[GRASS-SVN] r61380 - in grass/trunk/lib: gis init raster
svn_grass at osgeo.org
Wed Jul 23 14:06:07 PDT 2014
Author: glynn
Date: 2014-07-23 14:06:07 -0700 (Wed, 23 Jul 2014)
New Revision: 61380
grass/trunk/lib/gis/G.h
grass/trunk/lib/gis/flate.c
grass/trunk/lib/gis/gisinit.c
grass/trunk/lib/init/variables.html
grass/trunk/lib/raster/init.c
Enable zlib compression by default (set GRASS_INT_ZLIB=0 to use RLE)
Allow zlib compression to be set via GRASS_ZLIB_LEVEL environment variable
Modified: grass/trunk/lib/gis/G.h
--- grass/trunk/lib/gis/G.h 2014-07-23 19:11:04 UTC (rev 61379)
+++ grass/trunk/lib/gis/G.h 2014-07-23 21:06:07 UTC (rev 61380)
@@ -6,6 +6,7 @@
struct Cell_head window; /* Contains the current window */
int window_set; /* Flag: window set? */
int little_endian; /* Flag denoting little-endian architecture */
+ int compression_level; /* zlib compression level */
extern struct G__ G__; /* allocated in gisinit */
Modified: grass/trunk/lib/gis/flate.c
--- grass/trunk/lib/gis/flate.c 2014-07-23 19:11:04 UTC (rev 61379)
+++ grass/trunk/lib/gis/flate.c 2014-07-23 21:06:07 UTC (rev 61380)
@@ -123,6 +123,8 @@
#include <unistd.h>
#include <grass/gis.h>
+#include "G.h"
#define G_ZLIB_COMPRESSED_NO (unsigned char)'0'
#define G_ZLIB_COMPRESSED_YES (unsigned char)'1'
@@ -327,7 +329,9 @@
c_stream.next_out = buf;
/* Initialize using default compression (usually 6) */
- err = deflateInit(&c_stream, Z_DEFAULT_COMPRESSION);
+ err = deflateInit(&c_stream, G__.compression_level < 0
+ ? Z_DEFAULT_COMPRESSION
+ : G__.compression_level);
/* If there was an error initializing, return -1 */
if (err != Z_OK) {
Modified: grass/trunk/lib/gis/gisinit.c
--- grass/trunk/lib/gis/gisinit.c 2014-07-23 19:11:04 UTC (rev 61379)
+++ grass/trunk/lib/gis/gisinit.c 2014-07-23 21:06:07 UTC (rev 61380)
@@ -14,6 +14,7 @@
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
+#include <ctype.h>
#include <unistd.h>
#include <fcntl.h>
#include <sys/stat.h>
@@ -105,6 +106,8 @@
static int gisinit(void)
+ char *zlib;
#ifdef __MINGW32__
_fmode = O_BINARY;
#endif
@@ -114,6 +117,9 @@
/* byte order */
G__.little_endian = G_is_little_endian();
+ zlib = getenv("GRASS_ZLIB_LEVEL");
+ G__.compression_level = (zlib && *zlib && isdigit(*zlib)) ? atoi(zlib) : -1;
initialized = 1;
setlocale(LC_NUMERIC, "C");
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html 2014-07-23 19:11:04 UTC (rev 61379)
+++ grass/trunk/lib/init/variables.html 2014-07-23 21:06:07 UTC (rev 61380)
@@ -161,13 +161,24 @@
<key>, without the bracketing <string> tags.</dd>
<dt>GRASS_INT_ZLIB</dt>
- <dd>[libgis]<br> if the environment variable GRASS_INT_ZLIB exists,
+ <dd>[libraster]<br> if the environment variable GRASS_INT_ZLIB exists and has the value 0,
new compressed <i>integer</i> (CELL type) raster maps will be compressed
- using zlib instead of RLE compression. Such rasters will have a <tt>compressed</tt>
+ using RLE compression.
+ <br><br>
+ If the variable doesn't exist, or the value is non-zero, zlib compression
+ will be used instead. Such rasters will have a <tt>compressed</tt>
value of 2 in the cellhd file.
<br><br>
Obviously, decompression is controlled by the
raster's <tt>compressed</tt> value, not the environment variable.</dd>
+ <dt>GRASS_ZLIB_LEVEL</dt>
+ <dd>[libgis]<br> if the environment variable GRASS_ZLIB_LEVEL exists and its value can
+ be parsed as an integer, it determines the compression level used when new compressed
+ <i>integer</i> (CELL type) raster maps are compressed using zlib compression.
+ <br><br>
+ If the variable doesn't exist, or the value cannot be parsed as an
+ integer, zlib's default compression level will be used.</dd>
<dt>GRASS_MESSAGE_FORMAT</dt>
<dd>[various modules, wxGUI]<br>
Modified: grass/trunk/lib/raster/init.c
--- grass/trunk/lib/raster/init.c 2014-07-23 19:11:04 UTC (rev 61379)
+++ grass/trunk/lib/raster/init.c 2014-07-23 21:06:07 UTC (rev 61380)
@@ -77,6 +77,8 @@
static int init(void)
+ char *zlib;
Rast__init_window();
/* no histograms */
@@ -90,8 +92,10 @@
R__.mask_fd = -1;
R__.nbytes = sizeof(CELL);
- R__.compression_type = getenv("GRASS_INT_ZLIB") ? 2 : 1;
+ zlib = getenv("GRASS_INT_ZLIB");
+ R__.compression_type = (!zlib || atoi(zlib)) ? 2 : 1;
G_add_error_handler(Rast__error_handler, NULL);
initialized = 1;
