[GRASS-SVN] r61415 - in grass/trunk: include/defs lib/gmath lib/raster raster/r.flow raster/r.li/r.li.daemon raster/r.random raster/r.spread raster/r.surf.fractal raster/r.surf.gauss raster/r.surf.random vector/v.extract vector/v.kcv vector/v.qcount vector/v.random
svn_grass at osgeo.org
Sat Jul 26 16:22:22 PDT 2014
Author: glynn
Date: 2014-07-26 16:22:22 -0700 (Sat, 26 Jul 2014)
New Revision: 61415
grass/trunk/include/defs/gmath.h
grass/trunk/lib/gmath/gauss.c
grass/trunk/lib/gmath/rand1.c
grass/trunk/lib/raster/color_rand.c
grass/trunk/raster/r.flow/main.c
grass/trunk/raster/r.li/r.li.daemon/daemon.c
grass/trunk/raster/r.random/creat_rand.c
grass/trunk/raster/r.spread/main.c
grass/trunk/raster/r.spread/pick_dist.c
grass/trunk/raster/r.spread/pick_ignite.c
grass/trunk/raster/r.surf.fractal/spec_syn.c
grass/trunk/raster/r.surf.gauss/gaussurf.c
grass/trunk/raster/r.surf.random/randsurf.c
grass/trunk/vector/v.extract/main.c
grass/trunk/vector/v.kcv/main.c
grass/trunk/vector/v.qcount/findquads.c
grass/trunk/vector/v.random/main.c
Replace rand/random/lrand48/etc with lib/gis random number functions
Modified: grass/trunk/include/defs/gmath.h
--- grass/trunk/include/defs/gmath.h 2014-07-26 08:51:29 UTC (rev 61414)
+++ grass/trunk/include/defs/gmath.h 2014-07-26 23:22:22 UTC (rev 61415)
@@ -22,14 +22,16 @@
extern int fft2(int, double (*)[2], int, int, int);
/* gauss.c */
-extern double G_math_rand_gauss(int, double);
+extern double G_math_rand_gauss(double);
/* max_pow2.c */
extern long G_math_max_pow2 (long n);
extern long G_math_min_pow2 (long n);
/* rand1.c */
-extern float G_math_rand(int);
+extern void G_math_srand(int);
+extern int G_math_srand_auto(void);
+extern float G_math_rand(void);
/* del2g.c */
extern int del2g(double *[2], int, double);
Modified: grass/trunk/lib/gmath/gauss.c
--- grass/trunk/lib/gmath/gauss.c 2014-07-26 08:51:29 UTC (rev 61414)
+++ grass/trunk/lib/gmath/gauss.c 2014-07-26 23:22:22 UTC (rev 61415)
@@ -14,14 +14,14 @@
* \return double
-double G_math_rand_gauss(const int seed, const double sigma)
+double G_math_rand_gauss(double sigma)
double x, y, r2;
do {
/* choose x,y in uniform square (-1,-1) to (+1,+1) */
- x = -1 + 2 * G_math_rand(seed);
- y = -1 + 2 * G_math_rand(seed);
+ x = -1 + 2 * G_math_rand();
+ y = -1 + 2 * G_math_rand();
/* see if it is in the unit circle */
r2 = x * x + y * y;
Modified: grass/trunk/lib/gmath/rand1.c
--- grass/trunk/lib/gmath/rand1.c 2014-07-26 08:51:29 UTC (rev 61414)
+++ grass/trunk/lib/gmath/rand1.c 2014-07-26 23:22:22 UTC (rev 61415)
@@ -1,5 +1,5 @@
-#include <grass/config.h>
#include <stdlib.h>
+#include <grass/gis.h>
#include <grass/gmath.h>
@@ -14,17 +14,29 @@
* \return float
-float G_math_rand(int seed)
+float G_math_rand(void)
-#if defined(HAVE_DRAND48)
- if (seed < 0)
- srand48(-seed);
+ return G_drand48();
- return (float)drand48();
-#else
- if (seed < 0)
- srand(-seed);
