[GRASS-SVN] r61352 - grass/trunk/lib/gis
Tue Jul 22 16:49:30 PDT 2014
Author: glynn
Date: 2014-07-22 16:49:30 -0700 (Tue, 22 Jul 2014)
New Revision: 61352
   grass/trunk/lib/gis/lrand48.c
Add documentation comments
Generate fatal error if requesting values without having seeded
Modified: grass/trunk/lib/gis/lrand48.c
--- grass/trunk/lib/gis/lrand48.c	2014-07-22 23:31:10 UTC (rev 61351)
+++ grass/trunk/lib/gis/lrand48.c	2014-07-22 23:49:30 UTC (rev 61352)
@@ -1,3 +1,15 @@
+ * \file lib/gis/lrand48.c
+ * \brief GIS Library - Pseudo-random number generation
+ * (C) 2014 by the GRASS Development Team
+ * This program is free software under the GNU General Public License
+ * (>=v2). Read the file COPYING that comes with GRASS for details.
+ * \author Glynn Clements
 #include <stdio.h>
 #include <stdlib.h>
@@ -27,17 +39,35 @@
 static const uint32 b0 = 0xB;
+static int seeded;
 #define LO(x) ((x) & 0xFFFFU)
 #define HI(x) ((x) >> 16)
+ * \brief Seed the pseudo-random number generator
+ * \param seedval 32-bit integer used to seed the PRNG
 void G_srand48(long seedval)
     uint32 x = (uint32) *(unsigned long *)&seedval;
     x2 = (uint16) HI(x);
     x1 = (uint16) LO(x);
     x0 = (uint16) 0x330E;
+    seeded = 1;
+ * \brief Seed the pseudo-random number generator from the time and PID
+ * A weak hash of the current time and PID is generated and used to
+ * seed the PRNG
+ * \return generated seed value passed to G_srand48()
 long G_srand48_auto(void)
     unsigned long seed = (unsigned long) getpid();
@@ -74,6 +104,9 @@
     uint32 y1 = LO(a0x1) + LO(a1x0) + HI(a0x0);
     uint32 y2 = LO(a0x2) + LO(a1x1) + LO(a2x0) + HI(a0x1) + HI(a1x0);
+    if (!seeded)
+	G_fatal_error(_("Pseudo-random number generator not seeded"));
     x0 = (uint16) LO(y0);
     y1 += HI(y0);
     x1 = (uint16) LO(y1);
@@ -81,6 +114,12 @@
     x2 = (uint16) LO(y2);
+ * \brief Generate an integer in the range [0, 2^31)
+ * \return the generated value
 long G_lrand48(void)
     uint32 r;
@@ -89,6 +128,12 @@
     return (long) r;
+ * \brief Generate an integer in the range [-2^31, 2^31)
 long G_mrand48(void)
     uint32 r;
@@ -97,6 +142,12 @@
     return (long) (int32) r;
+ * \brief Generate a floating-point value in the range [0,1)
 double G_drand48(void)
     double r = 0.0;
