[GRASS-SVN] r61334 - grass/trunk/lib/python/gunittest
svn_grass at osgeo.org
Tue Jul 22 13:01:02 PDT 2014
Author: wenzeslaus
Date: 2014-07-22 13:01:02 -0700 (Tue, 22 Jul 2014)
New Revision: 61334
grass/trunk/lib/python/gunittest/invoker.py
grass/trunk/lib/python/gunittest/reporters.py
gunittest: introduce possibility of multiple reports for test file invoker (now HTML report and simple text report)
Modified: grass/trunk/lib/python/gunittest/invoker.py
--- grass/trunk/lib/python/gunittest/invoker.py 2014-07-22 19:57:51 UTC (rev 61333)
+++ grass/trunk/lib/python/gunittest/invoker.py 2014-07-22 20:01:02 UTC (rev 61334)
@@ -21,7 +21,9 @@
TestProgram.USAGE = USAGE_AS_MAIN
from .loader import GrassTestLoader, discover_modules
-from .reporters import GrassTestFilesReporter
+from .reporters import (GrassTestFilesMultiReporter,
+ GrassTestFilesTextReporter,
+ GrassTestFilesHtmlReporter)
from .utils import silent_rmtree, ensure_dir
import grass.script.setup as gsetup
@@ -125,7 +127,11 @@
if os.path.abspath(results_dir) == os.path.abspath(self.start_dir):
raise RuntimeError("Results root directory should not be the same"
" as discovery start directory")
- self.reporter = GrassTestFilesReporter(results_dir=results_dir)
+ self.reporter = GrassTestFilesMultiReporter(
+ reporters=[
+ GrassTestFilesTextReporter(stream=sys.stderr),
+ GrassTestFilesHtmlReporter(),
# TODO: move constants out of loader class or even module
modules = discover_modules(start_dir=self.start_dir,
@@ -137,6 +143,7 @@
universal_location_value=GrassTestLoader.universal_tests_value,
import_modules=False)
+ self.reporter.start(results_dir)
for module in modules:
self._run_test_module(module=module, results_dir=results_dir,
gisdbase=gisdbase, location=location)
Modified: grass/trunk/lib/python/gunittest/reporters.py
--- grass/trunk/lib/python/gunittest/reporters.py 2014-07-22 19:57:51 UTC (rev 61333)
+++ grass/trunk/lib/python/gunittest/reporters.py 2014-07-22 20:01:02 UTC (rev 61334)
@@ -13,7 +13,6 @@
import os
-import sys
import datetime
import xml.sax.saxutils as saxutils
import xml.etree.ElementTree as et
@@ -67,7 +66,8 @@
def get_svn_revision():
"""Get SVN revision number
- :returns: SVN revision number as string or None if it is not possible to get
+ :returns: SVN revision number as string or None if it is
+ not possible to get
# TODO: here should be starting directory
# but now we are using current as starting
@@ -131,16 +131,118 @@
return None
-class GrassTestFilesReporter(object):
+class GrassTestFilesMultiReporter(object):
- def __init__(self, results_dir):
+ def __init__(self, reporters, forgiving=False):
+ self.reporters = reporters
+ self.forgiving = forgiving
+ def start(self, results_dir):
# TODO: no directory cleaning (self.clean_before)? now cleaned by caller
+ # TODO: perhaps only those whoe need it should do it (even multiple times)
+ # and there is also the delet problem
ensure_dir(os.path.abspath(results_dir))
+ for reporter in self.reporters:
+ try:
+ reporter.start(results_dir)
+ except AttributeError:
+ if self.forgiving:
+ pass
