[GRASS-SVN] r61298 - grass/branches/develbranch_6/locale/po
svn_grass at osgeo.org
Mon Jul 21 09:00:32 PDT 2014
Author: neteler
Date: 2014-07-21 09:00:31 -0700 (Mon, 21 Jul 2014)
New Revision: 61298
grass/branches/develbranch_6/locale/po/grasslibs_es.po
Javier Garcia Prieto: ES translation cont'ed)
Modified: grass/branches/develbranch_6/locale/po/grasslibs_es.po
--- grass/branches/develbranch_6/locale/po/grasslibs_es.po 2014-07-21 15:59:30 UTC (rev 61297)
+++ grass/branches/develbranch_6/locale/po/grasslibs_es.po 2014-07-21 16:00:31 UTC (rev 61298)
@@ -1,6 +1,6 @@
# translation of grasslibs_es.po to Español
# This file is distributed under the same license as the GRASS package.
-# Copyright (C) 2004,2010 GRASS Development Team
+# Copyright (C) 2004,2014 GRASS Development Team
# el bueno <manzano_jm at yahoo.es>, 2005.
# Luis Izquierdo <luisizq2002 at hotmail.com>, 2005.
@@ -9,21 +9,21 @@
# Roberto Antolin <tolanss at yahoo.es>, 2007.
# Carlos Davila <carluti at users.sourceforge.net>, 2007, 2008
# Joana Palahí/SIGTE-UdG <joana at sigte.udg.edu>, 2011.
-# Javier García Prieto <fjgarciaprieto at hotmail.com>, 2009, 2010, 2013.
+# Javier García Prieto <fjgarciaprieto at hotmail.com>, 2009, 2010, 2013, 2014.
msgid ""
msgstr ""
"Project-Id-Version: grasslibs_es\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2014-03-03 17:34+0100\n"
-"PO-Revision-Date: 2013-03-20 00:13-0600\n"
+"PO-Revision-Date: 2014-07-05 22:15-0600\n"
"Last-Translator: Javier García Prieto <fjgarciaprieto at hotmail.com>\n"
"Language-Team: Español; Castellano <grass-translations at lists.osgeo.org>\n"
"Language: es_ES\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
-"X-Generator: KBabel 1.11.4\n"
+"X-Generator: Poedit 1.5.4\n"
"Plural-Forms: nplurals=2; plural=(n != 1);\n"
#: ../lib/raster/rem_io.c:40
@@ -67,15 +67,12 @@
#: ../lib/raster/io_sock.c:72
#, c-format
msgid "Failed to get socket name for monitor <%s>."
-msgstr ""
-"No se ha podido obtener el nombre de conector (socket) para el monitor <%s>."
+msgstr "No se ha podido obtener el nombre de conector (socket) para el monitor <%s>."
#: ../lib/raster/io_sock.c:81
#, c-format
msgid "No socket to connect to for monitor <%s>."
-msgstr ""
-"No existe un conector (socket) al que pueda conectarse, el cual pertenezca "
-"al monitor <%s>."
+msgstr "No existe un conector (socket) al que pueda conectarse, el cual pertenezca al monitor <%s>."
#: ../lib/raster/io_sock.c:98
msgid "Socket is already in use or not accepting connections."
@@ -112,13 +109,11 @@
#: ../lib/ogsf/gk.c:322
msgid "Need at least 3 keyframes for spline"
-msgstr ""
-"Se necesita un minimo de 3 fotogramas clave (keyframes) para el spline."
+msgstr "Se necesita un minimo de 3 fotogramas clave (keyframes) para el spline."
#: ../lib/ogsf/gk.c:624
msgid "Need at least 2 keyframes for interpolation"
-msgstr ""
-"Son necesarios al menos 2 fotogramas clave (keyframes) para la interpolación."
+msgstr "Son necesarios al menos 2 fotogramas clave (keyframes) para la interpolación."
#: ../lib/ogsf/Gv3.c:57 ../lib/ogsf/Gp3.c:109 ../lib/vector/Vlib/map.c:328
#: ../lib/vector/Vlib/legal_vname.c:118 ../lib/vector/Vlib/legal_vname.c:121
@@ -135,9 +130,7 @@
#: ../lib/ogsf/Gv3.c:249
#, c-format
msgid "No features from vector map <%s> fall within current region"
-msgstr ""
-"No existen elementos pertenecientes al mapa vectorial <%s> que se encuentren "
-"dentro de la región actual."
+msgstr "No existen elementos pertenecientes al mapa vectorial <%s> que se encuentren dentro de la región actual."
#: ../lib/ogsf/Gv3.c:254
#, c-format
@@ -188,9 +181,7 @@
#: ../lib/ogsf/Gp3.c:206
#, c-format
msgid "No points from vector map <%s> fall within current region"
-msgstr ""
-"No hay puntos del mapa vectorial <%s> que se encuentren dentro de la región "
-"actual."
+msgstr "No hay puntos del mapa vectorial <%s> que se encuentren dentro de la región actual."
#: ../lib/ogsf/Gp3.c:211
#, c-format
@@ -199,8 +190,7 @@
#: ../lib/ogsf/trans.c:180
msgid "Out of matrix stack space"
-msgstr ""
-"No se dispone de mas espacio de almacenamiento en la pila de la matriz."
+msgstr "No se dispone de mas espacio de almacenamiento en la pila de la matriz."
#: ../lib/ogsf/trans.c:200
msgid "Tried to pop an empty stack"
@@ -259,9 +249,7 @@
#: ../lib/ogsf/gsd_img_mpeg.c:341
msgid "Unable to deduce output format from file extension: using MPEG"
-msgstr ""
-"No ha sido posible deducir el formato de salida a partir de la extensión del "
-"archivo: Utilizando MPEG."
+msgstr "No ha sido posible deducir el formato de salida a partir de la extensión del archivo: Utilizando MPEG."
#: ../lib/ogsf/gsd_img_mpeg.c:349
@@ -307,13 +295,8 @@
#: ../lib/ogsf/gsd_prim.c:630
#, c-format
-msgid ""
-"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
-"advise GRASS developers of this error"
-msgstr ""
-"gsd_rot(): %c es una especificación no válida de eje. Se ha ignorado la "
-"rotación, por favor notifique a los desarrolladores de GRASS acerca de este "
-"error."
+msgid "gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please advise GRASS developers of this error"
+msgstr "gsd_rot(): %c es una especificación no válida de eje. Se ha ignorado la rotación, por favor notifique a los desarrolladores de GRASS acerca de este error."
#: ../lib/ogsf/GS2.c:1207
#, c-format
@@ -328,16 +311,13 @@
#: ../lib/ogsf/GS2.c:1651
#, c-format
msgid "Raster map <%s> is outside of current region. Load failed."
-msgstr ""
-"La carga del mapa raster <%s> ha fallado, por que este se encuentra fuera de "
-"la región actual."
+msgstr "La carga del mapa raster <%s> ha fallado, por que este se encuentra fuera de la región actual."
#: ../lib/ogsf/GS2.c:1729 ../lib/ogsf/GS2.c:1735 ../lib/ogsf/GS2.c:1743
#: ../lib/ogsf/GS2.c:1752 ../lib/ogsf/GS2.c:1760 ../lib/ogsf/GS2.c:1770
#: ../lib/ogsf/GS2.c:1818
msgid "GS_load_att_map(): Out of memory. Unable to load map"
-msgstr ""
-"GS_load_att_map(): Sin memoria disponible. No es posible cargar el mapa."
+msgstr "GS_load_att_map(): Sin memoria disponible. No es posible cargar el mapa."
#: ../lib/ogsf/GS2.c:1846
msgid "Loading failed"
@@ -367,9 +347,7 @@
#: ../lib/ogsf/Gs3.c:647
#, c-format
msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
-msgstr ""
-"El rango de la tabla de colores no corresponde con los datos (mincol=%d, "
-"maxcol=%d."
+msgstr "El rango de la tabla de colores no corresponde con los datos (mincol=%d, maxcol=%d."
#: ../lib/ogsf/Gs3.c:709 ../lib/ogsf/Gs3.c:781
#, c-format
@@ -378,9 +356,7 @@
#: ../lib/ogsf/Gs3.c:1020
msgid "View not saved by this program,there may be some inconsistancies"
-msgstr ""
-"La vista no ha sido guardada por este programa, pueden existir algunas "
-"inconsistencias."
+msgstr "La vista no ha sido guardada por este programa, pueden existir algunas inconsistencias."
#: ../lib/ogsf/gs_bm.c:124
msgid "Bitmap mismatch"
@@ -388,9 +364,7 @@
#: ../lib/ogsf/gsd_surf.c:1742
msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
-msgstr ""
-"Error de concordancia de los puntos de corte del plano entre superficies. "
-"Revise la(s) resolucion(es)."
+msgstr "Error de concordancia de los puntos de corte del plano entre superficies. Revise la(s) resolucion(es)."
#: ../lib/ogsf/gsd_legend.c:245
@@ -402,7 +376,7 @@
#: ../lib/ogsf/gsd_legend.c:251
#, c-format
msgid "Unable to read category file of raster map <%s>"
-msgstr "No ha sido posible leer el archivo de categoría del mapa raster <%s>."
+msgstr "No ha sido posible leer el archivo de categorías del mapa raster <%s>."
#: ../lib/ogsf/gsd_legend.c:268
#, c-format
@@ -419,14 +393,12 @@
msgstr "Error en el rango requerido para la leyenda."
#: ../lib/ogsf/gsd_legend.c:384
-#, fuzzy
msgid "Unable to show discrete FP range (use list)"
-msgstr "No ha sido posible el mostrar el rango discreto FP (utilice list"
+msgstr "No ha sido posible el mostrar el rango discreto FP (utilice list)"
#: ../lib/ogsf/gsd_legend.c:500
msgid "Too many categories to show as discrete!"
-msgstr ""
-"¡Hay demasiadas categorías para que sea posible mostrarlas como discretas!"
+msgstr "¡Hay demasiadas categorías para que sea posible mostrarlas como discretas!"
#: ../lib/ogsf/gsd_legend.c:502
msgid "Try using smaller font!"
@@ -601,8 +573,7 @@
"-- math tool unit tests finished successfully --"
msgstr ""
"\n"
-"-- Las pruebas de la unidad de herramientas matemáticas han finalizado con "
-"exito. --"
+"-- Las pruebas de la unidad de herramientas matemáticas han finalizado con exito. --"
#: ../lib/gpde/test/test_assemble.c:42
msgid ""
@@ -666,8 +637,7 @@
"-- heat flow integration tests finished successfully --"
msgstr ""
"\n"
-"-- Las pruebas de integración de flujo de calor han finalizado exitosamente. "
+"-- Las pruebas de integración de flujo de calor han finalizado exitosamente. --"
#: ../lib/gpde/test/test_geom.c:36
msgid ""
@@ -731,8 +701,7 @@
"++ Running solute_transport integration tests ++"
msgstr ""
"\n"
-"++ Ejecutando las pruebas de integración de transporte de solutos "
-"(solute_transport). ++"
+"++ Ejecutando las pruebas de integración de transporte de solutos (solute_transport). ++"
#: ../lib/gpde/test/test_solute_transport.c:45
msgid "\t 1. testing 2d solute_transport"
@@ -748,8 +717,7 @@
"-- solute_transport integration tests failure --"
msgstr ""
"\n"
-"-- Las pruebas de integración de transporte de solutos (solute_transport) "
-"han fallado. --"
+"-- Las pruebas de integración de transporte de solutos (solute_transport) han fallado. --"
#: ../lib/gpde/test/test_solute_transport.c:55
msgid ""
@@ -757,8 +725,7 @@
"-- solute_transport integration tests finished successfully --"
msgstr ""
"\n"
-"han finalizado exitosamente. --"
+"-- Las pruebas de integración de transporte de solutos (solute_transport) han finalizado exitosamente. --"
#: ../lib/gpde/test/test_les.c:35
@@ -796,38 +763,24 @@
msgstr "\t * Probando la creación les en serie.\n"
#: ../lib/gpde/N_parse_options.c:59
-msgid ""
-"The type of solver which should solve the symmetric linear equation system"
-msgstr ""
-"El tipo de programa de solución que debería resolver el sistema de "
-"ecuaciones lineales simétricas."
+msgid "The type of solver which should solve the symmetric linear equation system"
+msgstr "El tipo de programa de solución que debería resolver el sistema de ecuaciones lineales simétricas."
#: ../lib/gpde/N_parse_options.c:71
msgid "The type of solver which should solve the linear equation system"
-msgstr ""
-"ecuaciones lineales."
+msgstr "El tipo de programa de solución que debería resolver el sistema de ecuaciones lineales."
#: ../lib/gpde/N_parse_options.c:80
msgid "Maximum number of iteration used to solver the linear equation system"
-msgstr ""
-"Número máximo de iteraciones usado para resolver el sistema de ecuaciones "
-"lineales."
+msgstr "Número máximo de iteraciones usado para resolver el sistema de ecuaciones lineales."
