[GRASS-SVN] r61235 - in grass-addons/grass7/raster3d: . r3.flow
Thu Jul 10 11:51:58 PDT 2014
Author: annakrat
Date: 2014-07-10 11:51:58 -0700 (Thu, 10 Jul 2014)
New Revision: 61235
Added:
   grass-addons/grass7/raster3d/Makefile
   grass-addons/grass7/raster3d/r3.flow/
   grass-addons/grass7/raster3d/r3.flow/Makefile
   grass-addons/grass7/raster3d/r3.flow/flowline.c
   grass-addons/grass7/raster3d/r3.flow/flowline.h
   grass-addons/grass7/raster3d/r3.flow/integrate.c
   grass-addons/grass7/raster3d/r3.flow/integrate.h
   grass-addons/grass7/raster3d/r3.flow/interpolate.c
   grass-addons/grass7/raster3d/r3.flow/interpolate.h
   grass-addons/grass7/raster3d/r3.flow/main.c
   grass-addons/grass7/raster3d/r3.flow/r3.flow.html
   grass-addons/grass7/raster3d/r3.flow/r3flow_structs.h
r3.flow: computing 3D flowlines, not all functionality ported yet from Python version in sandbox
Added: grass-addons/grass7/raster3d/Makefile
--- grass-addons/grass7/raster3d/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster3d/Makefile	2014-07-10 18:51:58 UTC (rev 61235)
@@ -0,0 +1,9 @@
+MODULE_TOPDIR = ..
+SUBDIRS = \
+	r3.flow
+include $(MODULE_TOPDIR)/include/Make/Dir.make
+default: subdirs
Property changes on: grass-addons/grass7/raster3d/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Added: grass-addons/grass7/raster3d/r3.flow/Makefile
--- grass-addons/grass7/raster3d/r3.flow/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster3d/r3.flow/Makefile	2014-07-10 18:51:58 UTC (rev 61235)
@@ -0,0 +1,12 @@
+MODULE_TOPDIR = ../..
+PGM=r3.flow
+LIBES = $(RASTER3DLIB) $(RASTERLIB) $(GISLIB) $(VECTORLIB)
+DEPENDENCIES = $(RASTER3DDEP) $(RASTERDEP) $(GISDEP) $(VECTORDEP)
+EXTRA_INC = $(VECT_INC)
+EXTRA_CFLAGS = $(VECT_CFLAGS)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Property changes on: grass-addons/grass7/raster3d/r3.flow/Makefile
   + text/x-makefile
   + native
Added: grass-addons/grass7/raster3d/r3.flow/flowline.c
--- grass-addons/grass7/raster3d/r3.flow/flowline.c	                        (rev 0)
+++ grass-addons/grass7/raster3d/r3.flow/flowline.c	2014-07-10 18:51:58 UTC (rev 61235)
@@ -0,0 +1,97 @@
+   \file flowline.c
+   \brief Generates flowlines as vector lines
+   (C) 2014 by the GRASS Development Team
+   This program is free software under the GNU General Public
+   License (>=v2).  Read the file COPYING that comes with GRASS
+   for details.
+   \author Anna Petrasova
+#include <grass/raster3d.h>
+#include <grass/vector.h>
+#include <grass/glocale.h>
+#include "r3flow_structs.h"
+#include "integrate.h"
+#include "flowline.h"
+   \brief Computes flowline by integrating velocity field.
