[GRASS-SVN] r61394 - in grass/trunk/lib/python/gunittest: . testsuite/data/samplecode/submodule_errors/subsubmodule_errors/testsuite testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite testsuite/data/samplecode/submodule_test_fail/testsuite testsuite/data/samplecode/testsuite
svn_grass at osgeo.org
Thu Jul 24 18:53:39 PDT 2014
Author: wenzeslaus
Date: 2014-07-24 18:53:39 -0700 (Thu, 24 Jul 2014)
New Revision: 61394
Added:
grass/trunk/lib/python/gunittest/testsuite/data/samplecode/testsuite/test_good_and_bad.py
grass/trunk/lib/python/gunittest/testsuite/data/samplecode/testsuite/test_python_unittest.py
grass/trunk/lib/python/gunittest/reporters.py
grass/trunk/lib/python/gunittest/runner.py
grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_errors/testsuite/test_error.py
grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_errors/testsuite/test_import_error.py
grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite/test_gfatalerror.py
grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite/test_osexit_one.py
grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite/test_osexit_zero.py
grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite/test_segfaut.py
grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite/test_sysexit_one.py
grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite/test_sysexit_zero.py
grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_test_fail/testsuite/test_fail.py
grass/trunk/lib/python/gunittest/testsuite/data/samplecode/testsuite/test_success.py
gunittest: count (and store) successful tests to get the right number; use gunittest for gunittest's test data
Modified: grass/trunk/lib/python/gunittest/reporters.py
--- grass/trunk/lib/python/gunittest/reporters.py 2014-07-25 00:16:19 UTC (rev 61393)
+++ grass/trunk/lib/python/gunittest/reporters.py 2014-07-25 01:53:39 UTC (rev 61394)
@@ -342,7 +342,8 @@
if returncode:
return '<span style="color: red">FAILED</span>'
else:
- return '<span style="color: green">succeeded</span>' # SUCCEEDED
+ # alternatives: SUCCEEDED, passed, OK
+ return '<span style="color: green">succeeded</span>'
def returncode_to_html_sentence(self, returncode):
if returncode:
@@ -368,18 +369,18 @@
# TODO: add success counter to GrassTestResult base class
skipped = test_summary.get('skipped', 0)
expected_failures = test_summary.get('expected_failures', 0)
- unexpected_success = test_summary.get('unexpected_success', 0)
+ unexpected_successes = test_summary.get('unexpected_successes', 0)
+ successes = test_summary.get('successes', 0)
self.failures += failures
self.errors += errors
self.skiped += skipped
self.expected_failures += expected_failures
- self.unexpected_success += unexpected_success
+ self.unexpected_success += unexpected_successes
if total is not None:
# success are only the clear ones
# percentage is influenced by all but putting only failures to table
- successes = total - failures - errors - skipped - expected_failures - unexpected_success
self.successes += successes
self.total += total
Modified: grass/trunk/lib/python/gunittest/runner.py
--- grass/trunk/lib/python/gunittest/runner.py 2014-07-25 00:16:19 UTC (rev 61393)
+++ grass/trunk/lib/python/gunittest/runner.py 2014-07-25 01:53:39 UTC (rev 61394)
@@ -18,7 +18,7 @@
import sys
import time
-from unittest.result import TestResult
+import unittest.result
from unittest.signals import registerResult
__unittest = True
@@ -40,6 +40,29 @@
self.write('\n') # text-mode streams translate to \r\n if needed
+class TestResult(unittest.result.TestResult):
+ # descriptions and verbosity unused
+ # included for compatibility with unittest's TestResult
+ # where are also unused, so perhaps we can remove them
+ # stream set to None and not included in interface, it would not make sense
+ def __init__(self, stream=None, descriptions=None, verbosity=None):
+ super(TestResult, self).__init__(
+ stream=stream, descriptions=descriptions, verbosity=verbosity)
+ self.successes = []
+ def addSuccess(self, test):
+ super(TestResult, self).addSuccess(test)
+ self.successes.append(test)
+ # TODO: better would be to pass start at the beginning
+ # alternative is to leave counting time on class
+ # TODO: document: we expect all grass classes to have setTimes
+ # TODO: alternatively, be more forgiving for non-unittest methods
+ def setTimes(self, start_time, end_time, time_taken):
+ pass
+ # TODO: implement this
class TextTestResult(TestResult):
"""A test result class that can print formatted text results to a stream.