#: ../lib/gpde/N_parse_options.c:89
-msgid ""
-"Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
-msgstr ""
-"Criterios de detención (Break) erróneos para programas de solución "
-"iterativos (Jacobi, sor, cg o bicgstab)."
+msgid "Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
+msgstr "Criterios de detención (Break) erróneos para programas de solución iterativos (Jacobi, sor, cg o bicgstab)."
#: ../lib/gpde/N_parse_options.c:98
-msgid ""
-"The relaxation parameter used by the jacobi and sor solver for speedup or "
-"stabilizing"
-msgstr ""
-"El parámetro de relajación utilizado por los programas solucionadores de "
-"Jacobi y Sor para la estabilización o aumento de velocidad."
+msgid "The relaxation parameter used by the jacobi and sor solver for speedup or stabilizing"
+msgstr "El parámetro de relajación utilizado por los programas solucionadores de Jacobi y Sor para la estabilización o aumento de velocidad."
#: ../lib/gpde/N_parse_options.c:106
msgid "The calculation time in seconds"
@@ -840,8 +793,7 @@
#: ../lib/proj/get_proj.c:230
msgid "Unable to initialise PROJ.4 with the following parameter list:"
-msgstr ""
-"No es posible inicializar PROJ 4 con la lista de parámetros siguientes."
+msgstr "No es posible inicializar PROJ 4 con la lista de parámetros siguientes."
#: ../lib/proj/get_proj.c:238
#, c-format
@@ -900,8 +852,7 @@
#: ../lib/proj/ellipse.c:98
msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
-msgstr ""
-"No hay un descriptor secundario del elipsoide (rf, es o b) en el archivo."
+msgstr "No hay un descriptor secundario del elipsoide (rf, es o b) en el archivo."
#: ../lib/proj/ellipse.c:102
msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
@@ -924,8 +875,7 @@
#: ../lib/proj/ellipse.c:269 ../lib/gis/get_ellipse.c:336
#, c-format
msgid "Lines%s of ellipsoid table file <%s> are invalid"
-msgstr ""
-"No son válidas las líneas %s del archivo de la tabla de elipsoides <%s>."
+msgstr "No son válidas las líneas %s del archivo de la tabla de elipsoides <%s>."
#: ../lib/proj/convert.c:110
msgid "Unable parse GRASS PROJ_INFO file"
@@ -933,53 +883,36 @@
#: ../lib/proj/convert.c:115
msgid "Unable get PROJ.4-style parameter string"
-msgstr ""
-"No es posible obtener la cadena de texto con los parámetros de estilo PROJ 4."
+msgstr "No es posible obtener la cadena de texto con los parámetros de estilo PROJ 4."
#: ../lib/proj/convert.c:127
#, c-format
-msgid ""
-"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
-msgstr ""
-"OGR no puede analizar la cadena de texto con los parámetros de estilo PROJ 4 "
-"%s. (El código de error OGR fue %d)."
+msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+msgstr "OGR no puede analizar la cadena de texto con los parámetros de estilo PROJ 4 %s. (El código de error OGR fue %d)."
#: ../lib/proj/convert.c:133
#, c-format
msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
-msgstr ""
-"OGR no puede obtener la cadena de texto con los parámetros de estilo WKT. "
-"(el código de error OGR fue %d)."
+msgstr "OGR no puede obtener la cadena de texto con los parámetros de estilo WKT. (el código de error OGR fue %d)."
#: ../lib/proj/convert.c:390
msgid "No projection name! Projection parameters likely to be meaningless."
-msgstr ""
-"¡Sin nombre de proyección! Es probable que los parámetros de la proyección "
-"puedan carecer de significado."
+msgstr "¡Sin nombre de proyección! Es probable que los parámetros de la proyección puedan carecer de significado."
#: ../lib/proj/convert.c:426
#, c-format
msgid "Datum <%s> not recognised by GRASS and no parameters found"
-msgstr ""
-"El datum <%s> no es reconocido por GRASS y no se han encontrado parámetros."
+msgstr "El datum <%s> no es reconocido por GRASS y no se han encontrado parámetros."
#: ../lib/proj/convert.c:442
#, c-format
-msgid ""
-"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
-"want to look into this."
-msgstr ""
-"El datum <%s> aparentemente es reconocido por GRASS pero no se han "
-"encontrado parámetros. Quiza usted quiera revisar esto."
+msgid "Datum <%s> apparently recognised by GRASS but no parameters found. You may want to look into this."
+msgstr "El datum <%s> aparentemente es reconocido por GRASS pero no se han encontrado parámetros. Quiza usted quiera revisar esto."
#: ../lib/proj/convert.c:446
#, c-format
-msgid ""
-"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
-"transform parameters unspecified."
-msgstr ""
-"Número de transformación inválido %d, el rángo válido es desde 1 hasta %d. "
-"Se dejan los parámetros de transformación del datum sin especificar."
+msgid "Invalid transformation number %d; valid range is 1 to %d. Leaving datum transform parameters unspecified."
+msgstr "Número de transformación inválido %d, el rángo válido es desde 1 hasta %d. Se dejan los parámetros de transformación del datum sin especificar."
#: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
#, c-format
@@ -1044,7 +977,7 @@
#: ../lib/sites/sites.c:136
msgid "Category must be integer"
-msgstr "La categoría debe ser un número entero."
+msgstr "La categoría debe ser de tipo entero."
#: ../lib/sites/sites.c:210
msgid "Memory error in writing timestamp"
@@ -1059,13 +992,8 @@
msgstr "Error de memoria en la asignación de fecha y hora."
#: ../lib/sites/sites.c:348 ../lib/sites/sites.c:478
-msgid ""
-"Dev note: Adapted sites library used for vector points. (module should be "
-"updated to GRASS 6 vector library)"
-msgstr ""
-"Nota del Des: Para los puntos vectoriales, se ha utilizado una librería de "
-"sitios adaptada. (El módulo debería ser actualizado a la librería de "
-"vectores de GRASS 6)."
+msgid "Dev note: Adapted sites library used for vector points. (module should be updated to GRASS 6 vector library)"
+msgstr "Nota del Des: Para los puntos vectoriales, se ha utilizado una librería de sitios adaptada. (El módulo debería ser actualizado a la librería de vectores de GRASS 6)."
#: ../lib/sites/sites.c:372 ../lib/db/dbmi_client/copy_tab.c:105
#: ../lib/db/dbmi_client/copy_tab.c:126 ../lib/db/dbmi_client/db.c:46
@@ -1076,19 +1004,17 @@
#: ../lib/vector/Vlib/net.c:356
#, c-format
msgid "Unable to open database <%s> by driver <%s>"
-msgstr ""
-"No ha sido posible abrir la base de datos <%s> con el controlador <%s>."
+msgstr "No ha sido posible abrir la base de datos <%s> con el controlador <%s>."
#: ../lib/sites/sites.c:381 ../lib/db/dbmi_client/table.c:110
#: ../lib/db/dbmi_client/copy_tab.c:199 ../lib/db/dbmi_client/copy_tab.c:276
#, c-format
msgid "Unable to open select cursor: '%s'"
-msgstr ""
-"No ha sido posible abrir el cursor resultado de la instrucción select:'%s'."
+msgstr "No ha sido posible abrir el cursor resultado de la instrucción select:'%s'."
#: ../lib/sites/sites.c:397
msgid "Cannot fetch row"
-msgstr "No se puede buscar la fila."
+msgstr "No se puede recuperar la fila."
#: ../lib/sites/sites.c:579
msgid "G_oldsite_new_struct: invalid # dims or fields"
@@ -1106,25 +1032,21 @@
#: ../lib/db/dbmi_base/legal_dbname.c:25
#, c-format
msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'.\n"
-msgstr ""
-"Nombre de tabla de mapa <%s> no admitido. No puede contener '.' o 'NULO'.\n"
+msgstr "Nombre de tabla de mapa <%s> no admitido. No puede contener '.' o 'NULO'.\n"
#: ../lib/db/dbmi_base/legal_dbname.c:33
#, c-format
msgid "Illegal table map name <%s>. Must start with a letter.\n"
-msgstr ""
-"Nombre de tabla de mapa <%s> no admitido. Debe empezar con una letra.\n"
+msgstr "Nombre de tabla de mapa <%s> no admitido. Debe empezar con una letra.\n"
#: ../lib/db/dbmi_base/legal_dbname.c:43
#, c-format
msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
-msgstr ""
-"Nombre no admitido de tabla de mapa <%s>. El uso del caractér <%c> no está "
-"permitido.\n"
+msgstr "Nombre tabla de mapa no admitido <%s>. El uso del caractér <%c> no está permitido.\n"
#: ../lib/db/dbmi_base/login.c:98
msgid "Login file corrupted"
-msgstr "Archivo de registro de ingreso corrompido."
+msgstr "Archivo de registro de ingreso se ha corrompido."
#: ../lib/db/dbmi_base/default_name.c:127
msgid "Programmer error"
@@ -1144,7 +1066,7 @@
#: ../lib/db/dbmi_client/copy_tab.c:144
#, c-format
msgid "Unable to get list tables in database <%s>"
-msgstr "No se puede recuperar la lista de tablas de la base de datos <%s>."
+msgstr "No se pueden recuperar las tablas de lista de la base de datos <%s>."
#: ../lib/db/dbmi_client/copy_tab.c:157
#, c-format
@@ -1198,7 +1120,7 @@
#: ../lib/db/dbmi_client/select.c:333
msgid "Key column type is not integer"
-msgstr "El tipo de la columna clave no es un entero."
+msgstr "El tipo de la columna clave no es entero."
#: ../lib/db/dbmi_client/delete_tab.c:53
#, c-format
@@ -1216,16 +1138,12 @@
#: ../lib/init/lock.c:42
msgid "Concurrent mapset locking is not supported on Windows"
-msgstr ""
-"El bloqueo concurrente del directorio de mapas de usuario (Mapset) no está "
-"soportado en Windows."
+msgstr "El bloqueo concurrente del directorio de mapas de usuario (Mapset) no está soportado en Windows."
#: ../lib/init/lock.c:60
#, c-format
msgid "Unable to write lockfile %s (disk full? Permissions?)"
-msgstr ""
-"No ha sido posible escribir el archivo de bloqueo %s (¿El disco está lleno?, "
-"¿Tiene los permisos de usuario necesarios?)."
+msgstr "No ha sido posible escribir el archivo de bloqueo %s (¿El disco está lleno?, ¿Tiene los permisos de usuario necesarios?)."
#: ../lib/display/tran_colr.c:129 ../lib/display/tran_colr.c:131
#, c-format
@@ -1239,11 +1157,8 @@
#: ../lib/symbol/read.c:259
#, c-format
-msgid ""
-"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
-msgstr ""
-"Nombre de símbolo incorrecto: '%s' (Debería ser: grupo / nombre o grupo / "
-"nombre at mapset)"
+msgid "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgstr "Nombre de símbolo incorrecto: '%s' (Debería ser: grupo / nombre o grupo / nombre at mapset)"
#: ../lib/symbol/read.c:283
#, c-format
@@ -1264,9 +1179,7 @@
#: ../lib/driver/parse_ftcap.c:32
#, c-format
msgid "%s: Unable to read font definition file; use the default"
-msgstr ""
-"No es posible leer el archivo de definición del tipo de letra %s; Se "
-"utilizará la opción predeterminada."
+msgstr "No es posible leer el archivo de definición del tipo de letra %s; Se utilizará la opción predeterminada."
#: ../lib/driver/parse_ftcap.c:38
#, c-format
@@ -1386,9 +1299,7 @@
#: ../lib/gmath/la.c:538
msgid "Procedure not yet available for selected matrix type"
-msgstr ""
-"El procedimiento todavía no se encuentra disponible para el tipo "
-"seleccionado de matriz."
+msgstr "El procedimiento todavía no se encuentra disponible para el tipo seleccionado de matriz."
#: ../lib/gmath/la.c:572
msgid "Matrix is not square. Cannot determine inverse"
@@ -1412,13 +1323,11 @@
#: ../lib/gmath/la.c:692
msgid "Specified element is outside array bounds"
-msgstr ""
-"El elemento especificado se encuentra fuera de las fronteras del arreglo."
+msgstr "El elemento especificado se encuentra fuera de las fronteras del arreglo."
#: ../lib/gmath/la.c:746
msgid "Specified matrix column index is outside range"
-msgstr ""
-"El índice de columna de la matriz especificado se encuentra fuera de rango."
+msgstr "El índice de columna de la matriz especificado se encuentra fuera de rango."
