[GRASS-SVN] r61274 - grass/trunk/lib/raster3d/test
svn_grass at osgeo.org
Fri Jul 18 01:55:42 PDT 2014
Author: huhabla
Date: 2014-07-18 01:55:42 -0700 (Fri, 18 Jul 2014)
New Revision: 61274
grass/trunk/lib/raster3d/test/test.raster3d.lib.html
grass/trunk/lib/raster3d/test/test_main.c
Fixed manpage keyword parsing bug
Modified: grass/trunk/lib/raster3d/test/test.raster3d.lib.html
--- grass/trunk/lib/raster3d/test/test.raster3d.lib.html 2014-07-18 08:16:19 UTC (rev 61273)
+++ grass/trunk/lib/raster3d/test/test.raster3d.lib.html 2014-07-18 08:55:42 UTC (rev 61274)
@@ -0,0 +1,11 @@
+<h2>DESCRIPTION</h2>
+<em>test.raster3d.lib</em>
+is a module dedicated for testing the raster 3d library functionality and to perform benchmark runs.
+This module is used by the testing framework to perform library tests.
+<h2>AUTHOR</h2>
+Sören Gebbert
Modified: grass/trunk/lib/raster3d/test/test_main.c
--- grass/trunk/lib/raster3d/test/test_main.c 2014-07-18 08:16:19 UTC (rev 61273)
+++ grass/trunk/lib/raster3d/test/test_main.c 2014-07-18 08:55:42 UTC (rev 61274)
@@ -103,7 +103,9 @@
module = G_define_module();
module->description
= "Performs unit and integration tests for the raster3d library";
+ G_add_keyword(_("test"));
/* Get parameters from user */
set_params();