+   \param region pointer to current 3D region
+   \param seed starting seed (point)
+   \param velocity_field pointer to array of 3 3D raster maps
+   \param integration pointer to integration struct
+   \param flowline_vec pointer to Map_info struct of flowline vector
+   \param cats pointer to line_cats struct of flowline vector
+   \param points pointer to line_pnts struct of flowline vector
+   \param cat category of the newly created flow line
+void compute_flowline(RASTER3D_Region * region, const struct Seed *seed,
+		      RASTER3D_Map ** velocity_field,
+		      struct Integration *integration,
+		      struct Map_info *flowline_vec, struct line_cats *cats,
+		      struct line_pnts *points, const int cat)
+    int i, count;
+    double delta_t;
+    double velocity_norm;
+    double point[3], new_point[3];
+    double vel_x, vel_y, vel_z;
+    double min_step, max_step;
+    point[0] = seed->x;
+    point[1] = seed->y;
+    point[2] = seed->z;
+    if (seed->flowline) {
+	/* append first point */
+	Vect_append_point(points, seed->x, seed->y, seed->z);
+    count = 1;
+    while (count <= integration->limit) {
+	if (get_velocity(region, velocity_field, point[0], point[1], point[2],
+			 &vel_x, &vel_y, &vel_z) < 0)
+	    break;		/* outside region */
+	velocity_norm = norm(vel_x, vel_y, vel_z);
+	if (velocity_norm <= VELOCITY_EPSILON)
+	    break;		/* zero velocity means end of propagation */
+	/* convert to time */
+	delta_t = get_time_step(integration->unit, integration->step,
+				velocity_norm, integration->cell_size);
+	/* integrate */
+	min_step = get_time_step("cell", MIN_STEP, velocity_norm,
+				 integration->cell_size);
+	max_step = get_time_step("cell", MAX_STEP, velocity_norm,
+	delta_t *= integration->direction;
+	if (rk45_integrate_next
+	    (region, velocity_field, point, new_point,
+	     &delta_t, min_step, max_step) < 0)
+	    break;
+	    Vect_append_point(points, new_point[0], new_point[1],
+			      new_point[2]);
+	for (i = 0; i < 3; i++) {
+	    point[i] = new_point[i];
+	count++;
+    if (seed->flowline && points->n_points > 1) {
+	Vect_cat_set(cats, 1, cat);
+	Vect_write_line(flowline_vec, GV_LINE, points, cats);
+	G_debug(1, "Flowline ended after %d steps", count - 1);
+    Vect_reset_line(points);
+    Vect_reset_cats(cats);
Property changes on: grass-addons/grass7/raster3d/r3.flow/flowline.c
   + text/x-csrc
   + native
Added: grass-addons/grass7/raster3d/r3.flow/flowline.h
--- grass-addons/grass7/raster3d/r3.flow/flowline.h	                        (rev 0)
+++ grass-addons/grass7/raster3d/r3.flow/flowline.h	2014-07-10 18:51:58 UTC (rev 61235)
@@ -0,0 +1,14 @@
+#ifndef FLOWLINE_H
+#define FLOWLINE_H
+static const double VELOCITY_EPSILON = 1e-8;
+		      struct line_pnts *points, const int cat);
+#endif // FLOWLINE_H
Property changes on: grass-addons/grass7/raster3d/r3.flow/flowline.h
   + text/x-chdr
   + native
Added: grass-addons/grass7/raster3d/r3.flow/integrate.c
--- grass-addons/grass7/raster3d/r3.flow/integrate.c	                        (rev 0)
+++ grass-addons/grass7/raster3d/r3.flow/integrate.c	2014-07-10 18:51:58 UTC (rev 61235)
@@ -0,0 +1,216 @@
+   \file integrate.c
+   \brief Flowline integration using Runge-Kutta 45 method
+   with adaptive step size control. Implementation based
+   on VTK class vtkRungeKutta45.
+   for details.
+#include <math.h>
+#include <float.h>
+#include <string.h>
+#include "interpolate.h"
+   \brief Computes vector norm.