#: ../lib/gmath/la.c:751 ../lib/gmath/la.c:792 ../lib/gmath/la.c:1105
#: ../lib/gmath/la.c:1157 ../lib/gmath/la.c:1232
@@ -1660,7 +1569,7 @@
"++ Running solver unit tests ++"
msgstr ""
"\n"
-"++ Ejecutando las pruebas de la unidad solucionadora ++"
+"++ Ejecutando las pruebas de la unidad de resolución ++"
#: ../lib/gmath/test/test_solvers.c:42
msgid ""
@@ -1737,9 +1646,7 @@
#: ../lib/g3d/g3dhistory.c:42 ../lib/gis/history.c:132
#, c-format
msgid "can't get history information for [%s] in mapset [%s]"
-msgstr ""
-"No se puede obtener la información del historial para [%s] en el directorio "
-"de mapas de usuario (mapset) [%s]."
+msgstr "No se puede obtener la información del historial para [%s] en el directorio de mapas de usuario (mapset) [%s]."
#: ../lib/g3d/g3dopen.c:20
msgid "G3d_openCellOldNoHeader: error in G3d_maskOpenOld"
@@ -1767,8 +1674,7 @@
#: ../lib/g3d/g3dopen.c:124
msgid "G3d_openCellOld: projection does not match window projection"
-msgstr ""
-"G3d_openCellOld: La proyección no coincide con la proyección de la ventana."
+msgstr "G3d_openCellOld: La proyección no coincide con la proyección de la ventana."
#: ../lib/g3d/g3dopen.c:128
msgid "G3d_openCellOld: zone does not match window zone"
@@ -1816,9 +1722,7 @@
#: ../lib/g3d/g3dparam.c:61
msgid "Precision used in the output file (default, max, or 0 to 52)"
-msgstr ""
-"Precisión utilizada en el archivo de salida (Se ha preestablecido la máxima, "
-"o elija de 0 a 52)."
+msgstr "Precisión utilizada en el archivo de salida (Se ha preestablecido la máxima, o elija de 0 a 52)."
#: ../lib/g3d/g3dparam.c:71
msgid "The compression method used in the output file"
@@ -1943,8 +1847,7 @@
#: ../lib/gis/put_title.c:29
#, c-format
msgid "category information for [%s] in [%s] missing or invalid"
-msgstr ""
-"La información de categoría para [%s] en [%s] no se encuentra o no es válida."
+msgstr "La información de categoría para [%s] en [%s] no se encuentra o no es válida."
#: ../lib/gis/put_title.c:39
#, c-format
@@ -1969,9 +1872,7 @@
#: ../lib/gis/get_row.c:46 ../lib/gis/get_row.c:1049
#, c-format
msgid "Reading raster map <%s@%s> request for row %d is outside region"
-msgstr ""
-"Leyendo el mapa raster <%s@%s> la solicitud para la fila %d está fuera de la "
-"región."
+msgstr "Leyendo el mapa raster <%s@%s> la solicitud para la fila %d está fuera de la región."
#: ../lib/gis/get_row.c:324
#, c-format
@@ -2003,12 +1904,8 @@
msgstr "No se puede reasignar la memoria intermedia (buffer)."
#: ../lib/gis/gisinit.c:54 ../lib/gis/gisinit.c:90
-msgid ""
-"Incompatible library version for module. You need to rebuild GRASS or "
-"untangle multiple installations."
-msgstr ""
-"Es necesario reconstruir GRASS o desenmarañar varias instalaciones. La "
-"versión de la biblioteca no es compatible con el módulo."
+msgid "Incompatible library version for module. You need to rebuild GRASS or untangle multiple installations."
+msgstr "Es necesario reconstruir GRASS o desenmarañar varias instalaciones. La versión de la biblioteca no es compatible con el módulo."
#: ../lib/gis/gisinit.c:63
#, c-format
@@ -2016,28 +1913,23 @@
msgstr "Permiso denegado - Directorio de mapas de usuario (mapset) %s "
#: ../lib/gis/gisinit.c:66
-#, fuzzy, c-format
+#, c-format
msgid "MAPSET %s not found at %s"
-msgstr "No se ha encontrado el directorio de mapas de usuario (mapset) %s "
+msgstr "No se ha encontrado el directorio de mapas de usuario (mapset) %s en %s."
#: ../lib/gis/gisinit.c:110
msgid "System not initialized. Programmer forgot to call G_gisinit()."
-msgstr ""
-"El sistema no ha sido inicializado. EL programador olvidó llamar G_gisinit()."
+msgstr "El sistema no ha sido inicializado. EL programador olvidó llamar G_gisinit()."
#: ../lib/gis/mapset_msc.c:60
#, c-format
msgid "Unable to make mapset element %s (%s): %s"
-msgstr ""
-"No se puede generar el elemento del directorio de mapas de usuario (mapset) "
-"%s (%s): %s."
+msgstr "No se puede generar el elemento del directorio de mapas de usuario (mapset) %s (%s): %s."
#: ../lib/gis/mapset_msc.c:64
#, c-format
msgid "Unable to access mapset element %s (%s): %s"
-msgstr ""
-"No es posible accesar el elemento del directorio de mapas (mapset) %s (%s): "
-"%s"
+msgstr "No es posible accesar el elemento del directorio de mapas (mapset) %s (%s): %s"
#: ../lib/gis/reclass.c:145
#, c-format
@@ -2047,9 +1939,7 @@
#: ../lib/gis/reclass.c:148
#, c-format
msgid "Illegal reclass format in header file for [%s in %s]"
-msgstr ""
-"Formato no válido de reclasificación en el archivo de encabezado para [%s en "
-"%s]."
+msgstr "Formato no válido de reclasificación en el archivo de encabezado para [%s en %s]."
#: ../lib/gis/reclass.c:238
msgid "Illegal reclass request"
@@ -2185,22 +2075,17 @@
#: ../lib/gis/cats.c:381
#, c-format
msgid "category support for [%s] in mapset [%s] %s"
-msgstr ""
-"Soporte de categoría para [%s] en el directorio de mapas (mapset) [%s] %s."
+msgstr "Soporte de categoría para [%s] en el directorio de mapas (mapset) [%s] %s."
#: ../lib/gis/cats.c:417
#, c-format
msgid "category support for vector map [%s] in mapset [%s] %s"
-msgstr ""
-"Soporte de categoría para el mapa vectorial [%s] en el conjunto de mapas de "
-"usuario (mapset) [%s] %s."
+msgstr "Soporte de categoría para el mapa vectorial [%s] en el conjunto de mapas de usuario (mapset) [%s] %s."
#: ../lib/gis/quant_rw.c:206
#, c-format
msgid "Cannot write quant rules: map %s is integer"
-msgstr ""
-"No se pueden escribir las reglas quant: Los valores del mapa %s son de tipo "
-"entero."
+msgstr "No se pueden escribir las reglas quant: Los valores del mapa %s son de tipo entero."
#: ../lib/gis/quant_rw.c:215
#, c-format
@@ -2209,8 +2094,7 @@
#: ../lib/gis/unix_socks.c:102
msgid "Unable to get GIS_LOCK environment variable value"
-msgstr ""
-"No ha sido posible recuperar el valor de la variable de entorno GIS_LOCK."
+msgstr "No ha sido posible recuperar el valor de la variable de entorno GIS_LOCK."
#: ../lib/gis/adj_cellhd.c:47 ../lib/gis/adj_cellhd.c:199
msgid "Illegal n-s resolution value"
@@ -2231,9 +2115,7 @@
#: ../lib/gis/adj_cellhd.c:79 ../lib/gis/adj_cellhd.c:247
#, c-format
msgid "Fixing subtle input data rounding error of north boundary (%g>%g)"
-msgstr ""
-"Corrigiendo un error sutil de redondeo en los datos de entrada del límite "
-"norte (%g>%g)."
+msgstr "Corrigiendo un error sutil de redondeo en los datos de entrada del límite norte (%g>%g)."
#: ../lib/gis/adj_cellhd.c:84 ../lib/gis/adj_cellhd.c:252
msgid "Illegal latitude for North"
@@ -2242,9 +2124,7 @@
#: ../lib/gis/adj_cellhd.c:90 ../lib/gis/adj_cellhd.c:258
#, c-format
msgid "Fixing subtle input data rounding error of south boundary (%g>%g)"
-msgstr ""
-"sur (%g>%g)."
+msgstr "Corrigiendo un error sutil de redondeo en los datos de entrada del límite sur (%g>%g)."
#: ../lib/gis/adj_cellhd.c:95 ../lib/gis/adj_cellhd.c:263
msgid "Illegal latitude for South"
@@ -2253,16 +2133,12 @@
#: ../lib/gis/adj_cellhd.c:107 ../lib/gis/adj_cellhd.c:275
#, c-format
msgid "Fixing subtle input data rounding error of west boundary (%g>%g)"
-msgstr ""
-"oeste (%g>%g)."
+msgstr "Corrigiendo un error sutil de redondeo en los datos de entrada del límite oeste (%g>%g)."
#: ../lib/gis/adj_cellhd.c:118 ../lib/gis/adj_cellhd.c:286
#, c-format
msgid "Fixing subtle input data rounding error of east boundary (%g>%g)"
-msgstr ""
-"este (%g>%g)."
+msgstr "Corrigiendo un error sutil de redondeo en los datos de entrada del límite este (%g>%g)."
#: ../lib/gis/adj_cellhd.c:131 ../lib/gis/adj_cellhd.c:299
msgid "North must be north of South"
@@ -2270,15 +2146,11 @@
#: ../lib/gis/adj_cellhd.c:133 ../lib/gis/adj_cellhd.c:301
msgid "North must be larger than South"
-msgstr ""
-"El valor de la coordenada Norte debe ser mayor que el valor de la coordenada "
-"Sur."
+msgstr "El valor de la coordenada Norte debe ser mayor que el valor de la coordenada Sur."
#: ../lib/gis/adj_cellhd.c:136 ../lib/gis/adj_cellhd.c:304
msgid "East must be larger than West"
-msgstr ""
-"El valor de la coordenada Este debe ser mayor que el valor de la coordenada "
-"Oeste."
+msgstr "El valor de la coordenada Este debe ser mayor que el valor de la coordenada Oeste."
#: ../lib/gis/adj_cellhd.c:155 ../lib/gis/adj_cellhd.c:348
msgid "Invalid coordinates"
@@ -2313,12 +2185,8 @@
msgstr "El valor atribuido a la cima debe ser superior que el del fondo."
#: ../lib/gis/set_window.c:76
-msgid ""
-"G_set_window(): projection/zone differs from that of currently open raster "
-"maps"
-msgstr ""
-"G_set_window(): La proyección o zona difiere de aquella de los mapas raster "
-"abiertos actualmente."
+msgid "G_set_window(): projection/zone differs from that of currently open raster maps"
+msgstr "G_set_window(): La proyección o zona difiere de aquella de los mapas raster abiertos actualmente."
#: ../lib/gis/home.c:39
msgid "unable to determine user's home directory"
@@ -2354,17 +2222,12 @@
#: ../lib/gis/view.c:546
#, c-format
msgid " Window saved in \"%s\" is completely outside of current GRASS window."
-msgstr ""
-" La ventana guardada en \"%s\" se encuentra completamente fuera de la "
-"ventana actual de GRASS."
+msgstr " La ventana guardada en \"%s\" se encuentra completamente fuera de la ventana actual de GRASS."
#: ../lib/gis/view.c:550
#, c-format
-msgid ""
-" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
-msgstr ""
-" Solamente %d%% de la ventana guardada en \"%s\" se sobrepone con la ventana "
-"actual de GRASS."
+msgid " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgstr " Solamente %d%% de la ventana guardada en \"%s\" se sobrepone con la ventana actual de GRASS."
#: ../lib/gis/error.c:262
msgid "WARNING: "
@@ -2410,12 +2273,12 @@
#: ../lib/gis/spawn.c:386
#, c-format
msgid "CreateProcess() failed: error = %d"
-msgstr "Falló CreateProcess(): error = %d"
+msgstr "La instrucción CreateProcess() ha fallado: error = %d"
#: ../lib/gis/spawn.c:421
#, c-format
msgid "G_spawn: unable to redirect descriptor %d"
-msgstr "G_spawn: No es posible desviar el descriptor %d "
+msgstr "G_spawn: No ha sido posible redireccionar el descriptor %d "
#: ../lib/gis/spawn.c:429 ../lib/gis/spawn.c:619
#, c-format
@@ -2523,28 +2386,22 @@
#: ../lib/gis/put_row.c:215
#, c-format
msgid "G_put_map_row: %s is not integer! Use G_put_[f/d]_raster_row()!"
-msgstr ""
-"G_put_map_row: %s ¡No es un número entero! Utilice G_put_[f/d]_raster_row()!"
+msgstr "G_put_map_row: %s ¡No es un número entero! Utilice G_put_[f/d]_raster_row()!"
#: ../lib/gis/put_row.c:251
#, c-format
msgid "%s: map [%s] not open for write - request ignored"
-msgstr ""
-"%s: El mapa [%s] no ha sido abierto para escritura - solicitud ignorada."
+msgstr "%s: El mapa [%s] no ha sido abierto para escritura - solicitud ignorada."
#: ../lib/gis/put_row.c:259
#, c-format
msgid "%s: map [%s] not open for random write - request ignored"
-msgstr ""
-"%s: El mapa [%s] no ha sido abierto para escritura aleatoria - solicitud "
-"ignorada."
