[GRASS-SVN] r61438 - grass/trunk/lib/python/gunittest
svn_grass at osgeo.org
Mon Jul 28 18:01:45 PDT 2014
Author: wenzeslaus
Date: 2014-07-28 18:01:45 -0700 (Mon, 28 Jul 2014)
New Revision: 61438
grass/trunk/lib/python/gunittest/invoker.py
grass/trunk/lib/python/gunittest/reporters.py
grass/trunk/lib/python/gunittest/runner.py
gunittest: generate keyvalue file for the whole report
Modified: grass/trunk/lib/python/gunittest/invoker.py
--- grass/trunk/lib/python/gunittest/invoker.py 2014-07-28 22:20:49 UTC (rev 61437)
+++ grass/trunk/lib/python/gunittest/invoker.py 2014-07-29 01:01:45 UTC (rev 61438)
@@ -25,36 +25,16 @@
from .loader import GrassTestLoader, discover_modules
from .reporters import (GrassTestFilesMultiReporter,
GrassTestFilesTextReporter, GrassTestFilesHtmlReporter,
- TestsuiteDirReporter, get_svn_path_authors,
- NoopFileAnonymizer)
+ TestsuiteDirReporter, GrassTestFilesKeyValueReporter,
+ get_svn_path_authors,
+ NoopFileAnonymizer, keyvalue_to_text)
from .utils import silent_rmtree, ensure_dir
import grass.script.setup as gsetup
import collections
-import types
-# TODO: change text_to_keyvalue to same sep as here
-def keyvalue_to_text(keyvalue, sep='=', vsep='\n', isep=',',
- last_vertical=None):
- if not last_vertical:
- last_vertical = vsep == '\n'
- items = []
- for key, value in keyvalue.iteritems():
- # TODO: use isep for iterables other than strings
- if (not isinstance(value, types.StringTypes)
- and isinstance(value, collections.Iterable)):
- # TODO: this does not work for list of non-strings
- value = isep.join(value)
- items.append('{key}{sep}{value}'.format(
- key=key, sep=sep, value=value))
- text = vsep.join(items)
- if last_vertical:
- text = text + vsep
- return text
# TODO: this might be more extend then update
def update_keyval_file(filename, module, returncode):
if os.path.exists(filename):
@@ -64,10 +44,12 @@
keyval = {}
# this is for one file
- # TODO: testing authors are more appropriate stat for testsuite dir index
test_file_authors = get_svn_path_authors(module.abs_file_path)
+ # in case that SVN is not available use empty authors
+ if test_file_authors is None:
+ test_file_authors = ''
- # always owerwrite name and ok
+ # always owerwrite name and status
keyval['name'] = module.name
keyval['tested_dir'] = module.tested_dir
if 'status' not in keyval.keys():
@@ -143,7 +125,9 @@
cwd = os.path.join(results_dir, module.tested_dir, module.name)
data_dir = os.path.join(module.file_dir, 'data')
if os.path.exists(data_dir):
- # TODO: link dir intead of copy tree
+ # TODO: link dir instead of copy tree and remove link afterwads
+ # (removing is good because of testsuite dir in samplecode)
+ # TODO: use different dir name in samplecode and test if it works
shutil.copytree(data_dir, os.path.join(cwd, 'data'),
ignore=shutil.ignore_patterns('*.svn*'))
ensure_dir(os.path.abspath(cwd))
@@ -195,6 +179,7 @@
GrassTestFilesTextReporter(stream=sys.stderr),
GrassTestFilesHtmlReporter(
file_anonymizer=self._file_anonymizer),
+ GrassTestFilesKeyValueReporter()
self.testsuite_dirs = collections.defaultdict(list) # reset list of dirs each time
# TODO: move constants out of loader class or even module
Modified: grass/trunk/lib/python/gunittest/reporters.py
--- grass/trunk/lib/python/gunittest/reporters.py 2014-07-28 22:20:49 UTC (rev 61437)
+++ grass/trunk/lib/python/gunittest/reporters.py 2014-07-29 01:01:45 UTC (rev 61438)
@@ -19,6 +19,7 @@
import subprocess
import StringIO
import collections
+import types
import re
import grass.script as gscript
@@ -27,6 +28,27 @@
from .checkers import text_to_keyvalue
+# TODO: change text_to_keyvalue to same sep as here
+# TODO: create keyvalue file and move it there together with things from checkers
+def keyvalue_to_text(keyvalue, sep='=', vsep='\n', isep=',',
+ last_vertical=None):
+ if not last_vertical:
+ last_vertical = vsep == '\n'
+ items = []
+ for key, value in keyvalue.iteritems():
+ # TODO: use isep for iterables other than strings
+ if (not isinstance(value, types.StringTypes)
+ and isinstance(value, collections.Iterable)):
+ # TODO: this does not work for list of non-strings
+ value = isep.join(value)
+ items.append('{key}{sep}{value}'.format(
+ key=key, sep=sep, value=value))
+ text = vsep.join(items)
+ if last_vertical:
+ text = text + vsep
+ return text
def replace_in_file(file_path, pattern, repl):