+ else:
+ raise
+ def finish(self):
+ try:
+ reporter.finish()
+ pass
+ else:
+ raise
+ def start_file_test(self, module):
+ try:
+ reporter.start_file_test(module)
+ pass
+ else:
+ raise
+ def end_file_test(self, module, cwd, returncode, stdout, stderr):
+ try:
+ reporter.end_file_test(module, cwd, returncode, stdout, stderr)
+ pass
+ else:
+ raise
+class GrassTestFilesCountingReporter(object):
+ def __init__(self):
+ self.test_files = None
+ self.files_fail = None
+ self.files_pass = None
+ self.file_pass_per = None
+ self.file_fail_per = None
+ self.main_start_time = None
+ self.main_end_time = None
+ self.main_time = None
+ self.file_start_time = None
+ self.file_end_time = None
+ self.file_time = None
+ self._start_file_test_called = False
+ self.test_files = 0
+ self.files_fail = 0
+ self.files_pass = 0
+ # this might be moved to some report start method
+ self.main_start_time = datetime.datetime.now()
+ def finish(self):
+ self.main_end_time = datetime.datetime.now()
+ self.main_time = self.main_end_time - self.main_start_time
+ assert self.test_files == self.files_fail + self.files_pass
+ self.file_pass_per = 100 * float(self.files_pass) / self.test_files
+ self.file_fail_per = 100 * float(self.files_fail) / self.test_files
+ self.file_start_time = datetime.datetime.now()
+ self._start_file_test_called = True
+ self.test_files += 1
+ assert self._start_file_test_called
+ self.file_end_time = datetime.datetime.now()
+ self.file_time = self.file_end_time - self.file_start_time
+ if returncode:
+ self.files_fail += 1
+ else:
+ self.files_pass += 1
+class GrassTestFilesHtmlReporter(GrassTestFilesCountingReporter):
+ super(GrassTestFilesHtmlReporter, self).__init__()
+ self.main_index = None
+ super(GrassTestFilesHtmlReporter, self).start(results_dir)
# having all variables public although not really part of API
self.main_index = open(os.path.join(results_dir, 'index.html'), 'w')
- # this might be moved to some report start method
- self.main_start_time = datetime.datetime.now()
svn_info = get_svn_info()
if not svn_info:
svn_text = ('<span style="font-size: 60%">'
@@ -165,19 +267,10 @@
'</tr></thead><tbody>'.format(
time=self.main_start_time,
svn=svn_text))
- self.file_start_time = None
- self._start_file_test_called = False
- self.test_files = 0
- self.files_failed = 0
- self.files_succeeded = 0
def finish(self):
- main_end_time = datetime.datetime.now()
- main_time = main_end_time - self.main_start_time
- assert self.test_files == self.files_failed + self.files_succeeded
+ super(GrassTestFilesHtmlReporter, self).finish()
- file_success_per = 100 * float(self.files_succeeded) / self.test_files
- file_fail_per = 100 * float(self.files_failed) / self.test_files
tfoot = ('<tfoot>'
'<tr>'
'<td>Summary</td>'
@@ -185,7 +278,7 @@
'<td>{nsper:.2f}% successful</td>'
'</tr>'
'</tfoot>'.format(nfiles=self.test_files,
- nsper=file_success_per))
+ nsper=self.file_pass_per))
summary_sentence = ('Executed {nfiles} test files in {time:}.'
' From them'
@@ -193,11 +286,11 @@
' and {nffiles} files ({nfper:.2f}%) failed.'