+msgstr "%s: El mapa [%s] no ha sido abierto para escritura aleatoria - solicitud ignorada."
#: ../lib/gis/put_row.c:266
#, c-format
msgid "%s: map [%s] not open for sequential write - request ignored"
-msgstr ""
-"%s: El mapa [%s] no ha sido abierto para escritura secuencial - solicitud "
-"ignorada."
+msgstr "%s: El mapa [%s] no ha sido abierto para escritura secuencial - solicitud ignorada."
#: ../lib/gis/put_row.c:270
#, c-format
@@ -2589,22 +2446,17 @@
#: ../lib/gis/range.c:359 ../lib/gis/range.c:412
#, c-format
msgid "can't write range file for [%s in %s]"
-msgstr ""
-"No es posible escribir el archivo que contiene los rangos para [%s en %s]."
+msgstr "No es posible escribir el archivo que contiene los rangos para [%s en %s]."
#: ../lib/gis/list.c:114
#, c-format
msgid "no %s files available in current mapset\n"
-msgstr ""
-"No hay archivos %s disponibles en el directorio de mapas de usuario actual "
-"(mapset).\n"
+msgstr "No hay archivos %s disponibles en el directorio de mapas de usuario actual (mapset).\n"
#: ../lib/gis/list.c:117
#, c-format
msgid "no %s files available in mapset <%s>\n"
-msgstr ""
-"No hay archivos %s disponibles en el directorio de mapas de usuario (mapset) "
-"<%s>.\n"
+msgstr "No hay archivos %s disponibles en el directorio de mapas de usuario (mapset) <%s>.\n"
#: ../lib/gis/list.c:132
#, c-format
@@ -2614,8 +2466,7 @@
#: ../lib/gis/list.c:183
#, c-format
msgid "%s files available in mapset <%s>:\n"
-msgstr ""
-"Archivos %s disponibles en el directorio de mapas de usuario (Mapset)<%s>:\n"
+msgstr "Archivos %s disponibles en el directorio de mapas de usuario (Mapset)<%s>:\n"
#: ../lib/gis/list.c:254
msgid "G_list: Unknown element type"
@@ -2631,9 +2482,9 @@
#: ../lib/gis/make_colr.c:40
-#, fuzzy, c-format
+#, c-format
msgid "The raster map <%s@%s> is empty"
-msgstr " El mapa raster %s@%s está vacío."
+msgstr " El mapa raster <%s@%s> está vacío."
#: ../lib/gis/make_colr.c:48
#, c-format
@@ -2644,8 +2495,7 @@
msgstr ""
"\n"
"\n"
-"Se necesita la tabla de colores para el archivo [%s] que se encuentra en el "
-"directorio de mapas de usuario (Mapset)[%s].\n"
+"Se necesita la tabla de colores para el archivo [%s] que se encuentra en el directorio de mapas de usuario (Mapset)[%s].\n"
#: ../lib/gis/make_colr.c:51
#, c-format
@@ -2717,15 +2567,11 @@
#: ../lib/gis/history.c:263
msgid "Not enough room in history file to record command line."
-msgstr ""
-"No existe espacio suficiente en el archivo de historial para guardar la "
-"línea de comandos "
+msgstr "No existe espacio suficiente en el archivo de historial para guardar la línea de comandos "
#: ../lib/gis/history.c:285
msgid "Not enough room in history file for command line (truncated)."
-msgstr ""
-"No existe suficiente espacio en el archivo de historial para registrar la "
-"línea de comando (El texto ha sido recortado)."
+msgstr "No existe suficiente espacio en el archivo de historial para registrar la línea de comando (El texto ha sido recortado)."
#: ../lib/gis/opencell.c:105
#, c-format
@@ -2739,55 +2585,38 @@
#: ../lib/gis/opencell.c:188
#, c-format
-msgid ""
-"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@"
-"%s> which does not exist"
-msgstr ""
-"No se puede abrir el mapa raster <%s@%s> ya que es una reclasificación de un "
-"mapa raster <%s@%s> que no existe."
+msgid "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%s> which does not exist"
+msgstr "No se puede abrir el mapa raster <%s@%s> ya que es una reclasificación de un mapa raster <%s@%s> que no existe."
#: ../lib/gis/opencell.c:212
#, c-format
msgid "Raster map <%s@%s>: format field in header file invalid"
-msgstr ""
-"Mapa raster <%s@%s>: El campo de formato en el archivo de cabecera no es "
-"válido."
+msgstr "Mapa raster <%s@%s>: El campo de formato en el archivo de cabecera no es válido."
#: ../lib/gis/opencell.c:219
#, c-format
-msgid ""
-"Raster map <%s@%s> is in different projection than current region. Found "
-"raster map <%s@%s>, should be <%s>."
-msgstr ""
-"El mapa raster <%s@%s> se encuentra en una proyección diferente a la región "
-"actual. El mapa raster encontrado <%s@%s>, debería ser <%s>."
+msgid "Raster map <%s@%s> is in different projection than current region. Found raster map <%s@%s>, should be <%s>."
+msgstr "El mapa raster <%s@%s> se encuentra en una proyección diferente a la región actual. El mapa raster encontrado <%s@%s>, debería ser <%s>."
#: ../lib/gis/opencell.c:226
#, c-format
msgid "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
-msgstr ""
-"El mapa raster <%s@%s> se encuentra en una zona diferente (%d) a la de la "
-"región actual (%d)."
+msgstr "El mapa raster <%s@%s> se encuentra en una zona diferente (%d) a la de la región actual (%d)."
#: ../lib/gis/opencell.c:233
#, c-format
msgid "Raster map <%s@%s>: bytes per cell (%d) too large"
-msgstr ""
-"Para el mapa raster <%s@%s>: los bytes por celda (%d) son demasiado grandes."
+msgstr "Para el mapa raster <%s@%s>: los bytes por celda (%d) son demasiado grandes."
#: ../lib/gis/opencell.c:262
#, c-format
msgid "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
-msgstr ""
-"El mapa <%s@%s> es una liga GDAL pero grass ha sido compilado sin soporte "
-"para GDAL."
+msgstr "El mapa <%s@%s> es una liga GDAL pero grass ha sido compilado sin soporte para GDAL."
#: ../lib/gis/opencell.c:642
#, c-format
msgid "Raster map <%s> is not in the current mapset (%s)"
-msgstr ""
-"El mapa raster <%s> no se encuentra en el directorio de mapas de usuario "
-"actual (mapset). (%s)."
+msgstr "El mapa raster <%s> no se encuentra en el directorio de mapas de usuario actual (mapset). (%s)."
#: ../lib/gis/opencell.c:649
#, c-format
@@ -2801,21 +2630,15 @@
#: ../lib/gis/opencell.c:666 ../lib/gis/opencell.c:767
msgid "G__open_raster_new(): no temp files available"
-msgstr ""
-"G__open_raster_new(): No se encuentran disponibles los archivos temporales."
+msgstr "G__open_raster_new(): No se encuentran disponibles los archivos temporales."
#: ../lib/gis/opencell.c:736
-msgid ""
-"Unable to write embedded null values for raster map open for random access"
-msgstr ""
-"No se pueden escribir valores nulos embebidos, en un mapa raster abierto "
-"para acceso aleatorio."
+msgid "Unable to write embedded null values for raster map open for random access"
+msgstr "No se pueden escribir valores nulos embebidos, en un mapa raster abierto para acceso aleatorio."
#: ../lib/gis/opencell.c:941
msgid "G_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
-msgstr ""
-"G_set_fp_type(): Solamente puede ser invocado mediante FCELL_TYPE o "
-"DCELL_TYPE."
+msgstr "G_set_fp_type(): Solamente puede ser invocado mediante FCELL_TYPE o DCELL_TYPE."
#: ../lib/gis/opencell.c:976 ../lib/gis/opencell.c:1064
#, c-format
@@ -2825,8 +2648,7 @@
#: ../lib/gis/opencell.c:1009
#, c-format
msgid "Raster map <%s> not found in mapset <%s>"
-msgstr ""
-"El mapa raster <%s> no se encuentra en el directorio de mapas (mapset) <%s>."
+msgstr "El mapa raster <%s> no se encuentra en el directorio de mapas (mapset) <%s>."
#: ../lib/gis/opencell.c:1070
#, c-format
@@ -2849,11 +2671,8 @@
msgstr "El mapa raster <%s> no es xdr: orden de bytes: %s."
#: ../lib/gis/opencell.c:1179
-msgid ""
-"G_set_quant_rules() can be called only for raster maps opened for reading"
-msgstr ""
-"G_set_quant_rules() Únicamente puede ser invocado para mapas raster abiertos "
-"para lectura."
+msgid "G_set_quant_rules() can be called only for raster maps opened for reading"
+msgstr "G_set_quant_rules() Únicamente puede ser invocado para mapas raster abiertos para lectura."
#: ../lib/gis/auto_mask.c:64
msgid "Unable to open automatic MASK file"
@@ -2872,9 +2691,7 @@
#: ../lib/gis/find_file.c:74
#, c-format
msgid "'%s/%s' was found in more mapsets (also found in <%s>)"
-msgstr ""
-"'%s / %s' fue encontrado en mas directorios de mapas (mapsets) (también fue "
-"hallado en <%s>)."
+msgstr "'%s / %s' fue encontrado en mas directorios de mapas (mapsets) (también fue hallado en <%s>)."
#: ../lib/gis/find_file.c:82
#, c-format
@@ -2885,8 +2702,7 @@
#: ../lib/gis/get_cellhd.c:71 ../lib/gis/get_cellhd.c:100
#, c-format
msgid "Unable to read header file for raster map <%s@%s>."
-msgstr ""
-"No se puede leer el archivo de cabecera para el mapa vectorial <%s@%s>."
+msgstr "No ha sido posible leer el archivo de cabecera para el mapa raster <%s@%s>."
#: ../lib/gis/get_cellhd.c:74
#, c-format
@@ -2907,15 +2723,12 @@
#: ../lib/gis/get_cellhd.c:88
#, c-format
msgid "Unable to open header file for raster map <%s@%s>"
-msgstr ""
-"No ha sido posible abrir el archivo de cabecera del mapa raster <%s@%s>."
+msgstr "No ha sido posible abrir el archivo de cabecera del mapa raster <%s@%s>."
#: ../lib/gis/get_cellhd.c:105
#, c-format
msgid " It is a reclass of raster map <%s@%s> whose header file is invalid."
-msgstr ""
-" Es una reclasificación del mapa raster <%s@%s> cuyo archivo de cabecera no "
-"es válido."
+msgstr " Es una reclasificación del mapa raster <%s@%s> cuyo archivo de cabecera no es válido."
#: ../lib/gis/get_cellhd.c:109
#, c-format
@@ -2969,8 +2782,7 @@
#: ../lib/gis/closecell.c:261
#, c-format
msgid "Error writing floating point format file for map %s"
-msgstr ""
-"Error al escribir un archivo de formato de punto flotante para el mapa %s."
+msgstr "Error al escribir un archivo de formato de punto flotante para el mapa %s."
#: ../lib/gis/closecell.c:272
@@ -3024,8 +2836,7 @@
#: ../lib/gis/closecell.c:444
#, fuzzy
msgid "Unable to write f_format file for CELL maps"
-msgstr ""
-"No es posible escribir el archivo f_format file para los mapas de celdas."
+msgstr "No es posible escribir el archivo f_format file para los mapas de celdas."
#: ../lib/gis/get_datum_name.c:53
#, c-format
@@ -3063,9 +2874,7 @@
#: ../lib/gis/open_misc.c:45
#, c-format
msgid "G__open_misc(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr ""
-"G__open_misc(read): El directorio de mapas de usuario (mapset) <%s> no "
-"corresponde al xmapset <%s>."
+msgstr "G__open_misc(read): El directorio de mapas de usuario (mapset) <%s> no corresponde al xmapset <%s>."
#: ../lib/gis/open_misc.c:67
#, c-format
@@ -3095,13 +2904,11 @@
#: ../lib/gis/get_ellipse.c:402
#, c-format
msgid "No ellipsoid info given in file %s in <%s>"
-msgstr ""
-"No se ha proporcionado información del elipsoide en el archivo %s en <%s>."
+msgstr "No se ha proporcionado información del elipsoide en el archivo %s en <%s>."
#: ../lib/gis/parser.c:340
msgid "WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-"Condiciones \"WHERE\", de la instrucción SQL sin la palabra clave \"where\"."
+msgstr "Condiciones \"WHERE\", de la instrucción SQL sin la palabra clave \"where\"."
#: ../lib/gis/parser.c:341
msgid "Example: income < 1000 and inhab >= 10000"
@@ -3197,12 +3004,8 @@
#: ../lib/gis/parser.c:596
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use."
-msgstr ""
-"Es posible conectar un solo mapa vectorial con múltiples tablas de una base "
-"de datos. Este número determina qué tabla se ha de usar."
