ ../gunittest/)
$(call run_grass,$(SPHINXAPIDOC) -T -f -o src/ ../pydispatch/)
$(call run_grass,$(SPHINXAPIDOC) -T -f -o src/ ../pygrass/)
$(call run_grass,$(SPHINXAPIDOC) -T -f -o src/ ../script/)
Modified: grass/trunk/lib/python/docs/conf.py
--- grass/trunk/lib/python/docs/conf.py 2014-07-10 02:18:32 UTC (rev 61227)
+++ grass/trunk/lib/python/docs/conf.py 2014-07-10 03:24:54 UTC (rev 61228)
@@ -24,6 +24,8 @@
sys.exit("GISBASE not defined")
sys.path.insert(0, os.path.abspath(os.path.join(os.environ['GISBASE'], 'etc', 'python', 'grass')))
sys.path.insert(0, os.path.abspath(os.path.join(os.environ['GISBASE'], 'etc', 'python', 'grass', 'ctypes')))
+sys.path.insert(0, os.path.abspath(os.path.join(os.environ['GISBASE'], 'etc', 'python', 'grass', 'exceptions')))
+sys.path.insert(0, os.path.abspath(os.path.join(os.environ['GISBASE'], 'etc', 'python', 'grass', 'gunittest')))
sys.path.insert(0, os.path.abspath(os.path.join(os.environ['GISBASE'], 'etc', 'python', 'grass', 'imaging')))
sys.path.insert(0, os.path.abspath(os.path.join(os.environ['GISBASE'], 'etc', 'python', 'grass', 'pydispatch')))
sys.path.insert(0, os.path.abspath(os.path.join(os.environ['GISBASE'], 'etc', 'python', 'grass', 'pygrass')))
Copied: grass/trunk/lib/python/docs/src/gunittest_testing.rst (from rev 61225, grass/trunk/lib/python/gunittest/testing.rst)
--- grass/trunk/lib/python/docs/src/gunittest_testing.rst (rev 0)
+++ grass/trunk/lib/python/docs/src/gunittest_testing.rst 2014-07-10 03:24:54 UTC (rev 61228)
@@ -0,0 +1,322 @@
+Testing GRASS GIS source code and modules
+Introduction
+For the testing we will be using system based on Python `unittest`_ package.
+The system is not finished yet.
+For now, the best way is to use just Python unittest package as is.
+Additionally, it is possible to use Python `doctest`_ package
+which is compatible with unittest at certain level.
+Both packages are part of the standard Python distribution.
+The content of this document may become part of submitting files and
+the documentation of testing framework classes and scripts.
+Testing with gunittest package in general
+The tests should be in files in a ``testsuite`` directory which is a subdirectory
+of the directory with tested files (module, package, library). Each testing file
+(test file) can have can have several testing classes (test cases).
+All test files names should have pattern ``test*.py``.
+GRASS GIS `gunittest` package and testing framework is similar to the standard
+Python ``unittest`` package, so the ways to build tests are very similar.
+ from grass.guinttest import TestCase
+ class TestPython(TestCase):
+ def test_counting(self):
+ """Test that Python can count to two"""
+ self.assertEqual(1 + 1, 2)
+ if __name__ == '__main__':
+ from grass.guinttest import test
+ test()
+Each test file should be able to run by itself and accept certain set of command
+line parameters. This is ensured using `gunittest.test()`.
+To run (invoke) all tests in the source tree run::
+ python python -m grass.gunittest.main [gisdbase] location test_data_category
+All test files in all ``testsuite`` directories will be executed and
+a report will be created in a newly created ``testreport`` directory.
+Open the file ``testreport/index.html`` to browse though the results.
+You need to be in GRASS session to run the tests.
+The test_data_category parameter serves to filter tests accoring to data
+they can run successfully with. It is ignored for tests which does not have
+this specified.
+Each running test file gets its own mapset and current working directory
+but all run are in one location.
+.. warning::
+ The current location is ignored but you should run not invoke tests
+ in the location which is precious to you for the case that something fails.
+To run individual tests file you should be in GRASS session in GRASS NC sample
+location in a mapset of arbitrary name (except for the predefined mapsets).
+Your tests can rely on maps which are present in the GRASS NC sample location.
+But if you can provide tests which are independent on location it is better.
+Read the documentation of Python ``unittest`` package for a list of assert
+methods which you can use to test your results. For test of more complex
+GRASS-specific results refer to :class:`gunittest.case.TestCase` class
+documentation.
+Tests of GRASS modules
+ def test_elevation(self):
+ self.assertModule('r.info', map='elevation', flags='g')
+Use method ``assertRasterMinMax()`` to test that a result is within
+expected range. This is a very general test which checks the basic
+correctness of the result and can be used with different maps
+in different locations.
