[GRASS-SVN] r61325 - grass-addons/grass7/raster3d/r3.flow
svn_grass at osgeo.org
Tue Jul 22 09:36:36 PDT 2014
Author: annakrat
Date: 2014-07-22 09:36:36 -0700 (Tue, 22 Jul 2014)
New Revision: 61325
grass-addons/grass7/raster3d/r3.flow/flowline.c
grass-addons/grass7/raster3d/r3.flow/main.c
grass-addons/grass7/raster3d/r3.flow/r3flow_structs.h
r3.flow: flowlines can be integrated in both directions
Modified: grass-addons/grass7/raster3d/r3.flow/flowline.c
--- grass-addons/grass7/raster3d/r3.flow/flowline.c 2014-07-22 16:24:03 UTC (rev 61324)
+++ grass-addons/grass7/raster3d/r3.flow/flowline.c 2014-07-22 16:36:36 UTC (rev 61325)
@@ -83,7 +83,7 @@
integration->cell_size);
max_step = get_time_step("cell", MAX_STEP, velocity_norm,
- delta_t *= integration->direction;
+ delta_t *= (integration->actual_direction == FLOWDIR_UP ? 1 : -1);
if (rk45_integrate_next
(region, gradient_info, point, new_point,
&delta_t, min_step, max_step) < 0)
Modified: grass-addons/grass7/raster3d/r3.flow/main.c
--- grass-addons/grass7/raster3d/r3.flow/main.c 2014-07-22 16:24:03 UTC (rev 61324)
+++ grass-addons/grass7/raster3d/r3.flow/main.c 2014-07-22 16:36:36 UTC (rev 61325)
@@ -101,8 +101,7 @@
int main(int argc, char *argv[])
struct Option *vector_opt, *seed_opt, *flowlines_opt, *flowacc_opt,
- *scalar_opt, *unit_opt, *step_opt, *limit_opt, *skip_opt;
- struct Flag *up_flag;
+ *scalar_opt, *unit_opt, *step_opt, *limit_opt, *skip_opt, *dir_opt;
struct GModule *module;
RASTER3D_Region region;
RASTER3D_Map *flowacc;
@@ -201,10 +200,15 @@
skip_opt->description =
_("Number of cells between flow lines in x, y and z direction");
- up_flag = G_define_flag();
- up_flag->key = 'u';
- up_flag->description = _("Compute upstream flowlines "
- "instead of default downstream flowlines");
+ dir_opt = G_define_option();
+ dir_opt->key = "direction";
+ dir_opt->type = TYPE_STRING;
+ dir_opt->required = NO;
+ dir_opt->multiple = NO;
+ dir_opt->options = "up,down,both";
+ dir_opt->answer = "down";
+ dir_opt->description = _("Compute flowlines upstream, "
+ "downstream or in both direction.");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -231,7 +235,12 @@
integration.step = 0.25;
integration.limit = atof(limit_opt->answer);
- integration.direction = up_flag->answer ? 1 : -1;
+ if (strcmp(dir_opt->answer, "up") == 0)
+ integration.direction_type = FLOWDIR_UP;
+ else if (strcmp(dir_opt->answer, "down") == 0)
+ integration.direction_type = FLOWDIR_DOWN;
+ else
+ integration.direction_type = FLOWDIR_BOTH;
/* cell size is the diagonal */
@@ -333,8 +342,18 @@
G_percent(seed_count, n_seeds, 1);
cat = seed_count + 1;
- compute_flowline(®ion, &seed, &gradient_info, flowacc,
- &integration, &fl_map, fl_cats, fl_points, cat);
+ if (integration.direction_type == FLOWDIR_UP ||
+ integration.direction_type == FLOWDIR_BOTH) {
+ integration.actual_direction = FLOWDIR_UP;
+ compute_flowline(®ion, &seed, &gradient_info, flowacc,
+ &integration, &fl_map, fl_cats, fl_points, cat);
+ if (integration.direction_type == FLOWDIR_DOWN ||
+ integration.actual_direction = FLOWDIR_DOWN;
seed_count++;
@@ -365,9 +384,20 @@
if (seed.flowaccum || seed.flowline) {
flowacc, &integration, &fl_map,
+ flowacc, &integration, &fl_map,
+ fl_cats, fl_points, cat);
seed_count++;
Modified: grass-addons/grass7/raster3d/r3.flow/r3flow_structs.h
--- grass-addons/grass7/raster3d/r3.flow/r3flow_structs.h 2014-07-22 16:24:03 UTC (rev 61324)
+++ grass-addons/grass7/raster3d/r3.flow/r3flow_structs.h 2014-07-22 16:36:36 UTC (rev 61325)
@@ -12,9 +12,12 @@
int flowaccum;
+enum flowdir {FLOWDIR_UP, FLOWDIR_DOWN, FLOWDIR_BOTH};
struct Integration
- int direction;
+ enum flowdir direction_type;
+ enum flowdir actual_direction;
char *unit;
double step;
double cell_size;
