[GRASS-SVN] r61358 - in grass/trunk: lib/init temporal/t.rast.neighbors
svn_grass at osgeo.org
Wed Jul 23 00:37:34 PDT 2014
Author: martinl
Date: 2014-07-23 00:37:34 -0700 (Wed, 23 Jul 2014)
New Revision: 61358
grass/trunk/lib/init/variables.html
grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.html
GRASS_RND_SEED replaced by seed= (see r61353)
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html 2014-07-23 02:35:53 UTC (rev 61357)
+++ grass/trunk/lib/init/variables.html 2014-07-23 07:37:34 UTC (rev 61358)
@@ -201,11 +201,6 @@
<dd>[used during install process for generating man pages]<br>
set Perl with path.</dd>
- <dt>GRASS_RND_SEED</dt>
- <dd>set random seed
- for <em><a href="r.mapcalc.html">r.mapcalc</a></em> rand()
- function.</dd>
<dt>GRASS_SKIP_MAPSET_OWNER_CHECK</dt>
<dd>By default it is not possible to work with MAPSETs that are
not owned by current user. Setting this variable to any non-empty value
Modified: grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.html
--- grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.html 2014-07-23 02:35:53 UTC (rev 61357)
+++ grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.html 2014-07-23 07:37:34 UTC (rev 61358)
@@ -34,8 +34,7 @@
count=1
for map in ${MAPS} ; do
- export GRASS_RND_SEED=${count}
- r.mapcalc --o expr="${map} = rand(0, 550)"
+ r.mapcalc --o expr="${map} = rand(0, 550)" seed=${count}
echo ${map} >> map_list.txt
count=$((count+1))
done