@@ -230,9 +252,21 @@
# so test code authors list also contains authors of tests only
# TODO: don't do this for the top level directories?
tests_authors = set(tests_authors)
+ no_svn_text = ('<span style="font-size: 60%">'
+ 'Test file authors were not obtained.'
+ '</span>')
+ if (not tests_authors
+ or (len(tests_authors) == 1 and list(tests_authors)[0] == '')):
+ return '<h3>Code and test authors</h3>' + no_svn_text
from_date = years_ago(datetime.date.today(), years=1)
tested_dir_authors = get_svn_path_authors(directory, from_date)
- not_testing_authors = tested_dir_authors - tests_authors
+ if tested_dir_authors is not None:
+ not_testing_authors = tested_dir_authors - tests_authors
+ else:
+ 'Authors cannot be obtained using SVN.'
+ '</span>')
+ not_testing_authors = tested_dir_authors = [no_svn_text]
if not not_testing_authors:
not_testing_authors = ['all recent authors contributed tests']
@@ -484,7 +518,7 @@
svn_info = get_svn_info()
if not svn_info:
- 'SVN revision cannot be be obtained'
+ 'SVN revision cannot be obtained'
'</span>')
else:
url = get_source_url(path=svn_info['relative-url'],
@@ -693,6 +727,139 @@
# a stream can be added and if not none, we could write
+class GrassTestFilesKeyValueReporter(GrassTestFilesCountingReporter):
+ def __init__(self):
+ super(GrassTestFilesKeyValueReporter, self).__init__()
+ self.result_dir = None
+ def start(self, results_dir):
+ super(GrassTestFilesKeyValueReporter, self).start(results_dir)
+ # having all variables public although not really part of API
+ self.result_dir = results_dir
+ # TODO: this can be moved to the counter class
+ self.failures = 0
+ self.errors = 0
+ self.skipped = 0
+ self.successes = 0
+ self.expected_failures = 0
+ self.unexpected_success = 0
+ self.total = 0
+ # TODO: document: tested_dirs is a list and it should fit with names
+ self.names = []
+ self.tested_dirs = []
+ self.files_returncodes = []
+ # sets (no size specified)
+ self.modules = set()
+ self.test_files_authors = set()
+ def finish(self):
+ super(GrassTestFilesKeyValueReporter, self).finish()
+ # this shoul be moved to some additional meta passed in constructor
+ svn_info = get_svn_info()
+ if not svn_info:
+ svn_revision = ''
+ else:
+ svn_revision = svn_info['revision']
+ summary = {}
+ summary['files_total'] = self.test_files
+ summary['files_successes'] = self.files_pass
+ summary['files_failures'] = self.files_fail
+ summary['names'] = self.names
+ summary['tested_dirs'] = self.tested_dirs
+ # TODO: we don't have a general mechanism for storing any type in text
+ summary['files_returncodes'] = [str(item)
+ for item in self.files_returncodes]
+ # let's use seconds as a universal time delta format
+ # (there is no standard way how to store time delta as string)
+ summary['time'] = self.main_time.total_seconds()
+ status = 'failed' if self.files_fail else 'succeeded'
+ summary['status'] = status
+ summary['total'] = self.total
+ summary['successes'] = self.successes
+ summary['failures'] = self.failures
+ summary['errors'] = self.errors
+ summary['skipped'] = self.skipped
+ summary['expected_failures'] = self.expected_failures
+ summary['unexpected_successes'] = self.unexpected_success
+ summary['test_files_authors'] = self.test_files_authors
+ summary['tested_modules'] = self.modules
+ summary['svn_revision'] = svn_revision
+ # ignoring issues with time zones
