[GRASS-SVN] r61403 - in grass-addons/grass7/raster3d/r3.flow: . testsuite
Fri Jul 25 12:42:31 PDT 2014
Author: annakrat
Date: 2014-07-25 12:42:30 -0700 (Fri, 25 Jul 2014)
New Revision: 61403
Added:
   grass-addons/grass7/raster3d/r3.flow/test.r3flow.html
   grass-addons/grass7/raster3d/r3.flow/test_main.c
   grass-addons/grass7/raster3d/r3.flow/testsuite/
   grass-addons/grass7/raster3d/r3.flow/testsuite/r3flow_test.py
   grass-addons/grass7/raster3d/r3.flow/Makefile
r3.flow: testing module and test added
Modified: grass-addons/grass7/raster3d/r3.flow/Makefile
--- grass-addons/grass7/raster3d/r3.flow/Makefile	2014-07-25 15:21:47 UTC (rev 61402)
+++ grass-addons/grass7/raster3d/r3.flow/Makefile	2014-07-25 19:42:30 UTC (rev 61403)
@@ -1,12 +1,15 @@
 MODULE_TOPDIR = ../..
-PGM=r3.flow
+PROGRAMS = r3.flow test.r3flow
 LIBES = $(RASTER3DLIB) $(RASTERLIB) $(GISLIB) $(VECTORLIB)
 DEPENDENCIES = $(RASTER3DDEP) $(RASTERDEP) $(GISDEP) $(VECTORDEP)
 EXTRA_INC = $(VECT_INC)
 EXTRA_CFLAGS = $(VECT_CFLAGS)
-include $(MODULE_TOPDIR)/include/Make/Module.make
+r3_flow_OBJS = main.o flowline.o gradient.o integrate.o interpolate.o voxel_traversal.o
+test_r3flow_OBJS = test_main.o flowline.o gradient.o integrate.o interpolate.o voxel_traversal.o
-default: cmd
+include $(MODULE_TOPDIR)/include/Make/Multi.make
+default: multi
Added: grass-addons/grass7/raster3d/r3.flow/test.r3flow.html
--- grass-addons/grass7/raster3d/r3.flow/test.r3flow.html	                        (rev 0)
+++ grass-addons/grass7/raster3d/r3.flow/test.r3flow.html	2014-07-25 19:42:30 UTC (rev 61403)
@@ -0,0 +1,14 @@
+<h2>DESCRIPTION</h2>
+Testing module for <em>r3.flow</em>.
+<h2>AUTHORS</h2>
+Anna Petrasova
+<h2>SEE ALSO</h2>
+<em>
+<a href="r3.flow.html">r3.flow</a>
+</em>
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/raster3d/r3.flow/test.r3flow.html
___________________________________________________________________
Added: svn:mime-type
   + text/html
Added: svn:keywords
   + Author Date Id
Added: svn:eol-style
   + native
Added: grass-addons/grass7/raster3d/r3.flow/test_main.c
--- grass-addons/grass7/raster3d/r3.flow/test_main.c	                        (rev 0)
+++ grass-addons/grass7/raster3d/r3.flow/test_main.c	2014-07-25 19:42:30 UTC (rev 61403)
@@ -0,0 +1,105 @@
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <math.h>
+#include <grass/raster3d.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/vector.h>
+#include <grass/glocale.h>
+#include "r3flow_structs.h"
+#include "flowline.h"
+#include "interpolate.h"
+static void test_interpolation(RASTER3D_Region * region,
+			       RASTER3D_Map ** input_maps, double north,
+			       double east, double top)
+    double interpolated[3];
+    if (interpolate_velocity(region, input_maps, north, east, top,
+			     &interpolated[0], &interpolated[1],
+			     &interpolated[2]) < 0) {
+	fprintf(stdout, "return=-1\n");
+    else
+	fprintf(stdout, "return=0\nvalues=%.10f,%.10f,%.10f\n",
+		interpolated[0], interpolated[1], interpolated[2]);
+int main(int argc, char *argv[])
+    int i;
+    struct GModule *module;
+    struct Option *test_opt, *coordinates_opt, *input_opt;
+    RASTER3D_Region region;
+    RASTER3D_Map *input_3drasters[3];
+    double coordinates[3];
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    G_add_keyword(_("raster3d"));
+    G_add_keyword(_("voxel"));
+    G_add_keyword(_("flowline"));
+    module->description = _("Testing flow lines.");
+    test_opt = G_define_option();
+    test_opt->key = "test";
+    test_opt->required = YES;
+    test_opt->type = TYPE_STRING;
+    test_opt->options = "interpolation,gradient";
+    test_opt->description = "Select what is tested";
+    coordinates_opt = G_define_option();
