[GRASS-SVN] r61282 - in grass/trunk: include/defs lib/raster3d lib/raster3d/test
svn_grass at osgeo.org
Sat Jul 19 17:02:05 PDT 2014
Author: huhabla
Date: 2014-07-19 17:02:05 -0700 (Sat, 19 Jul 2014)
New Revision: 61282
grass/trunk/include/defs/raster3d.h
grass/trunk/lib/raster3d/region.c
grass/trunk/lib/raster3d/test/test_coordinate_transform.c
grass/trunk/lib/raster3d/test/test_put_get_value.c
grass/trunk/lib/raster3d/window.c
raster3dlib: Fixed wrong northern coordinates to row conversion resulting from wrong
index scheme for rows in the raster3d library unittest. Updated the tests accordingly.
Added Rast3d_location2coord_double() to receive col,
row and depth indices as double values.
Unfortunately changed the editor that i use the indention and converted
all tabs into spaces at save time. Hence,
the commit contains 95% tab to space conversion noise.
The important changes are in region.c in Rast3d_location2coord()
and in test_coordinate_transform.c and test_put_get_value.c in the test directory.
Modified: grass/trunk/include/defs/raster3d.h
--- grass/trunk/include/defs/raster3d.h 2014-07-19 22:09:49 UTC (rev 61281)
+++ grass/trunk/include/defs/raster3d.h 2014-07-20 00:02:05 UTC (rev 61282)
@@ -125,12 +125,12 @@
int Rast3d_key_get_double(struct Key_Value *, const char *, double *);
int Rast3d_key_get_string(struct Key_Value *, const char *, char **);
int Rast3d_key_get_value(struct Key_Value *, const char *, char *, char *, int,
- int, int *);
+ int, int *);
int Rast3d_key_set_int(struct Key_Value *, const char *, const int *);
int Rast3d_key_set_double(struct Key_Value *, const char *, const double *);
int Rast3d_key_set_string(struct Key_Value *, const char *, char *const *);
int Rast3d_key_set_value(struct Key_Value *, const char *, const char *,
- const char *, int, int, const int *);
+ const char *, int, int, const int *);
/* long.c */
int Rast3d_long_encode(long *, unsigned char *, int);
void Rast3d_long_decode(unsigned char *, long *, int, int);
@@ -183,13 +183,13 @@
/* param.c */
void Rast3d_set_standard3d_input_params(void);
int Rast3d_get_standard3d_params(int *, int *, int *, int *, int *,
- int *, int *, int *, int *, int *);
+ int *, int *, int *, int *, int *);
void Rast3d_set_window_params(void);
char *Rast3d_get_window_params(void);
/* range.c */
void Rast3d_range_update_from_tile(RASTER3D_Map *, const void *, int, int, int, int,
- int, int, int, int);
+ int, int, int, int);
int Rast3d_read_range(const char *, const char *, struct FPRange *);
int Rast3d_range_load(RASTER3D_Map *);
void Rast3d_range_min_max(RASTER3D_Map *, double *, double *);
@@ -208,6 +208,7 @@
int Rast3d_read_region_map(const char *, const char *, RASTER3D_Region *);
int Rast3d_is_valid_location(RASTER3D_Region *, double, double, double);
void Rast3d_location2coord(RASTER3D_Region *, double, double, double, int *, int *, int *);
+void Rast3d_location2coord_double(RASTER3D_Region *, double, double, double, double *, double *, double *);
void Rast3d_location2coord2(RASTER3D_Region *, double, double, double, int *, int *, int *);
void Rast3d_coord2location(RASTER3D_Region *, double, double, double, double *, double *, double *);
/* resample.c */
@@ -219,12 +220,12 @@
/* volume.c */
void Rast3d_get_volume_a(void *, double[2][2][2][3], int, int, int, void *, int);
void Rast3d_get_volume(void *, double, double, double, double, double, double,
- double, double, double, double, double, double, int, int,
- int, void *, int);
+ double, double, double, double, double, double, int, int,
+ int, void *, int);
void Rast3d_get_aligned_volume(void *, double, double, double, double, double,