+ def test_slope_limits(self):
+ slope = 'limits_slope'
+ self.assertModule('r.slope.aspect', elevation='elevation',
+ slope=slope)
+ self.assertRasterMinMax(map=slope, refmin=0, refmax=90,
+ msg="Slope in degrees must be between 0 and 90")
+.. todo::
+ Add example of assertions of key-value results.
+.. todo::
+ Add example with module producing a map.
+ from grass.gunittest import SimpleModule
+ class TestRInfoInputHandling(TestCase):
+ def test_rinfo_wrong_map(self):
+ map_name = 'does_not_exist'
+ rinfo = SimpleModule('r.info', map=, flags='g')
+ self.assertModuleFail(rinfo)
+ self.assertTrue(rinfo.outputs.stderr)
+ self.assertIn(map_name, stderr)
+Tests of C and C++ code
+Tests of Python code
+Testing Python code with doctest
+In Python, the easiest thing to test are functions which performs some computations
+or string manipulations, i.e. they have sum numbers or strings on the input and
+some others on the output.
+At the beginning you can use doctest for this purpose. The syntax is as follows::
+ def sum_list(list_to_sum):
+ """Here is some documentation in docstring.
+ And here is the test::
+ >>> sum_list([2, 5, 3])
+ 10
+In case of GRASS modules which are Python scripts, you can add something like
+this to your script::
+ if __name__ == "__main__":
+ if len(sys.argv) == 2 and sys.argv[1] == '--doctest':
+ import doctest
+ doctest.testmod()
+ else:
+ grass.parser()
+ main()
+No output means that everything was successful. Note that you cannot use all
+the ways of running doctest since doctest will fail don the module file due
+to the dot or dots in the file name. Moreover, it is sometimes required that
+the file is accessible through sys.path which is not true for case of GRASS modules.
+Do not use use doctest for tests of edge cases, for tests which require
+generate complex data first, etc. In these cases use `gunittest`.
+Data
+Most of the tests requires some input data. However, it is good to write
+a test in the way that it is independent on the available data.
+In case of GRASS, we have we can have tests of functions where
+some numbers or strings are input and some numbers or string are output.
+These tests does not require any data to be provided since the numbers
+can be part of the test. Then we have another category of tests, typically
+tests of GRASS modules, which require some maps to be on the input
+and thus the output (and test) depends on the specific data.
+Again, it it best to have tests which does not require any special data
+or generally environment settings (e.g. geographic projection)
+but it is much easier to write good tests with a given set of data.
+So, an compromises must be made and tests of different types should be written.
+In the GRASS testing framework, each test file should be marked according to
+category it belongs to. Each category corresponds to GRASS location or locations
+where the test file can run successfully.
+Universal tests
+ First category is *universal*. The tests in this category use some some
+ hard coded constants, generated data, random data, or their own imported
+ data as in input to function and GRASS modules. All the tests, input data
+ and reference results should be projection independent. These tests will
+ runs always regardless of available locations.
+Standard names tests
+ Second category are tests using *standard names*. Tests rely on a
+ certain set of maps with particular names to be present in the location.
+ Moreover, the tests can rely also on the (semantic) meaning of the
+ names, i.e. raster map named elevation will always contain some kind of
+ digital elevation model of some area, so raster map elevation can be
+ used to compute aspect. In other words, these tests should be able to
+ (successfully) run in any location with a maps named in the same way as
+ in the standard testing location(s).
+Standard data tests
+ Third category of tests rely on *standard data*. These tests expect that the
+ GRASS location they run in not only contains the maps with particular names
+ as in the *standard names* but the tests rely also on the data being the
+ same as in the standard testing location(s). However, the (geographic)
+ projection or data storage can be different. This is expected to be the
+ most common case but it is much better if the tests is one of the previous
+ categories (*universal* or *standard names*). If it is possible the
+ functions or modules with tests in this category should have also tests
+ which will fit into one of the previous categories, even though these
+ additional tests will not be as precise as the other tests.
+Location specific tests
+ Finally, there are tests which requires certain concrete location. There
+ is (or will be) a set of standard testing locations each will have the same
+ data (maps) but the projections and data storage types will be different.
+ The suggested locations are: NC sample location in SPM projection,
+ NC in SPF, NC in LL, NC in XY, and perhaps NC in UTM, and NC in some
+ custom projection (in case of strange not-fitting projection, there is
+ a danger that the results of analyses can differer significantly).
