[GRASS-SVN] r61354 - grass/trunk/gui/wxpython/modules
svn_grass at osgeo.org
Tue Jul 22 19:04:34 PDT 2014
Author: annakrat
Date: 2014-07-22 19:04:34 -0700 (Tue, 22 Jul 2014)
New Revision: 61354
grass/trunk/gui/wxpython/modules/mcalc_builder.py
wxGUI/mapcalc: seed handling added to the interface
Modified: grass/trunk/gui/wxpython/modules/mcalc_builder.py
--- grass/trunk/gui/wxpython/modules/mcalc_builder.py 2014-07-22 23:51:12 UTC (rev 61353)
+++ grass/trunk/gui/wxpython/modules/mcalc_builder.py 2014-07-23 02:04:34 UTC (rev 61354)
@@ -28,6 +28,7 @@
from core.utils import _
from gui_core.gselect import Select
from gui_core.forms import GUI
+from gui_core.widgets import IntegerValidator
from core.settings import UserSettings
class MapCalcFrame(wx.Frame):
@@ -230,7 +231,18 @@
self.overwrite = wx.CheckBox(parent = self.panel, id = wx.ID_ANY,
label=_("Allow output files to overwrite existing files"))
self.overwrite.SetValue(UserSettings.Get(group='cmd', key='overwrite', subkey='enabled'))
+ self.randomSeed = wx.CheckBox(parent=self.panel,
+ label=_("Generate random seed for rand()"))
+ self.randomSeedStaticText = wx.StaticText(parent=self.panel, label=_("Seed:"))
+ self.randomSeedText = wx.TextCtrl(parent=self.panel, size=(100, -1),
+ validator=IntegerValidator())
+ self.randomSeedText.SetToolTipString(_("Integer seed for rand() function"))
+ self.randomSeed.SetValue(True)
+ self.randomSeedStaticText.Disable()
+ self.randomSeedText.Disable()
self.addbox = wx.CheckBox(parent=self.panel,
label=_('Add created raster map into layer tree'), style = wx.NO_BORDER)
self.addbox.SetValue(UserSettings.Get(group='cmd', key='addNewLayer', subkey='enabled'))
@@ -258,6 +270,9 @@
self.newmaptxt.Bind(wx.EVT_TEXT, self.OnUpdateStatusBar)
self.text_mcalc.Bind(wx.EVT_TEXT, self.OnUpdateStatusBar)
self.overwrite.Bind(wx.EVT_CHECKBOX, self.OnUpdateStatusBar)
+ self.randomSeed.Bind(wx.EVT_CHECKBOX, self.OnUpdateStatusBar)
+ self.randomSeed.Bind(wx.EVT_CHECKBOX, self.OnSeedFlag)
+ self.randomSeedText.Bind(wx.EVT_TEXT, self.OnUpdateStatusBar)
self._layout()
@@ -379,7 +394,17 @@
border = 5)
sizer.Add(item = buttonSizer4, proportion = 0,
flag = wx.ALIGN_RIGHT | wx.ALL, border = 3)
+ randomSizer = wx.BoxSizer(wx.HORIZONTAL)
+ randomSizer.Add(item=self.randomSeed, proportion=0,
+ flag=wx.RIGHT | wx.ALIGN_CENTER_VERTICAL, border=20)
+ randomSizer.Add(item=self.randomSeedStaticText, proportion=0,
+ flag=wx.RIGHT | wx.ALIGN_CENTER_VERTICAL, border=5)
+ randomSizer.Add(item=self.randomSeedText, proportion=0)
+ sizer.Add(item=randomSizer, proportion=0,
+ flag=wx.LEFT | wx.RIGHT,
+ border=5)
sizer.Add(item = self.overwrite, proportion = 0,
flag = wx.LEFT | wx.RIGHT,
border = 5)
@@ -458,6 +483,13 @@
self.SetStatusText(command)
event.Skip()
+ def OnSeedFlag(self, event):
+ checked = self.randomSeed.IsChecked()
+ self.randomSeedText.Enable(not checked)
+ self.randomSeedStaticText.Enable(not checked)
+ event.Skip()
def _getCommand(self):
"""Returns entire command as string."""
expr = self.text_mcalc.GetValue().strip().replace("\n", " ")
@@ -467,10 +499,17 @@
overwrite = ''
if self.overwrite.IsChecked():
overwrite = ' --overwrite'
- return '{cmd} "{new} = {expr}"{overwrite}'.format(cmd=cmd, expr=expr,
- new=self.newmaptxt.GetValue(),
- overwrite=overwrite)
+ seed_flag = seed = ''
+ if re.search(pattern="rand *\(.+\)", string=expr):
+ if self.randomSeed.IsChecked():
+ seed_flag = ' -s'
+ else:
+ seed = " seed={val}".format(val=self.randomSeedText.GetValue().strip())
+ return ('{cmd} "{new} = {expr}"{seed}{seed_flag}{overwrite}'
+ .format(cmd=cmd, expr=expr, new=self.newmaptxt.GetValue(),
+ seed_flag=seed_flag, seed=seed, overwrite=overwrite))
def _addSomething(self, what):
"""Inserts operators, map names, and functions into text area
@@ -520,11 +559,23 @@
message = _("You must enter an expression "
"to create a new raster map."))
return
+ seed_flag = seed = None
+ seed_flag = '-s'
+ else:
+ seed = self.randomSeedText.GetValue().strip()
if self.log:
- cmd = [self.cmd, str('expression=%s = %s' % (name, expr))]
+ cmd = [self.cmd]
+ if seed_flag:
+ cmd.append('-s')
+ if seed:
+ cmd.append("seed={val}".format(val=seed))
cmd.append('--overwrite')
+ cmd.append(str('expression=%s = %s' % (name, expr)))
self.log.RunCmd(cmd, onDone = self.OnDone)
self.parent.Raise()
else:
@@ -532,10 +583,16 @@
overwrite = True
else:
overwrite = False
+ params = dict(expression="%s=%s" % (name, expr),
+ overwrite=overwrite)
+ if seed_flag:
+ params['flags'] = 's'
+ if seed:
+ params['seed'] = seed
RunCommand(self.cmd,
- expression = "%s=%s" % (name, expr),
- overwrite = overwrite)
+ **params)
def OnDone(self, cmd, returncode):
"""Add create map to the layer tree