- double, int, int, int, void *, int);
+ double, int, int, int, void *, int);
void Rast3d_make_aligned_volume_file(void *, const char *, double, double, double,
- double, double, double, int, int, int);
+ double, double, double, int, int, int);
/* window.c */
void Rast3d_get_value(RASTER3D_Map *, int, int, int, void *, int);
float Rast3d_get_float(RASTER3D_Map *, int, int, int);
@@ -244,33 +245,33 @@
/* int Rast3d_writeWindow (RASTER3D_Region *, char *); */
/* getblock.c */
void Rast3d_get_block_nocache(RASTER3D_Map *, int, int, int, int, int, int, void *,
- int);
+ int);
void Rast3d_get_block(RASTER3D_Map *, int, int, int, int, int, int, void *, int);
/* header.c */
int Rast3d_read_header(RASTER3D_Map *, int *, int *, double *, double *, double *,
- double *, double *, double *, int *, int *, int *,
- double *, double *, double *, int *, int *, int *, int *,
- int *, int *, int *, int *, int *, int *, int *, char **, int *, int *);
+ double *, double *, double *, int *, int *, int *,
+ double *, double *, double *, int *, int *, int *, int *,
+ int *, int *, int *, int *, int *, int *, int *, char **, int *, int *);
int Rast3d_write_header(RASTER3D_Map *, int, int, double, double, double, double,
- double, double, int, int, int, double, double, double,
- int, int, int, int, int, int, int, int, int, int, int,
- char *, int, int);
+ double, double, int, int, int, double, double, double,
+ int, int, int, int, int, int, int, int, int, int, int,
+ char *, int, int);
int Rast3d_rewrite_header(RASTER3D_Map * map);
int Rast3d_cache_size_encode(int, int);
int Rast3d__compute_cache_size(RASTER3D_Map *, int);
int Rast3d_fill_header(RASTER3D_Map *, int, int, int, int, int, int, int, int, int,
- int, int, int, int, int, int, int, double, double, double,
- double, double, double, int, int, int, double, double,
- double, char *, int, int);
+ int, int, int, int, int, int, int, double, double, double,
+ double, double, double, int, int, int, double, double,
+ double, char *, int, int);
/* headerinfo.c */
void Rast3d_get_coords_map(RASTER3D_Map *, int *, int *, int *);
void Rast3d_get_coords_map_window(RASTER3D_Map *, int *, int *, int *);
void Rast3d_get_nof_tiles_map(RASTER3D_Map *, int *, int *, int *);
void Rast3d_get_region_map(RASTER3D_Map *, double *, double *, double *, double *,
- double *, double *);
+ double *, double *);
void Rast3d_get_window_map(RASTER3D_Map *, double *, double *, double *, double *,
void Rast3d_get_tile_dimensions_map(RASTER3D_Map *, int *, int *, int *);
int Rast3d_tile_type_map(RASTER3D_Map *);
int Rast3d_file_type_map(RASTER3D_Map *);
@@ -317,13 +318,13 @@
void Rast3d_tile_coord_origin(RASTER3D_Map *, int, int, int, int *, int *, int *);
void Rast3d_tile_index_origin(RASTER3D_Map *, int, int *, int *, int *);
void Rast3d_coord2tile_coord(RASTER3D_Map *, int, int, int, int *, int *, int *, int *,
- int *, int *);
+ int *, int *);
void Rast3d_coord2tile_index(RASTER3D_Map *, int, int, int, int *, int *);
int Rast3d_coord_in_range(RASTER3D_Map *, int, int, int);
int Rast3d_tile_index_in_range(RASTER3D_Map *, int);
int Rast3d_tile_in_range(RASTER3D_Map *, int, int, int);
int Rast3d_compute_clipped_tile_dimensions(RASTER3D_Map *, int, int *, int *, int *,
- int *, int *, int *);
+ int *, int *, int *);
/* tilenull.c */
void Rast3d_set_null_tile_type(RASTER3D_Map *, void *, int);
Modified: grass/trunk/lib/raster3d/region.c
--- grass/trunk/lib/raster3d/region.c 2014-07-19 22:09:49 UTC (rev 61281)
+++ grass/trunk/lib/raster3d/region.c 2014-07-20 00:02:05 UTC (rev 61282)
@@ -10,7 +10,7 @@
- * \brief
+ * \brief
* Returns in <em>region2d</em> the <em>2d</em> portion of <em>region3d</em>.
