[GRASS-SVN] r61338 - in grass/branches/releasebranch_7_0: . raster/r.patch
svn_grass at osgeo.org
Tue Jul 22 13:54:12 PDT 2014
Author: neteler
Date: 2014-07-22 13:54:12 -0700 (Tue, 22 Jul 2014)
New Revision: 61338
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/raster/r.patch/do_patch.c
r.patch: rename G_is_zero_value to is_zero_value (trunk, r60835)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:60219,60278,60610,60807,60936-60937,61275,61288,61290,61292,61294,61301
+ /grass/trunk:60219,60278,60610,60807,60835,60936-60937,61275,61288,61290,61292,61294,61301
Modified: grass/branches/releasebranch_7_0/raster/r.patch/do_patch.c
--- grass/branches/releasebranch_7_0/raster/r.patch/do_patch.c 2014-07-22 20:51:08 UTC (rev 61337)
+++ grass/branches/releasebranch_7_0/raster/r.patch/do_patch.c 2014-07-22 20:54:12 UTC (rev 61338)
@@ -9,7 +9,7 @@
* 0 the result contains no zero nulls
-int G_is_zero_value(void *rast, RASTER_MAP_TYPE data_type)
+int is_zero_value(void *rast, RASTER_MAP_TYPE data_type)
/* insert 0 check here */
@@ -28,14 +28,14 @@
more = 0;
while (ncols-- > 0) {
if (use_zero) { /* use 0 for transparency instead of NULL */
- if (G_is_zero_value(result, out_type) ||
+ if (is_zero_value(result, out_type) ||
Rast_is_null_value(result, out_type)) {
/* Don't patch hole with a null, just mark as more */
if (Rast_is_null_value(patch, out_type))
more = 1;
else {
/* Mark that there is more to be done if we patch with 0 */
- if (G_is_zero_value(patch, out_type))
+ if (is_zero_value(patch, out_type))
more = 1;
Rast_raster_cpy(result, patch, 1, out_type);
if (out_type == CELL_TYPE)