@@ -231,17 +254,20 @@
# 'date={start_datetime}\n'
# 'date={end_datetime}\n'
+ failed, errored = map(len, (self.failures, self.errors))
+ succeeded = len(self.successes)
results = map(len, (self.expectedFailures,
self.unexpectedSuccesses,
self.skipped))
expectedFails, unexpectedSuccesses, skipped = results
- infos.append("status=%s" % ('failed' if self.wasSuccessful() else 'passed'))
+ status = 'succeeded' if self.wasSuccessful() else 'failed'
+ infos.append("status=%s" % status)
+ infos.append("total=%d" % (run))
- infos.append("total=%d" % (run))
- failed, errored = map(len, (self.failures, self.errors))
infos.append("failures=%d" % failed)
infos.append("errors=%d" % errored)
+ infos.append("successes=%d" % succeeded)
infos.append("skipped=%d" % skipped)
# TODO: document this: if not supported by view,
@@ -314,7 +340,7 @@
super(MultiTestResult, self).addError(test, err)
for result in self._results:
try:
- result.addSuccess(test)
+ result.addError(test, err)
except AttributeError:
if self._forgiving:
pass
@@ -325,7 +351,7 @@
super(MultiTestResult, self).addFailure(test, err)
try:
+ result.addFailure(test, err)
if self._forgiving:
pass
@@ -336,7 +362,7 @@
super(MultiTestResult, self).addSkip(test, reason)
try:
+ result.addSuccess(test, reason)
if self._forgiving:
pass
@@ -347,7 +373,7 @@
super(MultiTestResult, self).addExpectedFailure(test, err)
try:
+ result.addExpectedFailure(test, err)
if self._forgiving:
pass
@@ -358,7 +384,7 @@
super(MultiTestResult, self).addUnexpectedSuccess(test)
try:
+ result.addUnexpectedSuccess(test)
if self._forgiving:
pass
Modified: grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_errors/testsuite/test_error.py
--- grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_errors/testsuite/test_error.py 2014-07-25 00:16:19 UTC (rev 61393)
+++ grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_errors/testsuite/test_error.py 2014-07-25 01:53:39 UTC (rev 61394)
@@ -1,7 +1,6 @@
# -*- coding: utf-8 -*-
-# TODO: change to GrassTestCase
-from unittest import TestCase
+from grass.gunittest import TestCase, test
class TestError(TestCase):
@@ -55,5 +54,4 @@
if __name__ == '__main__':
- import unittest
- unittest.main()
+ test()
Modified: grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_errors/testsuite/test_import_error.py
--- grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_errors/testsuite/test_import_error.py 2014-07-25 00:16:19 UTC (rev 61393)
+++ grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_errors/testsuite/test_import_error.py 2014-07-25 01:53:39 UTC (rev 61394)
@@ -1,11 +1,10 @@
# comment to get rid of the wrong import
-# (if it is imported before all tests start)
+# (if it is imported before all tests start and everything would fail)
#import this_module_or_package_does_not_exists__testing_import_error
class TestNeverCalled(TestCase):
@@ -14,11 +13,9 @@
def test_something(self):
self.assertFalse("This should not be called"
" if we are testing failed import."
- " But it is good OK if one wrong import"
- " would prevent other tests from running"
- " due to the implementation of test invocation.")
+ " It is all right if this fails and the wrong"
+ " import is commented.")
- import unittest
- unittest.main()
+ test()
Modified: grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite/test_gfatalerror.py
--- grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite/test_gfatalerror.py 2014-07-25 00:16:19 UTC (rev 61393)
+++ grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite/test_gfatalerror.py 2014-07-25 01:53:39 UTC (rev 61394)
@@ -1,11 +1,9 @@
import grass.lib.gis as libgis
class TestGFatalError(TestCase):
# pylint: disable=R0904
@@ -14,5 +12,4 @@
- import unittest
- unittest.main()
+ test()
Modified: grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite/test_osexit_one.py
--- grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite/test_osexit_one.py 2014-07-25 00:16:19 UTC (rev 61393)
+++ grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite/test_osexit_one.py 2014-07-25 01:53:39 UTC (rev 61394)
@@ -1,11 +1,9 @@
import os
class TestOsExit(TestCase):
@@ -14,5 +12,4 @@
- import unittest
- unittest.main()
+ test()
Modified: grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite/test_osexit_zero.py
--- grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite/test_osexit_zero.py 2014-07-25 00:16:19 UTC (rev 61393)