@@ -37,7 +37,7 @@
- * \brief
+ * \brief
@@ -75,7 +75,7 @@
- * \brief
+ * \brief
* Replaces the <em>2d</em> portion of <em>region3d</em> with the
* values stored in <em>region2d</em>.
@@ -104,7 +104,7 @@
- * \brief
+ * \brief
@@ -140,7 +140,7 @@
- * \brief
+ * \brief
* Computes an adjusts the resolutions in the region structure from the region
* boundaries and number of cells per dimension.
@@ -158,7 +158,7 @@
Rast3d_region_from_to_cell_head(®ion2d, region);
if (region->depths <= 0)
- Rast3d_fatal_error("Rast3d_adjust_region: depths <= 0");
+ Rast3d_fatal_error("Rast3d_adjust_region: depths <= 0");
region->tb_res = (region->top - region->bottom) / region->depths;
@@ -166,7 +166,7 @@
- * \brief
+ * \brief
* Computes an adjusts the number of cells per dimension in the region
* structure from the region boundaries and resolutions.
@@ -184,19 +184,19 @@
if (region->tb_res <= 0)
- Rast3d_fatal_error("Rast3d_adjust_region_res: tb_res <= 0");
+ Rast3d_fatal_error("Rast3d_adjust_region_res: tb_res <= 0");
region->depths = (region->top - region->bottom + region->tb_res / 2.0) /
- region->tb_res;
+ region->tb_res;
if (region->depths == 0)
- region->depths = 1;
+ region->depths = 1;
- * \brief
+ * \brief
* Copies the values of <em>regionSrc</em> into <em>regionDst</em>.
@@ -207,23 +207,23 @@
void Rast3d_region_copy(RASTER3D_Region * regionDest, RASTER3D_Region * regionSrc)
- regionDest->proj = regionSrc->proj;
- regionDest->zone = regionSrc->zone;
+ regionDest->proj = regionSrc->proj;
+ regionDest->zone = regionSrc->zone;
- regionDest->north = regionSrc->north;
- regionDest->south = regionSrc->south;
- regionDest->east = regionSrc->east;
- regionDest->west = regionSrc->west;
- regionDest->top = regionSrc->top;
- regionDest->bottom = regionSrc->bottom;
+ regionDest->north = regionSrc->north;
+ regionDest->south = regionSrc->south;
+ regionDest->east = regionSrc->east;
+ regionDest->west = regionSrc->west;
+ regionDest->top = regionSrc->top;
+ regionDest->bottom = regionSrc->bottom;
- regionDest->rows = regionSrc->rows;
- regionDest->cols = regionSrc->cols;
- regionDest->depths = regionSrc->depths;
+ regionDest->rows = regionSrc->rows;
+ regionDest->cols = regionSrc->cols;
+ regionDest->depths = regionSrc->depths;
- regionDest->ns_res = regionSrc->ns_res;
- regionDest->ew_res = regionSrc->ew_res;
- regionDest->tb_res = regionSrc->tb_res;
+ regionDest->ns_res = regionSrc->ns_res;
+ regionDest->ew_res = regionSrc->ew_res;
+ regionDest->tb_res = regionSrc->tb_res;
@@ -236,11 +236,11 @@
char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
if (G_name_is_fully_qualified(name, xname, xmapset))
- Rast3d_filename(fullName, RASTER3D_HEADER_ELEMENT, xname, xmapset);
+ Rast3d_filename(fullName, RASTER3D_HEADER_ELEMENT, xname, xmapset);
else {
- if (!mapset || !*mapset)
- mapset = G_find_raster3d(name, "");
- Rast3d_filename(fullName, RASTER3D_HEADER_ELEMENT, name, mapset);
+ if (!mapset || !*mapset)
+ mapset = G_find_raster3d(name, "");
+ Rast3d_filename(fullName, RASTER3D_HEADER_ELEMENT, name, mapset);
return Rast3d_read_window(region, fullName);
@@ -249,9 +249,9 @@
- * \brief
+ * \brief
- * Returns 1 if region-coordinates <em>(north, west, bottom)</em> are
+ * Returns 1 if region-coordinates <em>(north, east, top)</em> are
* inside the region of <em>map</em>. Returns 0 otherwise.