+ * \brief Seed the pseudo-random number generator
+ * \param seedval 32-bit integer used to seed the PRNG
- return 1.0f * rand() / RAND_MAX;
-#endif
+void G_math_srand(int seed)
+ G_srand48(seed);
+ * \brief Seed the pseudo-random number generator from the time and PID
+ * \return generated seed value passed to G_srand48()
+int G_math_srand_auto(void)
+ return (int) G_srand48_auto();
Modified: grass/trunk/lib/raster/color_rand.c
--- grass/trunk/lib/raster/color_rand.c 2014-07-26 08:51:29 UTC (rev 61414)
+++ grass/trunk/lib/raster/color_rand.c 2014-07-26 23:22:22 UTC (rev 61415)
@@ -33,16 +33,17 @@
G_fatal_error(_("Rast_make_random_colors: min (%d) > max (%d)"),
min, max);
- srand(time(NULL));
+ /* FIXME - allow seed to be specified for repeatability */
+ G_srand48_auto();
- count = MAX_COLORS - DEVIATION + rand() % DEVIATION;
+ count = MAX_COLORS - DEVIATION + G_lrand48() % DEVIATION;
if (count > max - min + 1)
count = max - min + 1;
for (n = 1; n <= count; n++) {
- red = rand() & 0377;
- grn = rand() & 0377;
- blu = rand() & 0377;
+ red = G_lrand48() & 0xff;
+ grn = G_lrand48() & 0xff;
+ blu = G_lrand48() & 0xff;
Rast_add_modular_c_color_rule(&n, red, grn, blu,
&n, red, grn, blu, colors);
Modified: grass/trunk/raster/r.flow/main.c
--- grass/trunk/raster/r.flow/main.c 2014-07-26 08:51:29 UTC (rev 61414)
+++ grass/trunk/raster/r.flow/main.c 2014-07-26 23:22:22 UTC (rev 61415)
@@ -26,8 +26,6 @@
** Update MN: commented line 387
-#include <stdlib.h> /* for the random number generation */
-#include <time.h>
#include <grass/raster.h>
#include <grass/glocale.h>
@@ -320,7 +318,8 @@
ystep = region.ns_res * (double)loopstep;
- srand(time(0));
+ G_srand48_auto();
for (row = 0, y = (double)region.north - (region.ns_res * .5);
row < region.rows; row += loopstep, y -= ystep) {
@@ -337,9 +336,9 @@
#ifdef OFFSET
/* disabled by helena June 2005 */
roffset = parm.offset * (double)region.ew_res
- * ((2. * (double)rand() / (double)RAND_MAX) - 1.);
+ * ((2. * G_drand48()) - 1.);
coffset = parm.offset * (double)region.ns_res
#endif
pts.x = x;
pts.y = y;
Modified: grass/trunk/raster/r.li/r.li.daemon/daemon.c
--- grass/trunk/raster/r.li/r.li.daemon/daemon.c 2014-07-26 08:51:29 UTC (rev 61414)
+++ grass/trunk/raster/r.li/r.li.daemon/daemon.c 2014-07-26 23:22:22 UTC (rev 61415)
@@ -15,7 +15,6 @@
* \include
#include <stdlib.h>
#include <stddef.h>
#include <fcntl.h>
@@ -36,11 +35,6 @@
#include "daemon.h"
-#ifdef __MINGW32__
-#define srandom srand
-#define random rand
-#endif
int calculateIndex(char *file, rli_func *f,
char **parameters, char *raster, char *output)
@@ -524,11 +518,11 @@
G_fatal_error(_("Too many units to place"));
assigned = G_malloc(units * sizeof(int));
i = 0;
- srandom(0);
+ G_srand48(0);
while (i < units) {
int j, position, found = FALSE;
- position = random() % max_units;
+ position = G_lrand48() % max_units;
for (j = 0; j < i; j++) {
