[GRASS-SVN] r61396 - in grass/trunk/lib/python: pygrass/modules/interface/testsuite pygrass/vector/testsuite temporal/testsuite
Thu Jul 24 19:50:51 PDT 2014
Author: wenzeslaus
Date: 2014-07-24 19:50:51 -0700 (Thu, 24 Jul 2014)
New Revision: 61396
   grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_modules.py
   grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_parameter.py
   grass/trunk/lib/python/pygrass/vector/testsuite/test_geometry.py
   grass/trunk/lib/python/pygrass/vector/testsuite/test_table.py
   grass/trunk/lib/python/pygrass/vector/testsuite/test_vector3d.py
   grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster3d_algebra.py
   grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra.py
testing: use gunittest instead of Python unittest (now key-value summary can be collected)
Modified: grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_modules.py
--- grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_modules.py	2014-07-25 02:46:38 UTC (rev 61395)
+++ grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_modules.py	2014-07-25 02:50:51 UTC (rev 61396)
@@ -4,7 +4,7 @@
 @author: pietro
-import unittest
+from grass.gunittest import TestCase, test
 from grass.script.core import get_commands
 from grass.pygrass.modules.interface import Module
@@ -28,9 +28,9 @@
         return type.__new__(mcs, name, bases, dict)
-class TestModules(unittest.TestCase):
+class TestModules(TestCase):
     __metaclass__ = TestModulesMeta
 if __name__ == '__main__':
-    unittest.main()
+    test()
Modified: grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_parameter.py
--- grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_parameter.py	2014-07-25 02:46:38 UTC (rev 61395)
+++ grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_parameter.py	2014-07-25 02:50:51 UTC (rev 61396)
@@ -5,7 +5,7 @@
 @author: pietro
 from __future__ import print_function
-import unittest
 from grass.pygrass.modules.interface.parameter import Parameter, _check_value
@@ -18,7 +18,7 @@
     'all': lambda x: x,
-class TestCheckValueFunction(unittest.TestCase):
+class TestCheckValueFunction(TestCase):
     def test_single_all(self):
         param = Parameter(diz=dict(name='int_number', required='yes',
@@ -272,7 +272,7 @@
             _check_value(param, "elevation")
-class TestParameterGetBASH(unittest.TestCase):
+class TestParameterGetBash(TestCase):
     def test_single_float_double(self):
         for ptype in ('float', 'double'):
             param = Parameter(diz=dict(name='number', required='yes',
@@ -342,4 +342,4 @@
             _check_value(param, 1)
-    unittest.main()
+    test()
Modified: grass/trunk/lib/python/pygrass/vector/testsuite/test_geometry.py
--- grass/trunk/lib/python/pygrass/vector/testsuite/test_geometry.py	2014-07-25 02:46:38 UTC (rev 61395)
+++ grass/trunk/lib/python/pygrass/vector/testsuite/test_geometry.py	2014-07-25 02:50:51 UTC (rev 61396)
@@ -8,12 +8,14 @@
 import unittest
 import numpy as np
 import grass.lib.vector as libvect
 from grass.pygrass.vector.geometry import Point, Line
-class PointTestCase(unittest.TestCase):
+class PointTestCase(TestCase):
     def test_empty_init(self):
         """Test Point()"""
@@ -83,7 +85,7 @@
         pass
-class LineTestCase(unittest.TestCase):
+class LineTestCase(TestCase):
     def test_len(self):
         """Test __len__ magic method"""
@@ -127,4 +129,4 @@
-    unittest.main()
+    test()
Modified: grass/trunk/lib/python/pygrass/vector/testsuite/test_table.py
--- grass/trunk/lib/python/pygrass/vector/testsuite/test_table.py	2014-07-25 02:46:38 UTC (rev 61395)
+++ grass/trunk/lib/python/pygrass/vector/testsuite/test_table.py	2014-07-25 02:50:51 UTC (rev 61396)
@@ -5,15 +5,14 @@
 @author: pietro
 import os
-import unittest
 import sqlite3
 import tempfile as tmp
 from string import ascii_letters, digits
 from random import choice
 import numpy as np
 from grass.pygrass.vector.table import Table, get_path
@@ -147,7 +146,7 @@
         self.cols = None
-class ColumnsTestCase(DBconnection, unittest.TestCase):
+class ColumnsTestCase(DBconnection, TestCase):
     def test_check_insert_update_str(self):
         """Check insert_str and update_str attribute of Columns are correct"""
@@ -157,7 +156,7 @@
         self.assertEqual(self.cols.update_str, update % self.tname)
-class TableInsertTestCase(DBconnection, unittest.TestCase):
+class TableInsertTestCase(DBconnection, TestCase):
     def setUp(self):
         """Create a not empty table instance"""
@@ -192,7 +191,7 @@
         self.assertListEqual(vals, cur.fetchall())
-class TableUpdateTestCase(DBconnection, unittest.TestCase):
+class TableUpdateTestCase(DBconnection, TestCase):
     def test_update(self):
         """Test Table.update method"""
@@ -206,4 +205,4 @@
-    unittest.main()
+    test()
Modified: grass/trunk/lib/python/pygrass/vector/testsuite/test_vector3d.py
--- grass/trunk/lib/python/pygrass/vector/testsuite/test_vector3d.py	2014-07-25 02:46:38 UTC (rev 61395)
+++ grass/trunk/lib/python/pygrass/vector/testsuite/test_vector3d.py	2014-07-25 02:50:51 UTC (rev 61396)
@@ -4,9 +4,10 @@
 @author: pietro
-import unittest
 import numpy as np
 from grass.script.core import run_command
 from grass.pygrass.vector import VectorTopo
@@ -26,7 +27,7 @@
     return x, y
-class VectorTopo3DTestCase(unittest.TestCase):
+class VectorTopo3DTestCase(TestCase):
     npoints = 10
     tmpname = "tmp_vect3d"
@@ -64,4 +65,4 @@
-    unittest.main()
+    test()
Modified: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster3d_algebra.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster3d_algebra.py	2014-07-25 02:46:38 UTC (rev 61395)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster3d_algebra.py	2014-07-25 02:50:51 UTC (rev 61396)
@@ -11,12 +11,12 @@
 import grass.script
 import grass.temporal as tgis
-import unittest
+import grass.gunittest as gunittest
 import datetime
-import os
-class TestRegisterFunctions(unittest.TestCase):
+class TestRegisterFunctions(gunittest.TestCase):
     @classmethod
     def setUpClass(cls):
         """!Initiate the temporal GIS and set the region
@@ -79,6 +79,4 @@
         grass.script.del_temp_region()
-    unittest.main()
+    gunittest.test()
Modified: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra.py	2014-07-25 02:46:38 UTC (rev 61395)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra.py	2014-07-25 02:50:51 UTC (rev 61396)
@@ -11,12 +11,12 @@
 import grass.script
-import unittest
 import datetime
-import os
     @classmethod
@@ -368,7 +368,6 @@
         ret = grass.script.run_command("t.remove", flags="rf", input="A,B,C", quiet=True)
-if __name__ == '__main__':
-    unittest.main()
+if __name__ == '__main__':
+    gunittest.test()
