[GRASS-SVN] r61255 - grass/trunk/gui/wxpython/core
svn_grass at osgeo.org
Mon Jul 14 12:03:34 PDT 2014
Author: wenzeslaus
Date: 2014-07-14 12:03:34 -0700 (Mon, 14 Jul 2014)
New Revision: 61255
grass/trunk/gui/wxpython/core/utils.py
wxGUI/core: use gray always, sync purple with lib/gis/color_str.c although it is probably wrong
before: depending on dict ordering gray or grey was used, (un)checking Transparent in GUI caused switching from gray to grey
purple: accoring to Wikipedia it is different from violet and was correctly defined in the GUI before but this was not the same as in library
Modified: grass/trunk/gui/wxpython/core/utils.py
--- grass/trunk/gui/wxpython/core/utils.py 2014-07-14 18:27:46 UTC (rev 61254)
+++ grass/trunk/gui/wxpython/core/utils.py 2014-07-14 19:03:34 UTC (rev 61255)
@@ -945,29 +945,37 @@
# update path
if addonPath not in os.environ['PATH']:
os.environ['PATH'] = addonPath + os.pathsep + os.environ['PATH']
-# From lib/gis/col_str.c, except purple which is mentioned
-# there but not given RGB values
+# predefined colors and their names
+# must be in sync with lib/gis/color_str.c
str2rgb = {'aqua': (100, 128, 255),
'black': (0, 0, 0),
'blue': (0, 0, 255),
'brown': (180, 77, 25),
'cyan': (0, 255, 255),
'gray': (128, 128, 128),
+ 'grey': (128, 128, 128),
'green': (0, 255, 0),
- 'grey': (128, 128, 128),
'indigo': (0, 128, 255),
'magenta': (255, 0, 255),
'orange': (255, 128, 0),
- 'purple': (128, 0, 128),
'red': (255, 0, 0),
'violet': (128, 0, 255),
+ 'purple': (128, 0, 255),
'white': (255, 255, 255),
'yellow': (255, 255, 0)}
rgb2str = {}
-for (s,r) in str2rgb.items():
- rgb2str[ r ] = s
+for (s, r) in str2rgb.items():
+ rgb2str[r] = s
+# ensure that gray value has 'gray' string and not 'grey'
+rgb2str[str2rgb['gray']] = 'gray'
+# purple is defined as nickname for violet in lib/gis
+# (although Wikipedia says that purple is (128, 0, 128))
+# we will prefer the defined color, not nickname
+rgb2str[str2rgb['violet']] = 'violet'
def color_resolve(color):
if len(color) > 0 and color[0] in "0123456789":
rgb = tuple(map(int, color.split(':')))