+   \param x,y,z vector components
+   \return norm
+double norm(const double x, const double y, const double z)
+    return sqrt(x * x + y * y + z * z);
+   \brief Converts integration step to time
+   \param unit type of unit
+   \param step step value
+   \param velocity velocity value
+   \param cell_size size of voxel diagonal
+   \return time step
+double get_time_step(const char *unit, const double step,
+		     const double velocity, const double cell_size)
+    if (strcmp(unit, "time") == 0)
+	return step;
+    else if (strcmp(unit, "length") == 0)
+	return step / velocity;
+    else			/* cell */
+	return (step * cell_size) / velocity;
+int get_velocity(RASTER3D_Region * region, RASTER3D_Map ** velocity_field,
+		 const double x, const double y, const double z,
+		 double *vel_x, double *vel_y, double *vel_z)
+    return interpolate_velocity(region, velocity_field, y, x, z,
+				vel_x, vel_y, vel_z);
+   \brief Runge-Kutta45 (inner steps)
+   \param velocity_field pointer to array of 3 3D raster maps (velocity field)
+   \param point pointer to array of geographic coordinates of starting point
+   \param[out] next_point pointer to array of geographic coordinates of integrated point
+   \param delta_t integration time step
+   \param error pointer to array of error values
+   \return 0 success
+   \return -1 out of region or null values
+static int rk45_next(RASTER3D_Region * region, RASTER3D_Map ** velocity_field,
+		     const double *point, double *next_point,
+		     const double delta_t, double *error)
+    double tmp1[6][3];		/* 3 is 3 dimensions, 6 is the number of k's */
+    double tmp_point[3];
+    double sum_tmp;
+    int i, j, k;
+	return -1;
+    tmp1[0][0] = vel_x;
+    tmp1[0][1] = vel_y;
+    tmp1[0][2] = vel_z;
+    /* compute k's */
+    for (i = 1; i < 6; i++) {
+	for (j = 0; j < 3; j++) {	/* for each coordinate */
+	    sum_tmp = 0;
+	    for (k = 0; k < i; k++) {	/* k1; k1, k2; ... */
+		sum_tmp += B[i - 1][k] * tmp1[k][j];
+	    tmp_point[j] = point[j] + delta_t * sum_tmp;
+	if (get_velocity
+	    (region, velocity_field, tmp_point[0], tmp_point[1], tmp_point[2],
+	    return -1;
+	tmp1[i][0] = vel_x;
+	tmp1[i][1] = vel_y;
+	tmp1[i][2] = vel_z;
+    /* compute next point */
+	sum_tmp = 0;
+	for (i = 0; i < 6; i++) {
+	    sum_tmp += C[i] * tmp1[i][j];
+	next_point[j] = point[j] + delta_t * sum_tmp;
+    if (!Rast3d_is_valid_location
+	(region, next_point[1], next_point[0], next_point[2]))
+	return -1;
+    /* compute error vector */
+	sum_tmp = 0;
+	    sum_tmp += DC[i] * tmp1[i][j];
+	error[j] = delta_t * sum_tmp;
+    return 0;
+   \brief Runge-Kutta45 with step size control
+   \param[in,out] delta_t integration time step
+   \param min_step minimum time step
+   \param max_step maximum time step
+   \return 0 success
+int rk45_integrate_next(RASTER3D_Region * region,
+			RASTER3D_Map ** velocity_field, const double *point,
+			double *next_point, double *delta_t,
+			const double min_step, const double max_step)
+    double estimated_error;
+    double error_ratio;
+    double error[3];
+    double tmp, tmp2;
+    int do_break;
+    estimated_error = DBL_MAX;
+    /* check if min_step < delta_t < max_step */
+    if (fabs(*delta_t) < min_step)
+	*delta_t = min_step * (*delta_t > 0 ? 1 : -1);
+    else if (fabs(*delta_t) > max_step)
+	*delta_t = max_step * (*delta_t > 0 ? 1 : -1);
+    /* try to iteratively decrease error to less than max error */
+    while (estimated_error > MAX_ERROR) {
+	/* compute next point and get estimated error */
+	if (rk45_next
+	    (region, velocity_field, point, next_point, *delta_t, error) == 0)
+	    estimated_error = norm(error[0], error[1], error[2]);
+	else
+	    return -1;
+	/* compute new step size (empirically) */