+ summary['timestamp'] = self.main_start_time.strftime('%Y-%m-%d %H:%M:%S')
+ # TODO: add some general metadata here (passed in constructor)
+ summary_filename = os.path.join(self.result_dir,
+ 'test_keyvalue_result.txt')
+ with open(summary_filename, 'w') as summary_file:
+ text = keyvalue_to_text(summary, sep='=', vsep='\n', isep=',')
+ summary_file.write(text)
+ def end_file_test(self, module, cwd, returncode, stdout, stderr,
+ test_summary):
+ super(GrassTestFilesKeyValueReporter, self).end_file_test(
+ module=module, cwd=cwd, returncode=returncode,
+ stdout=stdout, stderr=stderr)
+ # TODO: considering others accoring to total, OK?
+ # here we are using 0 for total but HTML reporter is using None
+ total = test_summary.get('total', 0)
+ failures = test_summary.get('failures', 0)
+ errors = test_summary.get('errors', 0)
+ # Python unittest TestResult class is reporting success for no
+ # errors or failures, so skipped, expected failures and unexpected
+ # success are ignored
+ # but successful tests are only total - the others
+ skipped = test_summary.get('skipped', 0)
+ expected_failures = test_summary.get('expected_failures', 0)
+ unexpected_successes = test_summary.get('unexpected_successes', 0)
+ successes = test_summary.get('successes', 0)
+ # TODO: move this to counter class and perhaps use aggregation
+ # rather then inheritance
+ self.failures += failures
+ self.errors += errors
+ self.skipped += skipped
+ self.expected_failures += expected_failures
+ self.unexpected_success += unexpected_successes
+ # TODO: should we test for zero?
+ if total is not None:
+ # success are only the clear ones
+ # percentage is influenced by all
+ # but putting only failures to table
+ self.successes += successes
+ self.total += total
+ self.files_returncodes.append(returncode)
+ self.tested_dirs.append(module.tested_dir)
+ self.names.append(module.name)
+ modules = test_summary.get('tested_modules', None)
+ if modules:
+ # TODO: replace by better handling of potential lists when parsing
+ # TODO: create link to module if running in grass or in addons
+ # alternatively a link to module test summary
+ if type(modules) not in [list, set]:
+ modules = [modules]
+ self.modules.update(modules)
+ test_file_authors = test_summary['test_file_authors']
+ if type(test_file_authors) not in [list, set]:
+ test_file_authors = [test_file_authors]
+ self.test_files_authors.update(test_file_authors)
class GrassTestFilesTextReporter(GrassTestFilesCountingReporter):
def __init__(self, stream):
@@ -843,7 +1010,7 @@
test_file_authors = summary['test_file_authors']
if type(test_file_authors) is not list:
- test_files_authors += test_file_authors
+ test_files_authors.extend(test_file_authors)
file_total += 1
file_successes += 0 if summary['returncode'] else 1
Modified: grass/trunk/lib/python/gunittest/runner.py
--- grass/trunk/lib/python/gunittest/runner.py 2014-07-28 22:20:49 UTC (rev 61437)
+++ grass/trunk/lib/python/gunittest/runner.py 2014-07-29 01:01:45 UTC (rev 61438)
@@ -280,7 +280,7 @@
infos.append("unexpected_successes=%d" % unexpectedSuccesses)
# TODO: include each module just once? list good and bad modules?
- infos.append("modules=%s" % ','.join(self._grass_modules))
+ infos.append("tested_modules=%s" % ','.join(self._grass_modules))
infos.append("supplementary_files=%s" % ','.join(self._supplementary_files))
# module, modules?, c, c++?, python
