[GRASS-SVN] r61243 - grass/trunk/lib/vector/rtree/test_suite
Sat Jul 12 04:51:49 PDT 2014
Author: huhabla
Date: 2014-07-12 04:51:49 -0700 (Sat, 12 Jul 2014)
New Revision: 61243
Removed:
   grass/trunk/lib/vector/rtree/test_suite/test.gmath.lib.html
   grass/trunk/lib/vector/rtree/test_suite/test_main.c
Fixed wrong description and obsolete options and flags. Removed wrong html description file.
Deleted: grass/trunk/lib/vector/rtree/test_suite/test.gmath.lib.html
--- grass/trunk/lib/vector/rtree/test_suite/test.gmath.lib.html	2014-07-12 11:33:11 UTC (rev 61242)
+++ grass/trunk/lib/vector/rtree/test_suite/test.gmath.lib.html	2014-07-12 11:51:49 UTC (rev 61243)
@@ -1,3 +0,0 @@
-Take a look at the module command line help for more information.
Modified: grass/trunk/lib/vector/rtree/test_suite/test_main.c
--- grass/trunk/lib/vector/rtree/test_suite/test_main.c	2014-07-12 11:33:11 UTC (rev 61242)
+++ grass/trunk/lib/vector/rtree/test_suite/test_main.c	2014-07-12 11:51:49 UTC (rev 61243)
@@ -1,12 +1,12 @@
- * MODULE:       test.gpde.lib
+ * MODULE:       test.rtree.lib
  * AUTHOR(S):    Original author
  *               Soeren Gebbert soerengebbert <at> gmx <dot> de
  * 		05 Sep 2007 Berlin
- * PURPOSE:      Unit and integration tests for the gmath library
+ * PURPOSE:      Unit test for the vector rtree implementation
  * COPYRIGHT:    (C) 2007 by the GRASS Development Team
@@ -23,8 +23,7 @@
 /*- Parameters and global variables -----------------------------------------*/
 typedef struct {
-    struct Option *unit, *integration, *solverbenchmark, *blasbenchmark, *rows;
-    struct Flag *full, *testunit, *testint;
+    struct Option *unit;
 } paramType;
 paramType param; /*Parameters */
@@ -41,13 +40,8 @@
     param.unit->key = "unit";
     param.unit->type = TYPE_STRING;
     param.unit->required = YES;
-    param.unit->options = "basics";
+    param.unit->options = "basic";
     param.unit->description = _("Choose the unit tests to run");
-    param.testunit = G_define_flag();
-    param.testunit->key = 'u';
-    param.testunit->description = _("Run all unit tests");
@@ -64,7 +58,7 @@
     module = G_define_module();
     module->description
-            = _("Performs benchmarks, unit and integration tests for the gmath library");
+            = _("Unit tests for the vector rtree library");
     /* Get parameters from user */
     set_params();
@@ -76,7 +70,7 @@
     i = 0;
     if (param.unit->answers) {
         while (param.unit->answers[i]) {
-            if (strcmp(param.unit->answers[i], "basics") == 0)
+            if (strcmp(param.unit->answers[i], "basic") == 0)
                 returnstat += unit_test_basics();
             i++;
@@ -85,9 +79,9 @@
     if (returnstat != 0)
-        G_warning("Errors detected while testing the gmath lib");
+        G_warning("Errors detected while testing the vector rtree lib");
     else
-        G_message("\n-- gmath lib tests finished successfully --");
+        G_message("\n-- vector rtree lib tests finished successfully --");
     return (returnstat);