* \param REgion
@@ -264,15 +264,15 @@
int Rast3d_is_valid_location(RASTER3D_Region *region, double north, double east, double top)
return ((north >= region->south) && (north <= region->north) &&
- (east >= region->west) && (east <= region->east) &&
- (((top >= region->bottom) && (top <= region->top)) ||
- ((top <= region->bottom) && (top >= region->top))));
+ (east >= region->west) && (east <= region->east) &&
+ (((top >= region->bottom) && (top <= region->top)) ||
+ ((top <= region->bottom) && (top >= region->top))));
- * \brief
+ * \brief
* Converts region-coordinates <em>(north, east,
* top)</em> into cell-coordinates <em>(x, y, z)</em>.
@@ -289,28 +289,51 @@
void
Rast3d_location2coord(RASTER3D_Region *region, double north, double east, double top,
- int *x, int *y, int *z)
+ int *x, int *y, int *z)
double col, row, depth;
- col = (east - region->west) / (region->east -
- region->west) * (double)(region->cols);
- row = (north - region->south) / (region->north -
- region->south) * (double)(region->rows);
- depth = (top - region->bottom) / (region->top -
- region->bottom) * (double)(region->depths);
+ Rast3d_location2coord_double(region, north, east, top, &col, &row, &depth);
*x = (int)col;
- /* Adjust row to start at the northern edge*/
- *y = region->rows - (int)row - 1;
+ *y = (int)row;
*z = (int)depth;
- G_debug(4, "Rast3d_location2coord x %i y %i z %i\n", *x, *y, *z);
+ * \brief
+ * Converts region-coordinates <em>(north, east,
+ * top)</em> into cell-coordinates <em>(x, y, z)</em>.
+ * <b>Note:</b> The results are <i>double</i> numbers. Casting them to
+ * <i>int</i> will give the column, row and depth number.
+ * \param map
+ * \param north
+ * \param east
+ * \param top
+ * \param x
+ * \param y
+ * \param z
+ * \return void
+void
+Rast3d_location2coord_double(RASTER3D_Region *region, double north, double east, double top,
+ double *x, double *y, double *z)
+ double row;
+ *x = (east - region->west) / (region->ew_res);
+ *y = (region->north - north) / (region->ns_res);
+ *z = (top - region->bottom) / (region->tb_res);
+ G_debug(4, "Rast3d_location2coord_double x %f y %f z %f\n", *x, *y, *z);
- * \brief
+ * \brief
@@ -328,37 +351,35 @@
void
Rast3d_location2coord2(RASTER3D_Region *region, double north, double east, double top,
if (!Rast3d_is_valid_location(region, north, east, top))
- Rast3d_fatal_error("Rast3d_location2coord2: location not in region");
+ Rast3d_fatal_error("Rast3d_location2coord2: location not in region");
Rast3d_location2coord(region, north, east, top, x, y, z);
- * \brief
+ * \brief
- * Converts cell-coordinates <em>(x, y, z)</em> into region-coordinates
- * <em>(north, east, top)</em>.
+ * Converts cell-coordinates <em>(x, y, z)</em> into region-coordinates
+ * <em>(north, east, top)</em>.
* * <b>Note:</b> x, y and z is a double:
* - x+0.0 will return the easting for the western edge of the column.
* - x+0.5 will return the easting for the center of the column.
* - x+1.0 will return the easting for the eastern edge of the column.
* - y+0.0 will return the northing for the northern edge of the row.
* - y+0.5 will return the northing for the center of the row.
* - y+1.0 will return the northing for the southern edge of the row.
* - z+0.0 will return the top for the lower edge of the depth.
* - z+0.5 will return the top for the center of the depth.
* - z+1.0 will return the top for the upper edge of the column.
- * <b>Note:</b> The result is a <i>double</i>. Casting it to an
- * <i>int</i> will give the column, row and depth number.