if (assigned[j] == position)
found = TRUE;
@@ -592,7 +586,7 @@
if (r_strat_len < g->rl || c_strat_len < g->cl)
G_fatal_error(_("Too many stratified random sample for raster map"));
loop = r_strat * c_strat;
- srandom(0);
+ G_srand48(0);
for (i = 0; i < loop; i++) {
msg m;
@@ -600,9 +594,9 @@
m.type = AREA;
m.f.f_a.aid = i;
m.f.f_a.x = (int)g->sf_x + ((i % c_strat) * c_strat_len) +
- (random() % (c_strat_len - g->cl));
+ (G_lrand48() % (c_strat_len - g->cl));
m.f.f_a.y = (int)g->sf_y + (rint(i / c_strat) * r_strat_len) +
- (random() % (r_strat_len - g->rl));
+ (G_lrand48() % (r_strat_len - g->rl));
m.f.f_a.rl = g->rl;
m.f.f_a.cl = g->cl;
insertNode(l, m);
@@ -611,10 +605,10 @@
m.type = MASKEDAREA;
m.f.f_ma.aid = i;
m.f.f_ma.x = (int)g->sf_x + ((i % c_strat) * c_strat_len) +
m.f.f_ma.y =
m.f.f_ma.rl = g->rl;
m.f.f_ma.cl = g->cl;
strcpy(m.f.f_ma.mask, g->maskname);
Modified: grass/trunk/raster/r.random/creat_rand.c
--- grass/trunk/raster/r.random/creat_rand.c 2014-07-26 08:51:29 UTC (rev 61414)
+++ grass/trunk/raster/r.random/creat_rand.c 2014-07-26 23:22:22 UTC (rev 61415)
@@ -1,43 +1,14 @@
-#include <time.h>
-#include <unistd.h>
-#include <sys/types.h>
-#ifndef USE_RAND
-#ifndef HAVE_DRAND48
-#define lrand48() (((long) rand() ^ ((long) rand() << 16)) & 0x7FFFFFFF)
-#define srand48(sv) (srand((unsigned)(sv)))
-#endif
long make_rand(void)
- return lrand48();
+ return G_lrand48();
void init_rand(void)
- srand48((long)time((time_t *) 0));
+ G_srand48_auto();
-#else
-static long labs(int n)
- return n < 0 ? (-n) : n;
-long make_rand(void)
- return (labs(rand() + (rand() << 16)));
-void init_rand(void)
- srand(getpid());
-#endif
Modified: grass/trunk/raster/r.spread/main.c
--- grass/trunk/raster/r.spread/main.c 2014-07-26 08:51:29 UTC (rev 61414)
+++ grass/trunk/raster/r.spread/main.c 2014-07-26 23:22:22 UTC (rev 61415)
@@ -336,7 +336,8 @@
exit(EXIT_FAILURE);
- srand(getpid());
+ G_srand48_auto();
display = flag.display->answer;
#if 1
Modified: grass/trunk/raster/r.spread/pick_dist.c
--- grass/trunk/raster/r.spread/pick_dist.c 2014-07-26 08:51:29 UTC (rev 61414)
+++ grass/trunk/raster/r.spread/pick_dist.c 2014-07-26 23:22:22 UTC (rev 61415)
@@ -18,13 +18,14 @@
#include <stdlib.h>
#include <limits.h>
#include <math.h>
#include "local_proto.h"
int pick_dist(int u)
int v;
- v = (int)((u + 0.99999999999) * rand() / INT_MAX);
- u = (int)((v + 0.99999999999) * rand() / INT_MAX);
- return ((int)((u + 0.99999999999) * rand() / INT_MAX)); /*4th for a test */
+ v = (int)((u + 0.99999999999) * G_drand48());
+ u = (int)((v + 0.99999999999) * G_drand48());
+ return ((int)((u + 0.99999999999) * G_drand48())); /*4th for a test */
Modified: grass/trunk/raster/r.spread/pick_ignite.c
--- grass/trunk/raster/r.spread/pick_ignite.c 2014-07-26 08:51:29 UTC (rev 61414)
+++ grass/trunk/raster/r.spread/pick_ignite.c 2014-07-26 23:22:22 UTC (rev 61415)
@@ -13,6 +13,7 @@
