[GRASS-SVN] r61280 - in grass/trunk/gui: icons/grass wxpython/lmgr
Sat Jul 19 09:58:44 PDT 2014
Author: wenzeslaus
Date: 2014-07-19 09:58:44 -0700 (Sat, 19 Jul 2014)
New Revision: 61280
Added:
   grass/trunk/gui/icons/grass/aspect-arrow.png
   grass/trunk/gui/icons/grass/cell-cats.png
   grass/trunk/gui/icons/grass/his.png
   grass/trunk/gui/icons/grass/label.png
   grass/trunk/gui/icons/grass/raster.png
   grass/trunk/gui/icons/grass/raster3d.png
   grass/trunk/gui/icons/grass/rgb.png
   grass/trunk/gui/icons/grass/shaded-relief.png
   grass/trunk/gui/icons/grass/vector-chart.png
   grass/trunk/gui/icons/grass/vector-thematic.png
   grass/trunk/gui/icons/grass/vector.png
   grass/trunk/gui/icons/grass/wms.png
   grass/trunk/gui/wxpython/lmgr/layertree.py
wxGUI: icons for layers in lmgr tree without 'layer' and 'add' symbols
Size of icons is 16x16 to avoid imperfect resampling at some (or all) platforms.
The motivation is to make the icons more useful, they now can actually help to recognize type of layer.
The commit assumes that the icon objects defined in layertree are used only for layers, not for other things although item label suggests that.
Command and grid layer still use the layer-xxx-add icon because there is no SVG for them in OSGeo icons (trac.osgeo.org/osgeo/browser/graphics/trunk/).
Geodesic and rhumbline layers are already using an icon with this style (the same icon, actually).
Added: grass/trunk/gui/icons/grass/aspect-arrow.png
(Binary files differ)
Property changes on: grass/trunk/gui/icons/grass/aspect-arrow.png
___________________________________________________________________
Added: svn:mime-type
   + image/png
Added: grass/trunk/gui/icons/grass/cell-cats.png
Property changes on: grass/trunk/gui/icons/grass/cell-cats.png
   + image/png
Added: grass/trunk/gui/icons/grass/his.png
Property changes on: grass/trunk/gui/icons/grass/his.png
   + image/png
Added: grass/trunk/gui/icons/grass/label.png
Property changes on: grass/trunk/gui/icons/grass/label.png
   + image/png
Added: grass/trunk/gui/icons/grass/raster.png
Property changes on: grass/trunk/gui/icons/grass/raster.png
   + image/png
Added: grass/trunk/gui/icons/grass/raster3d.png
Property changes on: grass/trunk/gui/icons/grass/raster3d.png
   + image/png
Added: grass/trunk/gui/icons/grass/rgb.png
Property changes on: grass/trunk/gui/icons/grass/rgb.png
   + image/png
Added: grass/trunk/gui/icons/grass/shaded-relief.png
Property changes on: grass/trunk/gui/icons/grass/shaded-relief.png
   + image/png
Added: grass/trunk/gui/icons/grass/vector-chart.png
Property changes on: grass/trunk/gui/icons/grass/vector-chart.png
   + image/png
Added: grass/trunk/gui/icons/grass/vector-thematic.png
Property changes on: grass/trunk/gui/icons/grass/vector-thematic.png
   + image/png
Added: grass/trunk/gui/icons/grass/vector.png
Property changes on: grass/trunk/gui/icons/grass/vector.png
   + image/png
Added: grass/trunk/gui/icons/grass/wms.png
Property changes on: grass/trunk/gui/icons/grass/wms.png
   + image/png
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py	2014-07-19 14:56:40 UTC (rev 61279)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py	2014-07-19 16:58:44 UTC (rev 61280)
@@ -70,23 +70,23 @@
                             label = _('Add command layer')),
     'quit'       : MetaIcon(img = 'quit',
                             label = _('Quit')),
-    'layerRaster'    : MetaIcon(img = 'layer-raster-add',
+    'layerRaster'    : MetaIcon(img = 'raster',
                             label = _('Add raster map layer')),
-    'layerRgb'     : MetaIcon(img = 'layer-rgb-add',
+    'layerRgb'     : MetaIcon(img = 'rgb',
                             label = _('Add RGB map layer')),
-    'layerHis'     : MetaIcon(img = 'layer-his-add',
+    'layerHis'     : MetaIcon(img = 'his',
                                     label = _('Add HIS map layer')),
-    'layerShaded'  : MetaIcon(img = 'layer-shaded-relief-add',
+    'layerShaded'  : MetaIcon(img = 'shaded-relief',
                               label = _('Add shaded relief map layer')),
-    'layerRastarrow'  : MetaIcon(img = 'layer-aspect-arrow-add',
+    'layerRastarrow'  : MetaIcon(img = 'aspect-arrow',
                             label = _('Add raster flow arrows')),
-    'layerRastnum'    : MetaIcon(img = 'layer-cell-cats-add',
+    'layerRastnum'    : MetaIcon(img = 'cell-cats',
                             label = _('Add raster cell numbers')),
-    'layerVector'    : MetaIcon(img = 'layer-vector-add',
+    'layerVector'    : MetaIcon(img = 'vector',
                             label = _('Add vector map layer')),
-    'layerThememap': MetaIcon(img = 'layer-vector-thematic-add',
+    'layerThememap': MetaIcon(img = 'vector-thematic',
                             label = _('Add thematic area (choropleth) map layer')),
-    'layerThemechart'   : MetaIcon(img = 'layer-vector-chart-add',
+    'layerThemechart'   : MetaIcon(img = 'vector-chart',
                             label = _('Add thematic chart layer')),
     'layerGrid'    : MetaIcon(img = 'layer-grid-add',
                             label = _('Add grid layer')),
@@ -94,12 +94,12 @@
                             label = _('Add geodesic line layer')),
     'layerRhumb'   : MetaIcon(img = 'shortest-distance',
                             label = _('Add rhumbline layer')),
-    'layerLabels'  : MetaIcon(img = 'layer-label-add',
+    'layerLabels'  : MetaIcon(img = 'label',
                             label = _('Add labels')),
-    'layer3d-raster'  : MetaIcon(img = 'layer-raster3d-add',
+    'layer3d-raster'  : MetaIcon(img = 'raster3d',
                             label = _('Add 3D raster map layer'),
                             desc  =  _('Note that 3D raster data are rendered only in 3D view mode')),
-    'layerWms'      :  MetaIcon(img = 'layer-wms-add',
+    'layerWms'      :  MetaIcon(img = 'wms',
                             label = _('Add WMS layer.')),
     'layerOptions'  : MetaIcon(img = 'options',
                                label = _('Set options')),