+	error_ratio = estimated_error / MAX_ERROR;
+	if (error_ratio == 0.0)
+	    tmp = *delta_t > 0 ? min_step : -min_step;
+	else if (error_ratio > 1)
+	    tmp = 0.9 * *delta_t * pow(error_ratio, -0.25);
+	else
+	    tmp = 0.9 * *delta_t * pow(error_ratio, -0.2);
+	tmp2 = fabs(tmp);
+	do_break = FALSE;
+	/* adjust new step size to be within min max limits */
+	if (tmp2 > max_step) {
+	    do_break = TRUE;
+	else if (tmp2 < min_step) {
+	    do_break = TRUE;
+	else
+	    *delta_t = tmp;
+	/* break when the adjustment was needed (not sure why) */
+	if (do_break) {
+	    if (rk45_next(region, velocity_field, point, next_point,
+			  *delta_t, error) < 0)
+		return -1;
+	    break;
+    return 0;
Property changes on: grass-addons/grass7/raster3d/r3.flow/integrate.c
   + text/x-csrc
   + native
Added: grass-addons/grass7/raster3d/r3.flow/integrate.h
--- grass-addons/grass7/raster3d/r3.flow/integrate.h	                        (rev 0)
+++ grass-addons/grass7/raster3d/r3.flow/integrate.h	2014-07-10 18:51:58 UTC (rev 61235)
@@ -0,0 +1,36 @@
+#ifndef INTEGRATE_H
+#define INTEGRATE_H
+static const double MAX_ERROR = 1.0e-6;
+static const double MIN_STEP = 0.01;
+static const double MAX_STEP = 1;
+/* Cash-Karp parameters */
+static const double B[5][5] = { {1. / 5, 0, 0, 0, 0},
+{3. / 40, 9. / 40, 0, 0, 0},
+{3. / 10, -9. / 10, 6. / 5, 0, 0},
+{-11. / 54, 5. / 2, -70. / 27, 35. / 27, 0},
+{1631. / 55296, 175. / 512, 575. / 13824,
+ 44275. / 110592, 253. / 4096}
+static const double C[6] =
+    { 37. / 378, 0, 250. / 621, 125. / 594, 0, 512. / 1771 };
+static const double DC[6] = { 37. / 378 - 2825. / 27648, 0,
+    250. / 621 - 18575. / 48384, 125. / 594 - 13525. / 55296,
+    -277. / 14336, 512. / 1771 - 1. / 4
+double norm(const double x, const double y, const double z);
+		 double *vel_x, double *vel_y, double *vel_z);
+		     const double velocity, const double cell_size);
+			const double min_step, const double max_step);
+#endif // INTEGRATE_H
Property changes on: grass-addons/grass7/raster3d/r3.flow/integrate.h
   + text/x-chdr
   + native
Added: grass-addons/grass7/raster3d/r3.flow/interpolate.c
--- grass-addons/grass7/raster3d/r3.flow/interpolate.c	                        (rev 0)
+++ grass-addons/grass7/raster3d/r3.flow/interpolate.c	2014-07-10 18:51:58 UTC (rev 61235)
@@ -0,0 +1,181 @@
+   \file interpolate.c
+   \brief Trilinear interpolation
+   for details.
+   \brief Finds 8 nearest voxels from a point.
+   \param north,east,top geographic coordinates
+   \param[out] x,y,z pointer to indices of neighbouring voxels
+static void find_nearest_voxels(RASTER3D_Region * region,
+				const double north, const double east,
+				const double top, int *x, int *y, int *z)
+    double n_minus, e_minus, t_minus;
+    double n_plus, e_plus, t_plus;
+    n_minus = north - region->ns_res / 2;
+    n_plus = north + region->ns_res / 2;
+    e_minus = east - region->ew_res / 2;
+    e_plus = east + region->ew_res / 2;
+    t_minus = top - region->tb_res / 2;
+    t_plus = top + region->tb_res / 2;
+    Rast3d_location2coord(region, n_minus, e_minus, t_minus, x++, y++, z++);
+    Rast3d_location2coord(region, n_minus, e_plus, t_minus, x++, y++, z++);
+    Rast3d_location2coord(region, n_plus, e_minus, t_minus, x++, y++, z++);
+    Rast3d_location2coord(region, n_plus, e_plus, t_minus, x++, y++, z++);
+    Rast3d_location2coord(region, n_minus, e_minus, t_plus, x++, y++, z++);
+    Rast3d_location2coord(region, n_minus, e_plus, t_plus, x++, y++, z++);
+    Rast3d_location2coord(region, n_plus, e_minus, t_plus, x++, y++, z++);
+    Rast3d_location2coord(region, n_plus, e_plus, t_plus, x, y, z);
+   Computation is based on the sum of values of nearest voxels
+   weighted by the relative distance of a point
+   to the center of the nearest voxels.