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
+msgstr "Es posible conectar un solo mapa vectorial con múltiples tablas de una base de datos. Este número determina qué tabla se ha de usar."
#: ../lib/gis/parser.c:605
msgid "Category value"
@@ -3248,9 +3051,7 @@
#: ../lib/gis/parser.c:666
msgid "Either a standard color name or R:G:B triplet"
-msgstr ""
-"Puede ser un nombre de color estándar o tres valores que definan un color R: "
-"G: B."
+msgstr "Puede ser un nombre de color estándar o tres valores que definan un color R: G: B."
#: ../lib/gis/parser.c:675
msgid "Background color"
@@ -3258,9 +3059,7 @@
#: ../lib/gis/parser.c:677
msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
-msgstr ""
-"Puede ser un color estándar de GRASS, tres valores que definan un color R:G:"
-"B o \"ninguno\"."
+msgstr "Puede ser un color estándar de GRASS, tres valores que definan un color R:G:B o \"ninguno\"."
#: ../lib/gis/parser.c:818
#, c-format
@@ -3269,17 +3068,11 @@
#: ../lib/gis/parser.c:926
msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
-msgstr ""
-"Utilice cualquier identificador de opción (flag) --quiet (silencioso) o --"
-"verbose (detallado), pero no ambos, de ser este el caso se asume la opción "
-"detallado --verbose."
+msgstr "Utilice cualquier identificador de opción (flag) --quiet (silencioso) o --verbose (detallado), pero no ambos, de ser este el caso se asume la opción detallado --verbose."
#: ../lib/gis/parser.c:940
msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
-msgstr ""
-"verbose (detallado), pero no ambos, de ser este el caso se asume silencioso "
-"--quiet."
+msgstr "Utilice cualquier identificador de opción (flag) --quiet (silencioso) o --verbose (detallado), pero no ambos, de ser este el caso se asume silencioso --quiet."
#: ../lib/gis/parser.c:971
#, c-format
@@ -3611,9 +3404,7 @@
#: ../lib/gis/quant_io.c:168
#, c-format
msgid "quantization file [%s] in mapset [%s] %s"
-msgstr ""
-"El archivo de cuantización [%s] en el directorio de mapas de usuario "
-"(mapset) [%s]%s."
+msgstr "El archivo de cuantización [%s] en el directorio de mapas de usuario (mapset) [%s]%s."
#: ../lib/gis/get_window.c:67 ../lib/gis/get_window.c:85
#, c-format
@@ -3783,30 +3574,22 @@
#: ../lib/gis/timestamp.c:282
#, c-format
msgid "Can't create timestamp file for %s map %s in mapset %s"
-msgstr ""
-"No es posible crear el archivo de marca de tiempo (timestamp) para %s mapa "
-"%s que se encuentra en el directorio de mapas de usuario (mapset) %s."
+msgstr "No es posible crear el archivo de marca de tiempo (timestamp) para %s mapa %s que se encuentra en el directorio de mapas de usuario (mapset) %s."
#: ../lib/gis/timestamp.c:291
#, c-format
msgid "Invalid timestamp specified for %s map %s in mapset %s"
-msgstr ""
-"Se ha especificado una marca de tiempo no válida para %s mapa %s que se "
-"encuentra en el directorio de mapas de usuario (mapset) %s."
+msgstr "Se ha especificado una marca de tiempo no válida para %s mapa %s que se encuentra en el directorio de mapas de usuario (mapset) %s."
#: ../lib/gis/timestamp.c:313
#, c-format
msgid "Can't open timestamp file for %s map %s in mapset %s"
-msgstr ""
-"No se puede abrir el archivo de marca de tiempo para %s mapa %s que se "
-"encuentra en el directorio de mapas de usuario (Mapset) %s."
+msgstr "No se puede abrir el archivo de marca de tiempo para %s mapa %s que se encuentra en el directorio de mapas de usuario (Mapset) %s."
#: ../lib/gis/timestamp.c:322
#, c-format
msgid "Invalid timestamp file for %s map %s in mapset %s"
-msgstr ""
-"Archivo de marca de tiempo no válido para %s mapa %s que se encuentra en el "
-"directorio de mapas (mapset) %s."
+msgstr "Archivo de marca de tiempo no válido para %s mapa %s que se encuentra en el directorio de mapas (mapset) %s."
#: ../lib/gis/get_projinfo.c:33 ../lib/gis/get_projinfo.c:60
#, c-format
@@ -3826,13 +3609,12 @@
#: ../lib/gis/gdal.c:117
msgid "Unable to load GDAL library"
-msgstr "No ha sido posible cargar la librería GDAL."
+msgstr "No ha sido posible cargar la librería de abstracción de datos geoespaciales GDAL."
#: ../lib/gis/histogram.c:57
#, c-format
msgid "Histogram for [%s in %s] missing (run r.support)"
-msgstr ""
-"El histograma para [%s en %s] no ha sido encontrado (ejecute r.support)."
+msgstr "El histograma para [%s en %s] no ha sido encontrado (ejecute r.support)."
#: ../lib/gis/histogram.c:65
#, c-format
@@ -3865,9 +3647,7 @@
#: ../lib/gis/open.c:62
#, c-format
msgid "G__open(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr ""
-"G__open(read): El directorio de mapas (mapset) <%s> no corresponde a xmapset "
-"<%s>."
+msgstr "G__open(read): El directorio de mapas (mapset) <%s> no corresponde a xmapset <%s>."
#: ../lib/gis/open.c:84
#, c-format
@@ -3876,12 +3656,8 @@
#: ../lib/gis/distance.c:160
#, c-format
-msgid ""
-"G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,"
-"%f)(%f,%f)"
-msgstr ""
-"G_distance_point_to_line_segment: Esto no debería ocurrir: codigo=%d P=(%f,"
-"%f) S=(%f,%f)(%f,%f)."
+msgid "G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
+msgstr "G_distance_point_to_line_segment: Esto no debería ocurrir: codigo=%d P=(%f,%f) S=(%f,%f)(%f,%f)."
#: ../lib/arraystats/class.c:21
msgid "Discont algorithm currently not available because of bugs"
@@ -3899,31 +3675,17 @@
#: ../lib/arraystats/class.c:221
#, c-format
-msgid ""
-"There are classbreaks outside the range min-max. Number of classes reduced "
-"to %i, but using probabilities for %i classes."
-msgstr ""
-"Existen límites de clase fuera del mínimo o máximo del rango. El número de "
-"clases se reducirá a %i, pero se utilizan probabilidades para el número de "
-"clases %i."
+msgid "There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."
+msgstr "Existen límites de clase fuera del mínimo o máximo del rango. El número de clases se reducirá a %i, pero se utilizan probabilidades para el número de clases %i."
#: ../lib/rst/interp_float/interp2d.c:212
#, c-format
-msgid ""
-"Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) "
-"cell. Z-value %f, zmin %f, zmax %f."
-msgstr ""
-"Sobrepico o rebasamiento- Se sugiere un aumento en la tensión. El sobrepico "
-"ocurre en las celdas (%d,%d). Valor-Z %f, zmin %f, zmax %f."
+msgid "Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
+msgstr "Sobrepico o rebasamiento- Se sugiere un aumento en la tensión. El sobrepico ocurre en las celdas (%d,%d). Valor-Z %f, zmin %f, zmax %f."
#: ../lib/rst/interp_float/segmen2d.c:111
-msgid ""
-"Taking too long to find points for interpolation - please change the region "
-"to area where your points are. Continuing calculations..."
-msgstr ""
-"Ha tomado demasiado tiempo en encontrar puntos de interpolación - por favor, "
-"cambie la región a la zona donde están los puntos. Continuando con los "
-"cálculos ..."
+msgid "Taking too long to find points for interpolation - please change the region to area where your points are. Continuing calculations..."
+msgstr "Ha tomado demasiado tiempo en encontrar puntos de interpolación - por favor, cambie la región a la zona donde están los puntos. Continuando con los cálculos ..."
#: ../lib/rst/interp_float/input2d.c:47
#, c-format
@@ -3934,7 +3696,7 @@
msgid "Bitmap mask created"
msgstr "Se ha creado la máscara del mapa de bits."
-# almost translated,
+# almost translated,
# as I am not an advanced user I do not understand the meaning of "nsizc" so this word remains the same in the translation
#: ../lib/rst/interp_float/output2d.c:125
#, c-format
@@ -3979,7 +3741,7 @@
#: ../lib/rst/interp_float/vinput2d.c:171
#: ../lib/rst/interp_float/vinput2d.c:288
msgid "Negative value of smoothing detected: sm must be >= 0"
-msgstr "Se ha detectado un valor de suavizado negativo: sm debe ser >= 0"
+msgstr "Se ha detectado un valor de suavizado negativo: sm debe ser >= 0."
#: ../lib/rst/interp_float/vinput2d.c:233
msgid "Reading nodes from vector map ..."
@@ -3992,9 +3754,7 @@
#: ../lib/rst/interp_float/vinput2d.c:328
#, c-format
msgid "There are points outside specified 2D/3D region - %d points ignored"
-msgstr ""
-"Existen puntos fuera de la región 2D/3D especificada -Se han ignorado %d "
-"puntos."
+msgstr "Existen puntos fuera de la región 2D/3D especificada -Se han ignorado %d puntos."
#: ../lib/rst/interp_float/vinput2d.c:331
#, c-format
@@ -4003,12 +3763,8 @@
#: ../lib/rst/interp_float/vinput2d.c:335
#, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given NPMIN="
-"%d"
-msgstr ""
-"Los %d puntos dados para la interpolación (después de adelgazar) son menos "
-"que el NPMIN dado=%d."
+msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
+msgstr "Los %d puntos dados para la interpolación (después de adelgazar) son menos que el NPMIN dado=%d."
#: ../lib/rst/interp_float/vinput2d.c:340
msgid "Zero points in the given region"
@@ -4017,23 +3773,13 @@
# word "smooth" not translated, easier to understand the concept in English
#: ../lib/rst/interp_float/vinput2d.c:345
#, c-format
-msgid ""
-"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
-"smooth connection of segments, npmin > segmax (see manual)"
-msgstr ""
-"Los parámetros de segmentación tienen valores asignados no válidos: npmin= "
-"%d, segmax= %d. Para lograr conexiones suaves de segmentos, npmin > segmax "
-"(Por favor consulte el manual)."
+msgid "Segmentation parameters set to invalid values: npmin= %d, segmax= %d for smooth connection of segments, npmin > segmax (see manual)"
+msgstr "Se han asignado valores no válidos a los parámetros de segmentación: npmin= %d, segmax= %d. Para lograr conexiones suaves de segmentos, npmin > segmax (Por favor consulte el manual)."
#: ../lib/rst/interp_float/vinput2d.c:351
#, c-format
-msgid ""
-"There are less than %d points for interpolation. No segmentation is "
-"necessary, to run the program faster set segmax=%d (see manual)"
-msgstr ""
-"Hay menos de %d puntos para la interpolación. No es necesaria la "
-"segmentación, para ejecutar el programa mas rápidamente defina segmax=%d "
+msgid "There are less than %d points for interpolation. No segmentation is necessary, to run the program faster set segmax=%d (see manual)"
+msgstr "Hay menos de %d puntos para la interpolación. No es necesaria la segmentación, para ejecutar el programa mas rápidamente defina segmax=%d (Por favor consulte el manual)."
#: ../lib/rst/interp_float/vinput2d.c:355
#, c-format
@@ -4081,21 +3827,17 @@
#: ../lib/imagery/fopen.c:79
#, c-format
msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"No se puede crear el archivo [%s] para el subgrupo [%s] del grupo [%s en %s]."
+msgstr "No se puede crear el archivo [%s] para el subgrupo [%s] del grupo [%s en %s]."
#: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
#, c-format
msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"No se puede abrir el archivo [%s] para el subgrupo [%s] del grupo [%s en %s]."
+msgstr "No se puede abrir el archivo [%s] para el subgrupo [%s] del grupo [%s en %s]."
#: ../lib/imagery/fopen.c:116
#, c-format
msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"No se puede encontrar el archivo [%s] para el subgrupo [%s] del grupo [%s en "
-"%s]."
+msgstr "No se puede encontrar el archivo [%s] para el subgrupo [%s] del grupo [%s en %s]."
#: ../lib/imagery/target.c:38
#, c-format
@@ -4110,52 +3852,37 @@
#: ../lib/imagery/list_subgp.c:48
#, c-format
msgid "subgroup <%s> of group <%s> references the following raster maps\n"
-msgstr ""
-"El subgrupo <%s> perteneciente al grupo <%s> hace referencia a los "
-"siguientes mapas raster:\n"
+msgstr "El subgrupo <%s> perteneciente al grupo <%s> hace referencia a los siguientes mapas raster:\n"
#: ../lib/imagery/sigsetfile.c:41
#, c-format
-msgid ""
-"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
-"is not current mapset"
-msgstr ""
-"No se puede crear el archivo de firma <%s> para el subgrupo <%s> del grupo <"
-"%s> - <%s> No es el directorio de mapas de usuario (Mapset) actual."
+msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> is not current mapset"
+msgstr "No se puede crear el archivo de firma <%s> para el subgrupo <%s> del grupo <%s> - <%s> No es el directorio de mapas de usuario (Mapset) actual."
#: ../lib/imagery/sigsetfile.c:57
#, c-format
msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
-msgstr ""
-"%s>."
+msgstr "No se puede crear el archivo de firma <%s> para el subgrupo <%s> del grupo <%s>."
#: ../lib/imagery/sigsetfile.c:86
#, c-format
msgid "Unable to open signature file <%s> for subgroup <%s> of group <%s@%s>"
-msgstr ""
-"No se puede abrir el archivo de firma <%s> para el subgrupo <%s> del grupo <"
-"%s@%s>."
+msgstr "No se puede abrir el archivo de firma <%s> para el subgrupo <%s> del grupo <%s@%s>."
#: ../lib/imagery/points.c:124
#, c-format
msgid "Unable to open control point file for group [%s in %s]"
-msgstr ""
-"No ha sido posible abrir el archivo de puntos de control del grupo [%s en "
-"%s]."
+msgstr "No ha sido posible abrir el archivo de puntos de control del grupo [%s en %s]."
#: ../lib/imagery/points.c:132
#, c-format
msgid "Bad format in control point file for group [%s in %s]"
-msgstr ""
-"Formato incorrecto en el archivo de puntos de control para el grupo [%s en "
-"%s]."
+msgstr "Formato incorrecto en el archivo de puntos de control para el grupo [%s en %s]."
#: ../lib/imagery/points.c:159
#, c-format
msgid "Unable to create control point file for group [%s in %s]"
-msgstr ""
-"No se puede crear el archivo de puntos de control del grupo [%s en %s]."
+msgstr "No se puede crear el archivo de puntos de control del grupo [%s en %s]."
#: ../lib/imagery/list_gp.c:34
#, c-format
@@ -4169,56 +3896,52 @@
#: ../lib/vector/diglib/plus_node.c:217
#, c-format
-msgid ""
-"Attempt to read line angle for the line which is not connected to the node: "
-"node %d, line %d"
-msgstr ""
-"Intento de leer el ángulo de línea para la línea que no está conectada al "
-"nodo: Nodo %d, línea %d."
+msgid "Attempt to read line angle for the line which is not connected to the node: node %d, line %d"
+msgstr "Intento de leer el ángulo de línea para la línea que no está conectada al nodo: Nodo %d, línea %d."
#: ../lib/vector/diglib/plus.c:288
msgid "Unable read topology for nodes"
-msgstr "No se puede leer la topología de los nodos."
+msgstr "No se puede leer la topología para los nodos."
#: ../lib/vector/diglib/plus.c:293
#, c-format
msgid "Unable to read topology for node %d"
-msgstr "No se puede leer la topología del nodo %d."
+msgstr "No se puede leer la topología para el nodo %d."
#: ../lib/vector/diglib/plus.c:298
msgid "Unable read topology for lines"
-msgstr "No se puede leer la topología de las líneas."
+msgstr "No se puede leer la topología para las líneas."
#: ../lib/vector/diglib/plus.c:303
#, c-format
msgid "Unable to read topology for line %d"
-msgstr "No se puede leer la topología de la línea %d."
+msgstr "No se puede leer la topología para la línea %d."
#: ../lib/vector/diglib/plus.c:308
msgid "Unable to read topo for areas"
-msgstr "No se puede leer la topología de las áreas."
+msgstr "No se puede leer la topología para las áreas."
#: ../lib/vector/diglib/plus.c:313
#, c-format
msgid "Unable read topology for area %d"
-msgstr "No se puede leer la topología del área %d."
+msgstr "No se puede leer la topología para el área %d."
#: ../lib/vector/diglib/plus.c:318
msgid "Unable to read topology for isles"
-msgstr "No se puede leer la topología de las islas."
+msgstr "No se puede leer la topología para las islas."
#: ../lib/vector/diglib/plus.c:323
#, c-format
msgid "Unable to read topology for isle %d"
-msgstr "No se puede leer la topología de la isla %d."
+msgstr "No se puede leer la topología para la isla %d."
#: ../lib/vector/diglib/plus.c:345 ../lib/vector/diglib/plus.c:371
@@ -4271,8 +3994,7 @@
#: ../lib/vector/diglib/file.c:200
msgid "Unable to load file to memory, file not open"
-msgstr ""
-"No se ha abierto el archivo, pues no ha sido posible cargarlo en la memoria."
+msgstr "No se ha abierto el archivo, pues no ha sido posible cargarlo en la memoria."
#: ../lib/vector/diglib/file.c:215
msgid "Vector memory mode not supported, using 'AUTO'"
@@ -4305,9 +4027,7 @@
#: ../lib/vector/diglib/plus_area.c:394
#, c-format
msgid "Dead centroid %d registered for area (bug in the vector library)"
-msgstr ""
-"Centroide (baricentro) inexistente %d, registrado para el área (error en la "
-"biblioteca de vectores)."
+msgstr "Centroide (baricentro) inexistente %d, registrado para el área (error en la biblioteca de vectores)."
#: ../lib/vector/diglib/plus_area.c:418
#, c-format
@@ -4332,8 +4052,7 @@
#: ../lib/vector/neta/timetables.c:244 ../lib/vector/neta/timetables.c:286
#, c-format
msgid "Unable to open select cursor: %s"
-msgstr ""
-"No ha sido posible abrir el cursor resultado de la instrucción select:%s."
+msgstr "No ha sido posible abrir el cursor resultado de la instrucción select:%s."
#: ../lib/vector/neta/utils.c:221
#, c-format
@@ -4342,9 +4061,7 @@
#: ../lib/vector/neta/utils.c:230
msgid "'where' and 'cats' parameters were supplied, cat will be ignored"
-msgstr ""
-"Como se han suministrado los parámetros 'where' y 'cats', las categorías "
-"(cat) serán ignoradas."
+msgstr "Como se han suministrado los parámetros 'where' y 'cats', las categorías (cat) serán ignoradas."
#: ../lib/vector/neta/utils.c:233
msgid "Unable to load data from database"
@@ -4386,13 +4103,11 @@
#: ../lib/vector/Vlib/intersect.c:313
msgid "Vect_segment_intersection() ERROR (collinear vertical segments)"
-msgstr ""
-"ERROR en Vect_segment_intersection() (segmentos verticales colineales)."
+msgstr "ERROR en Vect_segment_intersection() (segmentos verticales colineales)."
#: ../lib/vector/Vlib/intersect.c:407
msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
-msgstr ""
-"ERROR en Vect_segment_intersection() (segmentos colineales no verticales)."
+msgstr "ERROR en Vect_segment_intersection() (segmentos colineales no verticales)."
#: ../lib/vector/Vlib/intersect.c:1059 ../lib/vector/Vlib/intersect.c:1065
#: ../lib/vector/Vlib/intersect.c:1067 ../lib/vector/Vlib/intersect.c:1115
@@ -4464,8 +4179,7 @@
#: ../lib/vector/Vlib/map.c:481
#, c-format
msgid "Unable to find table <%s> linked to vector map <%s>"
-msgstr ""
-"No se puede encontrar la tabla <%s> enlazada con el mapa vectorial <%s>."
+msgstr "No se puede encontrar la tabla <%s> enlazada con el mapa vectorial <%s>."
#: ../lib/vector/Vlib/map.c:498
@@ -4497,9 +4211,7 @@
#: ../lib/vector/Vlib/map.c:605 ../lib/vector/Vlib/map.c:706
#, c-format
msgid "Unable to add database link for vector map <%s>"
-msgstr ""
-"No ha sido posible añadir el enlace del mapa vectorial <%s> a la base de "
-"datos."
+msgstr "No ha sido posible añadir el enlace del mapa vectorial <%s> a la base de datos."
#: ../lib/vector/Vlib/read_nat.c:136 ../lib/vector/Vlib/geos.c:66
#: ../lib/vector/Vlib/geos.c:256
@@ -4513,8 +4225,7 @@
#: ../lib/vector/Vlib/array.c:145 ../lib/vector/Vlib/array.c:269
msgid "Mixed area and other type requested for vector array"
-msgstr ""
-"Se ha solicitado un área mixta y de otro tipo para la matriz de vectores."
+msgstr "Se ha solicitado un área mixta y de otro tipo para la matriz de vectores."
#: ../lib/vector/Vlib/array.c:155 ../lib/vector/Vlib/array.c:178
#: ../lib/vector/Vlib/array.c:306 ../lib/vector/Vlib/array.c:339
@@ -4524,43 +4235,32 @@
#: ../lib/vector/Vlib/array.c:294
#, c-format
msgid "Unable to select record from table <%s> (key %s, where %s)"
-msgstr ""
-"No se puede seleccionar el registro de la tabla <%s> (clave %s, donde %s)."
+msgstr "No se puede seleccionar el registro de la tabla <%s> (clave %s, donde %s)."
#: ../lib/vector/Vlib/legal_vname.c:48
#, c-format
msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
-msgstr ""
-"El nombre del mapa vectorial <%s> no es válido. Este no podrá contener '.' "
-"o 'Nulo'."
+msgstr "El nombre del mapa vectorial <%s> no es válido. Este no podrá contener '.' o 'Nulo'."
#: ../lib/vector/Vlib/legal_vname.c:55
#, c-format
msgid "Illegal vector map name <%s>. Must start with a letter."
-msgstr ""
-"El nombre del mapa vectorial <%s> no es válido. Este deberá comenzar con una "
-"letra."
+msgstr "El nombre del mapa vectorial <%s> no es válido. Este deberá comenzar con una letra."
#: ../lib/vector/Vlib/legal_vname.c:63
#, c-format
msgid "Illegal vector map name <%s>. Character '%c' not allowed."
-msgstr ""
-"El nombre del mapa vectorial <%s> no es válido. No está permitido utilizar "
-"el caracter '%c'."
+msgstr "El nombre del mapa vectorial <%s> no es válido. No está permitido utilizar el caracter '%c'."
#: ../lib/vector/Vlib/legal_vname.c:70
#, c-format
-msgid ""
-"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
-msgstr ""
-"El nombre del mapa vectorial <%s> no es válido. No se puede utilizar una "
-"palabra reservada de SQL como nombre de un mapa vectorial."
+msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgstr "El nombre del mapa vectorial <%s> no es válido. No se puede utilizar una palabra reservada de SQL como nombre de un mapa vectorial."
#: ../lib/vector/Vlib/legal_vname.c:101 ../lib/vector/Vlib/legal_vname.c:105
#, c-format
msgid "Output vector map name <%s> is not valid map name"
-msgstr ""
-"El nombre del mapa vectorial resultante <%s> no es un nombre válido de mapa."
+msgstr "El nombre del mapa vectorial resultante <%s> no es un nombre válido de mapa."
#: ../lib/vector/Vlib/legal_vname.c:142 ../lib/vector/Vlib/legal_vname.c:146
#, c-format
@@ -4616,9 +4316,7 @@
#: ../lib/vector/Vlib/net.c:367
#, c-format
msgid "Data type of column <%s> not supported (must be numeric)"
-msgstr ""
-"El tipo de datos para la columna <%s> no está soportado (debe ser de tipo "
-"numérico)."
+msgstr "El tipo de datos para la columna <%s> no está soportado (debe ser de tipo numérico)."
#: ../lib/vector/Vlib/net.c:227
msgid "Registering arcs..."
@@ -4626,22 +4324,13 @@
#: ../lib/vector/Vlib/net.c:255
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, forward/both direction(s)) not found "
-"(forward/both direction(s) of line skipped)"
-msgstr ""
-"No se ha encontrado el registro de la base de datos para la línea %d (cat ="
-"%d, hacia adelante / en una o ambas direcciones) (se omite la línea hacia "
-"adelante / en una o ambas direcciones)."
+msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (forward/both direction(s) of line skipped)"
+msgstr "No se ha encontrado el registro de la base de datos para la línea %d (cat =%d, hacia adelante / en una o ambas direcciones) (se omite la línea hacia adelante / en una o ambas direcciones)."
#: ../lib/vector/Vlib/net.c:274
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not "
-"found(direction of line skipped)"
-msgstr ""
-"No se ha encontrado el registro de la línea %d (cat = %d, en la dirección "
-"hacia atrás) en la base de datos , (se omite la dirección de la línea)."
+msgid "Database record for line %d (cat = %d, backword direction) not found(direction of line skipped)"
+msgstr "No se ha encontrado el registro de la línea %d (cat = %d, en la dirección hacia atrás) en la base de datos , (se omite la dirección de la línea)."
#: ../lib/vector/Vlib/net.c:323
@@ -4655,9 +4344,7 @@
#: ../lib/vector/Vlib/net.c:403
#, c-format
msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
-msgstr ""
-"No se encuentra el registro para el nodo %d (cat = %d). (El coste se "
-"establece como 0)."