#include <stdlib.h>
#include <limits.h>
int p[18] = { 100, 100, 100, 90, 80, 70, 60, 50, 40, /*adapt the "average" */
@@ -21,5 +22,5 @@
int pick_ignite(int i)
- return ((100.0 * rand() / INT_MAX) <= p[i]);
+ return ((100.0 * G_drand48()) <= p[i]);
Modified: grass/trunk/raster/r.surf.fractal/spec_syn.c
--- grass/trunk/raster/r.surf.fractal/spec_syn.c 2014-07-26 08:51:29 UTC (rev 61414)
+++ grass/trunk/raster/r.surf.fractal/spec_syn.c 2014-07-26 23:22:22 UTC (rev 61415)
@@ -38,14 +38,13 @@
int row, col, /* Counts through half the data array. */
row0, col0, /* 'other half' of the array. */
- coeff, /* No. of Fourier coeffficents to calc. */
- seed; /* Random number seed. */
+ coeff; /* No. of Fourier coeffficents to calc. */
double phase, rad, /* polar coordinates of Fourier coeff. */
*temp[2];
- seed = -1 * getpid();
- G_math_rand(seed); /* Reset random number generator. */
+ G_math_srand_auto(); /* Reset random number generator. */
temp[0] = (double *)G_malloc(nn * nn * sizeof(double));
temp[1] = (double *)G_malloc(nn * nn * sizeof(double));
@@ -65,12 +64,12 @@
for (col = 0; col <= nn / 2; col++) {
/* Generate random Fourier coefficients. */
- phase = TWOPI * G_math_rand(0);
+ phase = TWOPI * G_math_rand();
if ((row != 0) || (col != 0))
rad =
pow(row * row + col * col,
- -(H + 1) / 2.0) * G_math_rand_gauss(0, 1.);
+ -(H + 1) / 2.0) * G_math_rand_gauss(1.);
else
rad = 0.0;
@@ -101,10 +100,10 @@
for (row = 1; row < nn / 2; row++)
for (col = 1; col < nn / 2; col++) {
rad =
*(data[0] + row * nn + nn - col) = rad * cos(phase);
*(data[1] + row * nn + nn - col) = rad * sin(phase);
Modified: grass/trunk/raster/r.surf.gauss/gaussurf.c
--- grass/trunk/raster/r.surf.gauss/gaussurf.c 2014-07-26 08:51:29 UTC (rev 61414)
+++ grass/trunk/raster/r.surf.gauss/gaussurf.c 2014-07-26 23:22:22 UTC (rev 61415)
@@ -32,7 +32,8 @@
/****** INITIALISE RANDOM NUMBER GENERATOR ******/
- G_math_rand(-1 * getpid());
/****** OPEN CELL FILES AND GET CELL DETAILS ******/
@@ -50,7 +51,7 @@
G_percent(row_count, nrows, 5);
for (col_count = 0; col_count < ncols; col_count++)
*(row_out + col_count) =
- (DCELL) (G_math_rand_gauss(2742, sigma) + mean);
+ (DCELL) (G_math_rand_gauss(sigma) + mean);
/* Write contents row by row */
Rast_put_d_row(fd_out, (DCELL *) row_out);
Modified: grass/trunk/raster/r.surf.random/randsurf.c
--- grass/trunk/raster/r.surf.random/randsurf.c 2014-07-26 08:51:29 UTC (rev 61414)
+++ grass/trunk/raster/r.surf.random/randsurf.c 2014-07-26 23:22:22 UTC (rev 61415)
@@ -1,4 +1,3 @@
#include <math.h>
@@ -21,7 +20,8 @@
int row_count, col_count;
fd_out = Rast_open_new(out, int_map ? CELL_TYPE : DCELL_TYPE);
@@ -40,12 +40,12 @@
for (col_count = 0; col_count < ncols; col_count++) {
if (int_map)
*(row_out_C + col_count) =
- (CELL) (G_math_rand(2742) * (max + 1 - min) + min);
+ (CELL) (G_math_rand() * (max + 1 - min) + min);
/* under represents first and last bin */