+ Moreover, the set can be extened by GRASS locations which are using
+ different storage backends, e.g. PostGIS for vectors and PostgreSQL for
+ temporal database. Tests can specify one or preferably more of these
+ standard locations.
+Specialized location tests
+ Additionally, an specialized location with a collection of strange,
+ incorrect, or generally extreme data will be provided. In theory, more
+ than one location like this can be created if the data cannot be
+ together in one location or if the location itself is somehow special,
+ e.g. because of projection.
+Each category, or perhaps each location (will) have a set of external data
+available for import or other purposes. The standardization of this data
+is in question and thus this may be specific to each location or this
+can be a separate resource common to all tests using one of the standardized
+locations, or alternatively this data can be associated with the location
+with special data.
+.. note::
+ The more general category you choose for your tests the more testing data
+ can applied to your tests and the more different circumstances can be tried
+ with your tests.
+.. note::
+ gunittest is under development but, so some things can change, however
+ this should not stop you from writing tests since the actual differences
+ in your code will be only subtle.
+.. note::
+ gunittest is not part of GRASS GIS source code yet, it is available
+ separately. If you don't want to deal with some other code now,
+ just write tests based only on Python ``unittest``. This will limit
+ your possibilities of convenient testing but should not stop you
+ from writing tests, especially if you will write tests of Python functions,
+ and C functions exposed to Python through ctypes API. (Note that it might
+ be a good idea to write tests for library function you rely on in your
+ GRASS module).
+Analyzing quality of source code
+Besides testing, you can also use some tools to check the quality of your code
+according to various standards and occurrence of certain code patterns.
+For C/C++ code use third party solution `Coverity Scan`_ where GRASS GIS
+is registered as project number `1038`_. Also you can use `Cppcheck`_
+which will show a lot of errors which compilers do not check.
+In any case, set your compiler to high error and warning levels,
+check them and fix them in your code.
+For Python, we recommend pylint and then for style issues pep8 tool
+(and perhaps also pep257 tool). However, there is more tools available
+you can use them together with the recommend ones.
+To provide a way to evaluate the Python source code in the whole GRASS source
+tree there is a Python script ``grass_py_static_check.py`` which uses
+pylint and pep8 with GRASS-specific settings. Run the tool in GRASS session
+in the source code root directory. A HTML report will be created in
+``pylint_report`` directory.
+ grass_py_static_check.py
+.. note::
+ ``grass_py_static_check.py`` is available in `sandbox`_.
+Additionally, if you are invoking your Python code manually using python command,
+e.g. when testing, use parameters::
+ python -Qwarn -tt -3 some_module.py
+This will warn you about usage of old division semantics for integers
+and about incompatibilities with Python 3 (if you are using Python 2)
+which 2to3 tool cannot fix. Finally, it will issue errors if are using tabs
+for indentation inconsistently (note that you should not use tabs for
+indentation at all).
+Further reading
+.. toctree::
+ :maxdepth: 2
+ gunittest
+.. _unittest: https://docs.python.org/2/library/unittest.html
+.. _doctest: https://docs.python.org/2/library/doctest.html
+.. _Coverity Scan: https://scan.coverity.com/
+.. _1038: https://scan.coverity.com/projects/1038
+.. _Cppcheck: http://cppcheck.sourceforge.net/
+.. _sandbox: https://svn.osgeo.org/grass/sandbox/wenzeslaus/grass_py_static_check.py
Modified: grass/trunk/lib/python/docs/src/index.rst
--- grass/trunk/lib/python/docs/src/index.rst 2014-07-10 02:18:32 UTC (rev 61227)
+++ grass/trunk/lib/python/docs/src/index.rst 2014-07-10 03:24:54 UTC (rev 61228)
@@ -9,6 +9,8 @@
script
pygrass_index
temporal
+ exceptions
imaging
+ gunittest_testing
pydispatch
Deleted: grass/trunk/lib/python/gunittest/testing.rst
--- grass/trunk/lib/python/gunittest/testing.rst 2014-07-10 02:18:32 UTC (rev 61227)
+++ grass/trunk/lib/python/gunittest/testing.rst 2014-07-10 03:24:54 UTC (rev 61228)
@@ -1,298 +0,0 @@
-Introduction
-For the testing we will be using system based on Python `unittest`_ package.
-The system is not finished yet.
-For now, the best way is to use just Python unittest package as is.
-Additionally, it is possible to use Python `doctest`_ package
-which is compatible with unittest at certain level.
-Both packages are part of the standard Python distribution.
-The content of this document may become part of submitting files and
-the documentation of testing framework classes and scripts.