* \param map
* \param x
* \param y
@@ -374,7 +395,7 @@
*north = region->north - y * region->ns_res;
*east = region->west + x * region->ew_res;
- *top = region->bottom + z * region->tb_res;
+ *top = region->bottom + z * region->tb_res;
G_debug(4, "Rast3d_coord2location north %g east %g top %g\n", *north, *east, *top);
Modified: grass/trunk/lib/raster3d/test/test_coordinate_transform.c
--- grass/trunk/lib/raster3d/test/test_coordinate_transform.c 2014-07-19 22:09:49 UTC (rev 61281)
+++ grass/trunk/lib/raster3d/test/test_coordinate_transform.c 2014-07-20 00:02:05 UTC (rev 61282)
@@ -20,9 +20,9 @@
sum += test_region();
if (sum > 0)
- G_warning("\n-- raster3d coordinate transform unit tests failure --");
+ G_warning("\n-- raster3d coordinate transform unit tests failure --");
else
- G_message("\n-- raster3d coordinate transform unit tests finished successfully --");
+ G_message("\n-- raster3d coordinate transform unit tests finished successfully --");
return sum;
@@ -31,19 +31,19 @@
int test_coordinate_transform(void)
- int sum = 0;
+ int sum = 0;
double north, east, top;
int col = 0, row = 0, depth = 0;
RASTER3D_Region region, default_region;
RASTER3D_Map *map = NULL;
/* We need to set up a specific region for the new raster3d map.
* First we safe the default region. */
Rast3d_get_window(&default_region);
Rast3d_region_copy(®ion, &default_region);
region.bottom = 0.0;
region.top = 1000;
region.south = 1000;
@@ -53,100 +53,100 @@
region.rows = 15;
region.cols = 10;
region.depths = 5;
Rast3d_adjust_region(®ion);
map = Rast3d_open_new_opt_tile_size("test_coordinate_transform", RASTER3D_USE_CACHE_XYZ, ®ion, FCELL_TYPE, 32);
/* The window is the same as the map region ... of course */
Rast3d_set_window_map(map, ®ion);
G_message("Test the upper right corner, coordinates must be col = 9, row = 0, depth = 4");
ROWS
- 1000 1500 2000 2500 3000 3500 4000 4500 5000 5500 6500 7000 7500 8000 8500 9000
+ 1000 1500 2000 2500 3000 3500 4000 4500 5000 5500 6000 6500 7000 7500 8000 8500
15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0
COLS
5000 5500 6000 6500 7000 7500 8000 8500 9000 9500 10000
0 1 2 3 4 5 6 7 8 9 10
DEPTHS
0 200 400 600 800 1000
- 0 1 2 3 4 5
+ 0 1 2 3 4 5
north = 8499.9;
east= 9999.9;
top = 999.9;
- Rast3d_location2coord(&(map->region), north, east, top, &col, &row, &depth);
+ Rast3d_location2coord(&(map->region), north, east, top, &col, &row, &depth);
printf("Rast3d_location2coord col %i row %i depth %i\n", col, row, depth);
if(region.cols - 1 != col || 0 != row || region.depths - 1 != depth) {
G_message("Error in Rast3d_location2coord");
sum++;
- G_message("Test the lower left corner, coordinates must be col = 0 row = 14 depth = 0");
+ G_message("Test the lower left corner, coordinates must be col = 0 row = 15 depth = 0");
north = 1000.0;
east= 5000.0;
top = 0.0;
- if(0 != col || 14 != row || 0 != depth) {
+ if(0 != col || 15 != row || 0 != depth) {
sum++;
G_message("Test the center, coordinates must be col = 4 row = 7 depth = 2");
north = 4750.0;
east= 7499.9;
top = 500.0;
if((region.cols - 1)/2 != col || (region.rows - 1)/2 != row || (region.depths - 1)/2 != depth) {
sum++;
G_message("Test the n=3000.1, e=7000.1 and t=800.1, coordinates must be col = 4 row = 10 depth = 4");
north = 3000.1;
east= 7000.1;
top = 800.1;
if(4 != col || map->region.rows - 5 != row || 4 != depth) {
sum++;
G_message("Test the n=2999.9, e=6999.9 and t=799.9, coordinates must be col = 3 row = 11 depth = 3");