+++ grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite/test_osexit_zero.py 2014-07-25 01:53:39 UTC (rev 61394)
@@ -1,11 +1,9 @@
import os
@@ -14,5 +12,4 @@
- import unittest
- unittest.main()
+ test()
Modified: grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite/test_segfaut.py
--- grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite/test_segfaut.py 2014-07-25 00:16:19 UTC (rev 61393)
+++ grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite/test_segfaut.py 2014-07-25 01:53:39 UTC (rev 61394)
@@ -1,11 +1,9 @@
import ctypes
class TestSegfault(TestCase):
@@ -21,5 +19,4 @@
- import unittest
- unittest.main()
+ test()
Modified: grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite/test_sysexit_one.py
--- grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite/test_sysexit_one.py 2014-07-25 00:16:19 UTC (rev 61393)
+++ grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite/test_sysexit_one.py 2014-07-25 01:53:39 UTC (rev 61394)
@@ -1,11 +1,9 @@
import sys
class TestSysExit(TestCase):
@@ -14,5 +12,4 @@
- import unittest
- unittest.main()
+ test()
Modified: grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite/test_sysexit_zero.py
--- grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite/test_sysexit_zero.py 2014-07-25 00:16:19 UTC (rev 61393)
+++ grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_errors/subsubmodule_exiting/testsuite/test_sysexit_zero.py 2014-07-25 01:53:39 UTC (rev 61394)
@@ -1,11 +1,9 @@
import sys
@@ -14,5 +12,4 @@
- import unittest
- unittest.main()
+ test()
Modified: grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_test_fail/testsuite/test_fail.py
--- grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_test_fail/testsuite/test_fail.py 2014-07-25 00:16:19 UTC (rev 61393)
+++ grass/trunk/lib/python/gunittest/testsuite/data/samplecode/submodule_test_fail/testsuite/test_fail.py 2014-07-25 01:53:39 UTC (rev 61394)
@@ -1,7 +1,6 @@
class TestFail(TestCase):
@@ -12,5 +11,4 @@
- import unittest
- unittest.main()
+ test()
Added: grass/trunk/lib/python/gunittest/testsuite/data/samplecode/testsuite/test_good_and_bad.py
--- grass/trunk/lib/python/gunittest/testsuite/data/samplecode/testsuite/test_good_and_bad.py (rev 0)
+++ grass/trunk/lib/python/gunittest/testsuite/data/samplecode/testsuite/test_good_and_bad.py 2014-07-25 01:53:39 UTC (rev 61394)
@@ -0,0 +1,23 @@
+# -*- coding: utf-8 -*-
+class TestSuccessAndFailure(TestCase):
+ # pylint: disable=R0904
+ def test_something(self):
+ self.assertTrue(True, msg="This should not fail in test_good_and_bad")
+ def test_something_else(self):
+ def test_something_failing(self):
+ self.assertTrue(False, msg="This failed in test_good_and_bad")
+ def test_something_erroring(self):
+ raise RuntimeError('Some error which was raised')
+if __name__ == '__main__':
+ test()
Property changes on: grass/trunk/lib/python/gunittest/testsuite/data/samplecode/testsuite/test_good_and_bad.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
Added: grass/trunk/lib/python/gunittest/testsuite/data/samplecode/testsuite/test_python_unittest.py
--- grass/trunk/lib/python/gunittest/testsuite/data/samplecode/testsuite/test_python_unittest.py (rev 0)
+++ grass/trunk/lib/python/gunittest/testsuite/data/samplecode/testsuite/test_python_unittest.py 2014-07-25 01:53:39 UTC (rev 61394)
@@ -0,0 +1,40 @@
+from unittest import TestCase, main
+class TestUnittestSuccessVerboseSetUp(TestCase):
+ def setUp(self):
+ print "print from setUp"
+ def tearDown(self):
+ print "print from tearDown"
+ self.assertTrue(True, msg="This should not fail")
+ self.assertTrue(False, msg="This should fail")
+class TestUnittestSuccessVerboseClassSetUp(TestCase):
+ @classmethod
+ def setUpClass(cls):
+ print "print from setUpClass"
+ @classmethod
+ def tearDownClass(cls):
+ print "print from tearDownClass"
+ main()
Property changes on: grass/trunk/lib/python/gunittest/testsuite/data/samplecode/testsuite/test_python_unittest.py
+ text/x-python
+ native
Modified: grass/trunk/lib/python/gunittest/testsuite/data/samplecode/testsuite/test_success.py
--- grass/trunk/lib/python/gunittest/testsuite/data/samplecode/testsuite/test_success.py 2014-07-25 00:16:19 UTC (rev 61393)
+++ grass/trunk/lib/python/gunittest/testsuite/data/samplecode/testsuite/test_success.py 2014-07-25 01:53:39 UTC (rev 61394)
@@ -1,7 +1,6 @@
class TestSuccessVerboseSetUp(TestCase):
@@ -32,5 +31,4 @@
self.assertTrue(True)
- import unittest
- unittest.main()
+ test()