/* *(row_out_C + col_count) = (CELL) floor(rand1(2742)*(max-min)+min +0.5); */
else
*(row_out_D + col_count) =
- (DCELL) (G_math_rand(2742) * (max - min) + min);
+ (DCELL) (G_math_rand() * (max - min) + min);
Modified: grass/trunk/vector/v.extract/main.c
--- grass/trunk/vector/v.extract/main.c 2014-07-26 08:51:29 UTC (rev 61414)
+++ grass/trunk/vector/v.extract/main.c 2014-07-26 23:22:22 UTC (rev 61415)
@@ -317,19 +317,15 @@
G_fatal_error(_("Random category count is larger or equal to "
"uniq <%s> feature category count %d"),
opt.type->answer, ucat_count);
- if (ucat_count >= RAND_MAX)
- G_fatal_error(_("There are more categories than random number "
- "generator can reach. Report this as a GRASS bug."));
- seed = getpid();
/* Initialise random number generator */
- G_math_rand(-1 * seed);
/* Fill cat_array with list of valid random numbers */
while (cat_count < nrandom) {
/* Random number in range from 0 to largest CAT value */
- prnd = (int) floor(G_math_rand(seed) *
+ prnd = (int) floor(G_math_rand() *
(ucat_array[ucat_count - 1] + 1));
qsort(cat_array, cat_count, sizeof(int), cmp);
/* Check if generated number isn't already in
Modified: grass/trunk/vector/v.kcv/main.c
--- grass/trunk/vector/v.kcv/main.c 2014-07-26 08:51:29 UTC (rev 61414)
+++ grass/trunk/vector/v.kcv/main.c 2014-07-26 23:22:22 UTC (rev 61415)
@@ -19,25 +19,19 @@
#include <stdlib.h>
#include <math.h>
#include <grass/dbmi.h>
#include <grass/vector.h>
-static double myrand(void)
- return rand() / (1.0 + RAND_MAX);
struct Cell_head window;
int main(int argc, char *argv[])
int i, line, nlines, nlinks;
int idx, *line_idx, lines_left;
- double (*rng) ();
+ double (*rng)(void) = G_drand48;
int nsites, p, np, min_count, spill;
struct partition {
int id, count, max;
@@ -48,7 +42,6 @@
struct line_cats *Cats;
struct GModule *module;
struct Option *map_opt, *col_opt, *npart_opt, *field_opt;
- struct Flag *drand48_flag;
/* Attributes */
struct field_info *Fi;
@@ -81,15 +74,6 @@
col_opt->description =
_("Name for new column to which partition number is written");
- drand48_flag = G_define_flag();
- drand48_flag->key = 'd';
-#ifdef HAVE_DRAND48
- drand48_flag->description = _("Use drand48()");
-#else
- drand48_flag->description = _("Use drand48() (ignored)");
-#endif
G_gisinit(argv[0]);
if (G_parser(argc, argv))
@@ -99,17 +83,8 @@
if (np < 2)
G_fatal_error(_("'%s' must be > 1"), npart_opt->key);
- if (drand48_flag->answer) {
- rng = drand48;
- srand48((long)getpid());
- else
-#endif
- rng = myrand;
- srand(getpid());
+ G_srand48_auto();
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
Modified: grass/trunk/vector/v.qcount/findquads.c
--- grass/trunk/vector/v.qcount/findquads.c 2014-07-26 08:51:29 UTC (rev 61414)
+++ grass/trunk/vector/v.qcount/findquads.c 2014-07-26 23:22:22 UTC (rev 61415)
@@ -6,28 +6,15 @@
* Read the file GPL.TXT coming with GRASS for details.
