[GRASS-SVN] r61420 - grass/trunk/lib/init
svn_grass at osgeo.org
Mon Jul 28 00:00:25 PDT 2014
Author: mmetz
Date: 2014-07-28 00:00:25 -0700 (Mon, 28 Jul 2014)
New Revision: 61420
grass/trunk/lib/init/variables.html
libinit: fix GRASS_ZLIB_LEVEL documentation
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html 2014-07-27 09:28:27 UTC (rev 61419)
+++ grass/trunk/lib/init/variables.html 2014-07-28 07:00:25 UTC (rev 61420)
@@ -175,7 +175,8 @@
<dt>GRASS_ZLIB_LEVEL</dt>
<dd>[libgis]<br> if the environment variable GRASS_ZLIB_LEVEL exists and its value can
be parsed as an integer, it determines the compression level used when new compressed
- <i>integer</i> (CELL type) raster maps are compressed using zlib compression.
+ raster maps are compressed using zlib compression. This applies to all
+ raster map types (CELL, FCELL, DCELL).
<br><br>
If the variable doesn't exist, or the value cannot be parsed as an
integer, zlib's default compression level will be used.</dd>