-Testing with gunittest
-The tests should be in files in a ``testsuite`` directory which is a subdirectory
-of the directory with tested files (module, package, library). Each testing file
-(test file) can have can have several testing classes (test cases).
-All test files names should have pattern ``test*.py``.
-GRASS GIS `gunittest` package and testing framework is similar to the standard
-Python ``unittest`` package, so the ways to build tests are very similar.
- import guinttest
- class TestPython(gunittest.TestCase):
- def test_counting(self):
- """Test that Python can count to two"""
- self.assertEqual(1 + 1, 2)
- if __name__ == '__main__':
- gunittest.test()
-Each test file should be able to run by itself and accept certain set of command
-line parameters. This is ensured using `gunittest.test()`.
-To run (invoke) all tests in the source tree run::
- export PYTHONPATH=.../sandbox/wenzeslaus:$PYTHONPATH
- python python -m gunittest.main [gisdbase] location test_data_category
-All test files in all ``testsuite`` directories will be executed and
-a report will be created in a newly created ``testreport`` directory.
-Open the file ``testreport/index.html`` to browse though the results.
-You need to be in GRASS session to run the tests.
-The test_data_category parameter serves to filter tests accoring to data
-they can run successfully with. It is ignored for tests which does not have
-this specified.
-Each running test file gets its own mapset and current working directory
-but all run are in one location.
-.. warning:
- The current location is ignored but you should run not invoke tests
- in the location which is precious to you for the case that something fails.
-To run individual tests file you should be in GRASS session in GRASS NC sample
-location in a mapset of arbitrary name (except for the predefined mapsets).
-Your tests can rely on maps which are present in the GRASS NC sample location.
-But if you can provide tests which are independent on location it is better.
-Read the documentation of Python ``unittest`` package for a list of assert
-methods which you can use to test your results. For test of more complex
-GRASS-specific results refer to `TestCase` class documentation.
-Tests of GRASS modules
- class TestRInfo(gunittest.TestCase):
- def test_elevation(self):
- rinfo = Module('r.info', map='elevation', flags='g',
- stdout_=subprocess.PIPE, run_=False)
- self.assertModule(self.rinfo)
-.. todo:
- Add example of assertions of key-value results.
-.. todo:
- Add example with module producing a map.
- class TestRInfoInputHandling(gunittest.TestCase):
- def test_rinfo_wrong_map(self):
- map_name = 'does_not_exist'
- rinfo = Module('r.info', map=, flags='g',
- self.assertModuleFail(rinfo)
- self.assertTrue(rinfo.outputs.stderr)
- self.assertIn(map_name, stderr)
-.. todo:
- Create ``SimpleModule`` or ``TestModule`` class which will have the right
- parameters for ``assertModule()`` and ``assertModuleFail()`` functions.
-Tests of C and C++ code
-Tests of Python code
-Testing Python code with doctest
-In Python, the easiest thing to test are functions which performs some computations
-or string manipulations, i.e. they have sum numbers or strings on the input and
-some others on the output.
-At the beginning you can use doctest for this purpose. The syntax is as follows::
- def sum_list(list_to_sum):
- """Here is some documentation in docstring.
- And here is the test::
- >>> sum_list([2, 5, 3])
- 10
-In case of GRASS modules which are Python scripts, you can add something like
-this to your script::
- if __name__ == "__main__":
- if len(sys.argv) == 2 and sys.argv[1] == '--doctest':
- import doctest
- doctest.testmod()
- else:
- grass.parser()
- main()
-No output means that everything was successful. Note that you cannot use all
-the ways of running doctest since doctest will fail don the module file due
-to the dot or dots in the file name. Moreover, it is sometimes required that
-the file is accessible through sys.path which is not true for case of GRASS modules.
-Do not use use doctest for tests of edge cases, for tests which require
-generate complex data first, etc. In these cases use `gunittest`.
-Data
-Most of the tests requires some input data. However, it is good to write
-a test in the way that it is independent on the available data.
-In case of GRASS, we have we can have tests of functions where
-some numbers or strings are input and some numbers or string are output.
-These tests does not require any data to be provided since the numbers
-can be part of the test. Then we have another category of tests, typically
-tests of GRASS modules, which require some maps to be on the input
-and thus the output (and test) depends on the specific data.
-Again, it it best to have tests which does not require any special data
-or generally environment settings (e.g. geographic projection)
-but it is much easier to write good tests with a given set of data.
-So, an compromises must be made and tests of different types should be written.
-In the GRASS testing framework, each test file should be marked according to
-category it belongs to. Each category corresponds to GRASS location or locations
-where the test file can run successfully.
