[GRASS-SVN] r61411 - grass/trunk/lib/python/gunittest
svn_grass at osgeo.org
Fri Jul 25 14:51:44 PDT 2014
Author: wenzeslaus
Date: 2014-07-25 14:51:44 -0700 (Fri, 25 Jul 2014)
New Revision: 61411
grass/trunk/lib/python/gunittest/case.py
grass/trunk/lib/python/gunittest/reporters.py
grass/trunk/lib/python/gunittest/runner.py
gunittest: add summary table and stderr to test file HTML report
Modified: grass/trunk/lib/python/gunittest/case.py
--- grass/trunk/lib/python/gunittest/case.py 2014-07-25 21:15:32 UTC (rev 61410)
+++ grass/trunk/lib/python/gunittest/case.py 2014-07-25 21:51:44 UTC (rev 61411)
@@ -14,6 +14,8 @@
import os
import subprocess
+import StringIO
import unittest
from unittest.util import safe_repr
@@ -43,6 +45,7 @@
def __init__(self, methodName):
super(TestCase, self).__init__(methodName)
self.grass_modules = []
+ self.supplementary_files = []
def _formatMessage(self, msg, standardMsg):
"""Honor the longMessage attribute when generating failure messages.
@@ -873,7 +876,6 @@
os.remove(reference)
stdmsg = ("There is a difference between vectors when compared as"
" ASCII files.\n")
- import StringIO
output = StringIO.StringIO()
# TODO: there is a diff size constant which we can use
@@ -900,6 +902,7 @@
# TODO: standardize the format of name of HTML file
# for one test id there is only one possible file of this name
htmldiff_file_name = self.id() + '_ascii_diff' + '.html'
+ self.supplementary_files.append(htmldiff_file_name)
htmldiff = difflib.HtmlDiff().make_file(fromlines, tolines,
'reference', 'actual',
context=True,
Modified: grass/trunk/lib/python/gunittest/reporters.py
--- grass/trunk/lib/python/gunittest/reporters.py 2014-07-25 21:15:32 UTC (rev 61410)
+++ grass/trunk/lib/python/gunittest/reporters.py 2014-07-25 21:51:44 UTC (rev 61411)
@@ -17,6 +17,8 @@
import xml.sax.saxutils as saxutils
import xml.etree.ElementTree as et
import subprocess
+import StringIO
+import collections
from .utils import ensure_dir
from .checkers import text_to_keyvalue
@@ -327,6 +329,33 @@
html.close()
+def html_file_preview(filename):
+ before = '<pre>'
+ after = '</pre>'
+ if not os.path.isfile(filename):
+ return '<p style="color: red>File %s does not exist<p>' % filename
+ size = os.path.getsize(filename)
+ if not size:
+ return '<p style="color: red>File %s is empty<p>' % filename
+ max_size = 10000
+ html = StringIO.StringIO()
+ html.write(before)
+ if size < max_size:
+ with open(filename) as text:
+ for line in text:
+ html.write(color_error_line(html_escape(line)))
+ elif size < 10 * max_size:
+ def tail(filename, n):
+ return collections.deque(open(filename), n)
+ html.write('... (lines omitted)\n')
+ for line in tail(filename, 50):
+ else:
+ return '<p style="color: red>File %s is too large to show<p>' % filename
+ html.write(after)
+ return html.getvalue()
def returncode_to_html_text(returncode):
if returncode:
return '<span style="color: red">FAILED</span>'
@@ -335,6 +364,7 @@
return '<span style="color: green">succeeded</span>'
+# not used
def returncode_to_html_sentence(returncode):
if returncode:
return ('<span style="color: red">❌</span>'
@@ -344,6 +374,15 @@
' Test succeeded (return code %d)' % (returncode))
+def returncode_to_success_html_par(returncode):
+ if returncode:
+ return ('<p> <span style="color: red">❌</span>'
+ ' Test failed</p>')
+ else:
+ return ('<p> <span style="color: green">✓</span>'
+ ' Test succeeded</p>')
def success_to_html_text(total, successes):
if successes < total:
@@ -490,7 +529,8 @@
# TODO: should we test for zero?
if total is not None:
# success are only the clear ones
- # percentage is influenced by all but putting only failures to table
+ # percentage is influenced by all
+ # but putting only failures to table
self.successes += successes
self.total += total
@@ -501,12 +541,15 @@
bad_ones = failures + errors
self.main_index.write(
'<tr><td>{d}</td>'
- '<td><a href="{d}/{m}/index.html">{m}</a></td><td>{sf}</td>'
- '<td>{total}</td><td>{st}</td><td>{ft}</td><td>{pt}</td>'
+ '<td><a href="{d}/{m}/index.html">{m}</a></td>'
+ '<td>{status}</td>'
+ '<td>{ntests}</td><td>{stests}</td>'
+ '<td>{ftests}</td><td>{ptests}</td>'
'<tr>'.format(
d=module.tested_dir, m=module.name,
- sf=returncode_to_html_text(returncode),
- st=successes, ft=bad_ones, total=total, pt=pass_per))
+ status=returncode_to_html_text(returncode),
+ stests=successes, ftests=bad_ones, ntests=total,
+ ptests=pass_per))
wrap_stdstream_to_html(infile=stdout,
outfile=os.path.join(cwd, 'stdout.html'),
module=module, stream='stdout')
@@ -520,18 +563,65 @@
'<html><body>'
'<h1>{m.name}</h1>'
'<h2>{m.tested_dir} – {m.name}</h2>'
- '<p>{status}'
- '<p>Test duration: {dur}'
- '<ul>'
- '<li><a href="stdout.html">standard output (stdout)</a>'
- '<li><a href="stderr.html">standard error output (stderr)</a>'
- '<li><a href="testcodecoverage/index.html">code coverage</a>'
- '</ul>'
- '</body></html>'
+ '{status}'
.format(
- dur=self.file_time, m=module,
- status=returncode_to_html_sentence(returncode),
+ m=module,
+ status=returncode_to_success_html_par(returncode),
+ # TODO: include optionaly link to test suite
+ summary_section = (
+ '<table><tbody>'
+ '<tr><td>Test file</td><td>{m}</td></tr>'
+ '<tr><td>Testsuite</td><td>{d}</td></tr>'
+ '<tr><td>Status</td><td>{status}</td></tr>'
+ '<tr><td>Return code</td><td>{rc}</td></tr>'
+ '<tr><td>Number of tests</td><td>{ntests}</td></tr>'
+ '<tr><td>Successful tests</td><td>{stests}</td></tr>'
+ '<tr><td>Failed tests</td><td>{ftests}</td></tr>'
+ '<tr><td>Percent successful</td><td>{ptests}</td></tr>'
+ '<tr><td>Test duration</td><td>{dur}</td></tr>'
+ .format(
+ d=module.tested_dir, m=module.name,
+ ptests=pass_per, rc=returncode,
+ dur=self.file_time))
+ file_index.write(summary_section)
+ modules = test_summary.get('tested_modules', None)
+ if modules:
+ # TODO: replace by better handling of potential lists when parsing
+ # TODO: create link to module if running in grass or in addons
+ # alternatively a link to module test summary
+ if type(modules) is not list:
+ modules = [modules]
+ file_index.write(
+ '<tr><td>Tested modules</td><td>{}</td></tr>'.format(
+ ', '.join(modules)))
+ file_index.write('<tbody><table>')
+ files_section = (
+ '<h3>Supplementary files</h3>'
+ '<ul>'
+ '<li><a href="stdout.html">standard output (stdout)</a></li>'
+ '<li><a href="stderr.html">standard error output (stderr)</a></li>'
+ '<li><a href="testcodecoverage/index.html">code coverage</a></li>'
+ file_index.write(files_section)
+ supplementary_files = test_summary.get('supplementary_files', None)
+ if supplementary_files:
+ for f in supplementary_files:
+ file_index.write('<li><a href="{f}">{f}</a></li>'.format(f=f))
+ file_index.write('</ul>')
+ if returncode:
+ file_index.write('<h3>Standard error output (stderr)</h3>')
+ file_index.write(html_file_preview(stderr))
+ file_index.write('</body></html>')
file_index.close()
if returncode:
Modified: grass/trunk/lib/python/gunittest/runner.py
--- grass/trunk/lib/python/gunittest/runner.py 2014-07-25 21:15:32 UTC (rev 61410)
+++ grass/trunk/lib/python/gunittest/runner.py 2014-07-25 21:51:44 UTC (rev 61411)
@@ -225,6 +225,7 @@
self.test_type = 'not-specified'
self._grass_modules = []
+ self._supplementary_files = []
def setTimes(self, start_time, end_time, time_taken):
self.start_time = start_time
@@ -235,6 +236,8 @@
super(KeyValueTestResult, self).stopTest(test)
if hasattr(test, 'grass_modules'):
self._grass_modules.extend(test.grass_modules)
+ if hasattr(test, 'supplementary_files'):
+ self._supplementary_files.extend(test.supplementary_files)
def stopTestRun(self):
super(KeyValueTestResult, self).stopTestRun()
@@ -278,7 +281,8 @@
# TODO: include each module just once? list good and bad modules?
infos.append("modules=%s" % ','.join(self._grass_modules))
+ infos.append("supplementary_files=%s" % ','.join(self._supplementary_files))
# module, modules?, c, c++?, python
# TODO: include also type modules?
# TODO: include also C++ code?
