[GRASS-SVN] r61418 - grass/trunk/lib/python/gunittest
Sat Jul 26 21:02:34 PDT 2014
Author: wenzeslaus
Date: 2014-07-26 21:02:34 -0700 (Sat, 26 Jul 2014)
New Revision: 61418
   grass/trunk/lib/python/gunittest/invoker.py
   grass/trunk/lib/python/gunittest/main.py
   grass/trunk/lib/python/gunittest/reporters.py
gunittest: functions to remove full paths from standard output and other files
Modified: grass/trunk/lib/python/gunittest/invoker.py
--- grass/trunk/lib/python/gunittest/invoker.py	2014-07-27 01:53:12 UTC (rev 61417)
+++ grass/trunk/lib/python/gunittest/invoker.py	2014-07-27 04:02:34 UTC (rev 61418)
@@ -25,7 +25,8 @@
 from .loader import GrassTestLoader, discover_modules
 from .reporters import (GrassTestFilesMultiReporter,
                         GrassTestFilesTextReporter, GrassTestFilesHtmlReporter,
-                        TestsuiteDirReporter, get_svn_path_authors)
+                        TestsuiteDirReporter, get_svn_path_authors,
+                        NoopFileAnonymizer)
 from .utils import silent_rmtree, ensure_dir
 import grass.script.setup as gsetup
@@ -87,7 +88,7 @@
     # we can also save only failed tests, or generate only if assert fails
     def __init__(self, start_dir,
                  clean_mapsets=True, clean_outputs=True, clean_before=True,
-                 testsuite_dir='testsuite'):
+                 testsuite_dir='testsuite', file_anonymizer=None):
         :param bool clean_mapsets: if the mapsets should be removed
@@ -106,6 +107,10 @@
         self.reporter = None
         self.testsuite_dirs = None
+        if file_anonymizer is None:
+            self._file_anonymizer = NoopFileAnonymizer()
+        else:
+            self._file_anonymizer = file_anonymizer
     def _create_mapset(self, gisdbase, location, module):
         """Create mapset according to informations in module.
@@ -164,6 +169,8 @@
         returncode = p.wait()
         stdout.close()
         stderr.close()
+        self._file_anonymizer.anonymize([stdout_path, stderr_path])
         test_summary = update_keyval_file(
             os.path.join(cwd, 'test_keyvalue_result.txt'),
             module=module, returncode=returncode)
@@ -186,7 +193,8 @@
         self.reporter = GrassTestFilesMultiReporter(
             reporters=[
                 GrassTestFilesTextReporter(stream=sys.stderr),
-                GrassTestFilesHtmlReporter(),
+                GrassTestFilesHtmlReporter(
+                    file_anonymizer=self._file_anonymizer),
         self.testsuite_dirs = collections.defaultdict(list)  # reset list of dirs each time
         # TODO: move constants out of loader class or even module
Modified: grass/trunk/lib/python/gunittest/main.py
--- grass/trunk/lib/python/gunittest/main.py	2014-07-27 01:53:12 UTC (rev 61417)
+++ grass/trunk/lib/python/gunittest/main.py	2014-07-27 04:02:34 UTC (rev 61418)
@@ -22,6 +22,7 @@
                      TextTestResult, KeyValueTestResult)
 from .invoker import GrassTestFilesInvoker
+from .reporters import FileAnonymizer
 import grass.script.core as gcore
@@ -142,7 +143,12 @@
     results_dir = 'testreport'
     silent_rmtree(results_dir)  # TODO: too brute force?
-    invoker = GrassTestFilesInvoker(start_dir='.')
+    start_dir = '.'
+    abs_start_dir = os.path.abspath(start_dir)
+    invoker = GrassTestFilesInvoker(
+        start_dir=start_dir,
+        file_anonymizer=FileAnonymizer(paths_to_remove=[abs_start_dir]))
+    # TODO: remove also results dir from files
     # we can just iterate over all locations available in database
     # but the we don't know the right location label/shortcut
     invoker.run_in_location(gisdbase=gisdbase,
Modified: grass/trunk/lib/python/gunittest/reporters.py
--- grass/trunk/lib/python/gunittest/reporters.py	2014-07-27 01:53:12 UTC (rev 61417)
+++ grass/trunk/lib/python/gunittest/reporters.py	2014-07-27 04:02:34 UTC (rev 61418)
@@ -19,11 +19,63 @@
 import subprocess
 import StringIO
 import collections
+import re
+import grass.script as gscript
 from .utils import ensure_dir
 from .checkers import text_to_keyvalue
+def replace_in_file(file_path, pattern, repl):
+    :param repl: a repl paramter of ``re.sub()`` function
+    # using tmp file to store the replaced content
+    tmp_file_path = file_path + '.tmp'
+    old_file = open(file_path, 'r')
+    new_file = open(tmp_file_path, 'w')
+    for line in old_file:
+        new_file.write(re.sub(pattern=pattern, string=line, repl=repl))
+    new_file.close()
+    old_file.close()
+    # remove old file since it must not exist for rename/move
+    os.remove(file_path)
+    # replace old file by new file
+    os.rename(tmp_file_path, file_path)
+class NoopFileAnonymizer(object):
+    def anonymize(self, filenames):
+        pass
+class FileAnonymizer(object):
+    def __init__(self, paths_to_remove, remove_gisbase=True,
+                 remove_gisdbase=False):
+        self._paths_to_remove = []
+        if remove_gisbase:
+            gisbase = os.environ['GISBASE']
+            self._paths_to_remove.append(gisbase)
+        if remove_gisdbase:
+            gisdbase = gscript.gis.get['GISDBASE']
+            self._paths_to_remove.append(gisdbase)
+        if paths_to_remove:
+            self._paths_to_remove.extend(paths_to_remove)
+        # besides GISBASE and test recursion start directory (which is
+        # supposed to be source root directory or similar) we can also try
+        # to remove user home directory and GISDBASE
+        # we suppuse that we run in standard grass session
+        # TODO: provide more effective implementation
+        for path in self._paths_to_remove:
+            for filename in filenames:
+                path_end = r'[\\/]?'
+                replace_in_file(filename, path + path_end, '')
 def get_source_url(path, revision, line=None):
@@ -410,9 +462,10 @@
     unknown_number = UNKNOWN_NUMBER_HTML
-    def __init__(self):
+    def __init__(self, file_anonymizer):
         super(GrassTestFilesHtmlReporter, self).__init__()
         self.main_index = None
     def start(self, results_dir):
         super(GrassTestFilesHtmlReporter, self).start(results_dir)
@@ -613,6 +666,14 @@
         supplementary_files = test_summary.get('supplementary_files', None)
         if supplementary_files:
+            # this is something we might want to do once for all and not
+            # risk that it will be done twice or rely that somebody else
+            # will do it for use
+            # the solution is perhaps do the multi reporter more grass-specific
+            # and do all common things, so that other can rely on it and
+            # moreover something can be shared with other explicity
+            # using constructors as seems advantageous for counting
+            self._file_anonymizer.anonymize(supplementary_files)
             for f in supplementary_files:
                 file_index.write('<li><a href="{f}">{f}</a></li>'.format(f=f))
