[GRASS-SVN] r61463 - grass/branches/releasebranch_7_0/lib/vector/Vlib
Wed Jul 30 11:30:02 PDT 2014
Author: mmetz
Date: 2014-07-30 11:30:01 -0700 (Wed, 30 Jul 2014)
New Revision: 61463
   grass/branches/releasebranch_7_0/lib/vector/Vlib/remove_areas.c
Vlib: disable fast version of Vect_remove_small_areas()
Modified: grass/branches/releasebranch_7_0/lib/vector/Vlib/remove_areas.c
--- grass/branches/releasebranch_7_0/lib/vector/Vlib/remove_areas.c	2014-07-30 17:08:10 UTC (rev 61462)
+++ grass/branches/releasebranch_7_0/lib/vector/Vlib/remove_areas.c	2014-07-30 18:30:01 UTC (rev 61463)
@@ -43,11 +43,14 @@
 Vect_remove_small_areas(struct Map_info *Map, double thresh,
 			struct Map_info *Err, double *removed_area)
+    return Vect_remove_small_areas_ext(Map, thresh, Err, removed_area);
+#if 0
     if (Map->format == GV_FORMAT_NATIVE)
 	return Vect_remove_small_areas_nat(Map, thresh, Err, removed_area);
     else
+#endif
 int