north = 2999.9;
east= 6999.9;
top = 799.9;
if(3 != col || map->region.rows - 4 != row || 3 != depth) {
sum++;
Rast3d_close(map);
G_remove("grid3", "test_coordinate_transform");
return sum;
@@ -156,7 +156,7 @@
int sum = 0;
RASTER3D_Region region, new_region;
Rast3d_get_window(®ion);
region.top = 1000;
@@ -170,97 +170,97 @@
region.ew_res = 0;
region.ns_res = 0;
region.tb_res = 0;
/* Test region adjustment */
if(region.ew_res != 500) {
G_message("Error in Rast3d_adjust_region: region.ew_res != 500");
sum++;
if(region.ns_res != 500) {
sum++;
if(region.tb_res != 200) {
sum++;
/* Test the region copy */
Rast3d_region_copy(&new_region, ®ion);
if(region.bottom != new_region.bottom) {
G_message("Error in Rast3d_region_copy: region.bottom != new_region.bottom");
sum++;
if(region.cols != new_region.cols) {
G_message("Error in Rast3d_region_copy: region.cols != new_region.cols");
sum++;
if(region.depths != new_region.depths) {
G_message("Error in Rast3d_region_copy: region.depths != new_region.depths");
sum++;
if(region.east != new_region.east) {
G_message("Error in Rast3d_region_copy: region.east != new_region.east");
sum++;
if(region.ew_res != new_region.ew_res) {
G_message("Error in Rast3d_region_copy: region.ew_res != new_region.ew_res");
sum++;
if(region.north != new_region.north) {
G_message("Error in Rast3d_region_copy: region.north != new_region.north");
sum++;
if(region.ns_res != new_region.ns_res) {
G_message("Error in Rast3d_region_copy: region.ns_res != new_region.ns_res");
sum++;
if(region.proj != new_region.proj) {
G_message("Error in Rast3d_region_copy: region.proj != new_region.proj");
sum++;
if(region.rows != new_region.rows) {
G_message("Error in Rast3d_region_copy: region.rows != new_region.rows");
sum++;
if(region.south != new_region.south) {
G_message("Error in Rast3d_region_copy: region.south != new_region.south");
sum++;
if(region.tb_res != new_region.tb_res) {
G_message("Error in Rast3d_region_copy: region.tb_res != new_region.tb_res");
sum++;
if(region.top != new_region.top) {
G_message("Error in Rast3d_region_copy: region.top != new_region.top");
sum++;
if(region.west != new_region.west) {
G_message("Error in Rast3d_region_copy: region.west != new_region.west");
sum++;
if(region.zone != new_region.zone) {
G_message("Error in Rast3d_region_copy: region.zone != new_region.zone");
sum++;
return sum;
Modified: grass/trunk/lib/raster3d/test/test_put_get_value.c
--- grass/trunk/lib/raster3d/test/test_put_get_value.c 2014-07-19 22:09:49 UTC (rev 61281)
+++ grass/trunk/lib/raster3d/test/test_put_get_value.c 2014-07-20 00:02:05 UTC (rev 61282)
@@ -4,7 +4,7 @@
* MODULE: Grass raster3d Library
* AUTHOR(S): Soeren Gebbert, Braunschweig (GER) Jun 2011
* soerengebbert <at> googlemail <dot> com
* PURPOSE: Unit and Integration tests
* COPYRIGHT: (C) 2000 by the GRASS Development Team
@@ -23,13 +23,13 @@
static int test_put_get_value_fcell(void);
static int test_put_get_value_resampling(void);
static int test_get_value_region(RASTER3D_Map *map, int cols, int rows, int depths);
-static int test_resampling_dcell(RASTER3D_Map *map, double north, double east, double
+static int test_resampling_dcell(RASTER3D_Map *map, double north, double east, double
top, int col, int row, int depth, int fact);
-static int test_resampling_fcell(RASTER3D_Map *map, double north, double east, double
+static int test_resampling_fcell(RASTER3D_Map *map, double north, double east, double