+msgstr "No se encuentra el registro para el nodo %d (cat = %d). (El coste se establece como 0)."
#: ../lib/vector/Vlib/net.c:430
msgid "Flattening the graph..."
@@ -4682,9 +4369,7 @@
#: ../lib/vector/Vlib/field.c:98
msgid "Unable to add database link, map is not opened in WRITE mode"
-msgstr ""
-"No ha sido posible añadir el enlace a la base de datos, el mapa no ha sido "
-"abierto en modo de ESCRITURA."
+msgstr "No ha sido posible añadir el enlace a la base de datos, el mapa no ha sido abierto en modo de ESCRITURA."
#: ../lib/vector/Vlib/field.c:104
msgid "Unable to add database link"
@@ -4728,12 +4413,8 @@
msgstr "No se puede abrir el controlador OGR DBMI."
#: ../lib/vector/Vlib/field.c:551
-msgid ""
-"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
-"available in OGR DB table"
-msgstr ""
-"Todas las pruebas FID han fallado. Ni los \"FID\" ni \"ogc_fid\" ni \"ogr_fid"
-"\" ni \"gid\", están disponibles en la tabla OGR DB."
+msgid "All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' available in OGR DB table"
+msgstr "Todas las pruebas FID han fallado. Ni los \"FID\" ni \"ogc_fid\" ni \"ogr_fid\" ni \"gid\", están disponibles en la tabla OGR DB."
#: ../lib/vector/Vlib/field.c:606
#, c-format
@@ -4748,15 +4429,11 @@
#: ../lib/vector/Vlib/field.c:709
#, c-format
msgid "Unable to open vector database definition file '%s'"
-msgstr ""
-"No se puede abrir el archivo de definición de la base de datos vectorial "
-"'%s'."
+msgstr "No se puede abrir el archivo de definición de la base de datos vectorial '%s'."
#: ../lib/vector/Vlib/field.c:804
msgid "Bug: attempt to update map which is not in current mapset"
-msgstr ""
-"Error de programa: Se ha intentado actualizar un mapa el cual no se "
-"encuentra en el directorio de mapas de usuario (mapset) actual."
+msgstr "Error de programa: Se ha intentado actualizar un mapa el cual no se encuentra en el directorio de mapas de usuario (mapset) actual."
#: ../lib/vector/Vlib/graph.c:143
@@ -4821,21 +4498,13 @@
#: ../lib/vector/Vlib/open_nat.c:145
#, c-format
-msgid ""
-"Coor files of vector map <%s@%s> is larger than it should be (%ld bytes "
-"excess)"
-msgstr ""
-"El archivo de coordenadas del mapa vectorial <%s@%s> es mayor de lo que "
-"debería ser (Existen %ld bytes de exceso)."
+msgid "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
+msgstr "El archivo de coordenadas del mapa vectorial <%s@%s> es mayor de lo que debería ser (Existen %ld bytes de exceso)."
#: ../lib/vector/Vlib/open_nat.c:149
#, c-format
-msgid ""
-"Coor files of vector <%s@%s> is shorter than it should be (%ld bytes "
-"missing)."
-msgstr ""
-"El archivo de coordenadas del mapa vectorial <%s@%s> es menor de lo que "
-"debería ser (faltan %ld bytes)."
+msgid "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+msgstr "El archivo de coordenadas del mapa vectorial <%s@%s> es menor de lo que debería ser (faltan %ld bytes)."
#: ../lib/vector/Vlib/cats.c:47
msgid "Vect_new_cats_struct(): Out of memory"
@@ -4844,16 +4513,12 @@
#: ../lib/vector/Vlib/cats.c:131
#, c-format
msgid "Too many categories (%d), unable to set cat %d (layer %d)"
-msgstr ""
-"Demasiadas categorías (%d), no ha sido posible establecer la categoría %d "
-"(capa %d)."
+msgstr "Demasiadas categorías (%d), no ha sido posible establecer la categoría %d (capa %d)."
#: ../lib/vector/Vlib/cats.c:410
#, c-format
msgid "Unable to convert category string '%s' (from '%s') to category range"
-msgstr ""
-"No ha sido posible convertir la cadena de texto de la categoría '%s' (de "
-"'%s') a un rango de categoria."
+msgstr "No ha sido posible convertir la cadena de texto de la categoría '%s' (de '%s') a un rango de categoria."
#: ../lib/vector/Vlib/remove_areas.c:96
msgid "Area is composed of dead boundary"
@@ -4869,12 +4534,8 @@
msgstr "No ha sido posible eliminar el objeto %d del índice espacial."
#: ../lib/vector/Vlib/sindex.c:127
-msgid ""
-"Unable to build spatial index from topology, vector map is not opened at "
-"topo level 2"
-msgstr ""
-"No ha sido posible construir el índice espacial a partir de la topología, el "
-"mapa vectorial no está abierto en el nivel de topología 2."
+msgid "Unable to build spatial index from topology, vector map is not opened at topo level 2"
+msgstr "No ha sido posible construir el índice espacial a partir de la topología, el mapa vectorial no está abierto en el nivel de topología 2."
#: ../lib/vector/Vlib/sindex.c:168
msgid "BUG (Vect_build_sidx_from_topo): node does not exist"
@@ -4914,8 +4575,7 @@
#: ../lib/vector/Vlib/line.c:529
msgid "Segment outside line, no segment created"
-msgstr ""
-"El segmento se encuentra fuera de la línea, no se ha creado ningún segmento."
+msgstr "El segmento se encuentra fuera de la línea, no se ha creado ningún segmento."
#: ../lib/vector/Vlib/rewind.c:35 ../lib/vector/Vlib/read.c:30
#: ../lib/vector/Vlib/close.c:38 ../lib/vector/Vlib/write.c:53
@@ -4930,12 +4590,8 @@
#: ../lib/vector/Vlib/read.c:102
#, c-format
-msgid ""
-"Vect_read_line(): feature id %d is not reasonable (max features in vector "
-"map <%s>: %d)"
-msgstr ""
-"Vect_read_line (): el id del objeto espacial %d no es razonable (Las "
-"características máximas en el mapa vectorial son: <%s>:% d)."
+msgid "Vect_read_line(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+msgstr "Vect_read_line (): el id del objeto espacial %d no es razonable (Las características máximas en el mapa vectorial son: <%s>:% d)."
#: ../lib/vector/Vlib/area.c:53
msgid "Attempt to read points of nonexistent area"
@@ -4960,12 +4616,8 @@
#: ../lib/vector/Vlib/geos.c:56
#, c-format
-msgid ""
-"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
-"vector map <%s>: %d)"
-msgstr ""
-"Vect_read_line_geos(): El identificador del razgo id %d no es razonable (El "
-"número máximo de rasgos en el mapa vectorial es <%s>: %d)"
+msgid "Vect_read_line_geos(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+msgstr "Vect_read_line_geos(): El identificador del razgo id %d no es razonable (El número máximo de rasgos en el mapa vectorial es <%s>: %d)"
#: ../lib/vector/Vlib/geos.c:61
msgid "only native format supported"
@@ -4979,15 +4631,13 @@
#: ../lib/vector/Vlib/geos.c:105
#, c-format
msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
-msgstr ""
-"Vect_read_area_geos(): No se puede leer el id de la isla %d del id del área "
-"%d"
+msgstr "Vect_read_area_geos(): No se puede leer el id de la isla %d del id del área %d"
#: ../lib/vector/Vlib/geos.c:203
#, c-format
msgid "Unable to read line offset %ld"
-msgstr "No se puede leer el desplazamiento de línea %ld"
+msgstr "No se puede leer el ajuste de desplazamiento de línea %ld"
#: ../lib/vector/Vlib/geos.c:410
#, c-format
@@ -5016,11 +4666,8 @@
msgstr "La construcción parcial de OGR no está soportada."
#: ../lib/vector/Vlib/build_ogr.c:342
-msgid ""
-"Random read is not supported by OGR for this layer, cannot build support"
-msgstr ""
-"La lectura aleatoria de esta capa no es soportada por OGR, no se puede "
-"construir el soporte."
+msgid "Random read is not supported by OGR for this layer, cannot build support"
+msgstr "La lectura aleatoria de esta capa no es soportada por OGR, no se puede construir el soporte."
#: ../lib/vector/Vlib/build_ogr.c:349
msgid "Feature: "
@@ -5070,9 +4717,7 @@
#: ../lib/vector/Vlib/cindex.c:512
#, c-format
msgid "Unable to open category index file for vector map <%s@%s>"
-msgstr ""
-"No ha sido posible abrir el archivo de índice de categoría del mapa "
-"vectorial <%s@%s>."
+msgstr "No ha sido posible abrir el archivo de índice de categoría del mapa vectorial <%s@%s>."
#: ../lib/vector/Vlib/close.c:134
#, c-format
@@ -5085,15 +4730,11 @@
#: ../lib/vector/Vlib/overlay.c:123
msgid "Overlay: line/boundary types not supported by AND operator"
-msgstr ""
-"Superposición: los tipos de línea / contorno no son compatibles con el "
-"operador AND."
+msgstr "Superposición: los tipos de línea / contorno no son compatibles con el operador AND."
#: ../lib/vector/Vlib/overlay.c:126
msgid "Overlay: area x area types not supported by AND operator"
-msgstr ""
-"Superposición: Los tipos \"area x area\" no son compatibles con el operador "
-"AND."
+msgstr "Superposición: Los tipos \"area x area\" no son compatibles con el operador AND."
#: ../lib/vector/Vlib/open_ogr.c:54
msgid "OGR format cannot be updated"
@@ -5117,22 +4758,13 @@
#: ../lib/vector/Vlib/open_ogr.c:157
#, c-format
-msgid ""
-"Feature index format version %d.%d is not supported by this release. Try to "
-"rebuild topology or upgrade GRASS."
-msgstr ""
-"La versión de formato de índice del objeto espacial %d.%d no está soportado "
-"en esta versión. Intente reconstruir la topología o actualice GRASS."
+msgid "Feature index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
+msgstr "La versión de formato de índice del objeto espacial %d.%d no está soportado en esta versión. Intente reconstruir la topología o actualice GRASS."
#: ../lib/vector/Vlib/open_ogr.c:162
#, c-format
-msgid ""
-"Your GRASS version does not fully support feature index format %d.%d of the "
-"vector. Consider to rebuild topology or upgrade GRASS."
-msgstr ""
-"Su versión de GRASS no soporta completamente el formato de índice del objeto "
-"espacial %d.%d del vector.Considere reconstruir la topología o actualizar "
-"GRASS."
+msgid "Your GRASS version does not fully support feature index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
+msgstr "Su versión de GRASS no soporta completamente el formato de índice del objeto espacial %d.%d del vector.Considere reconstruir la topología o actualizar GRASS."
#: ../lib/vector/Vlib/level.c:38
msgid "Map structure was never initialized"
@@ -5153,9 +4785,7 @@
#: ../lib/vector/Vlib/buffer2.c:598 ../lib/vector/Vlib/buffer2.c:609
msgid "Next edge was visited but it is not the first one !!! breaking loop"
-msgstr ""
-"El siguiente borde ya ha sido recorrido pero no es el primero!!! Rompiendo "
-"el lazo."
+msgstr "El siguiente borde ya ha sido recorrido pero no es el primero!!! Rompiendo el lazo."
#: ../lib/vector/Vlib/buffer2.c:657
msgid "side != 0 feature not implemented"
@@ -5180,9 +4810,7 @@
#: ../lib/vector/Vlib/write.c:135
msgid "Unable to write feature, vector map is not opened"
-msgstr ""
-"No ha sido posible escribir el objeto espacial, el mapa vectorial no ha sido "
-"abierto."
+msgstr "No ha sido posible escribir el objeto espacial, el mapa vectorial no ha sido abierto."
#: ../lib/vector/Vlib/write.c:148
msgid "Unable to write feature (negative offset)"
@@ -5190,9 +4818,7 @@
#: ../lib/vector/Vlib/write.c:181
msgid "Unable to rewrite feature, vector map is not opened"
-msgstr ""
-"No ha sido posible reescribir el objeto espacial, el mapa vectorial no ha "
-"sido abierto."
+msgstr "No ha sido posible reescribir el objeto espacial, el mapa vectorial no ha sido abierto."
#: ../lib/vector/Vlib/write.c:194
#, c-format
@@ -5201,19 +4827,13 @@
#: ../lib/vector/Vlib/write.c:219
#, c-format
-msgid ""
-"Unable to delete feature %d, vector map <%s> is not opened on topology level"
-msgstr ""
-"No ha sido posible eliminar el objeto espacial %d, pues el mapa vectorial <"
-"%s> no ha sido abierto en ese nivel topológico."
+msgid "Unable to delete feature %d, vector map <%s> is not opened on topology level"
+msgstr "No ha sido posible eliminar el objeto espacial %d, pues el mapa vectorial <%s> no ha sido abierto en ese nivel topológico."