.format(
- time=main_time,
- nsfiles=self.files_succeeded,
- nffiles=self.files_failed,
- nsper=file_success_per,
- nfper=file_fail_per))
+ time=self.main_time,
+ nsfiles=self.files_pass,
+ nffiles=self.files_fail,
+ nsper=self.file_pass_per,
+ nfper=self.file_fail_per))
self.main_index.write('<tbody>{tfoot}</table>'
'<p>{summary}</p>'
@@ -208,10 +301,8 @@
self.main_index.close()
- self.file_start_time = datetime.datetime.now()
- self._start_file_test_called = True
- self.main_index.flush() # to get previous ones to the report
- self.test_files += 1
+ super(GrassTestFilesHtmlReporter, self).start_file_test(module)
+ self.main_index.flush() # to get previous lines to the report
def wrap_stdstream_to_html(self, infile, outfile, module, stream):
before = '<html><body><h1>%s</h1><pre>' % (module.name + ' ' + stream)
@@ -232,13 +323,16 @@
def returncode_to_html_sentence(self, returncode):
if returncode:
- return '<span style="color: red">❌</span> Test failed (return code %d)' % (returncode)
+ return ('<span style="color: red">❌</span>'
+ ' Test failed (return code %d)' % (returncode))
else:
- return '<span style="color: green">✓</span> Test succeeded (return code %d)' % (returncode)
+ return ('<span style="color: green">✓</span>'
+ ' Test succeeded (return code %d)' % (returncode))
- assert self._start_file_test_called
- file_time = datetime.datetime.now() - self.file_start_time
+ super(GrassTestFilesHtmlReporter, self).end_file_test(
+ module=module, cwd=cwd, returncode=returncode,
+ stdout=stdout, stderr=stderr)
'<tr><td>{d}</td>'
'<td><a href="{d}/{m}/index.html">{m}</a></td><td>{sf}</td>'
@@ -253,27 +347,69 @@
module=module, stream='stderr')
file_index_path = os.path.join(cwd, 'index.html')
file_index = open(file_index_path, 'w')
- file_index.write('<html><body>'
- '<h1>{m.name}</h1>'
- '<h2>{m.tested_dir} – {m.name}</h2>'
- '<p>{status}'
- '<p>Test duration: {dur}'
- '<ul>'
- '<li><a href="stdout.html">standard output (stdout)</a>'
- '<li><a href="stderr.html">standard error output (stderr)</a>'
- '<li><a href="testcodecoverage/index.html">code coverage</a>'
- '</ul>'
- '</body></html>'.format(
- dur=file_time, m=module,
- status=self.returncode_to_html_sentence(returncode)))
+ file_index.write(
+ '<html><body>'
+ '<h1>{m.name}</h1>'
+ '<h2>{m.tested_dir} – {m.name}</h2>'
+ '<p>{status}'
+ '<p>Test duration: {dur}'
+ '<ul>'
+ '<li><a href="stdout.html">standard output (stdout)</a>'
+ '<li><a href="stderr.html">standard error output (stderr)</a>'
+ '<li><a href="testcodecoverage/index.html">code coverage</a>'
+ '</ul>'
+ '</body></html>'
+ .format(
+ dur=self.file_time, m=module,
+ status=self.returncode_to_html_sentence(returncode)))
file_index.close()
if returncode:
- sys.stderr.write('{d}/{m} failed (see {f})\n'.format(d=module.tested_dir,
- m=module.name,
- f=file_index_path))
- self.files_failed += 1
- else:
- self.files_succeeded += 1
+ pass
+ # TODO: here we don't have oportunity to write error file
+ # to stream (stdout/stderr)
+ # a stream can be added and if not none, we could write
+class GrassTestFilesTextReporter(GrassTestFilesCountingReporter):
+ def __init__(self, stream):
+ super(GrassTestFilesTextReporter, self).__init__()
+ self._stream = stream
+ super(GrassTestFilesTextReporter, self).start(results_dir)
+ def finish(self):
+ super(GrassTestFilesTextReporter, self).finish()
+ summary_sentence = ('\nExecuted {nfiles} test files in {time:}.'
+ '\nFrom them'
+ ' {nsfiles} files ({nsper:.2f}%) were successful'
+ ' and {nffiles} files ({nfper:.2f}%) failed.\n'
+ .format(
+ nfiles=self.test_files,
+ self._stream.write(summary_sentence)
+ super(GrassTestFilesTextReporter, self).start_file_test(module)
+ self._stream.flush() # to get previous lines to the report
+ super(GrassTestFilesTextReporter, self).end_file_test(
+ if returncode:
+ '{m} from {d} failed\n'
+ .format(
+ d=module.tested_dir,
+ m=module.name))
+ # TODO: here we lost the possibility to include also file name
+ # of the appropriate report