+   \param array_values pointer to values of 8 (neigboring) voxels
+   \param x,y,z relative coordinates (0 - 1)
+   \param[out] interpolated pointer to the array (of size 3) of interpolated values
+static void trilinear_interpolation(const double *array_values,
+				    const double z, double *interpolated)
+    int i, j;
+    double rx, ry, rz, value;
+    double weights[8];
+    rx = 1 - x;
+    ry = 1 - y;
+    rz = 1 - z;
+    weights[0] = rx * ry * rz;
+    weights[1] = x * ry * rz;
+    weights[2] = rx * y * rz;
+    weights[3] = x * y * rz;
+    weights[4] = rx * ry * z;
+    weights[5] = x * ry * z;
+    weights[6] = rx * y * z;
+    weights[7] = x * y * z;
+    /* weighted sum of surrounding values */
+	value = 0;
+	for (j = 0; j < 8; j++) {
+	    value += weights[j] * array_values[i * 8 + j];
+	interpolated[i] = value;
+   \brief Converts geographic to relative coordinates
+   Converts geographic to relative coordinates
+   which are needed for trilinear interpolation.
+   \param[out] x,y,z pointer to relative coordinates (0 - 1)
+static void get_relative_coords_for_interp(RASTER3D_Region * region,
+					   const double east,
+					   const double top, double *x,
+					   double *y, double *z)
+    int col, row, depth;
+    double temp;
+    Rast3d_location2coord(region, north, east, top, &col, &row, &depth);
+    /* x */
+    temp = east - region->west - col * region->ew_res;
+    *x = (temp > region->ew_res / 2 ?
+	  temp - region->ew_res / 2 : temp + region->ew_res / 2)
+	/ region->ew_res;
+    /* y */
+    temp = north - region->south - (region->rows - row - 1) * region->ns_res;
+    *y = (temp > region->ns_res / 2 ?
+	  temp - region->ns_res / 2 : temp + region->ns_res / 2)
+	/ region->ns_res;
+    /* z */
+    temp = top - region->bottom - depth * region->tb_res;
+    *z = (temp > region->tb_res / 2 ?
+	  temp - region->tb_res / 2 : temp + region->tb_res / 2)
+	/ region->tb_res;
+   \brief Interpolates velocity at a given point.
+   \param map pointer to array of 3 3D raster maps (velocity field)
+   \param[out] vel_x,vel_y,vel_z interpolated velocity
+   \return 0 success
+int interpolate_velocity(RASTER3D_Region * region, RASTER3D_Map ** map,
+			 const double top, double *vel_x, double *vel_y,
+			 double *vel_z)
+    int i, j;
+    double values[24];		/* 3 x 8, 3 dimensions, 8 neighbors */
+    double value;
+    double interpolated[3];
+    int x[8], y[8], z[8];
+    double rel_x, rel_y, rel_z;
+    int type;
+    /* check if we are out of region, any array should work */
+    if (!Rast3d_is_valid_location(region, north, east, top))
+	return -1;
+    find_nearest_voxels(region, north, east, top, x, y, z);
+    /* get values of the nearest cells */
+	type = Rast3d_tile_type_map(map[i]);
+	    Rast3d_get_value_region(map[i], x[j], y[j], z[j], &value, type);
+	    if (Rast_is_null_value(&value, type))
+		values[i * 8 + j] = 0;
+	    else
+		values[i * 8 + j] = value;
+    /* compute weights */
+    get_relative_coords_for_interp(region, north, east, top,
+                                   &rel_x, &rel_y, &rel_z);
+    trilinear_interpolation(values, rel_x, rel_y, rel_z, interpolated);
+    *vel_x = interpolated[0];
+    *vel_y = interpolated[1];
+    *vel_z = interpolated[2];
+    return 0;
Property changes on: grass-addons/grass7/raster3d/r3.flow/interpolate.c
   + text/x-csrc
   + native
Added: grass-addons/grass7/raster3d/r3.flow/interpolate.h
--- grass-addons/grass7/raster3d/r3.flow/interpolate.h	                        (rev 0)