#: ../lib/vector/Vlib/write.c:225
#, c-format
-msgid ""
-"Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr ""
-"No ha sido posible eliminar el objeto espacial %d, puesto que, el mapa "
-"vectorial <%s> no se ha abierto en modo de escritura."
+msgid "Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr "No ha sido posible eliminar el objeto espacial %d, puesto que, el mapa vectorial <%s> no se ha abierto en modo de escritura."
#: ../lib/vector/Vlib/write.c:239
#, c-format
@@ -5222,19 +4842,13 @@
#: ../lib/vector/Vlib/write.c:265
#, c-format
-msgid ""
-"Unable to restore feature %d, vector map <%s> is not opened on topology level"
-msgstr ""
-"No es posible restaurar el objeto espacial %d, por que el mapa vectorial <"
-"%s> no está abierto a nivel de topología."
+msgid "Unable to restore feature %d, vector map <%s> is not opened on topology level"
+msgstr "No es posible restaurar el objeto espacial %d, por que el mapa vectorial <%s> no está abierto a nivel de topología."
#: ../lib/vector/Vlib/write.c:271
#, c-format
-msgid ""
-"Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr ""
-"No es posible restaurar el objeto espacial %d, el mapa vectorial <%s> no "
-"está abierto en modo de \"escritura\"."
+msgid "Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr "No es posible restaurar el objeto espacial %d, el mapa vectorial <%s> no está abierto en modo de \"escritura\"."
#: ../lib/vector/Vlib/write.c:285
#, c-format
@@ -5279,21 +4893,14 @@
msgstr "El programador solicitó un nivel abierto desconocido %d."
#: ../lib/vector/Vlib/open.c:179
-msgid ""
-"Vector map which is not in the current mapset cannot be opened for update"
-msgstr ""
-"No puede ser abierto para su actualización, un mapa vectorial que no esté en "
-"el directorio actual de mapas de usuario (mapset)."
+msgid "Vector map which is not in the current mapset cannot be opened for update"
+msgstr "No puede ser abierto para su actualización, un mapa vectorial que no esté en el directorio actual de mapas de usuario (mapset)."
#: ../lib/vector/Vlib/open.c:211 ../lib/vector/Vlib/open.c:279
#: ../lib/vector/Vlib/open.c:299
#, c-format
-msgid ""
-"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
-"by v.build."
-msgstr ""
-"No se puede abrir el mapa vectorial <%s> en el nivel %d. Intente reconstruir "
-"la topología vectorial mediante v.build."
+msgid "Unable to open vector map <%s> on level %d. Try to rebuild vector topology by v.build."
+msgstr "No se puede abrir el mapa vectorial <%s> en el nivel %d. Intente reconstruir la topología vectorial mediante v.build."
#: ../lib/vector/Vlib/open.c:214
@@ -5304,15 +4911,13 @@
#: ../lib/vector/Vlib/open.c:236
#, c-format
msgid "Unable to open topology file for vector map <%s>"
-msgstr ""
-"No ha sido posible abrir el archivo de topología del mapa vectorial <%s>."
+msgstr "No ha sido posible abrir el archivo de topología del mapa vectorial <%s>."
#: ../lib/vector/Vlib/open.c:262
#, c-format
msgid "Unable to open category index file for vector map <%s>"
-msgstr ""
-"No se puede abrir archivo de índice de categorías del mapa vectorial <%s>."
+msgstr "No se puede abrir archivo de índice de categorías del mapa vectorial <%s>."
#: ../lib/vector/Vlib/open.c:353 ../lib/vector/Vlib/open.c:576
@@ -5323,9 +4928,7 @@
#: ../lib/vector/Vlib/open.c:531
#, c-format
msgid "%s is not in the current mapset (%s)"
-msgstr ""
-"%s no se encuentra en el directorio de mapas del usuario actual (current "
-"mapset) (%s)."
+msgstr "%s no se encuentra en el directorio de mapas del usuario actual (current mapset) (%s)."
#: ../lib/vector/Vlib/open.c:566
#, c-format
@@ -5339,9 +4942,7 @@
#: ../lib/vector/Vlib/open.c:731
msgid "Size of 'coor' file differs from value saved in topology file"
-msgstr ""
-"El tamaño del archivo de coordenadas difiere del valor guardado en el "
-"archivo de topología."
+msgstr "El tamaño del archivo de coordenadas difiere del valor guardado en el archivo de topología."
#: ../lib/vector/Vlib/open.c:742
#, c-format
@@ -5447,9 +5048,7 @@
#: ../lib/vector/Vlib/build.c:407
#, c-format
msgid "Unable open spatial index file for write <%s>"
-msgstr ""
-"No ha sido posible el abrir el archivo de índice espacial para su escritura <"
-"%s>."
+msgstr "No ha sido posible el abrir el archivo de índice espacial para su escritura <%s>."
#: ../lib/vector/Vlib/build.c:415
msgid "Error writing out spatial index file"
@@ -5465,48 +5064,41 @@
msgid "Unknown query tool"
msgstr "Herramienta de consulta desconocida."
-#~ msgid ""
-#~ "taking too long to find points for interpolation--please change the "
-#~ "region to area where your points are. Continuing calculations..."
-#~ msgstr ""
-#~ "Ha tomado demasiado tiempo el encontrar puntos de interpolación -- por "
-#~ "favor, cambie la región a la zona donde están sus puntos. Continuando con "
-#~ "los cálculos ..."
+msgid "taking too long to find points for interpolation--please change the region to area where your points are. Continuing calculations..."
+msgstr "Ha tomado demasiado tiempo el encontrar puntos de interpolación -- por favor, cambie la región a la zona donde están sus puntos. Continuando con los cálculos ..."
-#~ msgid "Reading lines from vector map ... "
-#~ msgstr "leyendo línea del mapa vectorial."
+msgid "Reading lines from vector map ... "
+msgstr "leyendo línea del mapa vectorial."
-#~ msgid "Reading nodes from vector map ... "
-#~ msgstr "Leyendo nodos del mapa vectorial... "
+msgid "Reading nodes from vector map ... "
+msgstr "Leyendo nodos del mapa vectorial... "
-#~ msgid "strip exists with insufficient data"
-#~ msgstr "La franja existe pero no tiene suficientes datos."
+msgid "strip exists with insufficient data"
+msgstr "La franja existe pero no tiene suficientes datos."
-#~ msgid "there are points outside specified 2D/3D region--ignored %d points"
-#~ msgstr ""
-#~ "Existen puntos fuera de la región 2D/3D especificada. -- Se han ignorado "
-#~ "%d puntos."
+msgid "there are points outside specified 2D/3D region--ignored %d points"
+msgstr "Existen puntos fuera de la región 2D/3D especificada. -- Se han ignorado %d puntos."
-#~ msgid "ignoring %d points -- too dense"
-#~ msgstr "Se ignoran %d puntos -- demasiado denso."
+msgid "ignoring %d points -- too dense"
+msgstr "Se ignoran %d puntos -- demasiado denso."
-#~ msgid "some points outside of region -- will ignore..."
-#~ msgstr "Algunos puntos fuera de la región --se ignorarán..."
+msgid "some points outside of region -- will ignore..."
+msgstr "Algunos puntos fuera de la región --se ignorarán..."
-#~ msgid "G_malloc: unable to allocate %lu bytes at %s:%d"
-#~ msgstr "G_malloc: Incapaz de destinar %lu bytes en %s:%d."
+msgid "G_malloc: unable to allocate %lu bytes at %s:%d"
+msgstr "G_malloc: Incapaz de destinar %lu bytes en %s:%d."
-#~ msgid "G_calloc: unable to allocate %lu * %lu bytes at %s:%d"
-#~ msgstr "G_calloc: incapaz de asignar %lu * %lu bytes en %s:%d."
+msgid "G_calloc: unable to allocate %lu * %lu bytes at %s:%d"
+msgstr "G_calloc: incapaz de asignar %lu * %lu bytes en %s:%d."
-#~ msgid "G_realloc: unable to allocate %lu bytes at %s:%d"
-#~ msgstr "G_realloc: incapaz de asignar %lu bytes en %s:%d."
+msgid "G_realloc: unable to allocate %lu bytes at %s:%d"
+msgstr "G_realloc: incapaz de asignar %lu bytes en %s:%d."
-#~ msgid "Snapped vertices"
-#~ msgstr "Vértices eliminados"
+msgid "Snapped vertices"
+msgstr "Vértices eliminados"
-#~ msgid "New vertices"
-#~ msgstr "Nuevos vértices"
+msgid "New vertices"
+msgstr "Nuevos vértices"
#~ msgid "Requested g3d map <%s> not found"
#~ msgstr "No ha sido posible encontrar el mapa g3d solicitado <%s>."
@@ -5518,8 +5110,7 @@
#~ msgstr "No se puede presentar %d del mapa vectorial <%s>."
#~ msgid "Invalid view position coordinates, using %f,%f"
-#~ msgstr ""
-#~ "Coordenadas de posición de visualización no válidas, utilizando %f,%f."
+#~ msgstr "Coordenadas de posición de visualización no válidas, utilizando %f,%f."
#~ msgid "Unknown Location"
#~ msgstr "Locación desconocida."
@@ -5531,34 +5122,25 @@
#~ msgstr "El vector no es 3D."
#~ msgid "Cannot find z column <%s> (please verify name, e.g. with v.info)"
-#~ msgstr ""
-#~ "No se encuentra la columna con los valores Z denominada <%s> (por favor, "
-#~ "verifique el nombre, p.ej. utilizando v.info)."
+#~ msgstr "No se encuentra la columna con los valores Z denominada <%s> (por favor, verifique el nombre, p.ej. utilizando v.info)."
#~ msgid "Column type of z column is not supported (must be integer or double)"
-#~ msgstr ""
-#~ "No se soportan columnas del tipo columna z (debe ser entero o doble)."
+#~ msgstr "No se soportan columnas del tipo columna z (debe ser entero o doble)."
#~ msgid "Cannot read column type of smooth column"
-#~ msgstr ""
-#~ "No se puede leer una columna del tipo columna con valores suavizados."
+#~ msgstr "No se puede leer una columna del tipo columna con valores suavizados."
#~ msgid "Column type of smooth column (datetime) is not supported"
-#~ msgstr ""
-#~ "No se soportan columnas del tipo columna con valores suavizados (fecha / "
-#~ "hora)."
+#~ msgstr "No se soportan columnas del tipo columna con valores suavizados (fecha / hora)."
#~ msgid "Column type of s column is not supported (must be integer or double)"
-#~ msgstr ""
-#~ "No se soportan columnas del tipo columna s (debe ser entero o doble)."
+#~ msgstr "No se soportan columnas del tipo columna s (debe ser entero o doble)."
#~ msgid "The linear equation system is not quadratic"
#~ msgstr "El sistema de ecuaciones lineales no es cuadrático."
#~ msgid "The gauss elimination solver does not work with sparse matrices"
-#~ msgstr ""
-#~ "El solucionador de eliminación de Gauss no funciona con matrices "
-#~ "dispersas."
+#~ msgstr "El solucionador de eliminación de Gauss no funciona con matrices dispersas."
#~ msgid "The lu solver does not work with sparse matrices"
#~ msgstr "El solucionador de LU no funciona con matrices dispersas."
@@ -5579,8 +5161,7 @@
#~ msgstr "G_gisinit() debe ser llamado primero. "
#~ msgid "Please advise GRASS developers of this error.\n"
-#~ msgstr ""
-#~ "Por favor notifique a los desarrolladores de GRASS acerca de este error.\n"
+#~ msgstr "Por favor notifique a los desarrolladores de GRASS acerca de este error.\n"
#~ msgid "Unable to make mapset element %s (%s)"
#~ msgstr "No se puede generar el elemento %s (%s) del directorio de mapas"
@@ -5688,8 +5269,7 @@
#, fuzzy
#~ msgid "Output name '%s' is not valid rast name."
-#~ msgstr ""
-#~ "El nombre del mapa vectorial de salida <%s> no es un nombre de mapa válido"
+#~ msgstr "El nombre del mapa vectorial de salida <%s> no es un nombre de mapa válido"
#, fuzzy
#~ msgid "Cannot find input map '%s'"
@@ -5730,8 +5310,13 @@
#~ msgstr "¡No es posible escribir el archivo quant!"
#~ msgid "unable to write f_format file for CELL maps"
-#~ msgstr ""
-#~ "No es posible escribir el archivo f_format para los mapas de celdas."
+#~ msgstr "No es posible escribir el archivo f_format para los mapas de celdas."
#~ msgid "'%s' must be > 0 for '%s'"
#~ msgstr "'%s' debe ser > 0 para '%s'"
+#~ msgid "No temp files available: %s"
+#~ msgstr "No hay archivos temp disponibles :%s"
+#~ msgid "Module built against version %s but trying to use version %s. You need to rebuild GRASS GIS or untangle multiple installations."
+#~ msgstr "El módulo fue construido respecto a la versión %s, sin embargo se está intentando utilizar la versión %s. Usted necesita recompilar el SIG GRASS o desenredar múltiples instalaciones."