+    coordinates_opt->key = "coordinates";
+    coordinates_opt->required = NO;
+    coordinates_opt->type = TYPE_DOUBLE;
+    coordinates_opt->multiple = YES;
+    coordinates_opt->description = "x,y,z coordinates";
+    input_opt = G_define_standard_option(G_OPT_R3_INPUTS);
+    input_opt->required = NO;
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    Rast3d_init_defaults();
+    Rast3d_get_window(&region);
+    if (strcmp(test_opt->answer, "interpolation") == 0) {
+	if (input_opt->answers) {
+	    for (i = 0; i < 3; i++) {
+		input_3drasters[i] =
+		    Rast3d_open_cell_old(input_opt->answers[i],
+					 G_find_raster3d(input_opt->
+							 answers[i], ""),
+					 &region, RASTER3D_TILE_SAME_AS_FILE,
+					 RASTER3D_USE_CACHE_DEFAULT);
+		if (input_3drasters[i] == NULL)
+		    Rast3d_fatal_error(_("Unable to open 3D raster map <%s>"),
+				       input_opt->answers[i]);
+	else
+	    G_fatal_error("No input map for interpolation test");
+	if (coordinates_opt->answers) {
+		if (coordinates_opt->answers[i]) {
+		    coordinates[i] = atof(coordinates_opt->answers[i]);
+		else
+		    G_fatal_error("Provide 3 coordinates");
+	else
+	    G_fatal_error("No coordinates for interpolation test");
+	test_interpolation(&region, input_3drasters, coordinates[1],
+			   coordinates[0], coordinates[2]);
+    return EXIT_SUCCESS;
Property changes on: grass-addons/grass7/raster3d/r3.flow/test_main.c
   + text/x-csrc
   + native
Added: grass-addons/grass7/raster3d/r3.flow/testsuite/r3flow_test.py
--- grass-addons/grass7/raster3d/r3.flow/testsuite/r3flow_test.py	                        (rev 0)
+++ grass-addons/grass7/raster3d/r3.flow/testsuite/r3flow_test.py	2014-07-25 19:42:30 UTC (rev 61403)
@@ -0,0 +1,52 @@
+# -*- coding: utf-8 -*-
+Test of r3.flow
+ at author Anna Petrasova
+from grass.gunittest import TestCase, test
+class FlowlineTest(TestCase):
+    @classmethod
+    def setUpClass(cls):
+        """Use temporary region settings"""
+        cls.use_temp_region()
+        cls.runModule("g.region", res=10, res3=10, n=80, s=0, w=0, e=120, b=0, t=50)
+        cls.runModule("r3.mapcalc", expression="map_1 = 100", overwrite=True)
+        cls.runModule("r3.mapcalc", expression="map_2 = -20", overwrite=True)
+        cls.runModule("r3.mapcalc", expression="map_3 = 0.01", overwrite=True)
+        cls.runModule("r3.mapcalc", expression="map_4 = col() + row() + depth()", overwrite=True)
+    @classmethod
+    def tearDownClass(cls):
+        """!Remove the temporary region"""
+        cls.del_temp_region()
+        cls.runModule('g.remove', rast3d=['map_1', 'map_2', 'map_3', 'map_4'])
+    def test_interpolation(self):
+        self.assertModuleKeyValue('test.r3flow', test='interpolation',
+                                  coordinates=[100, 55, 11], input=['map_1', 'map_2', 'map_3'],
+                                  reference={'return': 0, 'values': [100, -20, 0.01]},
+                                  precision=1e-10, sep='=')
+                                  coordinates=[5, 5, 5], input=['map_1', 'map_2', 'map_3'],
+                                  coordinates=[10, 10, 60], input=['map_1', 'map_2', 'map_3'],
+                                  reference={'return': -1},
+                                  coordinates=[25, 69, 17], input=['map_4', 'map_4', 'map_4'],
+                                  reference={'return': 0, 'values': [7.8, 7.8, 7.8]},
+                                  coordinates=[81, 30, 25], input=['map_4', 'map_4', 'map_4'],
+                                  reference={'return': 0, 'values': [18.1, 18.1, 18.1]},
+if __name__ == '__main__':
+    test()
Property changes on: grass-addons/grass7/raster3d/r3.flow/testsuite/r3flow_test.py
   + text/x-python
   + native