-/* Perform the coordinate transformation tests ******************* */
+/* Perform the put-get value tests ******************************* */
int unit_test_put_get_value()
@@ -43,9 +43,9 @@
if (sum > 0)
- G_warning("\n-- raster3d put/get value unit tests failure --");
+ G_warning("\n-- raster3d put/get value unit tests failure --");
else
- G_message("\n-- raster3d put/get value unit tests finished successfully --");
+ G_message("\n-- raster3d put/get value unit tests finished successfully --");
return sum;
@@ -54,23 +54,23 @@
int test_put_get_value_dcell(void)
- int sum = 0;
+ int sum = 0;
int x, y, z;
DCELL value;
DCELL value_ref;
G_message("Testing DCELL put get value functions");
int col, row, depth;
RASTER3D_Region region;
region.top = 1000;
@@ -80,30 +80,30 @@
region.rows = 15;
region.cols = 10;
region.depths = 5;
map = Rast3d_open_new_opt_tile_size("test_put_get_value_dcell", RASTER3D_USE_CACHE_XY, ®ion, DCELL_TYPE, 32);
ROWS
- 1000 1500 2000 2500 3000 3500 4000 4500 5000 5500 6500 7000 7500 8000 8500 9000 north
+ 1000 1500 2000 2500 3000 3500 4000 4500 5000 5500 6000 6500 7000 7500 8000 8500 north
15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 region
COLS
5000 5500 6000 6500 7000 7500 8000 8500 9000 9500 10000 east
0 1 2 3 4 5 6 7 8 9 10 region
DEPTHS
0 200 400 600 800 1000 top
- 0 1 2 3 4 5 region
+ 0 1 2 3 4 5 region
for(z = 0; z < region.depths; z++) {
for(y = 0; y < region.rows; y++) { /* From the north to the south */
for(x = 0; x < region.cols; x++) {
@@ -119,65 +119,65 @@
Rast3d_close(map);
map = Rast3d_open_cell_old("test_put_get_value_dcell", G_mapset(), ®ion, DCELL_TYPE, RASTER3D_USE_CACHE_XY);
/* Reread the map and compare the expected results */
G_message("Get the value of the upper left corner -> 0");
col = row = depth = 0;
north = region.north - 0.1; /* north would be out of bounds therefor -0.1 */
east = region.west + region.ew_res * col;
top = region.bottom + region.tb_res * depth;
sum += test_resampling_dcell(map, north, east, top, col, row, depth, 1);
G_message("Get the value of x == y == z == 1 -> x + y + z == 3");
col = row = depth = 1;
- north = region.north - region.ns_res * (row + 1);
+ north = region.north - region.ns_res * row;
G_message("Get the value of x == 4 y == 3 z == 2 -> x + y + z = 9");
col = 4;
row = 3;
depth = 2;
G_message("Get the value of x == 9 y == 14 z == 4 -> x + y + z = 27");
col = 9;
row = 14;
depth = 4;
G_message("Get the value of x == 10 y == 15 z == 5 -> x + y + z = NAN");
col = 10;
row = 15;
depth = 5;
Rast3d_get_region_value(map, north, east, top, &value, DCELL_TYPE);
Rast3d_get_value(map, col, row, depth, &value_ref, DCELL_TYPE);
/* Rast3d_get_value_region does not work with coordinates outside the region */
printf("Value %g == %g\n", value, value_ref);
if(value == 0 || value < 0 || value > 0) {
G_message("Error in Rast3d_get_region_value");
sum++;
@@ -186,11 +186,11 @@
G_message("Error in Rast3d_get_value");
sum++;
Rast3d_close(map);
G_remove("grid3", "test_put_get_value_dcell");
return sum;
@@ -198,23 +198,23 @@
- int sum = 0;
+ int sum = 0;
int x, y, z;
FCELL value;
FCELL value_ref;
G_message("Testing FCELL put get value functions");
region.top = 1000;
@@ -224,14 +224,14 @@
region.rows = 15;
region.cols = 10;
region.depths = 5;
map = Rast3d_open_new_opt_tile_size("test_put_get_value_fcell", RASTER3D_USE_CACHE_XY, ®ion, FCELL_TYPE, 32);
@@ -247,63 +247,63 @@
Rast3d_close(map);
map = Rast3d_open_cell_old("test_put_get_value_fcell", G_mapset(), ®ion, DCELL_TYPE, RASTER3D_USE_CACHE_XY);