+++ grass-addons/grass7/raster3d/r3.flow/interpolate.h	2014-07-10 18:51:58 UTC (rev 61235)
@@ -0,0 +1,10 @@
+#ifndef INTERPOLATE_H
+#define INTERPOLATE_H
+int interpolate_velocity(RASTER3D_Region *region, RASTER3D_Map **map,
+			 double *vel_z);
+#endif // INTERPOLATE_H
Property changes on: grass-addons/grass7/raster3d/r3.flow/interpolate.h
   + text/x-chdr
   + native
Added: grass-addons/grass7/raster3d/r3.flow/main.c
--- grass-addons/grass7/raster3d/r3.flow/main.c	                        (rev 0)
+++ grass-addons/grass7/raster3d/r3.flow/main.c	2014-07-10 18:51:58 UTC (rev 61235)
@@ -0,0 +1,316 @@
+ * MODULE:       r3.flow
+ * AUTHOR(S):    Anna Petrasova kratochanna <at> gmail <dot> com
+ * PURPOSE:      Computes 3D flow lines and flow accumulation based on 3D raster map(s)
+ * COPYRIGHT:    (C) 2014 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *               License (>=v2). Read the file COPYING that comes with GRASS
+ *               for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <math.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+static void check_vector_input_maps(struct Option *vector_opt,
+				    struct Option *seed_opt)
+    int i;
+    /* Check for velocity components maps. */
+    if (vector_opt->answers != NULL) {
+	    if (vector_opt->answers[i] != NULL) {
+		if (NULL == G_find_raster3d(vector_opt->answers[i], ""))
+		    Rast3d_fatal_error(_("3D raster map <%s> not found"),
+				       vector_opt->answers[i]);
+	    else {
+		Rast3d_fatal_error(_("Please provide three 3D raster maps"));
+    if (seed_opt->answer != NULL) {
+	if (NULL == G_find_vector2(seed_opt->answer, ""))
+	    G_fatal_error(_("Vector seed map <%s> not found"),
+			  seed_opt->answer);
+static void load_input_velocity_maps(struct Option *vector_opt,
+				     RASTER3D_Region * region)
+    int i;
+	velocity_field[i] =
+	    Rast3d_open_cell_old(vector_opt->answers[i],
+				 G_find_raster3d(vector_opt->answers[i], ""),
+				 region, RASTER3D_TILE_SAME_AS_FILE,
+				 RASTER3D_USE_CACHE_DEFAULT);
+	if (!velocity_field[i])
+	    Rast3d_fatal_error(_("Unable to open 3D raster map <%s>"),
+int main(int argc, char *argv[])
+    struct Option *vector_opt, *seed_opt, *flowlines_opt,
+	*unit_opt, *step_opt, *limit_opt, *skip_opt;
+    struct Flag *up_flag;
+    struct GModule *module;
+    RASTER3D_Region region;
+    RASTER3D_Map *velocity_field[3];
+    struct Integration integration;
+    struct Seed seed;
+    struct Map_info seed_Map;
+    struct line_pnts *seed_points;
+    struct line_cats *seed_cats;
+    struct Map_info fl_map;
+    struct line_cats *fl_cats;	/* for flowlines */
+    struct line_pnts *fl_points;	/* for flowlines */
+    int cat;			/* cat of flowlines */
+    int i, r, c, d;
+    char *desc;
+    int n_seeds, seed_count, ltype;
+    int skip[3];
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    G_add_keyword(_("raster3d"));
+    G_add_keyword(_("voxel"));
+    G_add_keyword(_("flowline"));
+    module->description = _("Compute flow lines.");
+    vector_opt = G_define_standard_option(G_OPT_R3_INPUTS);
+    vector_opt->key = "vector_field";
+    vector_opt->required = YES;
+    vector_opt->description = _("Names of three 3D raster maps describing "
+				"x, y, z components of vector field");
+    seed_opt = G_define_standard_option(G_OPT_V_INPUT);
+    seed_opt->required = NO;
+    seed_opt->key = "seed_points";
+    seed_opt->description = _("If no map is provided, "