-#include <sys/types.h> /* for getpid() */
#include <stdlib.h>
#include <math.h>
#include "quaddefs.h"
-#ifndef RAND_MAX
-#define RAND_MAX (pow(2.0,31.0)-1)
-#endif
+#define RANDOM(lo,hi) (G_drand48() * (hi-lo) + lo)
-#define R_INIT srand
-#define RANDOM(lo,hi) ((double) rand() / (double)RAND_MAX * (hi-lo) + lo)
- #define R_MAX 1.0
- #define R_INIT srand48
- #define RANDOM(lo,hi) (drand48()/R_MAX*(hi-lo)+lo)
* returns Z struct filled with centers of n non-overlapping circles of
* radius r contained completely within window
@@ -42,8 +29,8 @@
if (quads == NULL)
G_fatal_error("cannot allocate memory for quadrats");
- srand((unsigned int)getpid());
- /* R_INIT (1); */
+ G_srand48_auto();
e_max = window.east - r;
e_min = window.west + r;
Modified: grass/trunk/vector/v.random/main.c
--- grass/trunk/vector/v.random/main.c 2014-07-26 08:51:29 UTC (rev 61414)
+++ grass/trunk/vector/v.random/main.c 2014-07-26 23:22:22 UTC (rev 61415)
@@ -32,8 +32,6 @@
#include <stdlib.h>
#include <math.h>
#include <string.h>
@@ -41,20 +39,6 @@
-#ifndef RAND_MAX
-#endif
-double myrand(void);
-#if defined(__CYGWIN__) || defined(__APPLE__) || defined(__MINGW32__)
-double drand48()
- return (rand() / (1.0 * RAND_MAX));
-#endif
/* for qsort */
typedef struct {
@@ -77,10 +61,10 @@
char *output, buf[DB_SQL_MAX];
- double (*rng) ();
- double max, zmin, zmax;
+ double zmin, zmax;
int seed;
- int i, j, k, n, b, type, usefloat;
+ int i, j, k, n, type, usefloat;
int area, nareas, field;
struct boxlist *List = NULL;
BOX_SIZE *size_list = NULL;
@@ -99,7 +83,7 @@
} parm;
struct
- struct Flag *rand, *drand48, *z, *notopo, *a;
+ struct Flag *z, *notopo, *a;
} flag;
dbDriver *driver;
@@ -187,10 +171,6 @@
flag.a->key = 'a';
flag.a->description = _("Generate n points for each individual area");
- flag.drand48 = G_define_flag();
- flag.drand48->key = 'd';
- flag.drand48->description = _("Use drand48() function instead of rand()");
flag.notopo = G_define_standard_flag(G_FLG_V_TOPO);
@@ -198,7 +178,6 @@
output = parm.output->answer;
n = atoi(parm.nsites->answer);
- b = flag.drand48->answer ? TRUE : FALSE;
if(parm.seed->answer)
seed = atoi(parm.seed->answer);
@@ -304,24 +283,11 @@
Vect_hist_command(&Out);
- if (b) {
- rng = drand48;
- max = 1.0;
- /* Init the random seed */
- if(parm.seed->answer)
- srand48((long)seed);
- else
- else { /* default is rand() */
- rng = myrand;
- max = RAND_MAX;
- srand(seed);
- else
- srand(getpid());
+ /* Init the random seed */
+ if(parm.seed->answer)
+ G_srand48(seed);
+ else
+ G_srand48_auto();
G_get_window(&window);
@@ -462,9 +428,9 @@
Vect_reset_cats(Cats);
while (outside) {
- x = rng() / max * (bbox.W - bbox.E) + bbox.E;
- y = rng() / max * (bbox.N - bbox.S) + bbox.S;
- z = rng() / max * (zmax - zmin) + zmin;
+ x = rng() * (bbox.W - bbox.E) + bbox.E;
+ y = rng() * (bbox.N - bbox.S) + bbox.S;
+ z = rng() * (zmax - zmin) + zmin;
ret = Vect_point_in_area(x, y, &In, area, &abox);
@@ -512,9 +478,9 @@
Vect_reset_line(Points);
- x = rng() / max * (window.west - window.east) + window.east;
- y = rng() / max * (window.north - window.south) + window.south;
+ x = rng() * (window.west - window.east) + window.east;
+ y = rng() * (window.north - window.south) + window.south;
if (nareas) {
int outside = 1;
@@ -588,9 +554,9 @@
if (outside) {
} while (outside);
@@ -635,8 +601,3 @@
exit(EXIT_SUCCESS);
-double myrand()
- return (double)rand();