-Universal tests
- First category is *universal*. The tests in this category use some some
- hard coded constants, generated data, random data, or their own imported
- data as in input to function and GRASS modules. All the tests, input data
- and reference results should be projection independent. These tests will
- runs always regardless of available locations.
-Standard names tests
- Second category are tests using *standard names*. Tests rely on a
- certain set of maps with particular names to be present in the location.
- Moreover, the tests can rely also on the (semantic) meaning of the
- names, i.e. raster map named elevation will always contain some kind of
- digital elevation model of some area, so raster map elevation can be
- used to compute aspect. In other words, these tests should be able to
- (successfully) run in any location with a maps named in the same way as
- in the standard testing location(s).
-Standard data tests
- Third category of tests rely on *standard data*. These tests expect that the
- GRASS location they run in not only contains the maps with particular names
- as in the *standard names* but the tests rely also on the data being the
- same as in the standard testing location(s). However, the (geographic)
- projection or data storage can be different. This is expected to be the
- most common case but it is much better if the tests is one of the previous
- categories (*universal* or *standard names*). If it is possible the
- functions or modules with tests in this category should have also tests
- which will fit into one of the previous categories, even though these
- additional tests will not be as precise as the other tests.
-Location specific tests
- Finally, there are tests which requires certain concrete location. There
- is (or will be) a set of standard testing locations each will have the same
- data (maps) but the projections and data storage types will be different.
- The suggested locations are: NC sample location in SPM projection,
- NC in SPF, NC in LL, NC in XY, and perhaps NC in UTM, and NC in some
- custom projection (in case of strange not-fitting projection, there is
- a danger that the results of analyses can differer significantly).
- Moreover, the set can be extened by GRASS locations which are using
- different storage backends, e.g. PostGIS for vectors and PostgreSQL for
- temporal database. Tests can specify one or preferably more of these
- standard locations.
-Specialized location tests
- Additionally, an specialized location with a collection of strange,
- incorrect, or generally extreme data will be provided. In theory, more
- than one location like this can be created if the data cannot be
- together in one location or if the location itself is somehow special,
- e.g. because of projection.
-Each category, or perhaps each location (will) have a set of external data
-available for import or other purposes. The standardization of this data
-is in question and thus this may be specific to each location or this
-can be a separate resource common to all tests using one of the standardized
-locations, or alternatively this data can be associated with the location
-with special data.
-.. note::
- The more general category you choose for your tests the more testing data
- can applied to your tests and the more different circumstances can be tried
- with your tests.
-.. note::
- gunittest is under development but, so some things can change, however
- this should not stop you from writing tests since the actual differences
- in your code will be only subtle.
-.. note::
- gunittest is not part of GRASS GIS source code yet, it is available
- separately. If you don't want to deal with some other code now,
- just write tests based only on Python ``unittest``. This will limit
- your possibilities of convenient testing but should not stop you
- from writing tests, especially if you will write tests of Python functions,
- and C functions exposed to Python through ctypes API. (Note that it might
- be a good idea to write tests for library function you rely on in your
- GRASS module).
-Analyzing quality of source code
-Besides testing, you can also use some tools to check the quality of your code
-according to various standards and occurrence of certain code patterns.
-For C/C++ code use third party solution `Coverity Scan`_ where GRASS GIS
-is registered as project number `1038`_. Also you can use `Cppcheck`_
-which will show a lot of errors which compilers do not check.
-In any case, set your compiler to high error and warning levels,
-check them and fix them in your code.
-For Python, we recommend pylint and then for style issues pep8 tool
-(and perhaps also pep257 tool). However, there is more tools available
-you can use them together with the recommend ones.
-To provide a way to evaluate the Python source code in the whole GRASS source
-tree there is a Python script ``grass_py_static_check.py`` which uses
-pylint and pep8 with GRASS-specific settings. Run the tool in GRASS session
-in the source code root directory. A HTML report will be created in
-``pylint_report`` directory.
- grass_py_static_check.py
-Additionally, if you are invoking your Python code manually using python command,
-e.g. when testing, use parameters::
- python -Qwarn -tt -3 some_module.py
-This will warn you about usage of old division semantics for integers
-and about incompatibilities with Python 3 (if you are using Python 2)
-which 2to3 tool cannot fix. Finally, it will issue errors if are using tabs
-for indentation inconsistently (note that you should not use tabs for
-indentation at all).
-.. _unittest: https://docs.python.org/2/library/unittest.html
-.. _doctest: https://docs.python.org/2/library/doctest.html
-.. _Coverity Scan: https://scan.coverity.com/
-.. _1038: https://scan.coverity.com/projects/1038
-.. _Cppcheck: http://cppcheck.sourceforge.net/