+			      "flow lines are generated "
+			      "from each cell of the input 3D raster");
+    seed_opt->label = _("Name of vector map with points "
+			"from which flow lines are generated");
+    flowlines_opt = G_define_standard_option(G_OPT_V_OUTPUT);
+    flowlines_opt->key = "flowline";
+    flowlines_opt->required = YES;
+    flowlines_opt->description = _("Name for vector map of flow lines");
+    unit_opt = G_define_option();
+    unit_opt->key = "unit";
+    unit_opt->type = TYPE_STRING;
+    unit_opt->required = NO;
+    unit_opt->answer = "cell";
+    unit_opt->options = "time,length,cell";
+    desc = NULL;
+    G_asprintf(&desc,
+	       "time;%s;"
+	       "length;%s;"
+	       "cell;%s",
+	       _("elapsed time"),
+	       _("length in map units"), _("length in cells (voxels)"));
+    unit_opt->descriptions = desc;
+    unit_opt->label = _("Unit of integration step");
+    unit_opt->description = _("Default unit is cell");
+    unit_opt->guisection = _("Integration");
+    step_opt = G_define_option();
+    step_opt->key = "step";
+    step_opt->type = TYPE_DOUBLE;
+    step_opt->required = NO;
+    step_opt->answer = "0.25";
+    step_opt->label = _("Integration step in selected unit");
+    step_opt->description = _("Default step is 0.25 cell");
+    step_opt->guisection = _("Integration");
+    limit_opt = G_define_option();
+    limit_opt->key = "limit";
+    limit_opt->type = TYPE_INTEGER;
+    limit_opt->required = NO;
+    limit_opt->answer = "2000";
+    limit_opt->description = _("Maximum number of steps");
+    limit_opt->guisection = _("Integration");
+    skip_opt = G_define_option();
+    skip_opt->key = "skip";
+    skip_opt->type = TYPE_INTEGER;
+    skip_opt->required = NO;
+    skip_opt->multiple = YES;
+    skip_opt->description =
+	_("Number of cells between flow lines in x, y and z direction");
+    up_flag = G_define_flag();
+    up_flag->key = 'u';
+    up_flag->description = _("Compute upstream flowlines "
+			     "instead of default downstream flowlines");
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    check_vector_input_maps(vector_opt, seed_opt);
+    Rast3d_init_defaults();
+    Rast3d_get_window(&region);
+    /* set up integration variables */
+    if (step_opt->answer) {
+	integration.step = atof(step_opt->answer);
+	integration.unit = unit_opt->answer;
+    else {
+	integration.unit = "cell";
+	integration.step = 0.25;
+    integration.limit = atof(limit_opt->answer);
+    integration.direction = up_flag->answer ? 1 : -1;
+    /* cell size is the diagonal */
+    integration.cell_size = sqrt(region.ns_res * region.ns_res +
+				 region.ew_res * region.ew_res +
+				 region.tb_res * region.tb_res);
+    /* set default skip if needed */
+    if (skip_opt->answers) {
+	    if (skip_opt->answers[i] != NULL) {
+		skip[i] = atoi(skip_opt->answers[i]);
+	    else {
+		G_fatal_error
+		    ("Please provide 3 integer values for skip option.");
+    else {
+	skip[0] = fmax(1, region.cols / 10);
+	skip[1] = fmax(1, region.rows / 10);
+	skip[2] = fmax(1, region.depths / 10);
+    /* open raster 3D maps of velocity components */
+    load_input_velocity_maps(vector_opt, velocity_field, &region);
+    /* open new vector map of flowlines */
+    fl_cats = Vect_new_cats_struct();
+    fl_points = Vect_new_line_struct();
+    if (Vect_open_new(&fl_map, flowlines_opt->answer, TRUE) < 0)
+	G_fatal_error(_("Unable to create vector map <%s>"),
+		      flowlines_opt->answer);
+    Vect_hist_command(&fl_map);
