[GRASS-SVN] r61400 - grass/trunk/lib/python/gunittest
svn_grass at osgeo.org
Fri Jul 25 06:58:29 PDT 2014
Author: wenzeslaus
Date: 2014-07-25 06:58:29 -0700 (Fri, 25 Jul 2014)
New Revision: 61400
grass/trunk/lib/python/gunittest/invoker.py
grass/trunk/lib/python/gunittest/reporters.py
gunittest: add function to obtain SVN authors and store test file authors to key-value summary
Modified: grass/trunk/lib/python/gunittest/invoker.py
--- grass/trunk/lib/python/gunittest/invoker.py 2014-07-25 09:57:16 UTC (rev 61399)
+++ grass/trunk/lib/python/gunittest/invoker.py 2014-07-25 13:58:29 UTC (rev 61400)
@@ -25,7 +25,7 @@
from .loader import GrassTestLoader, discover_modules
from .reporters import (GrassTestFilesMultiReporter,
GrassTestFilesTextReporter,
- GrassTestFilesHtmlReporter)
+ GrassTestFilesHtmlReporter, get_svn_path_authors)
from .utils import silent_rmtree, ensure_dir
import grass.script.setup as gsetup
@@ -54,6 +54,7 @@
return text
+# TODO: this might be more extend then update
def update_keyval_file(filename, module, returncode):
if os.path.exists(filename):
with open(filename, 'r') as keyval_file:
@@ -61,12 +62,17 @@
else:
keyval = {}
+ # this is for one file
+ # TODO: testing authors are more appropriate stat for testsuite dir index
+ test_file_authors = get_svn_path_authors(module.abs_file_path)
# always owerwrite name and ok
keyval['name'] = module.name
keyval['tested_dir'] = module.tested_dir
if 'status' not in keyval.keys():
keyval['status'] = 'failed' if returncode else 'passed'
keyval['returncode'] = returncode
+ keyval['test_file_authors'] = test_file_authors
with open(filename, 'w') as keyval_file:
keyval_file.write(keyvalue_to_text(keyval))
return keyval
Modified: grass/trunk/lib/python/gunittest/reporters.py
--- grass/trunk/lib/python/gunittest/reporters.py 2014-07-25 09:57:16 UTC (rev 61399)
+++ grass/trunk/lib/python/gunittest/reporters.py 2014-07-25 13:58:29 UTC (rev 61400)
@@ -131,6 +131,45 @@
return None
+def years_ago(date, years):
+ # dateutil relative delte would be better but this is more portable
+ return date - datetime.timedelta(weeks=years * 52)
+# TODO: these functions should be called only if we know that svn is installed
+# this will simplify the functions, caller must handle it anyway
+def get_svn_path_authors(path, from_date=None):
+ :returns: a set of authors
+ if from_date is None:
+ # this is the SVN default for local copies
+ revision_range = 'BASE:1'
+ else:
+ revision_range = 'BASE:{%s}' % from_date
+ try:
+ # TODO: allow also usage of --limit
+ p = subprocess.Popen(['svn', 'log', '--xml',
+ '--revision', revision_range, path],
+ stdout=subprocess.PIPE, stderr=subprocess.PIPE)
+ stdout, stderr = p.communicate()
+ rc = p.poll()
+ if not rc:
+ root = et.fromstring(stdout)
+ # TODO: get also date if this make sense
+ # expecting only one <entry> element
+ author_nodes = root.iterfind('*/author')
+ authors = [n.text for n in author_nodes]
+ return set(authors)
+ except OSError as e:
+ import errno
+ # ignore No such file or directory
+ if e.errno != errno.ENOENT:
+ raise
+ return None
class GrassTestFilesMultiReporter(object):
def __init__(self, reporters, forgiving=False):
@@ -417,6 +456,7 @@
self.wrap_stdstream_to_html(infile=stderr,
outfile=os.path.join(cwd, 'stderr.html'),
module=module, stream='stderr')
file_index_path = os.path.join(cwd, 'index.html')
file_index = open(file_index_path, 'w')
file_index.write(
@@ -433,7 +473,8 @@
'</body></html>'
.format(
dur=self.file_time, m=module,
- status=self.returncode_to_html_sentence(returncode)))
+ status=self.returncode_to_html_sentence(returncode),
file_index.close()
if returncode:
@@ -484,7 +525,8 @@
.format(
d=module.tested_dir,
m=module.name))
- num_failed = test_summary.get('failures', None)
+ num_failed = test_summary.get('failures', 0)
+ num_failed += test_summary.get('errors', 0)
if num_failed:
if num_failed > 1:
text = ' ({f} tests failed)'