G_message("Get the value of the lower left corner -> 0");
sum += test_resampling_fcell(map, north, east, top, col, row, depth, 1);
col = 4;
row = 3;
depth = 2;
col = 9;
row = 14;
depth = 4;
col = 10;
row = 15;
depth = 5;
Rast3d_get_region_value(map, north, east, top, &value, FCELL_TYPE);
Rast3d_get_value(map, 10, 15, 5, &value_ref, FCELL_TYPE);
sum++;
@@ -312,11 +312,11 @@
sum++;
Rast3d_close(map);
G_remove("grid3", "test_put_get_value_fcell");
return sum;
@@ -324,23 +324,23 @@
- int sum = 0;
+ int sum = 0;
int x, y, z;
DCELL value;
G_message("Testing put get resample value functions");
RASTER3D_Region window;
region.top = 1000;
@@ -350,32 +350,32 @@
region.rows = 15;
region.cols = 10;
region.depths = 5;
map = Rast3d_open_new_opt_tile_size("test_put_get_value_resample", RASTER3D_USE_CACHE_XY, ®ion, DCELL_TYPE, 32);
ROWS
30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 0 window
COLS
0 2 4 6 8 10 12 14 16 18 20 window
DEPTHS
- 0 2 4 6 8 10 window
+ 0 2 4 6 8 10 window
for(y = 0; y < region.rows; y++) { /* North to south */
@@ -404,56 +404,56 @@
/* The window has the 8x resolution as the map region */
Rast3d_set_window_map(map, &window);
sum += test_resampling_dcell(map, north, east, top, col, row, depth, 2);
G_message("Get the value of x == 7 y == 9 z == 3 -> x + y + z == 19");
col = 7;
row = 9;
depth = 3;
G_message("Get the value of x == 9 y == 14 z == 4 -> x + y + z == 27");
col = 9;
row = 14;
depth = 4;
sum += test_get_value_region(map, region.cols, region.rows, region.depths);
Rast3d_close(map);
G_remove("grid3", "test_put_get_value_resample");
return sum;
@@ -466,13 +466,13 @@
DCELL value_ref;
DCELL value_reg;
DCELL value_win;
Rast3d_get_window_value(map, north, east, top, &value_win, DCELL_TYPE);
Rast3d_get_value(map, col * fact, row * fact, depth * fact, &value_ref, DCELL_TYPE);
Rast3d_get_value_region(map, col, row, depth, &value_reg, DCELL_TYPE);
printf("Value %g == %g == %g == %g\n", value, value_win, value_ref, value_reg);
if(value != col + row + depth) {
sum++;
@@ -489,7 +489,7 @@
G_message("Error in Rast3d_get_value_region");
sum++;
return sum;
@@ -502,13 +502,13 @@
FCELL value_ref;
FCELL value_reg;
FCELL value_win;
Rast3d_get_window_value(map, north, east, top, &value_win, FCELL_TYPE);
Rast3d_get_value(map, col * fact, row * fact, depth * fact, &value_ref, FCELL_TYPE);
Rast3d_get_value_region(map, col, row, depth, &value_reg, FCELL_TYPE);
sum++;
@@ -525,7 +525,7 @@
sum++;
return sum;
@@ -538,14 +538,14 @@
FCELL fvalue2 = 0.0;
DCELL dvalue1 = 0.0;
DCELL dvalue2 = 0.0;
/* Test for correct Null value */
Rast3d_get_value_region(map, -1, -1, -1, &fvalue1, FCELL_TYPE);
Rast3d_get_value_region(map, cols, rows, depths, &fvalue2, FCELL_TYPE);
Rast3d_get_value_region(map, -1, -1, -1, &dvalue1, DCELL_TYPE);
Rast3d_get_value_region(map, cols, rows, depths, &dvalue2, DCELL_TYPE);
printf("Value %g == %g == %g == %g\n", fvalue1, fvalue2, dvalue1, dvalue2);
if(!Rast_is_f_null_value(&fvalue1)) {
sum++;
@@ -562,6 +562,6 @@
sum++;
return sum;
Modified: grass/trunk/lib/raster3d/window.c
--- grass/trunk/lib/raster3d/window.c 2014-07-19 22:09:49 UTC (rev 61281)
+++ grass/trunk/lib/raster3d/window.c 2014-07-20 00:02:05 UTC (rev 61282)
@@ -77,7 +77,7 @@
* \brief
- * Returns 1 if window-coordinates <em>(north, west, bottom)</em> are
+ * Returns 1 if window-coordinates <em>(north, east and top)</em> are
* inside the window of <em>map</em>. Returns 0 otherwise.
* \param map