+    n_seeds = 0;
+    /* open vector map of seeds */
+    if (seed_opt->answer) {
+	if (Vect_open_old2(&seed_Map, seed_opt->answer, "", "1") < 0)
+	    G_fatal_error(_("Unable to open vector map <%s>"),
+	if (!Vect_is_3d(&seed_Map))
+	    G_fatal_error(_("Vector map <%s> is not 3D"), seed_opt->answer);
+	n_seeds = Vect_get_num_primitives(&seed_Map, GV_POINT);
+    else {
+	n_seeds += ceil(region.cols / (double)skip[0]) *
+	    ceil(region.rows / (double)skip[1]) *
+	    ceil(region.depths / (double)skip[2]);
+    G_debug(1, "Number of seeds is %d", n_seeds);
+    seed_count = 0;
+	seed_points = Vect_new_line_struct();
+	seed_cats = Vect_new_cats_struct();
+	/* compute flowlines from vector seed map */
+	while (TRUE) {
+	    ltype = Vect_read_next_line(&seed_Map, seed_points, seed_cats);
+	    if (ltype == -1) {
+		Vect_close(&seed_Map);
+		G_fatal_error(_("Error during reading seed vector map"));
+	    else if (ltype == -2) {
+		break;
+	    else if (ltype == GV_POINT) {
+		seed.x = seed_points->x[0];
+		seed.y = seed_points->y[0];
+		seed.z = seed_points->z[0];
+		seed.flowline = TRUE;
+		seed.flowaccum = FALSE;
+	    G_percent(seed_count, n_seeds, 1);
+	    cat = seed_count + 1;
+	    compute_flowline(&region, &seed, velocity_field, &integration,
+			     &fl_map, fl_cats, fl_points, cat);
+	    seed_count++;
+	Vect_destroy_line_struct(seed_points);
+	Vect_destroy_cats_struct(seed_cats);
+    else {
+	/* compute flowlines from points on grid */
+	for (r = region.rows; r > 0; r--) {
+	    for (c = 0; c < region.cols; c++) {
+		for (d = 0; d < region.depths; d++) {
+		    seed.x =
+			region.west + c * region.ew_res + region.ew_res / 2;
+		    seed.y =
+			region.south + r * region.ns_res - region.ns_res / 2;
+		    seed.z =
+			region.bottom + d * region.tb_res + region.tb_res / 2;
+		    seed.flowline = FALSE;
+		    if ((c % skip[0] == 0) && (r % skip[1] == 0) &&
+			(d % skip[2] == 0)) {
+					 &integration, &fl_map, fl_cats,
+					 fl_points, cat);
+			seed_count++;
+    Vect_destroy_line_struct(fl_points);
+    Vect_destroy_cats_struct(fl_cats);
+    Vect_build(&fl_map);
+    Vect_close(&fl_map);
+    return EXIT_SUCCESS;
Property changes on: grass-addons/grass7/raster3d/r3.flow/main.c
   + text/x-csrc
   + native
Added: grass-addons/grass7/raster3d/r3.flow/r3.flow.html
--- grass-addons/grass7/raster3d/r3.flow/r3.flow.html	                        (rev 0)
+++ grass-addons/grass7/raster3d/r3.flow/r3.flow.html	2014-07-10 18:51:58 UTC (rev 61235)
@@ -0,0 +1,21 @@
+<h2>DESCRIPTION</h2>
+<em>r3.flow</em>
+<h2>NOTES</h2>
+<h2>EXAMPLES</h2>
+<h2>AUTHORS</h2>
+Anna Petrasova
+<h2>SEE ALSO</h2>
+<em>
+<a href="g.region.html">g.region</a>
+</em>
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/raster3d/r3.flow/r3.flow.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Added: grass-addons/grass7/raster3d/r3.flow/r3flow_structs.h
--- grass-addons/grass7/raster3d/r3.flow/r3flow_structs.h	                        (rev 0)
+++ grass-addons/grass7/raster3d/r3.flow/r3flow_structs.h	2014-07-10 18:51:58 UTC (rev 61235)
@@ -0,0 +1,24 @@
+#ifndef R3FLOW_STRUCTS_H
+#define R3FLOW_STRUCTS_H
+struct Seed
+    double x;
+    double y;
+    double z;
+    int flowline;
+    int flowaccum;
+struct Integration
+    int direction;
+    char *unit;
+    double step;
+    double cell_size;
+    int limit;
+#endif // R3FLOW_STRUCTS_H
Property changes on: grass-addons/grass7/raster3d/r3.flow/r3flow_structs.h
   + text/x-chdr
   + native
